    4. Adapter: Geofency
    Adapter: Geofency
      Sven2013 last edited by
      Hallo Daniel,
      eine tolle Idee von dir, vielen Dank dafür. Ich wollte den adapter testen, allerdings tauchen bei der install warnungen auf und der Adapter leider nicht im Admin.
      root@raspberrypi:~# npm install iobroker.geofency
      npm http GET https://registry.npmjs.org/iobroker.geofency
      npm http 304 https://registry.npmjs.org/iobroker.geofency
      npm http GET https://registry.npmjs.org/request
      npm http 304 https://registry.npmjs.org/request
      npm http GET https://registry.npmjs.org/extend
      npm http GET https://registry.npmjs.org/json-stringify-safe
      npm http GET https://registry.npmjs.org/forever-agent
      npm http GET https://registry.npmjs.org/form-data
      npm http GET https://registry.npmjs.org/mime-types
      npm http GET https://registry.npmjs.org/node-uuid
      npm http GET https://registry.npmjs.org/tunnel-agent
      npm http GET https://registry.npmjs.org/qs
      npm http GET https://registry.npmjs.org/tough-cookie
      npm http GET https://registry.npmjs.org/http-signature
      npm http GET https://registry.npmjs.org/oauth-sign
      npm http GET https://registry.npmjs.org/hawk
      npm http GET https://registry.npmjs.org/aws-sign2
      npm http GET https://registry.npmjs.org/stringstream
      npm http GET https://registry.npmjs.org/combined-stream
      npm http GET https://registry.npmjs.org/isstream
      npm http GET https://registry.npmjs.org/is-typedarray
      npm http GET https://registry.npmjs.org/har-validator
      npm http GET https://registry.npmjs.org/bl
      npm http GET https://registry.npmjs.org/caseless
      npm http 304 https://registry.npmjs.org/json-stringify-safe
      npm http 304 https://registry.npmjs.org/extend
      npm http 304 https://registry.npmjs.org/forever-agent
      npm http 304 https://registry.npmjs.org/form-data
      npm http 304 https://registry.npmjs.org/node-uuid
      npm http 304 https://registry.npmjs.org/mime-types
      npm http 304 https://registry.npmjs.org/tunnel-agent
      npm http 304 https://registry.npmjs.org/qs
      npm http 304 https://registry.npmjs.org/tough-cookie
      npm http 304 https://registry.npmjs.org/http-signature
      npm http 304 https://registry.npmjs.org/oauth-sign
      npm http 304 https://registry.npmjs.org/hawk
      npm http 304 https://registry.npmjs.org/aws-sign2
      npm http 304 https://registry.npmjs.org/stringstream
      npm http 304 https://registry.npmjs.org/combined-stream
      npm http 304 https://registry.npmjs.org/isstream
      npm http 304 https://registry.npmjs.org/is-typedarray
      npm http 304 https://registry.npmjs.org/har-validator
      npm http 304 https://registry.npmjs.org/bl
      npm http 304 https://registry.npmjs.org/caseless
      npm WARN engine hawk@3.1.2: wanted: {"node":">=0.10.32"} (current: {"node":"v0.10.22","npm":"1.3.14"})
      npm http GET https://registry.npmjs.org/delayed-stream
      npm http GET https://registry.npmjs.org/mime-db
      npm http GET https://registry.npmjs.org/async
      npm http 304 https://registry.npmjs.org/delayed-stream
      npm http 304 https://registry.npmjs.org/mime-db
      npm http 304 https://registry.npmjs.org/async
      npm http GET https://registry.npmjs.org/readable-stream
      npm http GET https://registry.npmjs.org/sshpk
      npm http GET https://registry.npmjs.org/assert-plus
      npm http GET https://registry.npmjs.org/jsprim
      npm http 304 https://registry.npmjs.org/readable-stream
      npm http 304 https://registry.npmjs.org/sshpk
