    4. JavaScript
    5. [Vorlage] Skript: Erstellen von User-Datenpunkten
    • dslraser
      dslraser Forum Testing Most Active @Mic last edited by
      @Mic
      Ich kapiere nicht so ganz wie ich das Script jetzt korrekt anwende ? Du hast oben so einiges auskommentiert ?
      Kannst Du mal ein komplettes Beispiel reinstellen?
      Dieses "auskommentierte" kann ich ja nicht komplett aktivieren ?
      * Create states under 0_userdata.0 or javascript.x
      * Current Version:     https://github.com/Mic-M/iobroker.createUserStates
      * Support:             https://forum.iobroker.net/topic/26839/
      * Autor:               Mic (ioBroker) | Mic-M (github)
      * Version:             1.0 (17 January 2020)
      * Example:
         let statesToCreate = [
             ['Test.Test1', {'name':'Test 1', 'type':'string', 'read':true, 'write':true, 'role':'info', 'def':'Hello' }],
             ['Test.Test2', {'name':'Test 2', 'type':'string', 'read':true, 'write':true, 'role':'info', 'def':'Hello' }],
         createUserStates('0_userdata.0', false, statesToCreate);
      * PLEASE NOTE: Per https://github.com/ioBroker/ioBroker.javascript/issues/474, the used function setObject()
      *              executes the callback PRIOR to completing the state creation. Therefore, we use a setTimeout and counter.
      * @param {string} where          Where to create the state: e.g. '0_userdata.0' or 'javascript.x'.
      * @param {boolean} force         Force state creation (overwrite), if state is existing.
      * @param {array} statesToCreate  State(s) to create. single array or array of arrays
      * @param {object} [callback]     Optional: a callback function -- This provided function will be executed after all states are created.
      function createUserStates(where, force, statesToCreate, callback = undefined) {
         const WARN = false; // Throws warning in log, if state is already existing and force=false. Default is false, so no warning in log, if state exists.
         const LOG_DEBUG = false; // To debug this function, set to true
         // Per issue #474 (https://github.com/ioBroker/ioBroker.javascript/issues/474), the used function setObject() executes the callback
         // before the state is actual created. Therefore, we use a setTimeout and counter as a workaround.
         // Increase this to 100, if it is not working.
         const DELAY = 50; // Delay in milliseconds (ms)
         // Validate "where"
         if (where.endsWith('.')) where = where.slice(0, -1); // Remove trailing dot
         if ( (where.match(/^javascript.([0-9]|[1-9][0-9])$/) == null) && (where.match(/^0_userdata.0$/) == null) ) {
             log('This script does not support to create states under [' + where + ']', 'error');
             return;
         // Prepare "statesToCreate" since we also allow a single state to create
         if(!Array.isArray(statesToCreate[0])) statesToCreate = [statesToCreate]; // wrap into array, if just one array and not inside an array
         let numStates = statesToCreate.length;
         let counter = -1;
         statesToCreate.forEach(function(param) {
             counter += 1;
             if (LOG_DEBUG) log ('[Debug] Currently processing following state: [' + param[0] + ']');
             // Clean
             let stateId = param[0];
             if (! stateId.startsWith(where)) stateId = where + '.' + stateId; // add where to beginning of string
             stateId = stateId.replace(/\.*\./g, '.'); // replace all multiple dots like '..', '...' with a single '.'
             const FULL_STATE_ID = stateId;
             if( ($(FULL_STATE_ID).length > 0) && (existsState(FULL_STATE_ID)) ) { // Workaround due to https://github.com/ioBroker/ioBroker.javascript/issues/478
                 // State is existing.
                 if (WARN && !force) log('State [' + FULL_STATE_ID + '] is already existing and will no longer be created.', 'warn');
                 if (!WARN && LOG_DEBUG) log('[Debug] State [' + FULL_STATE_ID + '] is already existing. Option force (=overwrite) is set to [' + force + '].');
                 if(!force) {
                     // State exists and shall not be overwritten since force=false
                     // So, we do not proceed.
                     numStates--;
                     if (numStates === 0) {
                         if (LOG_DEBUG) log('[Debug] All states successfully processed!');
                         if (typeof callback === 'function') { // execute if a function was provided to parameter callback
                             if (LOG_DEBUG) log('[Debug] An optional callback function was provided, which we are going to execute now.');
                             return callback();
                     } else {
                         // We need to go out and continue with next element in loop.
                         return; // https://stackoverflow.com/questions/18452920/continue-in-cursor-foreach
                 } // if(!force)
              * State is not existing or force = true, so we are continuing to create the state through setObject().
             let obj = {};
             obj.type = 'state';
             obj.native = {};
             obj.common = param[1];
             setObject(FULL_STATE_ID, obj, function (err) {
                 if (err) {
                     log('Cannot write object for state [' + FULL_STATE_ID + ']: ' + err);
                 } else {
                     if (LOG_DEBUG) log('[Debug] Now we are creating new state [' + FULL_STATE_ID + ']')
                     let init = null;
                     if(param[1].def === undefined) {
                         if(param[1].type === 'number') init = 0;
                         if(param[1].type === 'boolean') init = false;
                         if(param[1].type === 'string') init = '';
                     } else {
                         init = param[1].def;
                     setTimeout(function() {
                         setState(FULL_STATE_ID, init, true, function() {
                             if (LOG_DEBUG) log('[Debug] setState durchgeführt: ' + FULL_STATE_ID);
                             numStates--;
                                 if (LOG_DEBUG) log('[Debug] All states processed.');
                                     if (LOG_DEBUG) log('[Debug] Function to callback parameter was provided');
                                     return callback();
                     }, DELAY + (20 * counter) );
      Mic-M created this issue in ioBroker/ioBroker.javascript
      closed setObject() function: callback not working as intended. #474
      closed 0_userdata.0: existsState() vs. $-Selector $().length after state deletion #478
        paul53 @dslraser last edited by
        @dslraser sagte:
        Das sollst Du auch nicht, denn es ist eine "Gebrauchsanleitung".
        • dslraser
          dslraser Forum Testing Most Active @paul53 last edited by
          @paul53 sagte in [Vorlage] Skript: Erstellen von User-Datenpunkten:
          @dslraser sagte:
          ja, schon klar, aber diesen Teil brauche ich doch.
            @dslraser sagte:
            ... und den folgenden Funktionsaufruf.
            Kopier diese Zeilen an das Script-Ende und trage dort Deine User-Datenpunkte in das Array ein.
            • X
              xbow42 last edited by xbow42
              Wie macht man das, wenn man die Funktion nur in einigen Scripten braucht. Gibt es die Möglichkeit die Funktion in einem Script unter global abzulegen und mit include o.ä. in die gewünschten Scripte einzubinden?
