    4. JavaScript
    5. Hilfe bei RSS-feed benötigt !
      sigi234 Forum Testing Most Active @salmi last edited by
      @salmi sagte in Hilfe bei RSS-feed benötigt !:
      @sigi234 Widget für die Anzeige der Einsätze, du hast ja Anpassungen gemacht zudem vom @SBorg weil bei dir wird es anderes angezeigt.
      [{"tpl":"tplVis-materialdesign-Table","data":{"oid":"javascript.0.Feuerwehr.RSS_Meldung","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","countCols":"6","tableLayout":"cardOutlined","showHeader":"true","headerTextSize":"medium","showColumn0":"true","colType0":"text","textAlign0":"left","showColumn1":"true","colType1":"text","textAlign1":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"showColumn2":"true","colType2":"text","textAlign2":"left","headerRowHeight":"10","rowHeight":"10","headerFontFamily":"RobotoCondensed-Light","colorBackground":"#d7d7d5","colorHeaderRowBackground":"#9b9797","colorHeaderRowText":"#ffffff","colorRowText":"#000000","dividers":"#000000","borderColor":"#000000","label0":"Meldung","fontFamily0":"RobotoCondensed-Light","colTextColor0":"#da0108","colTextSize0":"subtitle2","label1":"Bezirk/Ort","colTextSize1":"subtitle2","fontFamily1":"RobotoCondensed-Light","colTextColor1":"#000000","colNoWrap0":false,"columnWidth0":"","columnWidth1":"","colNoWrap1":false,"imageSize1":"","imageSize2":"32","showColumn3":"true","colType3":"text","textAlign3":"left","showColumn4":"true","colType4":"text","textAlign4":"left","showColumn5":"true","colType5":"text","textAlign5":"left","showColumn6":"true","colType6":"text","textAlign6":"left","showColumn7":"true","colType7":"text","textAlign7":"center","label4":"Anzahl Feuerwehren","label2":"Einsatz","label3":"Alarmstufe","label5":"Zeit","fontFamily5":"RobotoCondensed-Light","colTextSize6":"subtitle2","colTextSize5":"subtitle2","fontFamily6":"RobotoCondensed-Light","fontFamily2":"RobotoCondensed-Light","colTextColor2":"#000000","fontFamily3":"RobotoCondensed-Light","colTextSize3":"subtitle2","colTextColor3":"#000000","colTextSize4":"subtitle2","colTextColor4":"#000000","fontFamily4":"RobotoCondensed-Light","colTextColor5":"#000000","colTextColor6":"#000000","label6":"Eingesetzte Feuerwehren","colTextSize2":"subtitle2"},"style":{"left":"19px","top":"89px","width":"1244px","height":"51px","z-index":"3"},"widgetSet":"materialdesign"}]
        sigi234 Forum Testing Most Active @salmi last edited by sigi234
        @salmi
        Arbeite gerade an einer Handy Version:
          salmi @sigi234 last edited by
          @sigi234 Super 👍 toll ! Wäre cool wenn du mir die dann auch zuverfügung stellen kannst.
          Ich baue gerade den Script für die "Einsatzschaltung" meines Smarthomes.
          Hier wird dann zum beispiel das Licht eingeschaltet, mein Gartentor geöffnet und nach 5 min sollte dann wieder alles ausgeschaltet werden. Mal sehen wie das funktionieren wird.
          Natürlich nur wenn ich Zuhause bin 🙂
          LG stefan
            @SBorg gibt es eine Möglichkeit bei Filter das man 2 Feuerwehren filtern kann? Mit einer funktioniert es ! Also einen oder Filter Wert z.b FF Lambach oder FF Bad Wimsbach-Neydharting.
