    4. JavaScript
    5. Script fürTabelle der Batterie Zustände
      MiB @liv-in-sky last edited by
      @liv-in-sky sagte in Script fürTabelle der Batterie Zustände:
      @MiB dieser punkt ist noch offen - so was wie ein todo
      Danke, habs dann wohl doch überflogen 🙄
        A Former User @liv-in-sky last edited by
        @liv-in-sky
        nach der API APILINK wäre es wohl dann NORMAL
          A Former User @Meister Mopper last edited by A Former User
          @Meister-Mopper
          Ich habe nur im Widget selbst was gemacht. Ich exportiere es mal, vielleicht hilft es Dir.
          [{"tpl":"tplJquiDialog","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":false,"g_gestures":true,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"title":"Batterie","html":"<center><br>Batteriestände</br></center","html_dialog":"{0_userdata.0.BatterieTabelle}","dialog_width":"780","dialog_height":"480","modal":true,"closeOnClick":true},"style":{"left":"433px","top":"635px","width":"146px","height":"52px","background":"","color":"#ffffff","background-color":"#696969"},"widgetSet":"jqui"}]
          Und das ist der allg. Hintergrund für die View:
            liv-in-sky @Guest last edited by
            @HeinrichB hast du netatmo auf true gesetzt ?
            • O
              Oli @liv-in-sky last edited by
              @liv-in-sky
              könntest du hier vielleicht auch meine homee Gräte einbinden?
              Hier mal meine json:
              homee.0.OpenCloseSensor-10.json
              homee.0.RadiatorThermostat-1.json
              homee.0.RoomThermostat-19.json
              homee.0.SmokeDetector-14.json
              liv-in-sky 1 Reply Last reply Reply Quote 1
                liv-in-sky @Oli last edited by
                @Oli im ersten post - sind drin - bitte testen
                ? O 2 Replies Last reply Reply Quote 0
                  @liv-in-sky Soll ich auch schon oder noch warten? Kein Stress - nur zu meiner Info 🙂
                    @HeinrichB kannst du gerne auch machen
                      @liv-in-sky Hier mein Ergebnis 🙂
                        @HeinrichB bei dir sollte sich nix ändern - netatmo sind ja noch nicht da
                        also alles ok
                        habe vorher noch fehler in tabelle selbst gesehen, also du bild gepostet hast - waren fehlende zell-linien
                          @liv-in-sky ich wollte nur mein Testergebnis posten. Hast es ja auch oben nicht als vefügbar deklariert 🙂
                          • Negalein
                            Negalein Global Moderator last edited by Negalein
                            @liv-in-sky
                            bei mir sind zT die senkrechten Linien unterbrochen und rechts außen ist ein teil zu weit außen.
                            Kann man das beheben?
                            Und noch eine Frage.
                            Wenn ich im Objekte-Tab die namen in der Spalte Name ändere (dass zB .battery nicht dabei steht), hat das Auswirkung auf die Funktion vom Adapter?
                              liv-in-sky @Negalein last edited by
                              @Negalein das habe ich schon behoben - aber das file ist noch in der testphasese - ich warte auf den test von @Oli wegen homee - dann kann ich es freigeben und im ersten post einsetzen
                              • Negalein
                                Negalein Global Moderator @liv-in-sky last edited by
                                Super
                                PS: ich hab oben zeitgleich noch was editiert.
                                Kennst du dich da auch aus? 😉
                                  liv-in-sky @Negalein last edited by liv-in-sky
                                  @Negalein
                                  eigentlich nicht - aber ich denke, wenn du mal die datenpunkte löschen willst, wird der adapter wieder mit batterie schreiben -der adapter wird sich eher nach der id richten und schreibt den namen des datenpunktes nur einmal beim anlegen
                                  • Negalein
                                    eigentlich nicht
                                    dann werd ich das mal machen.
                                    Schaut in der Tabelle schöner aus, wenn das .battery nicht dabei steht.
                                      @Negalein ich kann das auch rausfischen - dann mußt du nix ändern
                                      kommt mit nächsten update
                                        @Negalein ist drin - filter .battery am ende - beim nächsten update !
                                        • Negalein
                                          Super
                                          • O
                                            @liv-in-sky
                                            super funktioniert
                                            Vielen Dank für den Aufwand, den du hier treibst.
                                            javascript monitoring template
                                            67
                                            1379
                                            485207
