    2. Русский
    3. аппаратные средства
    4. Железо
    5. Установка ioBroker на android телефон-планшет…
    • V
      Vlad_k last edited by
      Linux-системы запускаются в chroot окружении, то есть паралельно андроиду
      • V
        удалось таки установить брокера, но при установке визуалки из админки ошибка
        $ ./iobroker add vis
        host.localhost install adapter vis
        npm install --production --prefix "/opt/iobr/node_modules/iobroker.vis" (System call)
        npm
        ERR!
        Linux 3.0.8+
        npm ERR! argv
        "node" "/usr/bin/npm" "install" "--production" "--prefix" "/opt/iobr/node_modules/iobroker.vis"npm ERR! node v0.10.41
        ! npm ERR! npm v3.5.3
        ! npm ERR! Cannot read property 'target' of null
        npm ERR! npm ERR! If you need help, you may report this error at:
        npm
        ERR! <https: github.com/npm/issues="">
        ! npm
        ERR! Please include the following file with any support request:
        npm ERR! /opt/npm-debug.log
        Cannot install iobroker.vis: 1
        ERROR: process exited with code 25</https:>
        >! ****npm log****
        >! 0 info it worked if it ends with ok
        >! 1 verbose cli [ 'node',
        >! 1 verbose cli '/usr/bin/npm',
        >! 1 verbose cli 'install',
        >! 1 verbose cli '–production',
        >! 1 verbose cli '--prefix',
        >! 1 verbose cli '/opt/iobr/node_modules/iobroker.vis' ]
        >! 2 info using npm@3.5.3
        >! 3 info using node@v0.10.41
        >! 4 verbose node symlink /usr/bin/node
        >! 5 silly loadCurrentTree Starting
        >! 6 silly install loadCurrentTree
        >! 7 silly install readLocalPackageData
        >! 8 silly install normalizeTree
        >! 9 silly loadCurrentTree Finishing
        >! 10 silly loadIdealTree Starting
        >! 11 silly install loadIdealTree
        >! 12 silly cloneCurrentTree Starting
        >! 13 silly install cloneCurrentTreeToIdealTree
        >! 14 silly cloneCurrentTree Finishing
        >! 15 silly loadShrinkwrap Starting
        >! 16 silly install loadShrinkwrap
        >! 17 silly loadShrinkwrap Finishing
        >! 18 silly loadAllDepsIntoIdealTree Starting
        >! 19 silly install loadAllDepsIntoIdealTree
        >! 20 silly loadAllDepsIntoIdealTree Finishing
        >! 21 silly idealTree:prePrune iobroker.vis@0.8.3
        >! 22 silly loadIdealTree Finishing
        >! 23 silly currentTree iobroker.vis@0.8.3
        >! 24 silly idealTree iobroker.vis@0.8.3
        >! 25 silly generateActionsToTake Starting
        >! 26 silly install generateActionsToTake
        >! 27 verbose type non_object_property_load
        >! 28 verbose stack TypeError: Cannot read property 'target' of null
        >! 28 verbose stack at module.exports (/usr/lib/node_modules/npm/lib/install/filter-invalid-actions.js:24:35)
        >! 28 verbose stack at Array.3 (/usr/lib/node_modules/npm/node_modules/slide/lib/bind-actor.js:15:8)
        >! 28 verbose stack at LOOP (/usr/lib/node_modules/npm/node_modules/slide/lib/chain.js:15:14)
        >! 28 verbose stack at /usr/lib/node_modules/npm/node_modules/slide/lib/chain.js:18:7
        >! 28 verbose stack at Object.Installer.computeLinked (/usr/lib/node_modules/npm/lib/install.js:411:41)
        >! 28 verbose stack at Array.2 (/usr/lib/node_modules/npm/node_modules/slide/lib/bind-actor.js:15:8)
        >! 28 verbose stack at module.exports (/usr/lib/node_modules/npm/lib/install/diff-trees.js:50:3)
        >! 28 verbose stack at Array.1 (/usr/lib/node_modules/npm/node_modules/slide/lib/bind-actor.js:15:8)
        >! 29 verbose cwd /opt
        >! 30 error Linux 3.0.8+
        >! 31 error argv "node" "/usr/bin/npm" "install" "--production" "--prefix" "/opt/iobr/node_modules/iobroker.vis"
        >! 32 error node v0.10.41
        >! 33 error npm v3.5.3
        >! 34 error Cannot read property 'target' of null
        >! 35 error If you need help, you may report this error at:
        >! 35 error <[https://github.com/npm/npm/issues](https://github.com/npm/npm/issues)>
        >! 36 verbose exit [ 1, true ]
          Haus last edited by
          npm ставили из репозиториев ?
          странная ссылка /opt/<u>iobr</u>/node_modules/iobroker.vis должна быть /opt/<u>iobroker</u>/node_modules/iobroker.vis
          у меня npm 2.14.14 node v0.10.41
          • V
            @Haus:
            у меня npm 2.14.14 node v0.10.41 `
            да ставил из репы, потом он вроде просил обновиться(точно не помню), а папка, обрезал название, просто это была вторая попытка поставить, после первой не удачной в обычную папку…
            может есть какой скрипт установочный чтоб запустил и он сам все проставил? если честно, убил на полурабочую инсталяцию пол дня, жалко времени... зато опенхаб тупо папку с проектом из винды бросаю по нужному пути и яву устанавливаю, все шуршит...