      npm http 304 https://registry.npmjs.org/assert-plus
      npm http 304 https://registry.npmjs.org/jsprim
      npm http GET https://registry.npmjs.org/chalk
      npm http GET https://registry.npmjs.org/commander
      npm http GET https://registry.npmjs.org/is-my-json-valid
      npm http GET https://registry.npmjs.org/pinkie-promise
      npm http 304 https://registry.npmjs.org/commander
      npm http 304 https://registry.npmjs.org/chalk
      npm http 304 https://registry.npmjs.org/is-my-json-valid
      npm http 304 https://registry.npmjs.org/pinkie-promise
      npm http GET https://registry.npmjs.org/verror/1.3.6
      npm http GET https://registry.npmjs.org/extsprintf/1.0.2
      npm http GET https://registry.npmjs.org/json-schema/0.2.2
      npm http GET https://registry.npmjs.org/ansi-styles
      npm http GET https://registry.npmjs.org/escape-string-regexp
      npm http GET https://registry.npmjs.org/has-ansi
      npm http GET https://registry.npmjs.org/strip-ansi
      npm http GET https://registry.npmjs.org/supports-color
      npm http 304 https://registry.npmjs.org/escape-string-regexp
      npm http 304 https://registry.npmjs.org/has-ansi
      npm http 304 https://registry.npmjs.org/ansi-styles
      npm http 304 https://registry.npmjs.org/strip-ansi
      npm http 304 https://registry.npmjs.org/supports-color
      npm http GET https://registry.npmjs.org/graceful-readlink
      npm http 304 https://registry.npmjs.org/verror/1.3.6
      npm http 304 https://registry.npmjs.org/extsprintf/1.0.2
      npm http 304 https://registry.npmjs.org/graceful-readlink
      npm http 304 https://registry.npmjs.org/json-schema/0.2.2
      npm http GET https://registry.npmjs.org/ansi-regex
      npm http 304 https://registry.npmjs.org/ansi-regex
      npm http GET https://registry.npmjs.org/isarray/0.0.1
      npm http GET https://registry.npmjs.org/process-nextick-args
      npm http GET https://registry.npmjs.org/string_decoder
      npm http GET https://registry.npmjs.org/util-deprecate
      npm http GET https://registry.npmjs.org/core-util-is
      npm http GET https://registry.npmjs.org/inherits
      npm http 304 https://registry.npmjs.org/string_decoder
      npm http 304 https://registry.npmjs.org/isarray/0.0.1
      npm http 304 https://registry.npmjs.org/process-nextick-args
      npm http 304 https://registry.npmjs.org/util-deprecate
      npm http 304 https://registry.npmjs.org/core-util-is
      npm http 304 https://registry.npmjs.org/inherits
      npm http GET https://registry.npmjs.org/asn1
      npm http GET https://registry.npmjs.org/dashdash
      npm http GET https://registry.npmjs.org/jsbn
      npm http GET https://registry.npmjs.org/jodid25519
      npm http GET https://registry.npmjs.org/ecc-jsbn
      npm http GET https://registry.npmjs.org/tweetnacl
      npm http 304 https://registry.npmjs.org/dashdash
      npm http 304 https://registry.npmjs.org/jsbn
      npm http 304 https://registry.npmjs.org/jodid25519
      npm http 304 https://registry.npmjs.org/tweetnacl
      npm http 304 https://registry.npmjs.org/asn1
      npm http 304 https://registry.npmjs.org/ecc-jsbn
      npm http GET https://registry.npmjs.org/generate-function
      npm http GET https://registry.npmjs.org/generate-object-property
      npm http GET https://registry.npmjs.org/xtend
      npm http GET https://registry.npmjs.org/jsonpointer/2.0.0
      npm http 304 https://registry.npmjs.org/generate-function
      npm http 304 https://registry.npmjs.org/generate-object-property
