    4. Test Adapter tr-064-community v1.0.x
    • SBorg
      SBorg Forum Testing Most Active @Mr. Burns last edited by
      @Mr-Burns sagte in Test Adapter tr-064-community v1.0.x:
      hab ich das richtig verstanden?
      Voll umfänglich zu 99.9%, aber "Klugschei*ermodus [ON]": es heißt SID 😁
      • Horst Böttcher
        Horst Böttcher last edited by Negalein
        Hallo der adpter geht bei mir nicht
        fehler
        tr-064-community.0	2020-01-22 23:57:22.091	info	(30177) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.18.1
        tr-064-community.0	2020-01-22 23:56:43.812	error	(30049) ~
        tr-064-community.0	2020-01-22 23:56:43.811	error	(30049) ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
        tr-064-community.0	2020-01-22 23:56:43.810	error	(30049) ~~ Fatal error. Can not connect to your FritzBox.
        tr-064-community.0	2020-01-22 23:56:43.809	error	(30049) ~
        tr-064-community.0	2020-01-22 23:56:43.806	error	(30049) Error: read ECONNRESET - {"errno":"ECONNRESET","code":"ECONNRESET","syscall":"read"}
        tr-064-community.0	2020-01-22 23:54:53.538	info	(30049) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.18.1
        tr-064-community.0	2020-01-22 23:54:15.317	error	(29887) ~
        tr-064-community.0	2020-01-22 23:54:15.316	error	(29887) ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
        tr-064-community.0	2020-01-22 23:54:15.316	error	(29887) ~~ Fatal error. Can not connect to your FritzBox.
        tr-064-community.0	2020-01-22 23:54:15.315	error	(29887) ~
        tr-064-community.0	2020-01-22 23:54:15.314	error	(29887) Error: read ECONNRESET - {"errno":"ECONNRESET","code":"ECONNRESET","syscall":"read"}
          crunchip Forum Testing Most Active @bahnuhr last edited by
          @bahnuhr is bei mir auch so
          Horst Böttcher 1 Reply Last reply Reply Quote 0
            apollon77 @Horst Böttcher last edited by
            @Horst-Böttcher die fritzbox lehnt die Verbindung ab ... Grund musst Du rausfinden 🙂 Ist alles in der Fritzbox korrekt aktiviert und so?
              apollon77 @bahnuhr last edited by
              @bahnuhr GitHub isue bitte!
              • Horst Böttcher
                Horst Böttcher @apollon77 last edited by
                @apollon77
                komisch login daten sind alle richtig und ip
                • Horst Böttcher
                  Horst Böttcher @crunchip last edited by
                  @crunchip sagte in Test Adapter tr-064-community v1.0.x:
                  ich hab die neuste beta firmware eine spielt und aufeima geht es
                    @Horst-Böttcher ist auch der Zugriff erlsubt auf das Feature?
                      Hallo liebe User ... ich habe eine Nachricht - ob gut oder schlecht muss jetzt jeder selbst entscheiden.
                      Nachdem wir jetzt 3 Monate versucht haben unter dem "neuen" Namen tr-064-community bei npm das paket zu veröffentlichen und npm das wegen dem Namen abgelehnt hat, hat es Bluefox nun geschafft den Zugriff auf den "echten" Namen tr-064 zu erhalten.
                      Aus diesem Grund haben wir uns entschieden die -community Version wieder einzustampfen und unter dem Orignalen Namen weiterzumachen. Wir werden daher unter tr-064-community keine Version auf npm veröffentlichen!
                      Die hohe Anzahl an bestehenden Usern die immer noch die alte Version nutzen (600 User auf Community Version, ca. 11k auf originaler Version) haben diesen Schritt aus unserer Sicht mehr als gerechtfertigt!
                      Die neue Version als kurzer GitHub test hier:
                      https://forum.iobroker.net/topic/29295/test-adapter-tr-064-v3-0-x
                      Ich hoffe Ihr seid nicht "zu böse". Die Konfiguration is Kompatibel, also lässt sich das system.adapter.tr-064-community.X Objekt unter "native" kopieren ...
                      Ingo
                      Negalein SBorg 2 Replies Last reply Reply Quote 0
                      • Negalein
                        Negalein Global Moderator @apollon77 last edited by
                        @apollon77 sagte in Test Adapter tr-064-community v1.0.x:
                        Hi Ingo!
                        wie ist das zu verstehen? Wie muss ich vorgehen um die Objekte vom Community in den alten TR064 bekomme?
                          apollon77 @Negalein last edited by
                          @Negalein https://github.com/iobroker-community-adapters/ioBroker.tr-064#how-to-migrate-from-tr-064-community-intermediate-verison-and-name
                          • SBorg
                            SBorg Forum Testing Most Active @apollon77 last edited by
                            Ich finde es gut, dann hat wenigstens das Wirrwarr um "welche Version nutzt du" ein Ende 👍 😎
                            • opossum
                              opossum last edited by
                              @apollon77 ,
                              die Instanz installiert, bis jetzt ist alles ok. Habe dann den community deinstalliert. Natürlich ein paar Anpassungen in der VIS-im Callmonitor gemacht. Es läuft aber bisher sauber.
