    4. Adapter: Geofency
    Adapter: Geofency
      pix last edited by
      Hallo Sven:
      zu 2 und 3) damit:
      Metro Tile ValueList Widget
      [{"tpl":"tplMetroTileList8","data":{"oid":"geofency.0.pix.Zu Hause.entry","visibility-cond":"==","visibility-val":1,"label0":"abwesend","label1":"zu Hause","label2":"Value list","label3":"Value list","label4":"Value list","label5":"Value list","label6":"Value list","label7":"Value list","bg_class0":"bg-transparent","bg_class1":"bg-transparent","bg_class2":"bg-indigo","bg_class3":"bg-indigo","bg_class4":"bg-indigo","bg_class5":"bg-indigo","bg_class6":"bg-indigo","bg_class7":"bg-indigo","icon_class0":"icon-custom","icon_class1":"icon-custom","icon_class2":"icon-pencil","icon_class3":"icon-pencil","icon_class4":"icon-pencil","icon_class5":"icon-pencil","icon_class6":"icon-pencil","icon_class7":"icon-pencil","icon_badge0":"icon-custom","icon_badge1":"icon-custom","icon_badge2":"icon-pencil","icon_badge3":"icon-pencil","icon_badge4":"icon-pencil","icon_badge5":"icon-pencil","icon_badge6":"icon-pencil","icon_badge7":"icon-pencil","badge_bg_class0":"","badge_bg_class1":"","badge_bg_class2":"bg-cyan","badge_bg_class3":"bg-cyan","badge_bg_class4":"bg-cyan","badge_bg_class5":"bg-cyan","badge_bg_class6":"bg-cyan","badge_bg_class7":"bg-cyan","brand_bg_class0":"bg-darkOrange","brand_bg_class1":"bg-olive","brand_bg_class2":"ribbed-steel","brand_bg_class3":"ribbed-steel","brand_bg_class4":"ribbed-steel","brand_bg_class5":"ribbed-steel","brand_bg_class6":"ribbed-steel","brand_bg_class7":"ribbed-steel","badge_top":"0","badge_left":"0","name":"Geoposition J","label_prepend":"","comment":"Daten aus Handyortung","icon0":"/icons-mfd-png/status_man.png","icon1":"/icons-mfd-png/status_man.png","icon_width":"79","icon_height":"79","icon_top":"22","icon_left":"32"},"style":{"left":"588px","top":"434px","z-index":"25","width":"137px","height":"137px"},"widgetSet":"metro"}]
      Jetzt zu meinem Problem:
      Ich nutze ioBroker rauf Mac OS X. Leider ist der Mac, nachdem Geofency den Status geändert hat, nicht mehr erreichbar. Er läuft noch, aber weder Bildschirmfreigabe noch Zugriffe auf die Webserver funktionieren noch (also kein VIS, etc..). Ich habe es durch Probieren definitiv auf den Adapter eingrenzen können.
      <size size="50">Kann ich den Port (7999) ändern, den der Adapter für seinen Webserver nutzt? Habe das Gefühl, der ist schon belegt.</size>
      EDIT: Peinlich, peinlich. GIbt es ja in den Einstellungen :oops: :oops: :oops:
      Pix
        RobS last edited by
        Hallo zusammen und Danke Dschaedl für den Adapter,
        leider bin ich nicht in der Lage ihn zu installieren. Nach der Eingabe von "npm install iobroker.geofency" im Ordner "/node modules" ist alles wunderbar ohne Mucken durchgelaufen. Es wird auch das Verzeichnis iobroker.geofency angelegt nur leider findet sich der Adapter nun nirgendwo wieder. Weder im Admin-GUI noch in der Konsole unter "list adapters"…
        Habe ich noch irgendetwas nicht bedacht oder wo könnte der Fehler bei mir liegen?
        Vielen Dank und Grüße,
        Rob
        • V
          versteckt last edited by
          Nicht im Ordner node_modules installieren, sondern eine Ebene höher.
          npm install legt automatisch seine Software in den node_modules Ordner
          Gesendet von meinem iPhone mit Tapatalk
            RobS last edited by
            Hey, Danke für die schnelle Anwort versteckt.
            So hatte ich es eigentlich schon als allererstes gemacht. Habe jetzt nochmal das Verzeichnis gelöscht und so installiert, wie von dir beschrieben und siehe da, der Adapter taucht auf… :shock:
            Vielen Dank!
            Rob
            305_heizungsscript_220_b03_temp.txt
            • Bluefox
              Bluefox last edited by
              Kann jemand ausprobieren, ob die neue Änderungen funktionieren?
              cd /opt/iobroker
              npm install https://github.com/ioBroker/ioBroker.geofency/tarball/master
              Ich habe kein iPhone.
