    4. JavaScript
    5. Energieanzeige (kWh) über HTML Tabelle - vis
      A Former User @Guest last edited by
      @Yetiberg Frage: Ist das eine Pop-Up-View? Wenn ja, wie gemacht? 🙂
        liv-in-sky @Guest last edited by
        @HeinrichB ein beispiel für popup
        https://forum.iobroker.net/post/354713
        ? O 2 Replies Last reply Reply Quote 0
          A Former User last edited by
          Transparentes Widget für PopUp
          [{"tpl":"tplContainerDialog","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":true,"g_signals":false,"g_last_change":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"contains_view":"Kosten1","dialog_width":"930","dialog_height":"560","modal":false,"autoclose":"59","title":"Stromverbrauch","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"html":"","dialog_left":"","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"885px","top":"14px","width":"97px","height":"40px","background":"transparent","z-index":"3"},"widgetSet":"jqui"}]
            A Former User @liv-in-sky last edited by
            @liv-in-sky Danke Dir 🙂 wo ihr das immer alles herhabt 🙂
            • Meister Mopper
              Meister Mopper @Guest last edited by
              Funktioniert bei mir!
              • O
                Oli @liv-in-sky last edited by
                @liv-in-sky
                funktioniert bei mir
                Nur leider werden mir im Sourceanalytix Adapter keine Preise angezeigt, weis da zufällig jemand woran das liegen kann?
                liv-in-sky crunchip 2 Replies Last reply Reply Quote 0
                  liv-in-sky @Oli last edited by
                  @Oli bin da nicht fachmann - war froh das es gleich ging - costs und consumption angeklickt pro power dp
                  ansonsten
                  bei der instanz
                  tage und monate ausgewählt und unter berechnung meinen strompreis - mehr war nicht -
                  wichtig ist, dass sich dann der datenpunkt auch aktualisiert - sonst wird nix geschrieben
                  • Z
                    zahnheinrich @liv-in-sky last edited by
                    @liv-in-sky
                    Hätte hier noch die FRITZ 200 Mess-Schalt-Steckdosen:
                    fritzdect.0.json
                    Ulrich
                      crunchip Forum Testing Most Active @Oli last edited by
                      @Oli sagte in Energieanzeige (kWh) über HTML Tabelle - vis:
                      meinst im Script keine Preise, oder vom Adapter her selbst?
                      Deine Preisangaben im Adapter hast du gesetzt?
                        läuft bei mir auch, außer das bei meinen Gosund Steckdosen der Preis einstellig nach dem Komma angezeigt wird(Werte sind dementsprechend Auf/Abgerundet.
                        • O
                          Oli @crunchip last edited by
                          @crunchip
                          hat sich erledigt, Preise werden jetzt im Adapter angezeigt, ich habe aber leider teilweise Minuswerte beim Verbrauch im Adapter, weist du woran das liegen kann?
                            crunchip Forum Testing Most Active @Oli last edited by crunchip
                            @Oli du musst bei Please enter start values in kWh or m3 überall deinen gleichen Start-Wert eintragen, das füllt sich dann entsprechend mit den korrekten Werten, wenn das Ereignis(Tag,Woche,Monat...) erreicht ist
                              liv-in-sky @zahnheinrich last edited by
                              @zahnheinrich wärst du so nett und machst mir ein bild der datenpunkte mit sichtbaren werten rechts
                              • Z
                                @liv-in-sky
                                Bitteschön:
                                  sigi234 Forum Testing Most Active @liv-in-sky last edited by sigi234
                                  @liv-in-sky
                                  Habe keine Anzeige für die Homematic Steckdose vom Verbrauch:
                                  hm-rpc.1.NEQ1662322.2.ENERGY_COUNTER
                                    "from": "system.adapter.hm-rpc.1",
                                    "user": "system.user.admin",
                                    "ts": 1577530833726,
                                    "common": {
                                      "name": "HM-ES-PMSw1-Pl-DN-R1 NEQ1662322:2.ENERGY_COUNTER",
                                      "type": "number",
                                      "unit": "Wh",
                                      "def": 0,
                                      "min": 0,
                                      "max": 838860.699219,
                                      "read": true,
                                      "write": false,
                                      "custom": {
                                        "history.0": {
                                          "enabled": true,
                                          "changesOnly": true,
                                          "debounce": "1000",
                                          "maxLength": "960",
                                          "retention": "31536000",
                                          "changesRelogInterval": 5,
                                          "changesMinDelta": 0,
                                          "aliasId": ""
                                    "native": {
                                      "CONTROL": "POWERMETER.ENERGY_COUNTER",
                                      "ID": "ENERGY_COUNTER",
                                      "TYPE": "FLOAT",
                                      "UNIT": "Wh",
                                      "DEFAULT": 0,
                                      "FLAGS": 1,
                                      "MAX": 838860.699219,
                                      "MIN": 0,
                                      "OPERATIONS": 5,
                                      "TAB_ORDER": 0
                                    "acl": {
                                      "object": 1636,
                                      "owner": "system.user.admin",
                                      "state": 1636
                                    "_id": "hm-rpc.1.NEQ1662322.2.ENERGY_COUNTER",
                                    "type": "state"
                                  Aha, sehe gerade Wert ist in Wh
                                  vauvau07 liv-in-sky 2 Replies Last reply Reply Quote 0
                                  • vauvau07
                                    vauvau07 @sigi234 last edited by
                                    @sigi234
                                    habe das gleiche Problem
                                    • Lenny.CB
                                      Lenny.CB Most Active last edited by
                                      @liv-in-sky kannst dein Script noch etwas anpassen für Blitzwolf?
                                      if (getState(id).val=="BlitzWolf SHP6" || getState(id).val=="BlitzWolf SHP7" || getState(id).val=="BlitzWolf SHP8") {
                                      BlitzWolf SHP6:
                                      BlitzWolf SHP7:
                                      hier gibt es eine Besonderheit: beide Dosen lassen sich separat schalten (also wieder Switch 1/2) jedoch wird nur der Gesamtverbrauch gemessen.
                                      BlitzWolf SHP8:
                                        liv-in-sky @Lenny.CB last edited by
                                        bin gerade mit batterie script beschäfigt - mache später hier weiter
                                          liv-in-sky last edited by liv-in-sky
                                          habe den **virtual-powermeter adapter
                                          wer testen will im ersten post - eine ausnahme - geräte dürfen nicht in einem ordner sein !!!
                                          die folgenden Settings für den virtual powermeter adapter müssen genauso angelegt sein, wie in der anleitung - auch groß - und kleinschreibung
                                          nach dem anlegen erscheinen die folgenden datenpunkte und davon muss man einen auswählen für sourceanalytixs
                                          ? sigi234 Bulli Bultmann 4 Replies Last reply Reply Quote 1
                                            liv-in-sky @Lenny.CB last edited by liv-in-sky
                                            @Lenny-CB habe die zeile eingefügt - bitte testen und feedback - erster post
                                            die switches sind noch nicht integriert
                                            Lenny.CB 1 Reply Last reply Reply Quote 0
                                            javascript template
                                            37
                                            696
                                            130331
