    5. Funktion zu bestimmten Zeiten
    • Negalein
      Negalein Global Moderator @J.A.R.V.I.S. last edited by
      @J-A-R-V-I-S sagte in Funktion zu bestimmten Zeiten:
      25
      irgendwas dürfte nicht passen.
      Er ist jetzt immer zwischen 20 und 25 hinundher gesprungen.
      J.A.R.V.I.S. 1 Reply Last reply Reply Quote 0
      • J.A.R.V.I.S.
        J.A.R.V.I.S. Developer @Negalein last edited by
        @Negalein oh, habe einen Block vergessen.
        <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="Dg.#=HIh7+v2T[r)h6qH" x="-37" y="288">
         <value name="OID0">
           <shadow type="field_oid" id="R[_*Cyn}x+f-2X](-Yn/">
           <block type="controls_if" id="g^mY}-Gdc7M7(2euJ8LX">
               <block type="logic_negate" id="dkG,-pvYv00ke1Q]vIn3">
                 <value name="BOOL">
                   <block type="time_compare_ex" id=":@_j_yRhgATQZh.l0:U5">
                     <mutation end_time="true" actual_time="true"></mutation>
                     <value name="START_TIME">
                       <shadow type="text" id="[^YWWxWIg8=4-K7IXDiO">
                         <field name="TEXT">06:00</field>
                     <value name="END_TIME">
                       <shadow type="text" id="kQyN(tj,E}s-T!#.X8j0">
                         <field name="TEXT">09:00</field>
               <block type="controls_if" id="@okBdqw=*J0Xkn0ETo7e">
                 <mutation elseif="2"></mutation>
                   <block type="logic_operation" id="V-J[Y!:l*^6$TNU8c]Nr">
                     <field name="OP">AND</field>
                       <block type="time_compare_ex" id="uKs.hkBLT#Kd83fc_|?3">
                           <shadow type="text" id="92JzR+eBNr.T!U8eb9ZX">
                             <field name="TEXT">18:00</field>
                           <shadow type="text" id="0DS4|IzMcs1M-pdua60*">
                             <field name="TEXT">20:30</field>
                       <block type="logic_compare" id="^6|PBPl*V6T*?)|_/ywm">
                         <field name="OP">GT</field>
                           <block type="get_value" id="+(VyRXtn04mu^ztZbf#C">
                             <field name="OID">ID auswählen</field>
                           <block type="math_number" id="t.:#4y6H`PT28$-GV^1/">
                             <field name="NUM">30</field>
                   <block type="control" id="Q0IJoo1mB7aq!dfS56hC">
                       <block type="math_number" id="Ys3o{!k#[2*rJtYNf#K?">
                 <value name="IF1">
                   <block type="logic_operation" id="},t|_l9b=xLo/sEdlnX`">
                       <block type="time_compare_ex" id="8aF2Tdtu?@y[nH0-FXj[">
                           <shadow type="text" id="1A;fF5vj%)hkO|/_CdEv">
                           <shadow type="text" id="*U~3k{XkXbtT0Y4`2sr]">
                       <block type="logic_compare" id="`Vz5|RKIL7K/k4/ny^PY">
                           <block type="get_value" id="A6o:LA{Y$HHu3@/H-=~?">
                           <block type="math_number" id=".t%VHUveF).%|U1Yh|%i">
                             <field name="NUM">20</field>
                 <statement name="DO1">
                   <block type="control" id=";E;mw03;;CI{1,OT#0Sd">
                       <block type="math_number" id="nrg29@Xd+(0G]*w6:7wa">
                 <value name="IF2">
                   <block type="logic_compare" id="|/?Qf[9(D(s);Q)zc(8R">
                       <block type="get_value" id=":+Zg!B6zv*tOK$j]i]6w">
                       <block type="math_number" id="PF/#|A#03rg0rUV2v0Ob">
                         <field name="NUM">25</field>
                 <statement name="DO2">
                   <block type="control" id="8I_-Oa-tJ`bZfaH}_X-G">
                       <block type="math_number" id="ls[]aM3U08I/49,h_ZVs">
        • Negalein
          Danke, funktioniert perfekt.
          Kann man das auch in dem Blockly einbauen, dass zu einer bestimmten Zeit ein Befehl (zB um 22:00 ein alexa2.0.Echo-Devices.XXXXXXXXXXXX.Commands.deviceStop) geschickt wird?
          Oder ist es ratsamer dies mit einem eigenen zu machen?
          • Negalein
            @J-A-R-V-I-S
            Kannst du mir nochmal behilflich sein?
            Eigentlich funktioniert es jetzt perfekt.
            Nur wird um 20:30 die Lautstärke nicht automatisch auf 30 gestellt.
              Homoran Global Moderator Administrators @Negalein last edited by
              @Negalein sagte in Funktion zu bestimmten Zeiten:
              ist in dem Skript auch nicht vorgesehen.
              Der Trigger ist eine Veränderung der Lautstärke
              • J.A.R.V.I.S.
                J.A.R.V.I.S. Developer @Homoran last edited by J.A.R.V.I.S.
                @Homoran sagte in Funktion zu bestimmten Zeiten:
                Dann müsstest du noch einen Zeittrigger einbauen.
                Oder meinst, dass, wenn die Lautstärke sich um 20:30 Uhr ändert, nichts passiert?
                • Negalein
                  Nein, dass die Lautstärke um 20:30 automatisch von 40 auf 30 geht.
                  • dslraser
                    dslraser Forum Testing Most Active @Negalein last edited by dslraser
                    Dann mach noch einen Zeitplan (so wie unten im Blockly, nur mit steuere volume mit 30)
                    • Negalein
                      Negalein Global Moderator @dslraser last edited by
                      @dslraser sagte in Funktion zu bestimmten Zeiten:
                      Danke, das funktioniert!
                      Das heißt, ich kann mehrere Zeitpläne untereinander geben und so zu verschiedenen Zeiten Funktionen schalten?
                      • J.A.R.V.I.S.
                        @Negalein ja.
                          JoWrusch last edited by
                          seit längerem versuche ich es mit der Zeitsteuerung, aber trotz korrekter Uhrzeit auf dem RasPi bekomme ich das Skript nicht hin. Es erfolgt keine Auslösung im gewünschten Zeitraum:
                          Hat jemand eine Idee?
                          Vielen Dank
                          • dslraser
                            dslraser Forum Testing Most Active @JoWrusch last edited by
                            @JoWrusch
                            was ist der Trigger ? (default ?)
                              Ich habe nichts passendes gefunden, was alle Minuten upgedatet wird und gedacht 'default' reicht....
                              dslraser Homoran 2 Replies Last reply Reply Quote 0
                              • dslraser
                                @JoWrusch
                                als was ist jetzt default, nix ? Also kein Trigger ? Wie soll das Blockly dann jemals starten ?
                                  Homoran Global Moderator Administrators @JoWrusch last edited by
                                  @JoWrusch sagte in Funktion zu bestimmten Zeiten:
                                  "Zeitplan"
                                  wobei das großer mist ist.
                                  Was bitte willst du denn erreichen?
                                  wann soll was passieren?
                                    Mein Ziel ist es, zum Zeitpunkt HH:MM zu checken, ob ein Gerät läuft, d.h. der Stromverbrauch entsprechend hoch ist. Telegram, Stromverbrauchscheck funktioniert; nur die Zeitabfrage halt nicht...
                                    1154
