    4. iob auf Win 10 (manuelle Installation)
    UNSOLVED iob auf Win 10 (manuelle Installation)
    • bahnuhr
      So,
      nun nochmal probiert und ganz detailliert.
      node installiert und geprüft:
      cmd als admin:
      Windows-build-tools installiert
      C:\>npm install --global windows-build-tools
      > windows-build-tools@5.2.2 postinstall C:\Users\Dieter\AppData\Roaming\npm\node_modules\windows-build-tools
      > node ./dist/index.js
      Downloading vs_BuildTools.exe
      [>                                            ] 0.0% (0 B/s)
      Downloaded vs_BuildTools.exe. Saved to C:\Users\Dieter\.windows-build-tools\vs_BuildTools.exe.
      Starting installation...
      Launched installers, now waiting for them to finish.
      This will likely take some time - please be patient!
      Status from the installers:
      ---------- Visual Studio Build Tools ----------
      Successfully installed Visual Studio Build Tools.
      ------------------- Python --------------------
      Python 2.7.15 is already installed, not installing again.
      Now configuring the Visual Studio Build Tools..
      All done!
      + windows-build-tools@5.2.2
      updated 1 package in 10.061s
      Verzeichnis mit "md C:\iobroker" angelegt.
      Der folgende Befehl klappt nicht!
      C:\>cd /d C:\iobroker npm install iobroker
      Das System kann den angegebenen Pfad nicht finden.
      Also gewechselt mit "cd iobroker" um in das Verzeichnis zu wechseln.
      Und dann "npm install iobroker"
      Es kommt:
      C:\>cd iobroker
      C:\iobroker>npm install iobroker
      > iobroker@2.0.3 install C:\iobroker\node_modules\iobroker
      > node lib/checkVersions.js
      NPM version: 6.13.4
      > iobroker@2.0.3 postinstall C:\iobroker\node_modules\iobroker
      > node lib/install.js
      │ The iobroker files have been downloaded successfully. │
      │ To complete the installation, you need to run         │
      │           npm i --production --unsafe-perm            │
      npm notice created a lockfile as package-lock.json. You should commit this file.
      npm WARN enoent ENOENT: no such file or directory, open 'C:\iobroker\package.json'
      npm WARN iobroker No description
      npm WARN iobroker No repository field.
      npm WARN iobroker No README data
      npm WARN iobroker No license field.
      + iobroker@2.0.3
      added 51 packages from 32 contributors and audited 83 packages in 3.903s
      1 package is looking for funding
       run `npm fund` for details
      found 0 vulnerabilities
      C:\iobroker>
      Und jetzt weicht es ab:
      Lt. Anleitung auf iob steht: npm i --production --no-optional --logevel=error
      (Anmerkung: loglevel ist auch falsch geschrieben)
      In dem grünen Kasten steht aber: npm i --production --unsafe-perm
      Ich habe nun mal die Anleitung genommen (den grünen Kasten hatte ich ja schon vergeblich probiert)
      Es wurde dann etliches installiert. Zum Schluss kam dann:
      + node-windows@0.1.14
      added 56 packages from 39 contributors in 3.356s
      ioBroker started!
      Visit http://127.0.0.1:8080 to configure it.
      ioBroker service installed. Write "serviceIoBroker start" to start the service and go to http://localhost:8081 to open the admin UI.
      To see the outputs do not start the service, but write "node node_modules/iobroker.js-controller/controller"
      added 375 packages from 343 contributors and audited 2018 packages in 65.951s
      5 packages are looking for funding
      found 13 vulnerabilities (10 low, 3 high)
       run `npm audit fix` to fix them, or `npm audit` for details
      C:\iobroker>
      Lt. Anleitung nun nochmal: cd /d C:\iobroker npm install --production --no-optional --logevel=error (auch hier dürfte loglevel nicht richtig geschrieben sein).
      Klappt aber nicht (aber ich hatte diesen ja auch schon, oder?):
      C:\iobroker>cd /d C:\iobroker npm install --production --no-optional --loglevel=error
      Die Hinweise sowie roten Punkte lt. Anleitung kamen eben nicht!
      Bei "iobroker status" kommt:
      C:\iobroker>iobroker status
      C:\iobroker>node node_modules/iobroker.js-controller/iobroker.js status
      At least one iobroker host is running.
      Objects type: file
      States  type: file
      Also läuft doch iob!! Auch bei "Dienste" ist ersichtlich, dass iob läuft.
      Soweit sogut.
      Nun iob im browser aufgerufen mit: ip:8081
      Bei den Instanzen sieht es nun so aus:
      Auch alles gut soweit.
