    4. JavaScript
    5. Script fürTabelle der Batterie Zustände
      A Former User @liv-in-sky last edited by
      @liv-in-sky
      Das habe ich ergänzt:
      Im Log steht nix 🤔
      22.1.2020, 14:19:14.662	[info ]: javascript.0 (1916) Stop script script.js.Batterien_Tabelle
      22.1.2020, 14:19:16.404	[info ]: javascript.0 (1916) Start javascript script.js.Batterien_Tabelle
      22.1.2020, 14:19:16.434	[info ]: javascript.0 (1916) script.js.Batterien_Tabelle: BATTERIE Alarm     : 7
      22.1.2020, 14:19:16.435	[info ]: javascript.0 (1916) script.js.Batterien_Tabelle: registered 0 subscriptions and 1 schedule
      22.1.2020, 14:19:40.747	[info ]: javascript.0 (1916) Stop script script.js.Batterien_Tabelle
      22.1.2020, 14:19:40.807	[info ]: javascript.0 (1916) Start javascript script.js.Batterien_Tabelle
      22.1.2020, 14:19:40.833	[info ]: javascript.0 (1916) script.js.Batterien_Tabelle: BATTERIE Alarm     : 7
      22.1.2020, 14:19:40.834	[info ]: javascript.0 (1916) script.js.Batterien_Tabelle: registered 0 subscriptions and 1 schedule
      22.1.2020, 14:20:00.038	[info ]: javascript.0 (1916) script.js.Batterien_Tabelle: BATTERIE Alarm     : 7
        liv-in-sky @Guest last edited by
        @HeinrichB schreibe bitte
        log("bin in netatmo  und id :"+id);
        über
        if (!filterArray.includes(id)){
        kommt da was
          @liv-in-sky said in Script fürTabelle der Batterie Zustände:
          Nee leider nicht
          22.1.2020, 14:26:05.982	[info ]: javascript.0 (1916) Stop script script.js.Batterien_Tabelle
          22.1.2020, 14:26:09.787	[info ]: javascript.0 (1916) Start javascript script.js.Batterien_Tabelle
          22.1.2020, 14:26:09.812	[info ]: javascript.0 (1916) script.js.Batterien_Tabelle: BATTERIE Alarm     : 7
          22.1.2020, 14:26:09.813	[info ]: javascript.0 (1916) script.js.Batterien_Tabelle: registered 0 subscriptions and 1 schedule
          22.1.2020, 14:26:35.230	[info ]: javascript.0 (1916) Stop script script.js.Batterien_Tabelle
            @HeinrichB im selektor bitte die 3 sterne
              $('netatmo.*.*.*.BatteryStatus').each(function(id, i) {
              @liv-in-sky
              22.1.2020, 14:29:31.459	[info ]: javascript.0 (1916) Start javascript script.js.Batterien_Tabelle
              22.1.2020, 14:29:31.492	[info ]: javascript.0 (1916) script.js.Batterien_Tabelle: BATTERIE Alarm     : 7
              22.1.2020, 14:29:31.493	[info ]: javascript.0 (1916) script.js.Batterien_Tabelle: registered 0 subscriptions and 1 schedule
              22.1.2020, 14:30:00.034	[info ]: javascript.0 (1916) script.js.Batterien_Tabelle: BATTERIE Alarm     : 7
              22.1.2020, 14:30:15.480	[info ]: javascript.0 (1916) Stop script script.js.Batterien_Tabelle
                liv-in-sky @Bulli Bultmann last edited by liv-in-sky
                @Bulli-Bultmann den fehler kann ich auch nicht nachvollziehen - den object object wäre ja eher der inhalt eines datenpunktes, den ich nicht abfrage
                daher mal ein test:
                stoppe fritzdect instanz
                lösche alle datenpunkte der frtzdect instanz
                starte fritzdect instanz wieder
                kannst auch das skript während dessen stoppen
                Bulli Bultmann 2 Replies Last reply Reply Quote 1
                  @HeinrichB
                  lust auf teamviewer oder anydesk session ?
