    4. Test Adapter Somfy Tahoma v0.3.x GitHub
    • integer63
      integer63 @StrathCole last edited by
      @StrathCole Ich habe gerade im Log ein paar warnings gesehen und gleich auch mal auf die neue 0.2.6 upgedatet - kommen aber weiter warnings:
      tahoma.0	2020-01-21 11:40:03.829	warn	refresh device state failed
      tahoma.0	2020-01-21 11:40:03.829	warn	error during tahomalink request: 503: null, request path: /setup/devices/states/refresh with payload:{}
      tahoma.0	2020-01-21 11:38:53.754	info	eventRegisterID = c7af0521-d9b6-8679-0606-16dacfe2135f
      tahoma.0	2020-01-21 11:38:52.482	info	[INFO] Configured polling interval: 10000
      tahoma.0	2020-01-21 11:38:52.479	info	[START] Starting adapter tahoma v0.2.6
      tahoma.0	2020-01-21 11:38:52.471	info	starting. Version 0.2.6 in /opt/iobroker/node_modules/iobroker.tahoma, node: v8.15.1
      tahoma.0	2020-01-21 11:38:52.368	info	States connected to redis: 192.168.11.31:6379
      tahoma.0	2020-01-21 11:25:06.589	warn	error during tahomalink request: 503: null, request path: events/c79e6daa-d9b6-8679-0606-16da8ec89b1e/fetch with payload:{}
      tahoma.0	2020-01-21 11:21:56.451	warn	error during tahomalink request: 503: null, request path: events/c79e6daa-d9b6-8679-0606-16da8ec89b1e/fetch with payload:{}
      tahoma.0	2020-01-21 11:20:46.399	info	eventRegisterID = c79e6daa-d9b6-8679-0606-16da8ec89b1e
      tahoma.0	2020-01-21 11:20:44.365	info	[INFO] Configured polling interval: 10000
      tahoma.0	2020-01-21 11:20:44.361	info	[START] Starting adapter tahoma v0.2.4
      tahoma.0	2020-01-21 11:20:44.353	info	starting. Version 0.2.4 in /opt/iobroker/node_modules/iobroker.tahoma, node: v8.15.1
      tahoma.0	2020-01-21 11:20:44.251	info	States connected to redis: 192.168.11.31:6379
      tahoma.0	2020-01-21 11:16:23.779	warn	error during tahomalink request: 503: null, request path: events/c78950de-d9b6-8679-0606-16da86bf1b15/fetch with payload:{}
      tahoma.0	2020-01-21 11:14:43.692	warn	error during tahomalink request: 503: null, request path: events/c78950de-d9b6-8679-0606-16da86bf1b15/fetch with payload:{}
      tahoma.0	2020-01-21 11:13:33.632	warn	error during tahomalink request: 503: null, request path: events/c78950de-d9b6-8679-0606-16da86bf1b15/fetch with payload:{}
      tahoma.0	2020-01-21 11:03:03.112	warn	refresh device state failed
      tahoma.0	2020-01-21 11:03:03.112	warn	error during tahomalink request: 503: null, request path: /setup/devices/states/refresh with payload:{}
      Muss ich mir da Sorgen machen?
      StrathCole 1 Reply Last reply Reply Quote 0
      • StrathCole
        StrathCole @integer63 last edited by
        @integer63 Somfy macht heute große Serverupdates. 503 heißt, dass der Dienst nicht erreichbar ist. Ich denke, es müsste auf der Tahomalink Plattform das gleiche sein.
        integer63 1 Reply Last reply Reply Quote 0
        • integer63
          @StrathCole Ach ja richtig, heute ist ja der 21. 💡 hatte ich schon wieder komplett verdrängt 🤦‍♂️ Na mal abwarten, was morgen noch so alles geht 🤔
          • integer63
            Ach so, was ich noch sagen wollte: ich habe eine Connexoon im Einsatz (also keine TaHoma Box) - funzt aber alles prima, ist also soweit kompatibel.
              blackeagle998 @integer63 last edited by
              @integer63 sagte in Test Adapter Somfy Tahoma v0.2.x GitHub:
              👍 ich habe auch "nur" die Connexoon Box und ja bisher läuft alles prima 😊
              • StrathCole
                So, alle zusammen.
                Es gibt nun eine neue Version 0.3.0.
                Diese sollte (ich kann es selbst nicht testen) den "low speed" oder "silent" Modus für unterstützte Rollläden ermöglichen. Außerdem wurden ein paar Dinge gefixt, unter anderem das Verhalten von "neuer Befehl, wenn alter noch läuft".