      Nun wollte ich javascript installieren.
      Dabei kommt:
      Fragen:
      Warum Fehlermeldung !
      Was ist schief gelaufen.
      Ich könnte nun mal Hilfe gebrauchen.
      mfg
      Dieter
      • Negalein
        Negalein Global Moderator @bahnuhr last edited by
        @bahnuhr sagte in iob auf Win 10 (manuelle Installation):
        Ich kann dir zwar nicht weiterhelfen, aber hast du schon den Thread zum Windows-Installer von @Stabilostick gesehen?
        • bahnuhr
          bahnuhr Forum Testing Most Active @Negalein last edited by
          @Negalein sagte in iob auf Win 10 (manuelle Installation):
          Ja, und siehe mein 2. satz im Beitrag #1
          • bahnuhr
            @Homoran
            @apollon77
            @Stabilostick
            Keiner eine Idee ?
            • bahnuhr
              So manchmal kommt es vor, dass niemand auf meine Thread antwortet.
              Ich frag mich dann halt immer woran das liegt.
              Hab ich mich undeutlich ausgedrückt?
              War es zu viel zu lesen?
              Oder interessiert das Thema einfach keinen?
              Fakt ist halt, dass ich nicht weiter komme.
              Eine kurze Antwort hätte ja gereicht, z.B.
              Manuelle Installation geht nicht mehr; nimm den Installer von stabilo.., oder
              Nimm die Befehle xy, dann klappt es, oder
              Es ist nicht mehr gewollt, dass manuell installiert wird,
              etc.
              etc.
              Aber gar keine Antwort ist schon komisch und nicht gerade motivierend.
              Falls sich jemand jetzt auf den Schlips getreten fühlt, dann negativ bewerten.
              Dann weiß ich ja auch woran ich bin.
              mfg
              htrecksler 1 Reply Last reply Reply Quote 1
              • htrecksler
                htrecksler Forum Testing @bahnuhr last edited by
                @bahnuhr warum willst du denn unbedingt manuell installieren? Ich kann dir zwar nicht helfen, aber mich würde der Grund interessieren. Jahrelang hatte ich den iob auf Basis Windows, und mit den Problemen (Windows Update, etc) gelebt. Jetzt bin ich sehr froh das ich den Schritt zu Linux gewagt habe.
                • bahnuhr
                  bahnuhr Forum Testing Most Active @htrecksler last edited by bahnuhr
                  @htrecksler
                  Ich habe iob nun seit Jahren iob auf windows.
                  Grund ist, dass ich mich mit Linux nur schlecht auskenne.
                  Aber auch die Diskussion hier mit dem Speicher vom raspi hab ich nicht.
                  Mein Laptop hat 16 GB und der neue hat 24 GB Speicher, das reicht erst einmal für zahlreiche Instanzen.
                  Grund für manuell ist primär:
                  Beim update mit dem stabilo Win wird immer ein neues Verzeichnis angelegt. Das bedeutet dann, dass ich Scripte anpassen muss.
                  Hab ich halt bei der manuellen Installation nicht. Außerdem muss man da nicht warten bis stabilo eine neue Version raus bringt.
                  mfg
                  • htrecksler
                    htrecksler Forum Testing last edited by
                    ok, vielleicht kommt ja noch eine Reaktion eines "Wissenden". Wie gesagt, ich kann dir leider nicht helfen, aber deine Begründung nachvollziehen.
                    Hast du mal versucht stabilo per "Chat" anzuschreiben? Ich denke, am ehesten kann er helfen
                    • bahnuhr
                      @htrecksler sagte in iob auf Win 10 (manuelle Installation):
                      Danke trotzdem für deine Reaktion.
                      • bahnuhr
                        Gut, habe die Reaktion im Forum verstanden.
                        Fazit:
                        bleibe auf win7.
                        Manuelle Installation auf win10 nicht möglich.
                        Anleitung stimmt nicht.
                        Info/Hilfe aus dem Forum kommt nicht.
                        Danke.
                          apollon77 last edited by
                          Also diese meldung das da ein File existiert was er dort nicht erwartet kenne ich von Linux nur wenn man irgendwie manuell im node_modules Verzeichnis Files kopiert hat und plötzlich aus einem Symlink ein echten File wurde. Kann das ggf bei Windows auch der Grund sein?
                          Ansonsten steht in der Fehlermeldung genau was man tun muss ... "Remove the existing file and try again". Habt Ihr das mal versucht?
                          Ich kenne mich mit Windows nicht gut genug aus um sagen zu können was hier die Ursache sein kann. Ich kenne nur die "übliche" Ursache auf Linux.