                    @liv-in-sky kannst dich gerne auf meinen rechner aufschalten und es dir ansehen. muss ich was installieren?
                    liv-in-sky ? 2 Replies Last reply Reply Quote 0
                      @HeinrichB wenn du teamviewer nicht hast, würde ich anydesk downloaden - da bekommst du eine exe datei, die du direkt aufrufen kannst - meine telefonnummer ist im chat
                      • Bulli Bultmann
                        Bulli Bultmann @liv-in-sky last edited by
                        @liv-in-sky 😊 👍
                        Läuft. Dankeschön.
                          A Former User @Guest last edited by
                          @liv-in-sky
                          Danke für den schnellen und unkomplizierten Support eben 🙂
                          @All
                          bei mir war das Problem, dass ich eine JavaScript-Version 4.1.x hatte; nach dem Update auf die 4.3.x ging es dann 🙂
                            @Bulli-Bultmann das ist schon mal positiv - jetzt noch zum doppelt erscheinen der homematc-ip sache
                            kannst du mir mal ein json von deinen datenpunkten als datei geben
                            doppelte devices habe ich eigentlich bis jetzt nur in homematic (ohne ip ) gehabt
                              liv-in-sky @vauvau07 last edited by
                              @vauvau07 kannst du bitte mal
                              log(arrDoppelt.toString())
                              vor (ung. zeile543)
                              $('hm-rpc.*.*.0.LOWBAT').each(function(id, i) {
                              einsetzen und nachsehen im log, ob dort ein array ausgegeben wird, von den werten , die doppelt sind
                              vauvau07 1 Reply Last reply Reply Quote 0
                              • vauvau07
                                vauvau07 @liv-in-sky last edited by
                                @liv-in-sky
                                javascript.2	2020-01-22 15:50:00.067	info	(16645) script.js.Test.Str:
                                javascript.2	2020-01-22 15:50:00.045	info	(16645) script.js.Test.Bat: hm-rpc.0.MEQ0476867.2.BATTERY_STATE,hm-rpc.0.MEQ0479694.2.BATTERY_STATE,hm-rpc.0.MEQ0794031.4.BATTERY_STATE,hm-rpc.0.MEQ0803173.4.BATTERY_STATE,hm-rpc.0.MEQ0804030.4.BATTER
                                javascript.2	2020-01-22 15:49:50.533	info	(16645) script.js.Test.Bat: registered 0 subscriptions and 1 schedule
                                javascript.2	2020-01-22 15:49:50.520	info	(16645) script.js.Test.Bat: hm-rpc.0.MEQ0476867.2.BATTERY_STATE,hm-rpc.0.MEQ0479694.2.BATTERY_STATE,hm-rpc.0.MEQ0794031.4.BATTERY_STATE,hm-rpc.0.MEQ0803173.4.BATTERY_STATE,hm-rpc.0.MEQ0804030.4.BATTE
                                javascript.2	2020-01-22 15:49:50.471	info	(16645) Start javascript script.js.Test.Bat
                                javascript.2	2020-01-22 15:49:50.378	info	(16645) Stop script script.js.Test.Bat
                                javascript.2	2020-01-22 15:49:00.069	info	(16645) script.js.Test.Str:
                                javascript.2	2020-01-22 15:48:00.006	info	(16645) script.js.Test.Str:
                                javascript.2	2020-01-22 15:47:00.076	info	(16645) script.js.Test.Str:
                                es sind nicht alle Geräte
                                  liv-in-sky @vauvau07 last edited by liv-in-sky
                                  @vauvau07 zeig mal ein gerät (nur den pfad), welches da drin stehen sollte, aber nicht da ist - wo kommt das her
                                  das array wird im block darüber gefüttert - wird es da mit VOLTAGE integriert, kommt es ins array
                                  bei mir sieht das array so aus
                                  hm-rpc.0.LEQ0080851.2.BATTERY_STATE,
                                  hm-rpc.0.LEQ0081020.2.BATTERY_STATE,
                                  hm-rpc.0.LEQ0417179.2.BATTERY_STATE,
                                  hm-rpc.0.LEQ0440620.2.BATTERY_STATE,
                                  hm-rpc.0.LTK0129844.2.BATTERY_STATE,
                                  hm-rpc.0.MEQ0180889.2.BATTERY_STATE,
                                  hm-rpc.0.MEQ0479049.2.BATTERY_STATE,
                                  hm-rpc.0.NEQ0122166.2.BATTERY_STATE