                @blackeagle998 Dein Problem sollte damit auch behoben sein.
                  blackeagle998 last edited by
                  @StrathCole
                  Adapter Version 0.3.0
                  Seit gestern im Einsatz und lief bis eben problemlos, jetzt kam aber eine Fehlermeldung, die zum Adapterneustart führte:
                  tahoma.0	2020-01-22 14:49:33.396	error	at process._tickCallback (internal/process/next_tick.js:63:19)
                  tahoma.0	2020-01-22 14:49:33.396	error	at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
                  tahoma.0	2020-01-22 14:49:33.396	error	at emitErrorNT (internal/streams/destroy.js:91:8)
                  tahoma.0	2020-01-22 14:49:33.396	error	at TLSSocket.emit (events.js:198:13)
                  tahoma.0	2020-01-22 14:49:33.396	error	at TLSSocket.socketErrorListener (_http_client.js:392:9)
                  tahoma.0	2020-01-22 14:49:33.396	error	at ClientRequest.emit (events.js:198:13)
                  tahoma.0	2020-01-22 14:49:33.396	error	at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:881:8)
                  tahoma.0	2020-01-22 14:49:33.396	error	at Request.emit (events.js:198:13)
                  tahoma.0	2020-01-22 14:49:33.396	error	at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                  tahoma.0	2020-01-22 14:49:33.396	error	at Request._callback (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:339:79)
                  tahoma.0	2020-01-22 14:49:33.396	error	(13752) TypeError: Cannot read property 'statusCode' of undefined
                  tahoma.0	2020-01-22 14:49:33.392	error	(13752) uncaught exception: Cannot read property 'statusCode' of undefined
                  • StrathCole
                    StrathCole @blackeagle998 last edited by
                    @blackeagle998 Danke, habe ich gerade im git behoben. Tritt auf, wenn nach der Anfrage an Tahomalink kein Antwortobjekt kommt (Anfrage-Timeout bspw).
                      blackeagle998 @StrathCole last edited by
                      @StrathCole
                      @StrathCole
                      Adapter Version: 0.2.6
                      Funzt astrein, trotzdem noch eine kleine Sache, folgendes Szenario:
                      1. Alle Rollläden hoch (oder runter)
                      2. kurz danach alle Rollläden stop
                        --> bis hier hin funktioniert das
                      Nach etwa 15 - 30 Sekunden gehen die Rollläden dann trotzdem weiter hoch (oder runter).
                      Hier wird irgendwo der Befehl vor STOP trotzdem weiter ausgeführt, das macht aber keinen Sinn, wenn ich STOP drücke 😉
                      Das "Problem" besteht auch weiterhin mit der Adapterversion 0.3.0.
                      Der Datenpunkt moving hat den Wert "up", dann kommt "stopped" und dann geht er nach ca. 2 Sekunden automatisch wieder auf "up".
                      • StrathCole
                        @blackeagle998 sagte in Test Adapter Somfy Tahoma v0.3.x GitHub:
                        @StrathCole
                        @StrathCole
                        Bewegen sie sich denn dann auch wieder oder ist es nur ein falscher Statuswert?
                          @StrathCole
                          Sie bewegen sich in den Endzustand (ganz hoch oder ganz runter).
                          • StrathCole
                            @blackeagle998 Kannst du einmal die aus dem Git installieren, ob der Fehler da behoben ist?
                              @StrathCole
                              Adapter Version 0.3.1
                              Bleibt leider unverändert 😞
                              • StrathCole
                                @blackeagle998 Kommt denn irgendwas an Fehler oder Warnung im Log?
                                  @StrathCole
                                  Ich habe den Adapter auf DEBUG gestellt und das ioBroker LOG File auf einen Rollladen reduziert.
                                  Ist trotzdem noch ganz schön umfangreich, kann ich dir das irgendwie so zukommen lassen (PN mit Anhang oder per Mail)?
                                  • StrathCole
                                    Falls aktuell niemand mehr ein akutes Problem mit dem Adapter hat, würde ich morgen die 0.3.1 veröffentlichen.
                                    • S Trohmer
                                      S Trohmer last edited by
                                      Hi
                                      Nach der Erstinstallation war alles prima.
                                      Nun, nachdem ich eine Reihe Adapter ugedatet habe (Admin, js, etc.) stoppt der
                                      die Instanz mit folgender Meldung
                                      tahoma.0 2020-01-27 19:41:37.421 error (21093) uncaught exception: controller.login is not a function
                                      Eine Idee ?
                                      • StrathCole
                                        StrathCole @S Trohmer last edited by
                                        @S-Trohmer Könntest du mal die aktuellste GitHub Version installieren?
                                        • S Trohmer
                                          Ist die 0.3.1 von heute
                                          bin ganz neu dabei 🙂
                                          • S Trohmer
                                            Nach Neuinstallation der 0.3.0 ist wieder alles gut
                                            31.7k
                                            79.8k
                                            rollladensteuerung somfy tahoma
                                            34
                                            294
                                            36446