              Mic 1 Reply Last reply Reply Quote 0
              • Mic
                Mic Developer @xbow42 last edited by Mic
                @xbow42 sagte in [Vorlage] Skript: Erstellen von User-Datenpunkten:
                Ja, siehe hier: Global functions
                Include brauchst du in JavaScript hierfür nicht (nur in TypeScript: declare): Alle globalen Skripte werden in alle anderen (nicht globale) Skripte kopiert und kompiliert. Siehe Scripteditor Unterschied zwischen common & global.
                • X
                  xbow42 @Mic last edited by
                  @Mic danke für den Hinweis, hatte ich auch schon mal gelesen und noch vage im Kopf. Deshalb war mein erster Satz "...nur in einigen Scripten braucht..." , dachte da gibts einen resoucenschonende Lösung. Ich will nicht in jedem Script eigene DP erstellen.
                  • Mic
                    @xbow42
                    Das verstehe ich gut! Eine andere Möglichkeit ist mir nicht bekannt, daher meide ich die globalen Scripte, soweit es geht.
                    Bei diesem Script machte ich tatsächlich eine Ausnahme, weil ich wohl in 50-70% der Scripte Datenpunkte erstelle.
                    • X
                      50-70% krass! ok danke dann werde ich vorerst deine Funktion in die Scripte einbinden wo ich sie brauche👍
                      Aktuell versuche ich gerade das Scipt für die Verbrauchsanalyse umzufriemeln auf 0_userdata.0
                      Was mir nicht gelungen ist, in einer Arrayinitialisierung unterschiedliche Parameter zu packen. Bsp. wenn ich z.B.
                              states2Create = [
                                  [pfad + geraet + '.eigenerPreis.aktuell.Arbeitspreis', {'name':'Strompreis - aktueller Arbeitspreis ab Datum (brutto)','type':'number', 'unit': '€/' + _unit_kilo, 'read':true, 'write':true, 'min':0, 'def':0 }],
                                  [pfad + geraet + '.eigenerPreis.aktuell.Grundpreis'  , {'name':'Strompreis - aktueller Grundpreis ab Datum (brutto)',  'type':'number', 'unit': '€/Monat'        , 'read':true, 'write':true, 'min':0,  'def':0 }],
                                  [pfad + geraet + '.eigenerPreis.neu.Arbeitspreis'    , {'name':'Strompreis - neuer Arbeitspreis ab Datum (brutto)',    'type':'number', 'unit': '€/' + _unit_kilo, 'read':true, 'write':true, 'min':0,  'def':0 }],
                                  [pfad + geraet + '.eigenerPreis.neu.Grundpreis'      , {'name':'Strompreis - neuer Grundpreis ab Datum (brutto)',      'type':'number', 'unit': '€/Monat'        , 'read':true, 'write':true, 'min':0,  'def':0 }],
                                  [pfad + geraet + '.eigenerPreis.neu.Datum', {'name':'Strompreis und Grundpreis ab folgendem Datum zur Berechnung heranziehen (Beispiel 01.01.2019)','type':'string','read':true, 'write':true, 'def':'01.01.1979' }]];
                      "rot_unterkrinngelt" mir der Editor die arrVariable. Würde nur gern wissen warum?
                      Hab es erst mal so gelöst, bin mir aber nicht sicher ob ich alle Stellen im Code erwischt habe damit das Script auch seinen Dienst tut.
                      //jshint maxerr:1000
                      // https://github.com/hdering/homematic_stromverbrauch_protokollieren
                      // Version: 1.3.3
                      // +++++++++  USER ANPASSUNGEN ++++++++++++++++++++++++
                      // debug logging
                      var logging = true;
                      // Aktivieren der History Instanz
                      var enable_history = false;
                      // history Instanz
                      var instance_history = 'history.0';
                      // Geräte können unterschiedliche Preise haben
                      var enable_unterschiedlichePreise = true;
                      // Speichern der Werte in zusätzlichen Objekten.
                      // Wenn 0, dann deaktiviert
                      var Tag_Anzahl_Werte_in_der_Vergangenheit       = 7;
                      var Woche_Anzahl_Werte_in_der_Vergangenheit     = 4;
                      var Monat_Anzahl_Werte_in_der_Vergangenheit     = 12;
                      var Quartal_Anzahl_Werte_in_der_Vergangenheit   = 4;
                      var Jahr_Anzahl_Werte_in_der_Vergangenheit      = 2;
                      // Grundpreis einberechnen
                      var enable_Grundpreis_einberechnen = false;
                      var instanznr    = '0';
                      //var instanz     = 'javascript.' + instanznr + '.';
                      var instanz     = '0_userdata.' + instanznr + '.';
                      // Pfad innerhalb der Instanz
                      var pfad        = 'Statistik.';
                      var default_unit = 'Wh';
                      var default_unit_kilo = 'kWh';
                      // Diese Teile werden aus den Gerätenamen entfernt
                      var blacklist   = [':1', ':2', ':3', ':4', ':5', ':6', ':7', ':8'];
                      var AnzahlKommastellenKosten = 2;
                      var AnzahlKommastellenVerbrauch = 3;
                      var AnzahlKommastellenZaehlerstand = 3;
                      var KumulierterWertIstBereitsInKilo = true;
                      var eigeneDatenpunkte = [
                      //[ 'smartmeter.0.1-0:1_8_0_255.value', 'Verbrauchszähler.Strom', 'Wh', 'kWh' ], // Bezug
                      //[ 'smartmeter.0.1-0:2_8_0_255.value', 'Lieferungszähler.Strom', 'Wh', 'kWh' ], // Lieferungswerte
                       [ 'shelly.0.SHPLG-S#041491#1.Relay0.Energy', 'Kaffeemaschine.Strom', 'kWh', 'kWh'],
                       [ 'sonoff.0.luminea-Trockner.ENERGY_Total' , 'Trockner.Strom'      , 'kWh', 'kWh'],
                       [ 'sonoff.0.luminea-WaMa.ENERGY_Total'     , 'Waschmaschine.Strom' , 'kWh', 'kWh']
                         // Beispiel:
                         // ['Datenpunkt', 'Aliasname', 'Einheit kumulierter Wert', 'Einheit berechnete Werte (kilo/1000)' ],
                         // [ 'hm-rpc.2.NEQ0861663.1.ENERGY_COUNTER', 'Stromzaehler:1.ENERGY_COUNTER', 'Wh', 'kWh' ],
                         // [ 'javascript.1.MeinSonoffGeraet1', 'Strom.Sonoff.MeinSonoffGeraet1', 'Wh', 'kWh' ],
                         // [ 'javascript.1.MeinSonoffGeraet2', 'Strom.Sonoff.MeinSonoffGeraet2', 'kWh', 'kWh' ],
                         // [ 'javascript.1.MeineGas1', 'Gas.MeinGaszaehler1', 'm3', 'm3' ],
                         // [ 'javascript.1.MeineGas2', 'Gas.MeinGaszaehler2', 'm3', 'm3' ],
                      // Pushmeldung
                      function send_message(text) {
                         // Hier können die Pushmeldung über alle möglichen Wege verschickt werden.