                                  diese werden dann im lowbat block nicht mehr angezeigt
                                  damit
                                   if (!filterArray.includes(id) && !arrDoppelt.includes(ida[0]+"."+ida[1]+"."+ida[2]+".*.BATTERY_STATE") ) {
                                  wird es dann gefiltert
                                    liv-in-sky last edited by liv-in-sky
                                    @liv-in-sky sagte in Script fürTabelle der Batterie Zustände:
                                    @vauvau07
                                    @vauvau07
                                    du kanns tmir auch gerne die datei des json export senden wo diese datenp. enthalten sind
                                    • vauvau07
                                      @liv-in-sky
                                      hm-rpc.0.PEQ1313474.json
                                      hm-rpc.0.OEQ1713445.json
                                      hm-rpc.0.OEQ1674852.json
                                      hm-rpc.0.OEQ0301166.json
                                      ein Ausschnitt, insgesamt 25 Stck
                                        @vauvau07 bitte testen - ich hoffe ich filtere jetzt nicht zuviel
                                        //@liv-in-sky Januar 2020
                                        //HIER WIRD PFAD UND FILENAME DEFINIERT
                                        const path = "/htmlakku.html";                   //FIlenamen definieren
                                        const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
                                        let   braucheEinFile=false;                          // bei true wird ein file geschrieben
                                        let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
                                        let dpVIS="controll-own.0.TABELLEN.AKKU"         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
                                        let dpAlarm="controll-own.0.TABELLEN.AkkuAlarm";  //WICHTIG datenpunkt erstellen vom typ "number" - bei 0 kein alarm und größer 0 die anzahl der schlechten batterien
                                        let dpAlarmMessage="controll-own.0.TABELLEN.AkkuMeessage";  //WICHTIG datenpunkt erstellen vom typ "string" Inhalt - alle devices mit lowbat-aalarm
                                        let wantAmessage=false;                                      // dieser message datenpunkt kann hier abgeschalten werden
                                        let htmlColorDeviceUeberschrift="#00BFFF"
                                        var battAlarm=30;                                     //alarm batterie wert
                                        var battAlarmWarning=55;                                     //warnungen batterie wert
                                        // ------------------------    hier einstellen, was man für adapter hat - die nicht gebraucht werden auf false setzen !!!
                                        var tradfri=true;
                                        var hue=true;
                                        var hueExt=true;
                                        var homematic=true;
                                        var homematicIp=true;
                                        var xiaomi=true;                                                // mihome.0
                                        var fritzDect=true;
                                        var netatmo=true;
                                        var homee=true;
                                        var tado=true;
                                        var iogo=true;                                                 // iogo - adapter - hat batterie abfrage
                                        var fullyBrowser=true;                                         // fullybrowser - adapter - hat batterie abfrage
                                        var handy1=false;                                              // sind einzelne datenpunkte,
                                        var handy2=false;
                                        //f          ür spezialisten bei devices mit über 3 volt batterien
                                        var bigBattAlarm=3.3; var bigBattWarn=3.6; //WICHTIG bei bigAlarm nicht unter 3.3 gehen !!!!!!!!