                Sven2013 last edited by
                Hallo Bluefox,
                was hast du denn geändert?
                Also auf was muss ich achten?
                Gruß Sven
                • Bluefox
                  @Sven2013:
                  Hallo Bluefox,
                  Gruß Sven
                  Gesendet von iPhone mit Tapatalk `
                  Ich habe ein Pull-Request gemerged. Was das genau macht weiß ich nicht:
                  https://github.com/ioBroker/ioBroker.ge … 349de2871f
                  Vermutlich werden neue States erzeugt: "lastLeave", "lastEnter"
                    Hallo Bluefox,
                    ich teste das nachher wenn ich zu Hause bin.
                    @all
                    kann mir nochmal einer sagen welche URL ihr angegeben habt bei Geofancy? Denn der Status kann nicht gesetzt werden sagt geofancy.
                    Und was ich auch versuche, es ändert sich leider nichts 😞
                    Gruß Sven
                      RobS last edited by
                      Hi Sven,
                      du brauchst meines Wissens eine feste IP-Adresse, eine dynd.dns oder, wenn du eine Fritzbox hast, eine myfritz.net-Adresse, die du als Domain einträgst und dann eine Portweiterleitung für den Port, den du in der URL angibst im Router. Bei mir funktioniert es wunderbar mit der Fritzbox.
                      Gruß, Rob
                      Edit: Gerade erst deine vorherige Frage gelesen:
                      @Sven2013:
                      Hallo, ich nochmal
                      ich habe heute die geofancy Meldung bekommen, das der Status abwesend nicht gesetzt werden kann.
                      Ist ja auch logisch, der Url nach habe ich ja auch die ip des raspi/Port/ablageort eingegeben. So ist diese von außen natürlich nicht erreichbar.
                      Kann ich nun die "feste ip"/Port/ablageort nehmen? Denn eigentlich fehlt ja die Zuordnung zum raspi dann oder? `
                      Die Zuordnung zum Raspi erfolgt dann über die Portweiterleitung
                        Dschaedl last edited by
                        @Bluefox:
                        cd /opt/iobroker
                        funktioniert bestens bei mir. :mrgreen:
                        Daniel
                          freeki last edited by
                          Hallo.
                          Geofency läuft bei mir soweit.
                          Allerdings habe ich ein Phänomen entdeckt, welches mir einige Probleme bereit.
                          Ich kann nicht sagen, ob es ab geofency Adapter liegt, oder an etwas anderem.
                          Wenn ich per Web Hook einen neuen Status übermittele, dann ich diesen aktuell unter "Ereignisse" und im Log.
                          <size size="85">geofency-0 2016-01-22 13:04:22 info adapter geofency received webhook from device marc with values: name: Akazienweg 4, entry: 1</size>
                          Wo ich ihn allerdings NICHT sehe, ist unter Objekte!
                          Dort aktualisiert sich der Status nicht!
                          geofency.0.marc.Akazienweg 4.entry ändert sich nicht!
                          Wie gesagt… keine Ahnung, ob das an geofency, oder an was anderem liegt.
                          Aktuell ist es z.B. auch so, dass ein createState im JS keinen solchen im JS Modul erzeugt...
                          alles sehr seltsam.
                            Vielen Dank, bei mir funktioniert es nun. Ich hatte eine falsche Portweiterleitung eingerichtet.
                            Darüber hinaus hatte ich den Namen meines Ortes von Straßenname in zu Hause geändert. Dadurch stimmte die Variable leider nicht mehr. Und die neue Variable war erst nicht zu finden.
                            Aber nun geht's. Vielen Dank nochmal.
                            Nun bleibt nur noch die Frage ob ich mit einem Widget 2 Variablen abfragen kann?
                            Zu Hause grün
                            Büro gelb
                            Nicht zu Hause und nicht im Büro rot
                            Und kann ich die Variable irgendwie auch in der Ccu anzeigen lassen, um sie da für Programme zu nutzen?
                            Gruß Sven
                            • Bluefox
                              Es gibt neue Version von Geofency von soaf.
                              Weil ich es nicht testen kann, konnte jemand das ausprobieren und Bescheid sagen?
                              cd /opt/iobroker
                              Falls dann alles OK ist, dann publische ich das auf npm.
                              Danke,
                              Bluefox
                              • Mr. Burns
                                Mr. Burns last edited by
                                ist es möglich eine globale Variable im Adapter anzulegen, welche die letze Aktion wiedergibt?
