    4. umstieg von pimatic
    umstieg von pimatic
      madison last edited by
      ich bin gerade beim umstieg von pimatic zu iobroker.
      die ganzen geräte funktionieren so weit.
      nur mit den regeln komm ich nicht klar.
      hatte in pimatic 2 regeln die ich mit blockly nicht hin bekomme.
      1. Regel: when powerGrid of Fronius Inverter is less than -500 for 3 minutes and fibaro_relais1 is turned off then turn fibaro_relais1 on
      2. Regel: when powerGrid of Fronius Inverter is greater than 100 for 5 minutes and fibaro_relais1 is turned on for 60 minutes and temperature of fibaro_temp_sensor3 is greater than 42 then turn fibaro_relais1 off
      kann mir ja jemand helfen bitte
      lg Mad
        das habe ich bisher geschafft, nur wo baue ich die zeiten ein?
          <block type="on" id="F!!Ou/C`OjBU2N;2s?US" x="188" y="38">
            <field name="OID">fronius.0.powerflow.P_Grid</field>
              <block type="controls_if" id="qjZ;R!,!*H=11p#Egh+v">
                  <block type="logic_operation" id="cmGS.ub1u5-/XRi/FQUE">
                    <field name="OP">AND</field>
                      <block type="logic_compare" id="?]lGz,I4K),UYyo[4%98">
                        <field name="OP">LT</field>
                          <block type="on_source" id="{LBQshF_hKMC,Wp=O!@@">
                          <block type="math_number" id="Bp?Fi=(b0uKhdv*u!Q6x">
                            <field name="NUM">-500</field>
                      <block type="logic_compare" id="HKpI5DKrAmnAcSak4W;s">
                        <field name="OP">EQ</field>
                          <block type="get_value" id="nyl~uf0Z2+_6kN1*+g?$">
                            <field name="OID">zwave.0.NODE6.SWITCH_BINARY.Instance_1:_Switch_1</field>
                          <block type="logic_boolean" id="k}DMur}sC,{*c[WncO63">
                  <block type="control" id="(zGO6Qkwq(f8e%kO|8Sg">
                      <block type="logic_boolean" id="/6AaiPMn826qm8P53w7[">
              <block type="on" id="mO34Zmd9SdeH=HtHZLOt">
                  <block type="controls_if" id="{[diRkfyM[.]Jtxg$4U)">
                      <block type="logic_operation" id="OevnL,[%w.+ve_h;6C(N">
                          <block type="logic_compare" id="-`b=fhm{mPh095}0@KuI">
                            <field name="OP">GT</field>
                              <block type="on_source" id="sETxhFI[-k*;pp3ZGJS_">
                              <block type="math_number" id="HqJ?48]sqCU]MT/=DZp`">
                                <field name="NUM">100</field>
                          <block type="logic_operation" id="(v5+?t,At.q]*haeK/fb">
                              <block type="logic_compare" id="fz-Npw-+wjlZzE.+gbCJ">
                                  <block type="get_value" id="uLBs7GxU[F*FMos)(nNI">
                                  <block type="logic_boolean" id="1~z()h5cV.tem6~D5#u~">
                              <block type="logic_compare" id="ow/FdN|$ThNgIO?.yN]T">
                                  <block type="get_value" id="v]?-?hf8HfB?D63nk;|A">
                                    <field name="OID">zwave.0.NODE8.SENSOR_MULTILEVEL.Instance_3:_Air_Temperature_3</field>
                                  <block type="math_number" id="EKA{Zn)Tii@{s7}u]G6M">
                                    <field name="NUM">42</field>
                      <block type="control" id="(|[X898Jn$%eta8@h%$I">
                          <block type="logic_boolean" id="{w9Ai~l*Td~H+xVOGn?J">
        FredF paul53 2 Replies Last reply Reply Quote 0
        • FredF
          FredF Most Active Forum Testing @madison last edited by
          @madison zeige mal ein Bild von deinem Blockly dann kann dir leichter geholfen werden
            paul53 @madison last edited by paul53
            @madison sagte:
            Vorschlag:
             <variables>
               <variable type="undefined" id="timeout1">timeout1</variable>
               <variable type="undefined" id="timeout3">timeout3</variable>
               <variable type="undefined" id="timeout2">timeout2</variable>
               <variable type="" id="+l8CB%A26RkWF;d6hPt^">gr100</variable>
               <variable type="" id="B7QKKsZJJ/rD9$B7mY6C">switch1h</variable>
             </variables>
                     <block type="controls_if" id="dg7U:~/QG^y@~UDh#j1k">