            Vielen Dank
            • SBorg
              SBorg Forum Testing Most Active @salmi last edited by
              @salmi "Ihr kleinen kaum gebe ich den kleinen Finger, zack, ist die Hand weg..." 😀
              Man könnte natürlich auch mehrere implementieren, dass wird aber aufwändig (da fehlt mir derzeit bisserl die Zeit dazu). Wenn dir aber zwei genügen könntest du das Skript doppeln, nicht wirklich schön, oder ich baue dir zwei Filter mit einer "ODER"-Verknüpfung ein. Das geht recht schnell. Der Nachteil liegt aber dabei am Konstrukt des Ganzen. Es wird immer nur die letzte Meldung des Feeds angezeigt: Wache A -- Meldung 1, Wache B -- Meldung 1
              Dann wirst du nur Wache B angezeigt bekommen 😞
              Ich mach mir darüber zwar so meine Gedanken (@sigi234 möchte das gerne haben), dass kann aber uU. noch etwas dauern...
              sigi234 SBorg 2 Replies Last reply Reply Quote 0
                sigi234 Forum Testing Most Active @SBorg last edited by sigi234
                @SBorg sagte in Hilfe bei RSS-feed benötigt !:
                Kein Problem, ein DP mit kein Alarm oder Alarm wäre noch Super.
                Kann man hier nur die Zahl anzeigen lassen?
                • SBorg
                  SBorg Forum Testing Most Active @SBorg last edited by
                  @sigi234 Ja, mach ich fertig...
                  @sigi234 sagte in Hilfe bei RSS-feed benötigt !:
                  Ist mir gerade beim schreiben eine Idee dazu eingefallen...
                  • SBorg
                    SBorg Forum Testing Most Active last edited by SBorg
                    Bitte schön:
                    • Zwei Feuerwehren mit "oder" (Anzeige nur der letzten Meldung des Feeds!)
                    • "Alarmstufe" + "Feuerwehren" entfernt
                    • Bei "Zeit" den "-" durch "Uhr" ersetzt (ein "bis" Uhrzeit gibt es IMO nicht. Ist der Einsatz beendet wird auch die Meldung gleich aus dem Feed gelöscht)
                    • neuer Datenpunkt für "neuen Alarm"
                    let   WACHE0   = /.*/ig;                        //RegEx
                    let   WACHE1   = /.*/ig;                        //RegEx
                    let   DP       = "javascript.0.Feuerwehr";      //Datenpunkt
                    const Zeitplan = "23 */1 * * * *";              //jede Minute bei 23 Sekunden
                    //Datenpunkt anlegen
                    createState(DP+'.RSS_Meldung', '', { name: "Feuerwehreinsatzmeldungen", type: "json",    role: "state" });
                    createState(DP+'.neuer_Alarm', '', { name: "neue Meldung",              type: "boolean", role: "state" });
                    //scheduler
                    schedule(Zeitplan, polldata);
                    polldata();  //einmalig direkt beim Start Daten holen
                    function polldata() {
                        var FeedParser = require('feedparser');
                        var request = require('request'); // for fetching the feed
                        var req = request('http://intranet.ooelfv.at/webext2/rss/rss_laufend.xml')
                        var feedparser = new FeedParser();
                        setState(DP+'.neuer_Alarm', false);  //DP leeren
                        req.on('error', function (error) {
                         // handle any request errors
                        req.on('response', function (res) {
                          var stream = this; // `this` is `req`, which is a stream
                          if (res.statusCode !== 200) { this.emit('error', new Error('Bad status code')); }
                          else { stream.pipe(feedparser); }
                        feedparser.on('error', function (error) {
                         // always handle errors
                        feedparser.on('readable', function () {
                         // This is where the action is!
                        var stream = this;    // `this` is `feedparser`, which is a stream
                        var meta = this.meta; // **NOTE** the "meta" is always available in the context of the feedparser instance
                        var item;
                        while (item = stream.read()) {
                          if (item.description.search(WACHE0) || item.description.search(WACHE1) != -1) {
                                let tmp = (item.description.split("<br>"));
                                let tmp1= (tmp[1].split(", "));
                                let tmp2= (tmp[2].split("  "));
                                tmp1[1] = tmp1[1].replace(/[a-z,A-Z,:, ]/ig, "");
                                tmp2[0] = tmp2[0].replace(/[a-z,A-Z,:, ]/ig, "");
                                tmp2[1] = tmp2[1].replace("-", "Uhr");
                                setState(DP+'.RSS_Meldung', JSON.stringify([{ 'Titel': item.title, 'Feuerwache': tmp[0], 'Einsatz': tmp1[0], 'Alarmstufe': tmp1[1], 'Feuerwehren': tmp2[0], 'Zeit': tmp2[1], 'Bezirk': tmp[3] }]));
                                console.log("Einsatzmeldung vorhanden...");
                                setState(DP+'.neuer_Alarm', true);
                    } //end polldata
                      @SBorg
                      SUPER 👍
                      Sehe gerade Anzahl der Feuerwehren sollte 2 sein.