                         //console.log(text);
                         //sendTelegram(text);
                      // ++++ ENDE USER ANPASSUNGEN ++++++++++++++++++++++++
                      var statesToCreate = [
                            [pfad + 'Allgemein.Stromkosten.aktuell.Arbeitspreis', {'name':'Strompreis - aktueller Arbeitspreis (brutto)', 'type':'number','unit': '€/' + default_unit_kilo, 'read':true, 'write':true, 'role':'info', 'min':0, 'def':0.25 }],
                            [pfad + 'Allgemein.Stromkosten.aktuell.Grundpreis', {'name':'Strompreis - aktueller Grundpreis (brutto)', 'type':'number', 'unit': '€/Monat', 'read':true, 'write':true, 'role':'info', 'min':0,  'def':0.25 }],
                            [pfad + 'Allgemein.Stromkosten.neu.Arbeitspreis', {'name':'Strompreis - neuer Arbeitspreis ab Datum (brutto)', 'type':'number','unit': '€/' + default_unit_kilo, 'read':true, 'write':true, 'role':'info', 'min':0,  'def':0.25 }],
                            [pfad + 'Allgemein.Stromkosten.neu.Grundpreis', {'name':'Strompreis - neuer Grundpreis ab Datum (brutto)', 'type':'number', 'unit': '€/Monat', 'read':true, 'write':true, 'role':'info', 'min':0,  'def':0.25 }],
                            [pfad + 'Allgemein.Stromkosten.neu.Datum', {'name':'Strompreis und Grundpreis ab folgendem Datum zur Berechnung heranziehen (Beispiel 01.01.2019)', 'type':'string', 'read':true, 'write':true, 'def':'01.01.1970' }],
                            [pfad + 'Allgemein.Stromkosten.neu.PreisaenderungDurchgefuehrt', {'name':'Preisänderung durchgeführt?', 'type':'boolean', 'read':true, 'write':true, 'def':false }]
                      var cacheSelectorStateMeter  = $('channel[state.id=*.METER]');
                      var cacheSelectorStateEnergyCounter  = $('channel[state.id=*.ENERGY_COUNTER$]');
                      function parseObjects(id) {
                         var obj = getObject(id);
                         return entferneDatenpunkt(obj.common.name);
                      function setRecognizedChange(type, anzahl) {
                         cacheSelectorStateMeter.each(function (id, i) {
                             var geraetename = parseObjects(id);
                             rotateVerbrauchUndKosten(geraetename, type, anzahl);
                             resetVerbrauchUndKosten(geraetename, type);
                             schreibeZaehlerstand(geraetename, type);
                         cacheSelectorStateEnergyCounter.each(function (id, i) {
                         if (eigeneDatenpunkte.length > 0) {
                             for(var i = 0; i < eigeneDatenpunkte.length; i++) {
                                 var alias = eigeneDatenpunkte[i][1];
                                 rotateVerbrauchUndKosten(alias, type, anzahl);
                                 resetVerbrauchUndKosten(alias, type);
                                 schreibeZaehlerstand(alias, type);
                      // Tageswechsel
                      schedule("0 0 * * *", function() {
                         setRecognizedChange('Tag', Tag_Anzahl_Werte_in_der_Vergangenheit);
                      // Wochenwechsel
                      schedule("0 0 * * 1", function() {
                         setRecognizedChange('Woche', Woche_Anzahl_Werte_in_der_Vergangenheit);
                      // Monatswechsel
                      schedule("0 0 1 * *", function() {
                         setRecognizedChange('Monat', Monat_Anzahl_Werte_in_der_Vergangenheit);
                      // Quartalswechsel
                      schedule("0 0 1 */3 *", function() {
                         setRecognizedChange('Quartal', Quartal_Anzahl_Werte_in_der_Vergangenheit);
                      // Jahreswechsel
                      schedule("0 0 1 1 *", function() {
                         setRecognizedChange('Jahr', Jahr_Anzahl_Werte_in_der_Vergangenheit);
                      // Eigene Datenpunkte
                      function pruefeEigeneDatenpunkte() {
                                 var datenpunkt = eigeneDatenpunkte[i][0];
                                 var einheit = eigeneDatenpunkte[i][2];
                                 var einheit_kilo = eigeneDatenpunkte[i][3];
                                 if(logging) console.log("Alias:" + alias + " Datenpunkt:" + datenpunkt + " Einheit:" + einheit + " Einheit_kilo:" + einheit_kilo);
                                 on(datenpunkt, function(obj) {
                                         if(eigeneDatenpunkte[i][0] === obj.id)
                                             run(obj, eigeneDatenpunkte[i][1], eigeneDatenpunkte[i][2], eigeneDatenpunkte[i][3]);
                      pruefeEigeneDatenpunkte();
                      // Einlesen der aktuellen Daten vom Zähler
                      function run(obj, alias, unit, unit_kilo) {
                         if (logging) {
                             log('-------- Strommesser ---------');
                             log('RegExp-Funktion ausgelöst');
                             log('id:           ' + obj.id);
                             log('Name:         ' + obj.common.name);   // Waschmaschine Küche:2.ENERGY_COUNTER
                             log('channel ID:   ' + obj.channelId);     // hm-rpc.0.MEQ0170864.2
                             log('channel Name: ' + obj.channelName);   // Waschmaschine Küche:2
                             log('device ID:    ' + obj.deviceId);      // hm-rpc.0.MEQ0170864
                             log('device name:  ' + obj.deviceName);    // Küche Waschmaschine
                             log('neuer Wert:   ' + obj.newState.val);  // 16499.699982
                             log('alter Wert:   ' + obj.oldState.val);  // 16499.699982
                         // Gerätenamen erstellen
                         if (logging) log('vor der Aufbereitung: ' + obj.common.name);
                         var geraetename = entferneDatenpunkt(obj.common.name);
                         if(typeof alias !== "undefined")  {
                             if(logging) console.log("Es wird der Aliasname gesetzt:" + alias);
                             geraetename = alias;
                         if (logging) log('Nach der Aufbereitung: ' + geraetename);
                         if(typeof geraetename !== "undefined") {
                             var _unit = default_unit;
                             var _unit_kilo = default_unit_kilo;
                             // States erstellen (CreateStates für dieses Gerät)
                             if(typeof unit !== "undefined")  {
                                 _unit = unit;
                             if(typeof unit_kilo !== "undefined")  {
                                 _unit_kilo = unit_kilo;
                             erstelleStates(geraetename, _unit, _unit_kilo);
                             // Schreiben der neuen Werte
                             var idKumuliert =  instanz + pfad + geraetename + '.Zaehlerstand.kumuliert';
                             var NeustartEventuellErkannt = false;
                             var NeustartSicherErkannt = false;
                             var oldState = obj.oldState.val;
                             var newState = obj.newState.val;
                             var difference = newState - oldState;
                             if(difference > 0) {
                                 if(oldState !== 0) {
