    4. Test Adapter Material Design Widgets v0.2.x
      PatrickFro @Oli last edited by
      @Oli Vielen Dank. Was sind das für Gauge-Widgets? Ich finde die nirgends und genau diese passen sehr gut.
      • O
        Oli @PatrickFro last edited by
        @PatrickFro
        bitte folgenden Adapter installieren:
        canvas-gauges style Widgets
          @Oli Kannst du das canvas-Gauge-Widget auch noch exportieren? Nachdem ich es gestern schon installiert habe und keine Bilder angezeigt wurden, funktioniert es jetzt, allerdings kann ich dein genutztes leider nicht finden. Vielleicht klappt es ja als exportierte Version 😉
          • O
            @PatrickFro
            [{"tpl":"tplCGradialGauge","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","factor":"1","valueOffset":"0","hCount":"3","minorTicks":"4","animation":"true","needle":"true","needleShadow":"true","needleType":"select","borders":"true","borderOuterWidth":"2","borderMiddleWidth":"2","borderInnerWidth":"2","borderShadowWidth":"2","valueBox":"false","ticksAngle":"270","startAngle":"45","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"javascript.0.Status.Speed-Test.download","units":"Mbit/s","title":"Download","minValue":"0","maxValue":"55","highlightsFrom1":"0","highlightsTo1":"28","highlightsFrom2":"28","highlightsTo2":"38","highlightsColor1":"#B71C1C","highlightsColor2":"yellow","highlightsFrom3":"38","highlightsTo3":"55","highlightsColor3":"#558B2F","valueBoxStroke":"0","valueTextShadow":false,"colorNeedleCircleInner":"#8f8f8f","colorNeedleCircleInnerEnd":"","colorNeedleCircleOuterEnd":"#8f8f8f","colorNeedleCircleOuter":"","name":"Anzeige","colorPlate":"#27272727","colorBorderOuter":"#27272727","colorBorderOuterEnd":"#27272727","colorBorderMiddle":"#27272727","colorBorderMiddleEnd":"#27272727","colorBorderInner":"","colorBorderInnerEnd":"","colorNumbers":"#8f8f8f","colorNeedle":"red","colorNeedleEnd":"red","colorNeedleShadowUp":"black","colorNeedleShadowDown":"black","colorBorderShadow":""},"style":{"left":"20px","top":"41px","width":"120px","height":"120px","background":"","border-color":"","border-width":"","z-index":12,"box-shadow":"2px 2px 3px rgba(20, 20, 20, 50)","border-radius":"10px","border-style":""},"widgetSet":"canvas-gauges"}]
              @Oli Nun klappt es, vielen Dank!
              • O
                @PatrickFro
                gerne
                  bommel_030 last edited by
                  @Scrounger
                  Zumindest für den ersten Teil kann ich dir in gewissem geistigen Abstand folgen...
                  Nicht schön, aber ich glaube ich hab zumindest die Grundzüge verstanden.
                  Ich bastel mir in Java die Tabelle wie ich sie haben möchte.
                  on({id: 'fb-checkpresence.0.json', change: "any"}, function (obj) {
                  let mylist = [];
                  let name = getState('0_userdata.0.Test.JSON.Name').val
                  let datenpunkt = getState('0_userdata.0.Test.JSON.Datenpunkt').val
                  let name2 = "testname"
                  let datenpunkt2 = "testdatenpunkt"
                  mylist.push(
                                         Inhalt: datenpunkt,
                                         Inhalt: datenpunkt2,
                  setState('0_userdata.0.Test.JSON.JSON', JSON.stringify(mylist))
                  Der Teil mit den Farben erschließt sich mir aber noch nicht mal ansatzweise...
                  • Scrounger
                    Scrounger Developer @bommel_030 last edited by
                    @bommel_030 sagte in Test Adapter Material Design Widgets v0.2.x:
                    Farben kannst du so z.B. ändern:
                    mylist.push(
                                           Name: '<font color="red">' + name + '</font>',
                                           Inhalt: '<font color="blue">' + datenpunkt + '</font>',
                    Jetzt kannst die Farben auch in variablen packen und entsprechend mit Bedingungen andere Farben verwenden.
                    • Scrounger
                      Scrounger Developer last edited by Scrounger
                      Es gibt jetzt ein neues Select Widget, mit der Fehler das die daten ständig an den datenpunkt gesendet werden hoffentlich behoben sind. Weiter könnt ihr neben Einagbe der Menüpunkte über den Editor, einen JSON string verwenden oder eine Werteliste.
                      Das alte Select Widget wird in der kommenden Version entfernt!
                      Und da das Autocomplete quasi ein Nebenprodukt des select Widget ist, gibts das auch noch dazu 😉
                      Wer testen will aktuellen master ziehen -> v 0.2.46
                      K sigi234 2 Replies Last reply Reply Quote 3
                        K_o_bold @Scrounger last edited by
                        Ich teste gerade die widgets und stehe vor einem Problem.
                        Wahrscheinlich eine dumme Frage ;-), aber wie kann ich denn die Größe des bool switch ändern?
                        @Scrounger ,
                        gefällt mir sehr gut was du da aus dem Ärmel zauberst 👍
                          darkiop Most Active last edited by
                          @Scrounger Klasse die neuen selects!