                                        var symbolOK="✅";
                                        var symbolKO="❌";     //z.b. auch "<font color=\"red\"><b>X</b>" für ein rotes kreuz
                                        var symbolWARN="⚠️";
                                        var filterArray=[]; //hier den ganzenpfad von ungewünschten LOW_BAT werten eingeben - diese werden dann gefiltert
        // BEISPIEL var filterArray=["hm-rpc.0.LEQ0242145.0.LOWBAT", "hm-rpc.0.LEQ0242152.0.LOWBAT","hm-rpc.1.OEQ0473764.0.LOWBAT"];
                                        let mySchedule=" */5 * * * * ";                       //jede minute
                                        //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 3
                                        var htmlFeld1='Device';      var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
                                        var htmlFeld2='Wert';        var Feld2lAlign="center";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
                                        var htmlFeld3='Status';         var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
                                        //------------------------------hier werden die styles für die tabelle definiert
                                        //ÜBERSCHRIFT ÜBER TABELLE
                                        let   htmlUberschrift=false;                           // mit Überschrift über der tabelle
                                        let   htmlSignature=true;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
                                        const htmlFeldUeber='Batterie Zustand Sensoren';              // Überschrift und Signature
                                        const htmlFarbUber="white";                         // Farbe der Überschrift
                                        const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
                                        const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
                                        //MEHRERE TABELLEN NEBENEINANDER
                                        let   mehrfachTabelle=4;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
                                        const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
                                        const htmlFarbTableColorUber="#BDBDBD";               // Überschrift in der tabelle - der einzelnen Spalten
                                        //GANZE TABELLE
                                        let abstandZelle="1";
                                        let weite="auto";                                     //Weite der Tabelle
                                        let zentriert=true;                                   //ganze tabelle zentriert
                                        const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
                                        const htmlSchriftart="Helvetica";
                                        const htmlSchriftgroesse="14px";
                                        //FELDER UND RAHMEN
                                        let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
                                        const htmlFarbFelderschrift="#BDBDBD";                  // SchriftFarbe der Felder
                                        const htmlFarbFelderschrift2="#D8D8D8";                 // SchriftFarbe der Felder für jede 2te Tabelle
                                        const htmlFarbTableColorGradient1="#424242";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
                                        const htmlFarbTableColorGradient2="#424242";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                                        const htmlFarbTableBorderColor="gray";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                                        let htmlRahmenLinien="cols";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                                        const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
                                        // AB HIER NICHTS  ÄNDERN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                                        let borderHelpBottum;
                                        let borderHelpRight;
                                        let htmlcenterHelp;
                                        let htmlcenterHelp2;
                                        if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
                                        if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
                                        if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
                                        if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
                                        zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
                                        zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
                                        const htmlZentriert='<center>'
                                        const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                                                         "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                                                         " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                                                        // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                                                         " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                                                         " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                                                         "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                                                         " </style></head><body> <div>";
                                        //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
                                        const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                                            "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
                                        const htmlTabUeber1="<tr style=\"color:"+htmlFarbTableColorUber+"; font-weight: bold\">";
                                        const htmlTabUeber3="</tr>";
                                        //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 3
                                         	var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td>";
                                        var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+"  align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld2+
                                                         "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td>";
                                        var htmlTabUeber="";
                                        var htmlOut="";
                                        var mix;
                                        var counter;
                                        var AkkuAlarm=[];
                                        var alarmMessage=[];
                                        let AkkuMessageLengthAlt=0;
                                        var arrDoppelt=[];
                                        //HIER SIND DIE  WERTE, DIE IN DER SCHLEIFE GEFILTERET WER%DEN - Jede spalte einen wert - jeder valx muss in dieser schleife gesetzt werden !!
                                        var val1; var val0; var val2;
                                        function writeHTML(){
                                         AkkuAlarm=[];
                                        htmlOut="";
                                        counter=-1;
                                        htmlTabUeber="";
                                        switch (mehrfachTabelle) {
                                         case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