                                     // Kumulierten Wert mit Ist-Wert (inkl. Backup) synchronisieren
                                     var newValueKumuliert = getState(idKumuliert).val + difference;
                                     newValueKumuliert = parseFloat(newValueKumuliert);
                                     setState(idKumuliert, newValueKumuliert);
                                 } else {
                                     if(newState < getState(pfad + geraetename + '.config.NeustartErkanntAlterWert').val) {
                                         NeustartSicherErkannt = true;
                             } else {
                                 // Fall 2 oder 3
                                 // Irgendetwas läuft außerplanmäßig. Wert wird sicherheitshalber gespeichert und nächster Lauf abgewartet
                                 NeustartEventuellErkannt = true;
                                 setState(pfad + geraetename + '.config.NeustartErkanntAlterWert', obj.oldState.val);
                             if(NeustartEventuellErkannt) {
                                 if(logging) {
                                     var message =  geraetename + '\n'
                                                     + 'Entweder die CCU oder Stromzähler wurden neugestartet/zurückgesetzt.\n'
                                                     + 'Dieser Wert wird einmal ignoriert und auf den nächsten Wert gewartet.';
                                     send_message(message);
                             if(NeustartSicherErkannt) {
                                 // zurücksetzen der Variable
                                 setState(pfad + geraetename + '.config.NeustartErkanntAlterWert', 0);
                                 var message2 = geraetename + '\n'
                                             + 'Der Stromzähler (' + geraetename + ') ist übergelaufen, gelöscht oder neugestartet worden (ggf. Stromausfall).\n'
                                             + 'newState:' + obj.newState.val + '\n'
                                             + 'oldState:' + obj.oldState.val + '\n'
                                             + 'differenz:' + difference + '\n'
                                             + 'idKumuliert:' + getState(idKumuliert).val;
                                 send_message(message2);
                             pruefePreisaenderung();
                             if(enable_unterschiedlichePreise)
                                 pruefePreisaenderung(geraetename);
                             var idStrompreis = instanz + pfad + 'Allgemein.Stromkosten.aktuell.Arbeitspreis';
                             var idGrundpreis = instanz + pfad + 'Allgemein.Stromkosten.aktuell.Grundpreis';
                             var _zaehler = null;
                             // aktualisiere den Verbrauch und die Kosten
                             if(KumulierterWertIstBereitsInKilo)
                                _zaehler    = (getState(idKumuliert).val).toFixed(AnzahlKommastellenZaehlerstand);
                             else
                                _zaehler    = (getState(idKumuliert).val / 1000).toFixed(AnzahlKommastellenZaehlerstand);
                             var _preis      = getState(idStrompreis).val;
                             var _grundpreis = getState(idGrundpreis).val;
                             // Wenn das Gerät einen eigenen Strompreis / Grundpreis hat
                             if(enable_unterschiedlichePreise) {
                                 if(getState(instanz + pfad + geraetename + '.eigenerPreis.aktuell.Arbeitspreis').val > 0) {
                                     _preis = getState(instanz + pfad + geraetename + '.eigenerPreis.aktuell.Arbeitspreis').val;
                                     if (logging) console.log("Das Gerät:" + geraetename + " hat eigenen Strompreis: " + _preis);
                                 if(getState(instanz + pfad + geraetename + '.eigenerPreis.aktuell.Grundpreis').val > 0) {
                                     _grundpreis = getState(instanz + pfad + geraetename + '.eigenerPreis.aktuell.Grundpreis').val;
                                     if (logging) console.log("Das Gerät:" + geraetename + " hat eigenen Grundpreis: " + _grundpreis);
                             berechneVerbrauchUndKosten(geraetename, _zaehler, _preis, _grundpreis); // in kWh
                             if (logging) log('------------ ENDE ------------');
                         } else {
                             var message3 = 'Fehler beim Erstellen des Gerätenamens:\n'
                                         + 'obj.common.name: ' + obj.common.name;
                             send_message(message3);
                      cacheSelectorStateMeter.on(function(obj) {
                        run(obj);
                      cacheSelectorStateEnergyCounter.on(function(obj) {
                        run(obj);
                      function entferneDatenpunkt(geraet) {
                         var rueckgabe = geraet;
                         // ":2.ENERGY_COUNTER" --> ".ENERGY_COUNTER"
                         if (geraet.indexOf(".ENERGY_COUNTER") != -1) {
                             rueckgabe = geraet.substring(0, geraet.indexOf(".ENERGY_COUNTER"));
                         } else if (geraet.indexOf(".METER") != -1) {
                             rueckgabe = geraet.substring(0, geraet.indexOf(".METER"));
                         if (logging) log('entferneDatenpunkt - rueckgabe1:' + rueckgabe);
                         // Rückgabe sollte keine Sonderzeichen oder Leerzeichen enthalten. Wenn doch, werden die entfernt oder ersetzt
                         try {
                             rueckgabe = checkBlacklist(rueckgabe);
                         catch(err) {
                             if (logging) log('entferneDatenpunkt - rueckgabe2:' + rueckgabe + ' error:' + err);
                         finally {
                             if (logging) log('entferneDatenpunkt - rueckgabe2:' + rueckgabe);
                         try {
                             if (rueckgabe.charAt(rueckgabe.length - 1) == "-") rueckgabe = rueckgabe.substr(0, rueckgabe.length - 1);
                             if (rueckgabe.charAt(rueckgabe.length - 1) == "\\") rueckgabe = rueckgabe.substr(0, rueckgabe.length - 1);
                             if (rueckgabe.charAt(rueckgabe.length - 1) == ":") rueckgabe = rueckgabe.substr(0, rueckgabe.length - 1);
                         catch(err) {
                             if (logging) log('entferneDatenpunkt - rueckgabe3:' + rueckgabe + ' error:' + err);
                         finally {
                             if (logging) log('entferneDatenpunkt - rueckgabe3:' + rueckgabe);
                         // per Regexp Leerzeichen entfernen
                         try {
                             rueckgabe = rueckgabe.replace(/\s/g, "");
                         catch(err) {
                             if (logging) log('entferneDatenpunkt - rueckgabe4:' + rueckgabe + ' error:' + err);
                         finally {
                             if (logging) log('entferneDatenpunkt - rueckgabe4:' + rueckgabe);
                         return rueckgabe;
                      function checkBlacklist(name) {
                         var _name = "";
                         if (blacklist.length > 0) {