      npm http 304 https://registry.npmjs.org/xtend
      npm http 304 https://registry.npmjs.org/jsonpointer/2.0.0
      npm http GET https://registry.npmjs.org/hoek
      npm http GET https://registry.npmjs.org/boom
      npm http GET https://registry.npmjs.org/cryptiles
      npm http GET https://registry.npmjs.org/sntp
      npm http 304 https://registry.npmjs.org/hoek
      npm http 304 https://registry.npmjs.org/boom
      npm http 304 https://registry.npmjs.org/cryptiles
      npm http 304 https://registry.npmjs.org/sntp
      npm WARN engine hoek@2.16.3: wanted: {"node":">=0.10.40"} (current: {"node":"v0.10.22","npm":"1.3.14"})
      npm WARN engine boom@2.10.1: wanted: {"node":">=0.10.40"} (current: {"node":"v0.10.22","npm":"1.3.14"})
      npm WARN engine cryptiles@2.0.5: wanted: {"node":">=0.10.40"} (current: {"node":"v0.10.22","npm":"1.3.14"})
      npm http GET https://registry.npmjs.org/is-property
      npm http 304 https://registry.npmjs.org/is-property
      iobroker.geofency@0.0.1 node_modules/iobroker.geofency
      └── request@2.67.0 (is-typedarray@1.0.0, aws-sign2@0.6.0, forever-agent@0.6.1, caseless@0.11.0, stringstream@0.0.5, tunnel-agent@0.4.2, oauth-sign@0.8.0, isstream@0.1.2, json-stringify-safe@5.0.1, extend@3.0.0, node-uuid@1.4.7, combined-stream@1.0.5, qs@5.2.0, tough-cookie@2.2.1, form-data@1.0.0-rc3, mime-types@2.1.9, bl@1.0.0, har-validator@2.0.5, http-signature@1.1.0, hawk@3.1.2)
      Gruss Sven
        pix last edited by
        hervorragend! Habe den Adpter schon unter CCU.IO genutzt und bin wirklich froh, dass du ihn zu ioBroker portiert hast. Er funktioniert ohne Murren.
        Danke und Gruß,
        Pix
        • Bluefox
          Bluefox last edited by
          Ich habe dich zu Collaborators hinzugefügt.
          Du kannst direkt dorthin puschen. Oder falls du bei sich den lassen willst, dann werde ich aus ioBroker Organisation löschen.
          P.S. Habe 2 Push-Request gestellt.
            Dschaedl last edited by
            @Bluefox: Cool, danke!
            Ich habe die Pfade nun auf iobroker/iobroker.gefency angepasst und als Version 0.0.2 auf npm publiziert - und dich als collaborator zum npm dazugefügt.
            viele Grüsse
            Daniel
              @Sven
              hmm.. sieht eigetnlich nur nach Warnungen ein. Deine nodejs Version scheint nicht die gewünschte zu sein.
              Hast du nach dem npm install auch ein Refresh der Adapter im Admin-Gui gemacht?
              viele Grüsse
              Daniel
                Hallo Daniel,
                leider ist auch nach dem refresh nichts unter Adapter erschienen. Allerdings gibt es auch keine neuere nodejs Version die mir im Admin angezeigt wird.
                Aber mal anders, nachdem du hinzugefügt bist für den Adapter, müsste dieser doch eh mit dabei sein. Oder?
                Gruß Sven
                  @Sven
                  noch eine blöde Frage: Von wo aus hast du npm aufgerufen? Du solltest dich dafür im iobroker Verzeichnis befinden.
                  viele Grüsse
                  Daniel
                  P.S.
                  es geht nicht um die Version von ioBroker, sondern um die node.js Version - die lässt sich nich im GUI updaten :roll:
                    Hey vielen Dank,
                    ich habe den Ordner natürlich nicht vorher gewechselt. Ich Depp!
                    Vielen dank nun funktioniert es soweit 100%
                    Danke für den tollen Adapter.
                    gruß Sven
                      BlueEssi last edited by
                      Top!!! Funktioniert auf Anhieb!!! Vielen Dank!
