    4. JavaScript
    5. Strom Geräte als HTML Tabelle - Vis - Iqontrol
    • O
      Oli @Negalein last edited by
      @Negalein
      [{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"3","visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"{javascript.0.Stromberechnung.ENERGY}","visibility-oid":"","name":"TV-22"},"style":{"left":"20px","top":"41px","color":"#8f8f8f","width":"calc(100% - 40px)","height":"257px","z-index":"10","overflow-y":"","background-color":"#2e2e2e","border-radius":"10px","box-shadow":"2px 2px 3px rgba(20, 20, 20, 50)","border-color":"","border-style":"","border-width":""},"widgetSet":"basic"}]
      Datenpunkt unter Html im Widget anpassen
      • Negalein
        Negalein Global Moderator @Oli last edited by
        @Oli sagte in Strom Geräte als HTML Tabelle - Vis - Iqontrol:
        Also statt {javascript.0.Stromberechnung.ENERGY} mach ich {0_userdata.0.StromgeraeteTabelle}
        • O
          @Negalein
          genau
            liv-in-sky @Chaot last edited by liv-in-sky
            @Chaot
            der datenpunkt für soureceanalytics heißt cur_power in tuya
            das andere habe ich eingefügt -danke für den hinweis
            • Negalein
              @Oli @liv-in-sky
              passt das so?
              • O
                @Negalein
                du kannst die nicht benötigten Überschriften noch auf "false" im Script setzen Zeile 17 - 26
                • Chaot
                  Chaot @Oli last edited by
                  Auf meiner Suche nach einer Strommessdose habe ich das gefunden:
                  Link Text
                  Was zur H..e ist denn das?????
                  • Negalein
                    Negalein Global Moderator @Chaot last edited by
                    @Chaot sagte in Strom Geräte als HTML Tabelle - Vis - Iqontrol:
                    muss High End sein.
                    ist ja Gold!! :😂 😂 😂
                    • Chaot
                      Chaot @liv-in-sky last edited by
                      @liv-in-sky
                      Kommt bei meinen Tuyas scheinbar nicht:
                        A Former User last edited by
                        @liv-in-sky
                        Guten Morgen 🙂
                        Ich weiss nicht, ob wir das Thema aufgrund SourceAnalytix aus dem Programm genommen haben, aber ich wollte nochmals die virtuellen Vebräuche aufgrund des Adapters "virtual powermeter" zur Diskussion stellen 🙂
                          @Chaot in der letzten version sind bis jetzt nur die kosten integriert - da müßte dann zumindest 0 € stehen - ist das bei dir so ?
                          die abfrage von meinem script an die sourceanalytics datenpunkte ist das ,was ich wissen wollte - ist auch nur für tuya und homematic im moment integriert - habe sourceanalyt. zum erstenmal installiert und weiß nicht, warum da 0 bei dir steht - das müßtest du bitte an anderer stelle klären - bei mir sind die meisten datenpunkte ja ohne adapter und ich simuliere nur werte für tuya, mihome, homematic und hs100 - ich hatte lauter 0er , weil der power -datenpunkt nicht aktualisiert wurde - evtl ist das bei dir die ursache, dass du nur 0er werte hast
                          in der nächsten version sind dann die kwh von sourceanalytics auch mit drin - dafür muss consumption angeklickt sein im sourcanalytics setting des datenpunktes
                            liv-in-sky @Guest last edited by
                            @HeinrichB das sind einfach zu wenig daten - kannst du mal einen solchen punkt in sourceanalytics einbinden - dann haben wir etwas mehr wie nur die leistung für die anzeige
                              A Former User @liv-in-sky last edited by
                              @liv-in-sky Okay, dann macht es echt keinen Sinn 🙂
                                @HeinrichB
                                ich müßte dann wohl das virtual powermeter als gerät einbinden und auf sourceanaly. abfragen
                                  liv-in-sky last edited by liv-in-sky
                                  hier geht es weiter https://forum.iobroker.net/topic/29189/energieanzeige-kwh-über-html-tabelle-vis
                                  damit im ersten post immer das aktuelle script liegt
                                  • Meister Mopper
                                    Meister Mopper @Guest last edited by Meister Mopper
                                    @HeinrichB sagte in Strom Geräte als HTML Tabelle - Vis - Iqontrol:
                                    @liv-in-sky
                                    Habe eben eine Teckin mit Tasmota geflasht. Siehe dazu den Screen und das Modul "Teckin"
                                    Wie hast Du sie geflashed? War es ein aktuelles Modell?
                                      A Former User @Meister Mopper last edited by
                                      @Meister-Mopper über tuya-convert. War eine SP22 und da ist gemäß Netz ein esp8266 drin. Da ging ich dann ins Risiko und habs probiert
                                      Hab es übrigens unter Debian gemacht auf einem alten Netbook
                                      javascript
                                      13
                                      289
                                      35429