                             for(var i = 0; i < blacklist.length; i++) {
                                 if (name.indexOf(blacklist[i]) != -1) {
                                     // Zeichenketten, die in der Blacklist stehen, aus dem Namen löschen
                                     _name = name.substring(0, name.indexOf(blacklist[i]));
                             if(_name === "") {
                                 return name;
                             } else {
                                 return _name;
                         } else return (name);
                      function schreibeZaehlerstand(geraet, zeitraum) {
                         var idKumuliert =    instanz + pfad + geraet + '.Zaehlerstand.kumuliert',
                             idZaehlerstand = instanz + pfad + geraet + '.Zaehlerstand.' + zeitraum;
                         // Zählerstand für übergebene Zeitraum und das Gerät in Wh auslesen und in kWh speichern (also durch 1000)
                             setState(idZaehlerstand, parseFloat( (getState(idKumuliert).val).toFixed(AnzahlKommastellenZaehlerstand)) );
                         else
                             setState(idZaehlerstand, parseFloat( (getState(idKumuliert).val / 1000).toFixed(AnzahlKommastellenZaehlerstand)) );
                         if (logging) log('Zählerstände für das Gerät ' + geraet + ' (' + zeitraum + ') in Objekten gespeichert');
                      function rotateVerbrauchUndKosten(geraet, zeitraum, anzahl) {
                         // Verbrauch
                         if(anzahl > 0) {
                             for(var i = anzahl; i >= 0; i--) {
                                 var j = i;
                                 j++;
                                 if(getObject(instanz + pfad + geraet + '.Verbrauch._' + zeitraum + '.' + zeitraum + '_' + j)) {
                                     if(i === 0)
                                         setState(instanz + pfad + geraet + '.Verbrauch._' + zeitraum + '.' + zeitraum + '_' + j, getState(instanz + pfad + geraet + '.Verbrauch.' + zeitraum).val);
                                     else
                                         setState(instanz + pfad + geraet + '.Verbrauch._' + zeitraum + '.' + zeitraum + '_' + j, getState(instanz + pfad + geraet + '.Verbrauch._' + zeitraum + '.' + zeitraum + '_' + i).val);
                         // Kosten
                         if(anzahl > 0) {
                                 var j = i;
                                 j++;
                                 if(getObject(instanz + pfad + geraet + '.Kosten._' + zeitraum + '.' + zeitraum + '_' + j)) {
                                     if(i === 0)
                                         setState(instanz + pfad + geraet + '.Kosten._' + zeitraum + '.' + zeitraum + '_' + j, getState(instanz + pfad + geraet + '.Kosten.' + zeitraum).val);
                                     else
                                         setState(instanz + pfad + geraet + '.Kosten._' + zeitraum + '.' + zeitraum + '_' + j, getState(instanz + pfad + geraet + '.Kosten._' + zeitraum + '.' + zeitraum + '_' + i).val);
                      function resetVerbrauchUndKosten(geraet, zeitraum) {
                         // Reset der Stromkosten für den übergebenen Zeitraum
                         // Reset des Stromverbrauchs für den übergebenen Zeitraum
                         setState(instanz + pfad + geraet + '.Kosten.' + zeitraum, 0);
                         setState(instanz + pfad + geraet + '.Verbrauch.' + zeitraum, 0);
                         if (logging) log('Stromkosten und Stromverbrauch für das Gerät ' + geraet + ' (' + zeitraum + ') zurückgesetzt');
                      function berechneVerbrauchUndKosten(geraet, zaehler, preis, grundpreis) {
                         // bei jedem eingehenden Wert pro Gerät
                         if(preis === 0) {
                             var message0 = 'Achtung!' + '.\n'
                                         + 'Es wurde noch kein Arbeitspreis angegeben.' + '\n'
                                         + 'Ohne Arbeitspreis kann das Skript keine Berechnungen durchführen.' + '\n'
                                         + 'Diese Information ist zwingend notwendig!';
                             log(message0, 'error');
                         } else {
                             var _grundpreis = 0;
                             if(enable_Grundpreis_einberechnen) {
                                 _grundpreis = grundpreis * 12 / 365;
                                 _grundpreis = parseFloat(_grundpreis.toFixed(3));
                             var grundpreis_tag      = _grundpreis;
                             var grundpreis_woche    = _grundpreis * 7;
                             var grundpreis_monat    = _grundpreis * 30;
                             var grundpreis_quartal  = _grundpreis * 90;
                             var grundpreis_jahr     = _grundpreis * 365;
                             // Tag [Verbrauchskosten = (Zähler_ist - Zähler_Tagesbeginn) * Preis ] --- zaehler muss immer größer sein als Tages, Wochen, etc.-Wert
                             setState(instanz + pfad + geraet + '.Kosten.Tag',        parseFloat( (((zaehler - getState(instanz + pfad + geraet + '.Zaehlerstand.Tag').val) * preis) + grundpreis_tag).toFixed(AnzahlKommastellenKosten) ) );  // Kosten an diesem Tag in €
                             // Woche
                             setState(instanz + pfad + geraet + '.Kosten.Woche',      parseFloat( (((zaehler - getState(instanz + pfad + geraet + '.Zaehlerstand.Woche').val) * preis) + grundpreis_woche).toFixed(AnzahlKommastellenKosten) ) );
                             // Monat
                             setState(instanz + pfad + geraet + '.Kosten.Monat',      parseFloat( (((zaehler - getState(instanz + pfad + geraet + '.Zaehlerstand.Monat').val) * preis) + grundpreis_monat).toFixed(AnzahlKommastellenKosten) ) );
                             // Quartal
                             setState(instanz + pfad + geraet + '.Kosten.Quartal',    parseFloat( (((zaehler - getState(instanz + pfad + geraet + '.Zaehlerstand.Quartal').val) * preis) + grundpreis_quartal).toFixed(AnzahlKommastellenKosten) ) );
                             // Jahr
                             setState(instanz + pfad + geraet + '.Kosten.Jahr',       parseFloat( (((zaehler - getState(instanz + pfad + geraet + '.Zaehlerstand.Jahr').val) * preis) + grundpreis_jahr).toFixed(AnzahlKommastellenKosten) ) );
                             if (logging) log('Stromkosten (' + geraet + ') aktualisiert');
                         // Verbrauch berechnen
                         setState(instanz + pfad + geraet + '.Verbrauch.Tag',     parseFloat(   (zaehler - getState(instanz + pfad + geraet + '.Zaehlerstand.Tag').val).toFixed(AnzahlKommastellenVerbrauch) ) );           // Verbrauch an diesem Tag in kWh
                         // Woche
                         setState(instanz + pfad + geraet + '.Verbrauch.Woche',   parseFloat(   (zaehler - getState(instanz + pfad + geraet + '.Zaehlerstand.Woche').val).toFixed(AnzahlKommastellenVerbrauch) ) );
                         // Monat
                         setState(instanz + pfad + geraet + '.Verbrauch.Monat',   parseFloat(   (zaehler - getState(instanz + pfad + geraet + '.Zaehlerstand.Monat').val).toFixed(AnzahlKommastellenVerbrauch) ) );