                        @SBorg 👍 einfach toll und danke für die Hilfe
                        • SBorg
                          SBorg Forum Testing Most Active @sigi234 last edited by
                          Kommt wenn man was beim C&P vergisst...
                          Zeile #49 (beginnt mit tmp2[0])
                          Ich ändere aber gleich oben den Quelltext ab.
                          @salmi Wenn es die Zeit erlaubt, immer gerne 🙂
                            Geht. Danke.
                              @SBorg
                              ich habe jetzt versucht den Filter zu setzen leider aber ohne Erfolg.
                              Testen könnte man es mit dem 6 Stunden feed vom LFK
                              http://intranet.ooelfv.at/webext2/rss/rss_6stunden.xml
                              da bei beide Feuerwehren heute einen Einsatz gehabt haben.
                              Habe es wie folgt eingegeben:
                              let   WACHE0   = /FF Lambach*/ig;                        //RegEx
                              let   WACHE1   = /FF Bad Wimsbach-Neydharting*/ig;                        //RegEx
                              //scheduler
                                  var item;
                              } //end polldata
                              Beim 1. Script habt der Filter funktioniert.
                              Danke vorerst
                              • SBorg
                                @salmi Würde ich beim kopieren auch noch mitdenken könnte es sogar etwas werden... :
                                //scheduler
                                    var req = request('http://intranet.ooelfv.at/webext2/rss/rss_laufend.xml');
                                    var item;
                                      if (item.description.search(WACHE0) != -1 || item.description.search(WACHE1) != -1) {
                                            tmp2[1] = tmp2[1].replace("- ", "Uhr");
                                } //end polldata
                                • Bostil
                                  Bostil last edited by
                                  Bekommt man etwas Ähnliches auch auf den RSS-Feed der Tagesschau z. B. umgemünzt ?
                                  http://www.ard.de/home/ard/RSS_Feeds_der_ARD/89464/index.html
                                  • SBorg
                                    SBorg Forum Testing Most Active @Bostil last edited by
                                    @Bostil Ja, dass ist ja das schöne an den Feeds. Es geht "eigentlich" recht einfach, wenn dann nicht immer mehr daraus werden würde 😀
                                    siehe bspw. gleich hier, oder bei "Lebensmittelwarnung" ... 😉
                                      Hi, mir ist aufgefallen das der Einsatz nach beenden nicht aus dem DP entfernt wird.
                                      Lg stefan
                                      SBorg sigi234 2 Replies Last reply Reply Quote 0
                                      • SBorg
                                        @salmi Das hatte ich drin gelassen, damit man sich ggf. die letzte Meldung noch anschauen kann. Die Sichtbarkeit kann man dann über den neuen DP regeln. Wenn du dies nicht willst, hinter #22 einfach in eine neue Zeile einfügen:
                                        setState(DP+'.RSS_Meldung', '');     //DP leeren
                                          @salmi
                                          gelöscht
                                            @SBorg
                                            Kann ich die Info Meldungen deaktivieren, oder so einstellen das die nur einmal kommt? Kommt immer wieder.
                                            javascript.0	2020-01-24 11:42:23.067	info	(16144) script.js.Eigene_Datenpunkte.RSS.Feuerwehr1: Einsatzmeldung vorhanden...
                                            javascript.0	2020-01-24 11:41:23.070	info	(16144) script.js.Eigene_Datenpunkte.RSS.Feuerwehr1: Einsatzmeldung vorhanden...
                                            426
                                            66917