                                         case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                                         case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber3; break;
                                         case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                                        if (!UeberschriftSpalten) {htmlTabUeber=""}
                                        //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
                                        //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2 !!!---------------------------------------------------------------------
                                        var myColl=[];
                                        var val1help;
                                          if (fritzDect){
                                                     // UNTERTEILUNG - ÜBERSCHRIFT IN TABELLE
                                                       tabelleAusbessern();
                                                       counter=0;
                                                         val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>FRITZDECT THERMOSTATE</b>"; val1=""; val2="";
                                                       tabelleBind();
                                                       counter=-1;
                                         $('fritzdect.*.*.battery').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                                var ida = id.split('.');
                                                  counter++;
                                                //  val0=ida[2]+"."+ida[3];
                                                  val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]).common.name ;
                                                  val1help=parseFloat((getState(id).val));
                                                  if (val1help<=battAlarm) {val1=(" <font color=\"red\"> ")+val1help.toString()+" %"} else{val1=(" <font color=\"green\"> ")+val1help.toString()+" %"}
                                                  if (val1help>battAlarm && val1help<=battAlarmWarning) {val1=(" <font color=\"yellow\"> ")+val1help.toString()+" %"}
                                                  if (getState(id).val==null) {val2="never used"}; //log(id)};
                                                  if (val1help<=battAlarm) {val2=symbolKO} else{val2=symbolOK}
                                                  if (val1help>battAlarm && val1help<=battAlarmWarning) val2=symbolWARN;
                                                  if (val1help<=battAlarm) AkkuAlarm.push(1);
                                                  if (val1help<=battAlarm)  alarmMessage.push(val0);
                                             tabelleBind(); //HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
                                           }  }); //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
                                        } //ende fritzdect
                                           if (homee){
                                              counter=0;
                                              val0=""; val1=""; val2="";
                                              counter=0;
                                              val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>HOMEE DEVICES</b>"; val1=""; val2="";
                                              counter=-1
                                         $('homee.0.*.BatteryLevel*').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                                  counter++;
                                                 //    var val2_1;
                                                //   if (parseInt((new Date().getTime())) - val2_2help < 120000) {val2_1=true} else {val2_1=false;}
                                                //  var val2_2help=Date.parse(getState(id.replace("BatteryStatus","LastUpdate")).val);
                                                //  if (val2_1) {val2=symbolOK} else{val2=symbolKO}
                                        } //ende fritzdect
                                           if (netatmo){
                                              counter=0;
                                              counter=0;
                                              val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>NETATMO DEVICES</b>"; val1=""; val2="";
                                              counter=-1
                                         $('netatmo.*.*.*.BatteryStatus').each(function(id, i) {           // netatmo.0.Hinxxxer.Außenmodul-Carport.BatteryStatus
                                        //  if (!filterArray.includes(id)){
                                                  counter++;
                                                  val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]+"."+ida[3]).common.name ;
                                                  //   var val2_1;
                                           /* }*/   }); //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
                                        } //ende fritzdect
                                         if (xiaomi){
                                              counter=0;
                                              counter=0;
                                              val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>XIAOMI DEVICES</b>"; val1=""; val2="";
                                              counter=-1
                                        $('mihome.*.devices.*.percent').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                              // log (id)
                                                  counter++;                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                                                //  val0=ida[3];
                                                 val0=val0.replace(/.battery$/,"");
                                                // log(val0+"   "+id);
                                         } //ende xiaomi
                                        if (hue){
                                              counter=0;
                                              counter=0;
                                              val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>HUE DEVICES</b>"; val1=""; val2="";
                                              counter=-1
                                        $('hue.*.*.battery').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                                 counter++;
                                                  val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]+"."+ida[3]).common.name ;   val0=val0.replace(/.battery$/,""); val0=val0.replace("Philips_hue.",""); val0=val0.replace(/_/g," ");                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                                         }  //ende hue
                                        if (hueExt){
                                              counter=0;
                                              counter=0;
                                              val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>HUE EXTENDED</b>"; val1=""; val2="";
                                              counter=-1
                                        $('hue-extended.*.*.*.config.battery').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                                   val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]+"."+ida[3]).common.name ;   val0=val0.replace("Philips_hue.",""); val0=val0.replace(/_/g," ");                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                                          } //ende hue-extended
                                        if (tradfri){
                                              counter=0;
                                              counter=0;
                                              val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>IKEA TRADFRI</b>"; val1=""; val2="";