                                z.B. "xy hat die Arbeitsstelle betreten" oder "xy ist zu Zuhause angekommen"
                                Oder hat einer von euch ein fertiges Script mit welchem ihr das gelöst habt?
                                Bin ganz frisch und tue mich noch etwas schwer mit dem Scripten.
                                • ruhr70
                                  ruhr70 last edited by
                                  Klasse, dass es Geofency nun als Adapter gibt 😉 Top!
                                  Folgende Punkte sind mir aufgefallen:
                                  Adapter Version 0.1.1 (neuste Version)
                                  1.) Kategorie: Wartung
                                  Passt nicht. Ich wüsste aber auch nicht die richtige Kategorie
                                  2.) atHome funktioniert bei mir nicht
                                  Ich habe als Ortsnahme für Zuhause Wohnung eingetragen.
                                  Mein Device ist in der Webholk-URL mit 0 bezeichnet.
                                  Der Datenpunkt 0.Wohnung.entry ändert sich auch korrekt.
                                  Die Datenpunkte atHome und atHomeCount bleiben leer.
                                  • Mr. Burns
                                    Wofür könnte man das brauchen, wenn die übergeordnete Variable at Home sich auch ändert?
                                    Mir sind die zwei "globalen" Variablen auch aufgefallen und das sie sich nicht ändern, hab das aber auf meine fehlprogrammierung des Adapters geschoben.
                                    Ich hatte gehofft, dass es sich um einen String handelt, welcher den aktuellen Standort respetive den letzten Standort im Klartext wiedergibt. Der count könnte so schön die verstrichene Zeit in min. Wiedergeben…das wäre doch was :roll:
                                    • ruhr70
                                      Hi Mr. Burns,
                                      ich verstehe das so:
                                      atHome
                                      hier werden die Personen eingetragen, die derzeit am definierten Ort "zuhause" sind.
                                      Die Namen der Personen sind dann die, die in der URL in geofency eingetragen sind.
                                      z.B: "Gabi, Horst,"
                                      atHomeCount
                                      Die Anzahl der Personen, die gerade zuhause sind.
                                      Im Beispiel oben: 2
                                      Kann man auch selbst per Script lösen. Mit den beiden Datenpunkten ist diese Info für eine Anwesenheitserkennung über Geofency direkt als State verfügbar, ohne dass man ein Script verwenden muss.
                                      Was Du möchtest kannst Du auch in Javascript lösen.
                                      Du machst je Person ein on( mit RegEx auf den Ort) und erhält damit immer den jeweiligen aktuellen Ort (oder verlassenen Ort) der entsprechenden Person.
                                      Meine Wünsche an den Adapter:
                                      • Leerzeichen in Ortsnamen werden in _ gewandelt. ein Punkt bleibt ein Punkt, z.B. in Dr. xyz. Damit habe ich eine Ebene mehr im Datensatz. Ggf. Konfigurierbar, ob Punkte auch im _ umgewandelt werden sollen.
                                      • die Info ob iBeacon oder Ort kann ich aus dem Device Object mit getObject extrahieren. schön wäre ggf. ein Datenpunkt mit der Info, bzw. konfigurierbar, dass man iBeacon Infos ausblenden kann. Wenn mein Auto in der Nähe meines Büros parkt, bin ich z.B. über iBeacon im Auto und gleichzeitig im Büro. Bekommt man aber auch per Javascript hin.
                                        soef last edited by
                                        das Ersetzen eines Punktes durch einen Unterstrich habe ich implementiert und dafür einen Pullrequest gestellt.
                                        Nicht ganz verstanden habe ich deinen Wunsch nach der Behandlung eine Beacons. Wenn der Beacon einen
                                        eigenen Ortsnamen hat, kannst Du ihn doch von den Geo-Orten unterscheiden. Eine ggf. übergebene Beacon-ID
                                        als Datenpunkt anzulegen ist aber kein Problem. Aber wo ist der tiefere Sinn, wenn durch den "Ortsnamen" schon
                                        bekannt ist, dass es sich um einen Beacon handelt.
                                        Viele Grüße.
                                        • ruhr70
                                          Danke soef 🙂
                                          ich glaube die Unterscheidung mit den iBeacons braucht man wirklich nicht 🙂
                                            Ein toller Adapter…
                                            vielen Dank dafür.
                                            Hat schon jemand hinbekommen, das sich die Übergeordnete Variable ändert?
                                            Bei mir bekomme ich das leider nicht hin.
                                            Wenn ja könntet Ihr mal sagen wie Ihr das eingerichtet habt?
                                            Gruß Sven
                                            205
                                            51963