                          So auf die Schnelle, ich glaube die Textfarbe wird nicht übernommen:
                          Scrounger 2 Replies Last reply Reply Quote 0
                          • Scrounger
                            Scrounger Developer @darkiop last edited by
                            @darkiop sagte in Test Adapter Material Design Widgets v0.2.x:
                            Stimmt da sind noch einige CSS Styling Fehler drin, schau ich mir an.
                            • 0
                              0018 last edited by 0018
                              Gibt es eine Möglichkeit im Widget "Top App Bar" die Zeilenüberschrift der Navigationsleiste in der Höhe zu verändern? Hintergrund hierfür ist das ich gerne "topAppBarLayout = dense" verwenden würde, hier aber dann die Höhe der Navigationsleistenüberschrift nicht übereinstimmt und hier dann das Gesamtbild nicht stimmig ist.
                              Im Bild der Bereich in lila der in der Höhe dem grünen angepasst werden soll.
                              • Scrounger
                                Scrounger Developer @0018 last edited by
                                @0018
                                Musst nen <font> Tag um den Text setzen.
                                0 2 Replies Last reply Reply Quote 0
                                • 0
                                  0018 @Scrounger last edited by
                                  @Scrounger Hast du ein Beispiel dafür damit es passen würde?
                                    @Scrounger
                                    Nachdem ich meinen Farbflash überwunden habe, habe ich mal versucht mir das passende JSON für meine Tabelle aus nem Skript zu erstellen.
                                    Der Zeilenumbruch in einer Zelle hat mich ein wenig zur Verzweifelung gebracht. Im Wohnzimmer gibt es halt Tür und Fenster...
                                                           Raum: name1,
                                                           Temperatur: temp1 +' °C',
                                       					Luftfeuchte: feuchte1 + '%',
                                       					Ventilstand: ventil1 + '%',
                                       					Fenster: [fenster1,  "\n" + tuer1],
                                       					Lüften:	empfehlung1,
                                       					Zustand: zustand1,
                                    Jetzt hänge ich aber an der Spaltenbreite... Egal was ich im Widget eintrage, die Spalte bleibt so wie sie ist...
                                    Hätte die Spalten gerne so breit, dass der Sortierpfeil keine zweite Zeile erzeugt. Und um zu sehen ob mein JSON Zeilenumbruch auch wirklich funktioniert ^^
                                    Da ich für wechselnde Farben quasi für jede Zelle nen DP erzeugen muss bleibt sie jetzt erstmal einfarbig.
                                    Und dank eines findigen Entwicklers übernimmt LinkedDevices die Übersetzung von Fenter true/false in offen/geschlossen von alleine...
                                      sigi234 Forum Testing Most Active @Scrounger last edited by sigi234
                                      @Scrounger sagte in Test Adapter Material Design Widgets v0.2.x:
                                      Der Intervall reagiert nicht in der Chart Line. Was mache ich Falsch?
                                      Info: geht mit der alten Version auch nicht mehr?
                                      • Scrounger
                                        Scrounger Developer @bommel_030 last edited by Scrounger
                                        @bommel_030
                                        Stell Mal bitte den Wert des Datenpunkt und das Widget zur verfugung, dann schau ich es mir an.
                                        @sigi234
                                        Muss Englisch sein, 30 Sekunden muss als wert 30 seconds bekommen. Schau bitte in die Doku.
                                        • Scrounger
                                          Müsste jetzt behoben sein, aktuellen master testen -> v0.2.47
                                          • I
                                            intruder7 last edited by
                                            @Scrounger
                                            Hallo, bei mir funktioniert das neue select widget überhaupt nicht (Crome)
                                            Bei Werten über den Editor gehts. Aber sobald ich auf Werteliste umstelle und dort was eingebe verschwinden alle anderen Einstellungen( Farbe,Text usw.)
                                            in der Konsole tauchen auch Fehler auf.
                                            Vuetify Select]: error: Cannot read property 'split' of undefined, stack: TypeError: Cannot read property 'split' of undefined
                                                at Object.generateItemList (http://192.168.100.85:8082/vis/widgets/materialdesign/js/widgets.min.js:1:22620)
                                                at Object.vis.binds.materialdesign.select (http://192.168.100.85:8082/vis/widgets/materialdesign/js/widgets.min.js:5:5371)
                                                at Object.eval (tplVis-materialdesign-Select.js:29:86)
                                                at Function.<anonymous> (http://192.168.100.85:8082/vis/lib/js/can.custom.min.js:64:6166)
                                                at Object.a.each (http://192.168.100.85:8082/vis/lib/js/can.custom.min.js:24:294)
                                                at http://192.168.100.85:8082/vis/lib/js/can.custom.min.js:64:6147
                                                at HTMLDivElement.<anonymous> (http://192.168.100.85:8082/vis/lib/js/can.custom.min.js:58:1841)
                                                at Function.hookup (http://192.168.100.85:8082/vis/lib/js/can.custom.min.js:58:1751)
                                                at Function.frag (http://192.168.100.85:8082/vis/lib/js/can.custom.min.js:58:1344)
                                            vis.binds.materialdesign.select @ widgets.min.js:5
                                            adapater material vis visualization widget
                                            77
                                            902
                                            203783