                              Z 1 Reply Last reply Reply Quote 1
                              • Z
                                zahnheinrich @opossum last edited by zahnheinrich
                                @apollon77
                                Ich betreibe iobroker in einem Docker Container neuester Version auf der Synology, alle Adapter aktuell.
                                Node.js: v10.18.1
                                NPM: 6.13.4
                                Der community tr-64 lief seit langem ohne Probleme.
                                Nach Installation des neuen tr-64 bekomme ich beim Start:
                                host.iobroker	2020-01-24 18:54:55.510	error	instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                host.iobroker	2020-01-24 18:54:55.510	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                host.iobroker	2020-01-24 18:54:55.509	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                host.iobroker	2020-01-24 18:54:55.509	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                                host.iobroker	2020-01-24 18:54:55.509	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                                host.iobroker	2020-01-24 18:54:55.509	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                                host.iobroker	2020-01-24 18:54:55.508	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.tr-064/lib/calllist.js:3:14)
                                host.iobroker	2020-01-24 18:54:55.508	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                                host.iobroker	2020-01-24 18:54:55.508	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
                                host.iobroker	2020-01-24 18:54:55.507	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                                host.iobroker	2020-01-24 18:54:55.507	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                                host.iobroker	2020-01-24 18:54:55.507	error	Caught by controller[0]: Error: Cannot find module './soef.js'
                                host.iobroker	2020-01-24 18:54:55.507	error	Caught by controller[0]: ^
                                host.iobroker	2020-01-24 18:54:55.506	error	Caught by controller[0]: throw err;
                                host.iobroker	2020-01-24 18:54:55.505	error	Caught by controller[0]: internal/modules/cjs/loader.js:638
                                host.iobroker	2020-01-24 18:54:54.975	info	instance system.adapter.tr-064.0 started with pid 31079
                                host.iobroker	2020-01-24 18:54:24.935	info	Restart adapter system.adapter.tr-064.0 because enabled
                                Ich dachte, das Problem bzgl soef wäre erledigt 😲
                                Wenn ich versuche, den soef im Verzeichnis nach zu installieren, bekomme ich
                                root@iobroker:/opt/iobroker# cd node_modules/iobroker.tr-064
                                root@iobroker:/opt/iobroker/node_modules/iobroker.tr-064# npm install soef
                                sudo: Die Audit-Nachricht kann nicht gesendet werden: Unbekannter Fehler -1
                                sudo: pam_open_session: Systemfehler
                                sudo: Regelwerks-Plugin konnte Sitzung nicht initialisieren
                                Das selbe übrigens mit angehaltenem iobroker!
                                Hat jemand einen Tip?
                                Z apollon77 3 Replies Last reply Reply Quote 0
                                • Z
                                  zahnheinrich @zahnheinrich last edited by
                                  @apollon77
                                  Da der community tr-64 nicht mehr auf github ist und ich meinen Docker neu aufgesetzt habe, habe ich auch leider keinen fallback.
                                  Keine Daten von der FritzBox, keine Anwesenheitserkennung usw...
                                  Kann ich den alten tr-64 noch irgendwo downloaden?
                                  Gruß Ulrich
                                  apollon77 Z 2 Replies Last reply Reply Quote 0
                                    apollon77 @zahnheinrich last edited by
                                    @zahnheinrich soef lib ist in der Version schon ewig raus und direkt drin. Und die Installation hat komplett geklappt?
                                    Da fehlt wohl ein file was an sich da sein müsste. Und du bist bisher der einzige
                                      @zahnheinrich Versuch doch die gleiche Version vom GitHub nochmal neu zu installieren.
                                      • Z
                                        zahnheinrich @zahnheinrich last edited by zahnheinrich
                                        @apollon77
                                        Kommando zurück:
                                        Nach erneuter Deinstallation des Adapters (nicht nur der Instanz) und Neuinstallation geht es ohne Probleme.
                                        Also alles gut!
                                        Gruß Ulrich
                                          @zahnheinrich ps: und du bist sicher das du nicjt irgendwelche rechte Problem hast? Kenne mich aber mit Docker nicht aus.
                                          • Z
                                            zahnheinrich @apollon77 last edited by
                                            @apollon77
                                            OK, einen hab ich noch:
                                            Der Datenpunkt "ringing" wird bei eingehendem Anruf zwar true, nach Anrufende jedoch nicht mehr "false".
                                            Das soll wohl nicht so sein, oder?
                                            Gruß Ulrich
                                            dslraser klausM 2 Replies Last reply Reply Quote 0
                                            1.2k
                                            community tr-064
                                            88
                                            727
                                            189325