                         <block type="logic_negate" id="#8v=)|plTUEd6ilm-Z=n">
                           <value name="BOOL">
                             <block type="variables_get" id="$1F//R)lhji{+.TUkw+~">
                               <field name="VAR" id="timeout1" variabletype="undefined">timeout1</field>
                         <block type="timeouts_settimeout" id="=LFs$DUT/hJCCGhQVXhv">
                           <field name="NAME">timeout1</field>
                           <field name="DELAY">3</field>
                             <block type="controls_if" id="b~mna{[e9y^z0HBTa7PW">
                   <statement name="ELSE">
                     <block type="timeouts_cleartimeout" id="%Zy:%ZMXlarV9@amW2bs">
                         <block type="controls_if" id="vGza`E-WefVyAnCb~14k">
                             <block type="logic_negate" id="y[LIf=4b~*fml%#!@l-n">
                               <value name="BOOL">
                                 <block type="variables_get" id="H+0rVt%$ht5xT{R{bC*e">
                                   <field name="VAR" id="timeout2" variabletype="undefined">timeout2</field>
                             <block type="timeouts_settimeout" id="$=NLcQVhfZO0,4%KbZfE">
                               <field name="DELAY">5</field>
                                 <block type="variables_set" id="b(=m)mt`IWT;sY~E?}g7">
                                   <field name="VAR" id="+l8CB%A26RkWF;d6hPt^" variabletype="">gr100</field>
                                     <block type="logic_boolean" id="M1wU31[B,uJ-Q@riDi|P">
                                     <block type="procedures_callnoreturn" id="bnJaxS]jMkxSPHlI=vqR">
                                       <mutation name="switchOff"></mutation>
                         <block type="timeouts_cleartimeout" id="[@T#iDT$Ud2;O,6;W.H/">
                             <block type="variables_set" id="i;,RLCdV},^zEa*_6cM2">
                                 <block type="logic_boolean" id="TUjF#,9drH]syK5szgO:">
                 <block type="on_ext" id="(xXt]eB6)Vix.:KPkq!}">
                   <value name="OID0">
                     <shadow type="field_oid" id="l_u/*Kbe1kX5xiQVF*p+">
                     <block type="text" id="nR@Mw^]bR6W}x@_KE7g)">
                       <field name="TEXT">zwave.0.NODE6.SWITCH_BINARY.Instance_1:_Switch_1</field>
                     <block type="controls_if" id="7b$3~[60wWg@u1}{Hj?/">
                         <block type="on_source" id="{Nr0}siZHCC!+`5xxx}~">
                         <block type="timeouts_settimeout" id="67xG/z!M$Uw-hlOqs_?j">
                           <field name="NAME">timeout3</field>
                           <field name="DELAY">60</field>
                             <block type="variables_set" id=",)^HX7BCttUtUiJ6^8qH">
                               <field name="VAR" id="B7QKKsZJJ/rD9$B7mY6C" variabletype="">switch1h</field>
                                 <block type="logic_boolean" id="!N(NF}d41aaElY%yc,)G">
                                 <block type="procedures_callnoreturn" id="o;QuduYqb*E@=3}E[bO{">
                         <block type="timeouts_cleartimeout" id="q){%NyVclQ|!6ej%+0SP">
                             <block type="variables_set" id="wApdLjyIMtf~^5?x|$6}">
                                 <block type="logic_boolean" id="q^-E#(SI3vcifr+9Lek=">
             <block type="procedures_defnoreturn" id="Ma~~XRRb?+r37-Nc_I6t" x="587" y="737">
               <field name="NAME">switchOff</field>
               <statement name="STACK">
                 <block type="controls_if" id=",Egp%5VyFA4~BuM*|2-|">
                     <block type="logic_operation" id="(v5+?t,At.q]*haeK/fb" inline="false">
                         <block type="logic_operation" id="LMS1G.{eF#;EVoZj3CCS">
                             <block type="variables_get" id="qd+g@:p3t285N6Qz;Dl5">
                             <block type="variables_get" id="i+;3+schEOyhG*^i9+$~">
              madison @paul53 last edited by
              @paul53 Re: umstieg von pimatic
              danke paul, werd ich mir ansehen und schauen ob ich das testen kann.
              soviel sonne gibts im moment leider nicht 😉
                ganz optimal funktioniert es noch nicht.
                die stunde aktiv klappt nicht.
                woran kann das liegen?
                blockly