                                              counter=-1
                                        $('tradfri.*.*.batteryPercentage').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                                val1help=getState(id).val;
                                         if (tado){
                                            counter=0;
                                            val0=val0=""; val1=""; val2="";
                                            counter=0;
                                            val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>TADO DEVICES</b>"; val1=""; val2="";
                                            counter=-1
                                        $('tado.*.*.*.*.*.*.info.batteryState').each(function(id, i) {           // tado.0.337268.Rooms.11.devices.VA3078030592.info.batteryState
                                            //  log(id)
                                               val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]+"."+ida[3]+"."+ida[4]).common.name                     //getObject(id).common.name ; //ida[2]+"."+ida[3];
        //tado.0.337268.Rooms.11
                                               //log(val0+"   "+id);
                                              if (val1help=="LOW") {val1=(" <font color=\"red\"> ")+"low bat"} else{val1=(" <font color=\"green\"> ")+"full bat"}
                                              //if (val1help<=battAlarm) {val2="<font color=\"red\"><b>X</b>"} else{val2=symbolOK}
                                              if (val1help=="LOW") {val2="<font color=\"red\">"+symbolKO} else{val2=symbolOK}
                                              //if (val1help) {val2=<font color=\"red\"><b>X</b>} else{val2="✔"}
                                              if (val1help=="LOW") AkkuAlarm.push(1);
                                              if (val1help=="LOW")  alarmMessage.push(val0);
                                             } // ende filterArr
                                          }  //ende tado
                                        if (homematic){
                                            counter=0;
                                            counter=0;
                                            val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>HOMEMATIC</b>"; val1=""; val2="";
                                            counter=-1
                                            arrDoppelt=[];
                                        $('hm-rpc.*.*.*.BATTERY_STATE').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                            var arrFilt=[];
                                                $(ida[0]+"."+ida[1]+"."+ida[2]+"."+ida[3]+".*").each(function(id, i) {   // kontrolliere ob OPERATING_VOLTAGE vorhanden
                                                    var idc = id.split('.');
                                                 arrFilt.push(idc[4])
                                              arrDoppelt.push(ida[0]+"."+ida[1]+"."+ida[2]);
                                           if (arrFilt.includes("BATTERY_STATE")) {
                                                       val0=getObject(id).common.name ;
                                                       var ida = val0.split('.');
                                                       val0=ida[0].replace(/:.+/g,"");
                                                       var  val1helper=getState(id.replace("LOW_BAT","BATTERY_STATUS")).val;
                                                       //bigBatterien
                                                       //log (val1helper.toFixed(1))
                                                       if (val1helper>3.2){
                                                              if (val1helper<=bigBattAlarm) {val2=symbolKO} else if (val1helper<=bigBattWarn && val1helper>bigBattAlarm)
        {val2=symbolWARN} else{val2=symbolOK};
                                                              if (val1helper<=bigBattAlarm) {val1=(" <font color=\"red\"> ")+val1helper.toFixed(1)+" V"} else if (val1helper<=bigBattWarn && val1helper>bigBattAlarm)
        {val1=(" <font color=\"yellow\"> ")+val1helper.toFixed(1)+" V"} else{val1=(" <font color=\"green\"> ")+(val1helper.toFixed(1))+" V"};
                                                              if (val1helper<bigBattAlarm) AkkuAlarm.push(1);
                                                              if (val1helper<=bigBattAlarm)  alarmMessage.push(val0);
                                                       else {
                                                             if (val1helper<2.2) {val2=symbolKO} else if (val1helper<=2.5 && val1helper>=2.2)
                                                             if (val1helper<2.2) {val1=(" <font color=\"red\"> ")+val1helper.toFixed(1)+" V"} else if (val1helper<=2.5 && val1helper>=2.2)
        {val1=(" <font color=\"yellow\"> ")+val1helper.toFixed(1)+" V"} else{val1=(" <font color=\"green\"> ")+val1helper.toFixed(1)+" V"};
                                                             if (val1helper<2.2) AkkuAlarm.push(1);
                                                             if (val1helper<2.2)  alarmMessage.push(val0);}
                                             } else {
                                                      if (val1help) {val1=(" <font color=\"red\"> ")+"low bat"} else{val1=(" <font color=\"green\"> ")+"full bat"}
                                                      if (val1help) {val2=symbolKO} else{val2=symbolOK}
                                                      if (val1help) AkkuAlarm.push(1);
                                                      if (val1help)  alarmMessage.push(val0);
                                        $('hm-rpc.*.*.0.LOWBAT').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                          //  log(id)
                                            //log(arrDoppelt.toString())
                                         //    if (!filterArray.includes(id) && !arrDoppelt.includes(ida[0]+"."+ida[1]+"."+ida[2]+".*.BATTERY_STATE") ) {
                                                     if (!filterArray.includes(id) && !arrDoppelt.includes(ida[0]+"."+ida[1]+"."+ida[2]) ) {
                                            //  log(id)
                                               val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]).common.name                     //getObject(id).common.name ; //ida[2]+"."+ida[3];
                                               //log(val0+"   "+id);
                                              if (val1help) {val2="<font color=\"red\">"+symbolKO} else{val2=symbolOK}
                                             } // log(id)// ende filterArr
                                          } //ende hm
                                        if (homematicIp ){
                                               counter=0;
                                               counter=0;
                                               val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>HOMEMATIC IP</b>"; val1=""; val2="";
                                               counter=-1
                                        $('hm-rpc.*.*.0.LOW_BAT').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                              var arrFilt=[];
                                              // log(arrFilt.toString());
                                             if (arrFilt.includes("OPERATING_VOLTAGE")) {
                                                       //  val0=getObject(id).common.name ;
                                                         var  val1helper=getState(id.replace("LOW_BAT","OPERATING_VOLTAGE")).val;
                                                         //bigBatterien
                                                         else {
                                                               if (val1helper<2.2) {AkkuAlarm.push(1);}