              Haus last edited by
              @Vlad_k:
              @Haus:
              может есть какой скрипт установочный чтоб запустил и он сам все проставил? если честно, убил на полурабочую инсталяцию пол дня, жалко времени... зато опенхаб тупо папку с проектом из винды бросаю по нужному пути и яву устанавливаю, все шуршит... `
              Я ставил вот так
              http://forum.iobroker.net/viewtopic.php … 120#p15011
              после установки /etc/init.d/iobroker.sh start
              • V
                Vlad_k last edited by Jey Cee
                2Haus
                снес все, поставил как ты, с первого раза не заработал, удалил папку иоброкер, поставил снова и только тогда завелось и шуршит… счас попробую накидать по логам, что делал, чтоб с первого раза заводилось...
                на всякий случай лог всего что делал
                log.txt
                  electric69 last edited by
                  @Vlad_k:
                  Linux-системы запускаются в chroot окружении, то есть паралельно андроиду `
                  А есть ли варианты линукс поставить прямо на устройство, сейчас есть не дорогие планшеты даже x86 на Intel…
                  Не пробовали копать в эту сторону?
                  • V
                    возможность есть, как раз один из планшетов у меня на рк3066 проце под него уже есть готовые http://4pda.ru/forum/index.php?showtopic=527032, но весь смак от Linux Deploy в том что не нужно заморачиваться с дровами под разное железо, искать даташиты на дисплеи wifi тачскрины и тп, просто запустил в паралели и пользуй уже проинициализированное железо…
                    Счас правда столкнулся с граблями, не могу получить доступ к юсб/ком шнурку из под линуха в /dev/tty не появляется ttyUSB устройств, установил ардуинку под линуксом, а шить могу только через debug-Uart порт, а это не совсем универсально, не везде есть возможность подпаяться, короче есть еще над чем погуглить
                    • V
                      c USBserial http://pccar.ru/showthread.php?t=18871, ttyUSB появился под линуксом, можно пожалуй что нибудь сваять, ткните в нужном направлении или мож примерчиком помогите:
                      как подключить свой скрипт
                      как в скрипте получить/отправить данные в переменную
                      как эту переменную использовать в визредакторе
                      PS есть вообще какой либо мануальчик по работе системы и взаимодействию мудулей внутри системы, желательно с примерами?
                        @Vlad_k:
                        есть вообще какой либо мануальчик по работе системы и взаимодействию мудулей внутри системы, желательно с примерами? `
                        Много на этом форуме, основное в немецко-язычной ветке, при умении пользоваться гуглом - можно более-менее понимать…
                        Много ценной информации с примерами есть на гитхабе...
                        А по поводу планшета - тема очень интересна!
                        Получаем в итоге устройство все в одном - и сервер ioBroker, и HMI, и тут же устройство голосовых команд, и система гарантированного питания - встроенный АКБ...
                        Есть и минусы - мало возможностей для периферии (нет I2C, UART, SPI и пр) и отсутствие ethernet'a по меди((
                        • V
                          @electric69:
                          Получаем в итоге устройство все в одном - и сервер ioBroker, и HMI, и тут же устройство голосовых команд, и система гарантированного питания - встроенный АКБ…
                          Есть и минусы - мало возможностей для периферии (нет I2C, UART, SPI и пр) и отсутствие ethernet'a по меди(( `
                          юарт есть встроенный в любом планшете надо только найти куда распаяться, а если планшет с ОТГ то по юсб подлючаем через мини хаб всю необходимую переферию…
                          Заходил к старым знакомым в мастерскую, дисплейчик подкинуть на разбитый планшет, так они мне темку накинули, очень много тв боксов счас на андроиде с проциком RK3066 и гиг оперативы на борту, то есть готовый контроллер получается под умный дом, в заводском корпусе, не нужны никакие PI и тп извращения покупать...
                          Ps... пробовал установить, на очередной планшет, брокера, тупо отказался устанавливаться и все, плюнул на все и скопировал папку с установленным брокером со старого планшета и все завелось, так что можно устанавливать простым копированием как и опенхаб...
                          • Bluefox
                            Bluefox last edited by
                            > так что можно устанавливать простым копированием как и опенхаб…
                            да, но только если системы более менее похожи. Некоторые пакеты при установке компилируют бинарные библиотеки для скорости и если скопировать такой бинарник с PowerPCx64 на ARMx32 то не заведётся.
                              @Vlad_k:
                              юарт есть встроенный в любом планшете надо только найти куда распаяться `
                              Согласен, можно найти на плате нужный интерфейс.
                              @Vlad_k:
                              а если планшет с ОТГ то по юсб подлючаем через мини хаб всю необходимую переферию… `
                              ИМХО - USB не советую применять в автоматизации, даже в домашней…
                              @Vlad_k:
                              Заходил к старым знакомым в мастерскую, дисплейчик подкинуть на разбитый планшет, так они мне темку накинули, очень много тв боксов счас на андроиде с проциком RK3066 и гиг оперативы на борту, то есть готовый контроллер получается под умный дом, в заводском корпусе, не нужны никакие PI и тп извращения покупать… `
                              Да, у меня есть подобный HDMI-свисток, только линукс как ни старался, не смог нормально запустить(( Сейчас как плеер интен-контента на телевизоре в деревне использую.
                              9756