                         // Quartal
                         setState(instanz + pfad + geraet + '.Verbrauch.Quartal', parseFloat(   (zaehler - getState(instanz + pfad + geraet + '.Zaehlerstand.Quartal').val).toFixed(AnzahlKommastellenVerbrauch) ) );
                         // Jahr
                         setState(instanz + pfad + geraet + '.Verbrauch.Jahr',    parseFloat(   (zaehler - getState(instanz + pfad + geraet + '.Zaehlerstand.Jahr').val).toFixed(AnzahlKommastellenVerbrauch) ) );
                         if (logging) log('Stromverbrauch (' + geraet + ') aktualisiert');
                      function erstelleStates (geraet, _unit, _unit_kilo) {
                         var states2Create = [
                            [pfad + geraet + '.Zaehlerstand.kumuliert', {'name':'Kumulierter Zählerstand ('   + geraet + ')', 'type':'number', 'unit': _unit,      'read':true, 'write':true, 'min':0, 'def':0 }],
                            [pfad + geraet + '.Zaehlerstand.Tag',       {'name':'Zählerstand Tagesbeginn ('   + geraet + ')', 'type':'number', 'unit': _unit_kilo, 'read':true, 'write':true, 'min':0,  'def':0 }],
                            [pfad + geraet + '.Zaehlerstand.Woche',     {'name':'Zählerstand Wochenbeginn ('  + geraet + ')', 'type':'number', 'unit': _unit_kilo, 'read':true, 'write':true, 'min':0,  'def':0 }],
                            [pfad + geraet + '.Zaehlerstand.Monat',     {'name':'Zählerstand Monatsbeginn ('  + geraet + ')', 'type':'number', 'unit': _unit_kilo, 'read':true, 'write':true, 'min':0,  'def':0 }],
                            [pfad + geraet + '.Zaehlerstand.Quartal',   {'name':'Zählerstand Quartalbeginn (' + geraet + ')', 'type':'number', 'unit': _unit_kilo, 'read':true, 'write':true, 'min':0,  'def':0 }],
                            [pfad + geraet + '.Zaehlerstand.Jahr',      {'name':'Zählerstand Jahressbeginn (' + geraet + ')', 'type':'number', 'unit': _unit_kilo, 'read':true, 'write':true, 'min':0,  'def':0 }],
                            [pfad + geraet + '.Verbrauch.Tag',       {'name':'Verbrauch seit Tagesbeginn ('   + geraet + ')', 'type':'number', 'unit': _unit_kilo, 'read':true, 'write':true, 'min':0,  'def':0 }],
                            [pfad + geraet + '.Verbrauch.Woche',     {'name':'Verbrauch seit Wochenbeginn ('  + geraet + ')', 'type':'number', 'unit': _unit_kilo, 'read':true, 'write':true, 'min':0,  'def':0 }],
                            [pfad + geraet + '.Verbrauch.Monat',     {'name':'Verbrauch seit Monatsbeginn ('  + geraet + ')', 'type':'number', 'unit': _unit_kilo, 'read':true, 'write':true, 'min':0,  'def':0 }],
                            [pfad + geraet + '.Verbrauch.Quartal',   {'name':'Verbrauch seit Quartalbeginn (' + geraet + ')', 'type':'number', 'unit': _unit_kilo, 'read':true, 'write':true, 'min':0,  'def':0 }],
                            [pfad + geraet + '.Verbrauch.Jahr',      {'name':'Verbrauch seit Jahressbeginn (' + geraet + ')', 'type':'number', 'unit': _unit_kilo, 'read':true, 'write':true, 'min':0,  'def':0 }],
                            [pfad + geraet + '.Kosten.Tag',       {'name':'Stromkosten heute ('               + geraet + ')', 'type':'number', 'unit': '€',        'read':true, 'write':true, 'min':0,  'def':0 }],
                            [pfad + geraet + '.Kosten.Woche',     {'name':'Stromkosten Woche ('               + geraet + ')', 'type':'number', 'unit': '€',        'read':true, 'write':true, 'min':0,  'def':0 }],
                            [pfad + geraet + '.Kosten.Monat',     {'name':'Stromkosten Monat ('               + geraet + ')', 'type':'number', 'unit': '€',        'read':true, 'write':true, 'min':0,  'def':0 }],
                            [pfad + geraet + '.Kosten.Quartal',   {'name':'Stromkosten Quartal ('             + geraet + ')', 'type':'number', 'unit': '€',        'read':true, 'write':true, 'min':0,  'def':0 }],
                            [pfad + geraet + '.Kosten.Jahr',      {'name':'Stromkosten Jahr ('                + geraet + ')', 'type':'number', 'unit': '€',        'read':true, 'write':true, 'min':0,  'def':0 }]
                         createUserStates('0_userdata.0', false, states2Create);
                         // Speichern der Werte in zusätzlichen Variablen
                         if(Tag_Anzahl_Werte_in_der_Vergangenheit > 0) {
                             for(var i = 1; i <= Tag_Anzahl_Werte_in_der_Vergangenheit; i++) {
                                 states2Create = [
                                   [pfad + geraet + '.Verbrauch._Tag.Tag_' + i, {'name':'Verbrauch vor '   + i + ' Tag(en) ('  + geraet + ')', 'type':'number', 'unit': _unit_kilo, 'read':true, 'write':true, 'min':0, 'def':0 }],
                                   [pfad + geraet + '.Kosten._Tag.Tag_' + i,    {'name':'Stromkosten vor ' + i + ' Tag(en) ('  + geraet + ')', 'type':'number', 'unit': '€'       , 'read':true, 'write':true, 'min':0,  'def':0 }]
                         if(Woche_Anzahl_Werte_in_der_Vergangenheit > 0) {
                             for(var i = 1; i <= Woche_Anzahl_Werte_in_der_Vergangenheit; i++) {
                                 let states2Create = [
                                   [pfad + geraet + '.Verbrauch._Woche.Woche_' + i, {'name':'Verbrauch vor '  + i + ' Woche(n) ('  + geraet + ')' , 'type':'number', 'unit': _unit_kilo, 'read':true, 'write':true, 'min':0, 'def':0 }],
                                   [pfad + geraet + '.Kosten._Woche.Woche_'    + i, {'name':'Stromkosten vor ' + i + ' Woche(n) ('  + geraet + ')', 'type':'number', 'unit': '€'       , 'read':true, 'write':true, 'min':0,  'def':0 }]
                         if(Monat_Anzahl_Werte_in_der_Vergangenheit > 0) {
                             for(var i = 1; i <= Monat_Anzahl_Werte_in_der_Vergangenheit; i++) {
                                 states2Create = [
                                   [pfad + geraet + '.Verbrauch._Monat.Monat_' + i, {'name':'Verbrauch vor '  + i + ' Monat(en) ('  + geraet + ')', 'type':'number', 'unit': _unit_kilo, 'read':true, 'write':true, 'min':0, 'def':0 }],
                                   [pfad + geraet + '.Kosten._Monat.Monat_' + i,    {'name':'Stromkosten vor ' + i + ' Monat(en) (' + geraet + ')', 'type':'number', 'unit': '€'       , 'read':true, 'write':true, 'min':0,  'def':0 }]
                         if(Quartal_Anzahl_Werte_in_der_Vergangenheit > 0) {
                             for(var i = 1; i <= Quartal_Anzahl_Werte_in_der_Vergangenheit; i++) {
                                 states2Create = [
                                   [pfad + geraet + '.Verbrauch._Quartal.Quartal_' + i, {'name':'Verbrauch vor '  + i + ' Quartal(en) ('  + geraet + ')', 'type':'number', 'unit': _unit_kilo, 'read':true, 'write':true, 'min':0, 'def':0 }],
                                   [pfad + geraet + '.Kosten._Quartal.Quartal_' + i,    {'name':'Stromkosten vor ' + i + ' Quartal(en) (' + geraet + ')', 'type':'number', 'unit': '€'       , 'read':true, 'write':true, 'min':0,  'def':0 }]
                         if(Jahr_Anzahl_Werte_in_der_Vergangenheit > 0) {
                             for(var i = 1; i <= Jahr_Anzahl_Werte_in_der_Vergangenheit; i++) {
                                 states2Create = [
                                   [pfad + geraet + '.Verbrauch._Jahr.Jahr_' + i, {'name':'Verbrauch vor '  + i + ' Jahr(en) ('  + geraet + ')', 'type':'number', 'unit': _unit_kilo, 'read':true, 'write':true, 'min':0, 'def':0 }],