                                               } else {
                                         }  //ende hm-ip
                                         if (fullyBrowser){
                                              counter=0;
                                              counter=0;
                                              val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>FULLYBROWSER</b>"; val1=""; val2="";
                                              counter=-1
                                        $('fullybrowser.*.*.Info.batteryLevel').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                                  val0=getState(id.replace("batteryLevel","deviceName")).val;
                                         } //ende fullybrowser
                                         if (iogo){
                                              counter=0;
                                              counter=0;
                                              val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>HANDY über IOGO</b>"; val1=""; val2="";
                                              counter=-1
                                        $('iogo.*.*.battery.level').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                               //   val0=ida[3];
                                         } //ende iogo
                                          if (handy1){
                                                  counter=0;
                                                  counter=0;
                                                  val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><b>HANDYs</b>"; val1=""; val2="";
                                                  counter=-1
                                               $('controll-own.0.HANDY.*batt*').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                                val0=ida[3];
                                          } //ende handy1
                                          if (handy2){
                                                   $('controll-own.0.HANDY.*Batt*').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                                val0=ida[3];
                                                if (val1help>battAlarm && val1help<=battAlarmWarning) {val1=(" <font color=\"yellow\"> ")+val1help.toString()}
                                          } //ende handy2
                                        //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                                            tabelleFinish(); // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
                                            if (AkkuAlarm.length >=1 ) {setState(dpAlarm,AkkuAlarm.length)} else {setState(dpAlarm,AkkuAlarm.length)}
                                           // log("BATTERIE Alarm     : "+AkkuAlarm.length.toString());
                                           if (AkkuMessageLengthAlt!=AkkuAlarm.length && wantAmessage) {setState(dpAlarmMessage,alarmMessage.toString()); AkkuMessageLengthAlt=AkkuAlarm.length}
                                           alarmMessage=[];
                                        } // function ende
                                        //MAIN:
                                        schedule(mySchedule,  function () {
                                        writeHTML();
                                        if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                                        writeHTML();
                                        if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}                                 //     <tdalign
                                        function tabelleBind(){
                                               case 1:                    htmlOut=htmlOut+"<tr><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;
                                               case 2:  if(counter%2==0)  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
        else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;
                                               case 3: if(counter%3==0 )  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
        else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>";}
        } break;
                                               case 4: if(counter%4==0)  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
        else {if(counter%2==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
        else    {if(counter%2==1 && counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";}
        else    {htmlOut = htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}}
        } break; } //switch ende
                                        function tabelleAusbessern() {
                                               case 1:    break;
                                               case 2:    mix=Math.abs(((counter+1)%2)-mehrfachTabelle);
                                                          if(mix==1)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                                          break;
                                               case 3:    mix =Math.abs(((counter+1)%3)-mehrfachTabelle);
                                                          if(mix==2)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                                          break;
                                               case 4:    mix=Math.abs(((counter+1)%4)-mehrfachTabelle);
                                                          if(mix==3)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                                          break; }
                                        function tabelleFinish() {
                                               case 1:    break;
                                                          break;
                                                          break;
                                                          break; }
                                               var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                                             var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>";
                                              if (!htmlSignature) htmlUnter="";
                                                //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                                                 var htmlOutVIS="";
                                               //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                                                  if (htmlUberschrift)
                                                      { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter ;
                                                    } else {
                                                     zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter;
                                        // log("bin raus aus tabelleBind");
                                                 if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
                                                 //console.log dpVIS;
                                        var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                                        var htmlEnd="</table>"+htmlUnter+"</div></body>";
                                        //mit oder ohne überschrift - zentriert oder links
                                        htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
                                        //log(htmlOut);
                                        • vauvau07
                                          @liv-in-sky
                                          ich habe nochmal nachgesehen alle Geräte im Log
                                            @vauvau07 lag auch eher am filter - im 2ten block
                                            javascript monitoring template
                                            67
                                            1379
                                            486520