                        Hallo, ich nochmal
                        ich habe heute die geofancy Meldung bekommen, das der Status abwesend nicht gesetzt werden kann.
                        Ist ja auch logisch, der Url nach habe ich ja auch die ip des raspi/Port/ablageort eingegeben. So ist diese von außen natürlich nicht erreichbar.
                        Kann ich nun die "feste ip"/Port/ablageort nehmen? Denn eigentlich fehlt ja die Zuordnung zum raspi dann oder?
                        2. Frage
                        mit welchem Widget habt ihr die Visualisierung für an bzw. Abwesenheit gemacht?
                        Frage 3
                        Ist es möglich das ich ein Icon als Widget nutze, das bei Anwesenheit grün/ bei Abwesenheit rot/ und bei Anwesenheit im Büro gelb ist?
                        Und wenn ja wie kann man das anlegen?
                        Ergibt ein weiterer geofancy Ort wenn ich den unter raspi ip/Port/ablageort 2 ?
                        Danke schonmal für eure Mühe :-))
                        Gruß Sven
                          pix last edited by
                          Hallo Sven:
                          zu 2 und 3) damit:
                          Metro Tile ValueList Widget
                          [{"tpl":"tplMetroTileList8","data":{"oid":"geofency.0.pix.Zu Hause.entry","visibility-cond":"==","visibility-val":1,"label0":"abwesend","label1":"zu Hause","label2":"Value list","label3":"Value list","label4":"Value list","label5":"Value list","label6":"Value list","label7":"Value list","bg_class0":"bg-transparent","bg_class1":"bg-transparent","bg_class2":"bg-indigo","bg_class3":"bg-indigo","bg_class4":"bg-indigo","bg_class5":"bg-indigo","bg_class6":"bg-indigo","bg_class7":"bg-indigo","icon_class0":"icon-custom","icon_class1":"icon-custom","icon_class2":"icon-pencil","icon_class3":"icon-pencil","icon_class4":"icon-pencil","icon_class5":"icon-pencil","icon_class6":"icon-pencil","icon_class7":"icon-pencil","icon_badge0":"icon-custom","icon_badge1":"icon-custom","icon_badge2":"icon-pencil","icon_badge3":"icon-pencil","icon_badge4":"icon-pencil","icon_badge5":"icon-pencil","icon_badge6":"icon-pencil","icon_badge7":"icon-pencil","badge_bg_class0":"","badge_bg_class1":"","badge_bg_class2":"bg-cyan","badge_bg_class3":"bg-cyan","badge_bg_class4":"bg-cyan","badge_bg_class5":"bg-cyan","badge_bg_class6":"bg-cyan","badge_bg_class7":"bg-cyan","brand_bg_class0":"bg-darkOrange","brand_bg_class1":"bg-olive","brand_bg_class2":"ribbed-steel","brand_bg_class3":"ribbed-steel","brand_bg_class4":"ribbed-steel","brand_bg_class5":"ribbed-steel","brand_bg_class6":"ribbed-steel","brand_bg_class7":"ribbed-steel","badge_top":"0","badge_left":"0","name":"Geoposition J","label_prepend":"","comment":"Daten aus Handyortung","icon0":"/icons-mfd-png/status_man.png","icon1":"/icons-mfd-png/status_man.png","icon_width":"79","icon_height":"79","icon_top":"22","icon_left":"32"},"style":{"left":"588px","top":"434px","z-index":"25","width":"137px","height":"137px"},"widgetSet":"metro"}]
                          Jetzt zu meinem Problem:
                          Ich nutze ioBroker rauf Mac OS X. Leider ist der Mac, nachdem Geofency den Status geändert hat, nicht mehr erreichbar. Er läuft noch, aber weder Bildschirmfreigabe noch Zugriffe auf die Webserver funktionieren noch (also kein VIS, etc..). Ich habe es durch Probieren definitiv auf den Adapter eingrenzen können.