                                   [pfad + geraet + '.Kosten._Jahr.Jahr_' + i,    {'name':'Stromkosten vor ' + i + ' Jahr(en) (' + geraet + ')', 'type':'number', 'unit': '€'       , 'read':true, 'write':true, 'min':0,  'def':0 }]
                         // Neustart von CCU oder Gerät erkannt
                         createUserStates('0_userdata.0', false, [pfad + geraet + '.config.NeustartErkanntAlterWert',{'name':'Neustart erkannt alter Wert', 'type':'boolean', 'read':true, 'write':true, 'def':false}]);
                         // Gerät hat eigenen Strompreis
                             states2Create = [
                                 [pfad + geraet + '.eigenerPreis.neu.Grundpreis'      , {'name':'Strompreis - neuer Grundpreis ab Datum (brutto)',      'type':'number', 'unit': '€/Monat'        , 'read':true, 'write':true, 'min':0,  'def':0 }]];
                             createUserStates('0_userdata.0', false, [pfad + geraet + '.eigenerPreis.neu.Datum', {'name':'Strompreis und Grundpreis ab folgendem Datum zur Berechnung heranziehen (Beispiel 01.01.2019)','type':'string','read':true, 'write':true, 'def':'01.01.1979' }]);
                             createUserStates('0_userdata.0', false, [pfad + geraet + '.eigenerPreis.neu.PreisaenderungDurchgefuehrt', {'name':'Preisänderung durchgeführt','type':'boolean','read':true, 'write':true,'def':false }]);
                         // history bei allen Datenpunkten aktivieren
                         if(enable_history) {
                             enableHistory(geraet, 'Tag');
                             enableHistory(geraet, 'Woche');
                             enableHistory(geraet, 'Monat');
                             enableHistory(geraet, 'Quartal');
                             enableHistory(geraet, 'Jahr');
                         if (logging) log('States in der Instanz ' + instanz + pfad + ' erstellt');
                      function enableHistory(geraet, zeitraum) {
                         if(instance_history !== '') {
                             sendTo(instance_history, 'enableHistory', {
                                 id: instanz + pfad + geraet + '.Kosten.' + zeitraum,
                                 options: {
                                     changesOnly:  true,
                                     debounce:     0,
                                     retention:    31536000,
                                     maxLength:    3,
                                     changesMinDelta: 0.5
                             }, function (result) {
                                 if (result.error) {
                                     if (logging) log("Fehler beim Aktivieren von History: " + result.error);
                                 id: instanz + pfad + geraet + '.Verbrauch.' + zeitraum,
                                 options: {
                                     changesOnly:  true,
                                     debounce:     0,
                                     maxLength:    3,
                                 if (result.error) {
                                 id: instanz + pfad + geraet + '.Zaehlerstand.' + zeitraum,
                                 options: {
                                     changesOnly:  true,
                                     debounce:     0,
                                     maxLength:    3,
                                 if (result.error) {
                      function pruefePreisaenderung(geraet) {
                         var _Datum = "";
                         var _PreisaenderungDurchgefuehrt = "";
                         var _Arbeitspreis = "";
                         var _Grundpreis = "";
                         var _ArbeitspreisNeu = "";
                         var _GrundpreisNeu = "";
                         if(typeof geraet === "undefined") {
                              // Default Arbeitspreis ändern
                             _Datum                          = instanz + pfad + 'Allgemein.Stromkosten.neu.Datum';
                             _PreisaenderungDurchgefuehrt    = instanz + pfad + 'Allgemein.Stromkosten.neu.PreisaenderungDurchgefuehrt';
                             _Arbeitspreis       = instanz + pfad + 'Allgemein.Stromkosten.aktuell.Arbeitspreis';
                             _Grundpreis         = instanz + pfad + 'Allgemein.Stromkosten.aktuell.Grundpreis';
                             _ArbeitspreisNeu    = instanz + pfad + 'Allgemein.Stromkosten.neu.Arbeitspreis';
                             _GrundpreisNeu      = instanz + pfad + 'Allgemein.Stromkosten.neu.Grundpreis';
                         } else {
                             // Arbeitspreis für Gerät ändern
                             _Datum                          = instanz + pfad + geraet + '.eigenerPreis.neu.Datum';
                             _PreisaenderungDurchgefuehrt    = instanz + pfad + geraet + '.eigenerPreis.neu.PreisaenderungDurchgefuehrt';
                             _Arbeitspreis       = instanz + pfad + geraet + '.eigenerPreis.aktuell.Arbeitspreis';
                             _Grundpreis         = instanz + pfad + geraet + '.eigenerPreis.aktuell.Grundpreis';
                             _ArbeitspreisNeu    = instanz + pfad + geraet + '.eigenerPreis.neu.Arbeitspreis';
                             _GrundpreisNeu      = instanz + pfad + geraet + '.eigenerPreis.neu.Grundpreis';
                         if(getObject(_Datum)) {
                             var date = getState(_Datum).val;
                             var Datum_Tag;
                             var Datum_Monat;
                             var Datum_Jahr;
                             try {
                                 var Datum = date.match(/\d{2}(\.|-)\d{2}(\.|-)\d{4}/g).toString();
                                 Datum_Tag = Datum.split(".")[0];
                                 Datum_Monat = Datum.split(".")[1];
                                 Datum_Jahr = Datum.split(".")[2];
                             } catch (err) {
                                 console.log("Fehler beim Auslesen des Datums. Eventuell falsche Syntax? " + date + " (Error:" + err + ")");
                             var newdate = new Date(Datum_Monat + " " + Datum_Tag + " " + Datum_Jahr);
                             var today = new Date();
                             today.setHours(0,0,0,0);
                             if(today.getTime() === newdate.getTime()) {
                                 if(!getState(_PreisaenderungDurchgefuehrt).val) {
                                     setState(_PreisaenderungDurchgefuehrt, true);
                                     var alterArbeitspreis = getState(_Arbeitspreis).val;
                                     var alterGrundpreis = getState(_Grundpreis).val;
                                     var neuerArbeitspreis = getState(_ArbeitspreisNeu).val;
                                     var neuerGrundpreis = getState(_GrundpreisNeu).val;
                                     setState(_Arbeitspreis, neuerArbeitspreis);
                                     setState(_Grundpreis, neuerGrundpreis);
                                     var message =  'Preisänderung für ' + geraet + ' wurde durchgeführt:' + '\n'
                                                 + 'alter Arbeitspreis:' + alterArbeitspreis + '.\n'