                          Hilft Euch das?
                          Ingo
                          • bahnuhr
                            Danke für die Antwort.
                            Hilft mir aber nicht.
                            Habe nichts kopiert.
                            Node 10.18.1 drauf gemacht und versucht manuell iob zu installieren.
                            • bahnuhr
                              bahnuhr Forum Testing Most Active @apollon77 last edited by
                              @apollon77 sagte in iob auf Win 10 (manuelle Installation):
                              Was genau muss gelöscht oder verschoben werden ?
                              Uhula apollon77 2 Replies Last reply Reply Quote 0
                              • Uhula
                                Uhula @bahnuhr last edited by
                                @bahnuhr Ich habe am Wochenende nach 2 Jahren auch meine iob Inst auf Win10 aktualisiert, und zwar nicht manuell, sondern mit dem Installer.
                                Dabei auch festgestellt, dass neue Verzeichnisse angelegt werden, was ich so nicht wollte. Also manuelle die neue iob Installation wieder gelöscht und mich besser vorbereitet.
                                Die alte iob Installation lag bisher in \home\iobroker - da sollte nun die neue rein.
                                • Also die alte Installation gestoppt, und den Order in \home\iobroker_old umbenannt.
                                • das Installationsprogramm gestartet
                                • Verzeichnis: \home
                                • Name: iobroker
                                • Übernahme alte Daten aus: \home\iobroker_old
                                Hat dann prima funktioniert und die neue Installation befindet sich in \home\iobroker. Man muss nur Geduld haben, zumindest in meinem Fall, da ja 2 Jahre vergangen waren und die neue iob erst einmal alle Adapter aktualisieren musste.
                                Vielleicht hilft es dir und du musst nicht die manuelle Installation nutzen.
                                Tipp: Der neue iob Dienst sollte über ein Konto "NT Servcie ..." gestartet werden, das ging bei mir nicht. Nach Änderung auf "lokales Systemkonto" in den Diensteigenschaften funktioniert es.
                                • bahnuhr
                                  @Uhula
                                  Ich wollte eine komplette Neuinstallation auf einem neuen Rechner.
                                  • Win 10 komplett neu drauf gemacht (FP komplett gelöscht)
                                  • Danach iob (ohne Übernahme von irgendwas) neu installiert.
                                  Und dies klappt nicht.
                                  Uhula 1 Reply Last reply Reply Quote 1
                                  • Uhula
                                    @bahnuhr Dein Grund für die manuelle Inst ist ja:
                                    Was so auch korrekt ist, aber durch die Angabe des Speicherorts (Bsp: \home) und des Namens (Bsp:iobroker) kannst du den Zielordner doch so wählen, dass er deinem alten Win7 entspricht (Bsp: \home\iobroker). Also den Speicherort um den Namen kürzen. Das wollte ich dir erläutern, vielleicht habe ich es zu umständlich ausgedrückt.
                                    Mehr Erfahrung habe ich damit allerdings auch nicht.
                                    • bahnuhr
                                      bahnuhr Forum Testing Most Active @Uhula last edited by
                                      @Uhula sagte in iob auf Win 10 (manuelle Installation):
                                      Habe dich nicht verstanden.
                                      Der alte (existierende) Speicherort wird nicht angenommen.
                                      Es muss ein neuer vergeben werden.
                                        sigi234 Forum Testing Most Active @bahnuhr last edited by
                                        bahnuhr 2 Replies Last reply Reply Quote 0
                                        • bahnuhr
                                          bahnuhr Forum Testing Most Active @sigi234 last edited by
                                          @sigi234 sagte in iob auf Win 10 (manuelle Installation):
                                          Gut, kann man mal probieren.
                                          Aber wir sind ja hier bei "manuelle Installation".
                                          Und wäre doch schön wenn dies klappen würden.
                                          Ansonsten würde ich empfehlen die Doku zu ändern.
                                          Dann halt in: auf Win nur stabilo installer möglich (oder so).
                                          sigi234 Uhula 2 Replies Last reply Reply Quote 0
                                            sigi234 Forum Testing Most Active @bahnuhr last edited by sigi234
                                            @bahnuhr
                                            Soweit ich weis kommt einen Neue Version vom @Stabilostick , würde ich einer manuellen bevorzugen.
                                            Ich habe schon X Mal den Installer verwendet und keine Probleme damit gehabt . Auch die Migration ist gut verlaufen. Diese dauerte aber 2 Stunden.
                                            1.0k
                                            install iobroker windows
                                            1051