                          <size size="50">Kann ich den Port (7999) ändern, den der Adapter für seinen Webserver nutzt? Habe das Gefühl, der ist schon belegt.</size>
                          EDIT: Peinlich, peinlich. GIbt es ja in den Einstellungen :oops: :oops: :oops:
                          Pix
                            RobS last edited by
                            Hallo zusammen und Danke Dschaedl für den Adapter,
                            leider bin ich nicht in der Lage ihn zu installieren. Nach der Eingabe von "npm install iobroker.geofency" im Ordner "/node modules" ist alles wunderbar ohne Mucken durchgelaufen. Es wird auch das Verzeichnis iobroker.geofency angelegt nur leider findet sich der Adapter nun nirgendwo wieder. Weder im Admin-GUI noch in der Konsole unter "list adapters"…
                            Habe ich noch irgendetwas nicht bedacht oder wo könnte der Fehler bei mir liegen?
                            Vielen Dank und Grüße,
                            Rob
                            • V
                              versteckt last edited by
                              Nicht im Ordner node_modules installieren, sondern eine Ebene höher.
                              npm install legt automatisch seine Software in den node_modules Ordner
                              Gesendet von meinem iPhone mit Tapatalk
                                RobS last edited by
                                Hey, Danke für die schnelle Anwort versteckt.
                                So hatte ich es eigentlich schon als allererstes gemacht. Habe jetzt nochmal das Verzeichnis gelöscht und so installiert, wie von dir beschrieben und siehe da, der Adapter taucht auf… :shock:
                                Vielen Dank!
                                Rob
                                305_heizungsscript_220_b03_temp.txt
                                • Bluefox
                                  Kann jemand ausprobieren, ob die neue Änderungen funktionieren?
                                  cd /opt/iobroker
                                  npm install https://github.com/ioBroker/ioBroker.geofency/tarball/master
                                  Ich habe kein iPhone.
                                    Hallo Bluefox,
                                    was hast du denn geändert?
                                    Also auf was muss ich achten?
                                    Gruß Sven
                                    • Bluefox
                                      @Sven2013:
                                      Hallo Bluefox,
                                      Gruß Sven
                                      Gesendet von iPhone mit Tapatalk `
                                      Ich habe ein Pull-Request gemerged. Was das genau macht weiß ich nicht:
                                      https://github.com/ioBroker/ioBroker.ge … 349de2871f
                                      Vermutlich werden neue States erzeugt: "lastLeave", "lastEnter"
                                        Hallo Bluefox,
                                        ich teste das nachher wenn ich zu Hause bin.
                                        @all
                                        kann mir nochmal einer sagen welche URL ihr angegeben habt bei Geofancy? Denn der Status kann nicht gesetzt werden sagt geofancy.
                                        Und was ich auch versuche, es ändert sich leider nichts 😞
                                        Gruß Sven
                                          RobS last edited by
                                          Hi Sven,
                                          du brauchst meines Wissens eine feste IP-Adresse, eine dynd.dns oder, wenn du eine Fritzbox hast, eine myfritz.net-Adresse, die du als Domain einträgst und dann eine Portweiterleitung für den Port, den du in der URL angibst im Router. Bei mir funktioniert es wunderbar mit der Fritzbox.
                                          Gruß, Rob
                                          Edit: Gerade erst deine vorherige Frage gelesen:
                                          @Sven2013:
                                          Hallo, ich nochmal
                                          Kann ich nun die "feste ip"/Port/ablageort nehmen? Denn eigentlich fehlt ja die Zuordnung zum raspi dann oder? `
                                          Die Zuordnung zum Raspi erfolgt dann über die Portweiterleitung
                                            @Bluefox:
                                            cd /opt/iobroker
                                            funktioniert bestens bei mir. :mrgreen:
                                            Daniel
                                            205
                                            51952