                                                 + 'alter Grundpeis:' + alterGrundpreis + '.\n'
                                                 + 'neuer Arbeitspreis:' + neuerArbeitspreis + '.\n'
                                                 + 'neuer Grundpreis:' + neuerGrundpreis;
                             } else if(today.getTime() > newdate.getTime()) {
                                 // Variable zurücksetzen
                                 setState(_PreisaenderungDurchgefuehrt, false);
                      * Example:
                        // Validate "where"
                            return;
                        let counter = -1;
                            counter += 1;
                            // Clean
                                if(!force) {
                                    numStates--;
                                            return callback();
                                    } else {
                                } // if(!force)
                            let obj = {};
                            obj.type = 'state';
                            obj.native = {};
                                if (err) {
                                } else {
                                    let init = null;
                                    } else {
                                            numStates--;
                                                    return callback();
                      der SourceAnalytix-Adapter baut wohl auch auf dem Script auf, hab aber noch nicht herausgefunden wie ich den benutzen kann. Datenpunkte wurden mir von dem Adapter zumindest noch nicht erzeugt.
                      Außerdem hätte ich es gern übersichtlich unter 0_userdata alle selbst angelegten DP, als verstreut unter den Adapter.Objekten.
                      wenn man dein createUserStates() mal als BlocklyPuzzle hätte wäre das echt cool.
                      Gruß Michael
                      • Mic
                        Bsp. wenn ich z.B. (...Code... ) "rot_unterkrinngelt" mir der Editor die arrVariable. Würde nur gern wissen warum?
                        Du musst die Variable states2Create zuerst deklarieren. Siehe https://javascript.info/variables
                        Also statt:
                        states2Create = ['hier die Inhalte'];
                        setzt Du ein let davor:
                        let states2Create = ['hier die Inhalte'];
                        Oder du deklarierst sie schon vorher:
                        let states2Create;
                        Statt let findet man in vielen Scripts auch var, das geht auch, ist aber veraltet und würde ich vermeiden. Siehe https://javascript.info/var
                        In deinem zweiten Code-Beispiel sieht das korrekt aus, nur würde ich eben var durch let ersetzen.
                          paul53 @Mic last edited by
                          @Mic sagte:
                          Ich würde var durch const ersetzen.
                          • Mic
                            Mic Developer @paul53 last edited by Mic
                            Sehr guter Einwand, hast absolut recht, ist viel sinnvoller, da man mit const im Gegensatz zu let/var damit eine nicht veränderbare Variable deklariert.
                            Und var am besten ganz meiden.
                            var – is an old-school variable declaration. Normally we don’t use it at all, but we’ll cover subtle differences from let in the chapter The old "var", just in case you need them. (Quelle)
                            • X
                              danke für die Info, das mit dem let_statt_var werde ich mir angewöhnen!
                              also im ersten states2Create fehlt das var weil ich die Variable schon vorher deklariert habe. Sorry sieht man leider nur im kompletten code s. Spoiler
                              Ich hab var genommen weil die die Variable mehrfach mit unterschiedlichen "Arrayfüllungen" wiederverwenden wollte, in der Hoffung dass es weniger Speicher braucht als wenn ich mehrere Konstantenarrays deklariere.
                              Quatsch?
                                paul53 @xbow42 last edited by
                                @xbow42 sagte:
                                Eine manuelle "Füllung" ist konstant bezogen auf das Script.
                                • X
                                  ah ja👍 , nix mit gretalike variablenrecycling 🔁
                                    @xbow42
                                    Übrigens: Der Inhalt von Arrays und Objekten kann auch dann zur Laufzeit geändert werden, wenn das Array/Objekt als Konstante deklariert wurde.
                                    • X
                                      bin echt verblüfft, sehr inkonsequente Programmiersprache.
                                      musste ich glatt mal ausprobieren.
                                      const arrAnysting = ['0','8','15'];
                                      console.log(arrAnysting[2]);
                                      arrAnysting[2] = '42';
                                      arrAnysting[1] = '10';
                                      console.log(arrAnysting[1]);  //10
                                      console.log(arrAnysting[2]);  //42
                                      arrAnysting[0] = '000000000000000000000000000000000000000000000000000000000000000000000000000000';
                                      console.log(arrAnysting[0]); //000000000000000000000000000000000000000000000000000000000000000000000000000000
                                      arrAnysting = ['0','8','15'];//ungültige Zuweisung
                                      arrAnysting.unshift('neu an pos 0');
                                      console.log(arrAnysting[0]); //neu an pos 0  // das geht komischer Weise wieder
                                      Also wird das "konstante" Array wild im Arbeitsspeicher gehalten/verschoben/vergrößert, welches man mit Daten des gleichen Typs vollmüllen kann bis der Speicher voll ist -> und das script/der Rechner abschmiert. richtig?
                                      Austesten werde ich das sicher nicht!☠
                                        @xbow42 sagte:
                                        Konstant ist nur der Bezeichner arrAnysting; es kann keine neue Zuweisung erfolgen. Der Inhalt des Arrays kann beliebig verändert werden, denn Objekte werden nur referenziert (Zeiger). Das ist in anderen Programmiersprachen nicht anders.
                                        • X
                                          @paul53 ok danke für die kleine Nachhilfe. Werde mich weiter einlesen. ... geht ja eigentlich um UserDP, da will ich mal hier nicht weiter abschweifen.
                                          wünsche eine gute Nacht!
                                          • Mic
                                            Mic Developer last edited by Mic
                                            Hier übrigens der Vollständigkeit halber das Github Issue für den JS-Adapter: createState in 0_userdata.0 ermöglichen #429
                                            Bitte fleißig dort voten, wäre viel besser, wenn der JS-Adapter das "out of the box" liefert 🙂
                                            1.0k
                                            86
                                            17993
