    4. JavaScript
    5. Script fürTabelle der Batterie Zustände
    • Meister Mopper
      Meister Mopper @Meister Mopper last edited by
      @Meister-Mopper Es schaukelt sich offenbar zeitlich auf:
      javascript.0	2020-01-23 19:50:00.306	error	(1487) at Timer.processTimers (timers.js:223:10)
      javascript.0	2020-01-23 19:50:00.305	error	(1487) at listOnTimeout (timers.js:263:5)
      javascript.0	2020-01-23 19:50:00.279	error	(1487) at tryOnTimeout (timers.js:300:5)
      javascript.0	2020-01-23 19:50:00.278	error	(1487) at ontimeout (timers.js:436:11)
      javascript.0	2020-01-23 19:50:00.278	error	(1487) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
      javascript.0	2020-01-23 19:50:00.269	error	(1487) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
      javascript.0	2020-01-23 19:50:00.268	error	(1487) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
      javascript.0	2020-01-23 19:50:00.268	error	(1487) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1319:34)
      javascript.0	2020-01-23 19:50:00.268	error	(1487) at Object.<anonymous> (script.js.java.sonstige.Batterien:1687:1)
      javascript.0	2020-01-23 19:50:00.267	error	(1487) at writeHTML (script.js.java.sonstige.Batterien:1671:52)
      javascript.0	2020-01-23 19:50:00.266	error	(1487) Error in callback: ReferenceError: wantAmessage is not defined
      host.raspberrypi	2020-01-23 19:50:00.067	info	instance system.adapter.dwd.0 started with pid 7920
      javascript.0	2020-01-23 19:46:53.630	error	(1487) at Script.runInContext (vm.js:133:20)
      javascript.0	2020-01-23 19:46:53.630	error	(1487) at script.js.java.sonstige.Batterien:1693:1
      javascript.0	2020-01-23 19:46:53.630	error	(1487) at writeHTML (script.js.java.sonstige.Batterien:1671:52)
      javascript.0	2020-01-23 19:46:53.629	error	(1487) ReferenceError: wantAmessage is not defined
      javascript.0	2020-01-23 19:46:53.629	error	(1487) ^
      javascript.0	2020-01-23 19:46:53.629	error	(1487) if (AkkuMessageLengthAlt < AkkuAlarm.length && wantAmessage) {setState(dpAlarmMessage,alarmMessage.toString()); AkkuMessageLengthAlt=AkkuAlarm.length}
      javascript.0	2020-01-23 19:46:53.629	error	(1487) script.js.java.sonstige.Batterien: script.js.java.sonstige.Batterien:1671
      javascript.0	2020-01-23 19:46:53.579	info	(1487) Start javascript script.js.java.sonstige.Batterien
      javascript.0	2020-01-23 19:46:44.664	info	(1487) Stop script script.js.java.sonstige.Batterien
      host.raspberrypi	2020-01-23 19:46:04.565	info	instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
      javascript.0	2020-01-23 19:45:54.083	error	(1487) at Script.runInContext (vm.js:133:20)
      javascript.0	2020-01-23 19:45:54.083	error	(1487) at script.js.java.sonstige.Batterien:1693:1
      javascript.0	2020-01-23 19:45:54.083	error	(1487) at writeHTML (script.js.java.sonstige.Batterien:1671:52)
      javascript.0	2020-01-23 19:45:54.083	error	(1487) ReferenceError: wantAmessage is not defined
      javascript.0	2020-01-23 19:45:54.083	error	(1487) ^
      javascript.0	2020-01-23 19:45:54.082	error	(1487) if (AkkuMessageLengthAlt < AkkuAlarm.length && wantAmessage) {setState(dpAlarmMessage,alarmMessage.toString()); AkkuMessageLengthAlt=AkkuAlarm.length}
      javascript.0	2020-01-23 19:45:54.082	error	(1487) script.js.java.sonstige.Batterien: script.js.java.sonstige.Batterien:1671
      javascript.0	2020-01-23 19:45:54.009	info	(1487) Start javascript script.js.java.sonstige.Batterien
      javascript.0	2020-01-23 19:45:45.071	info	(1487) Stop script script.js.java.sonstige.Batterien
      host.raspberrypi	2020-01-23 19:45:08.720	info	instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
      host.raspberrypi	2020-01-23 19:45:04.078	info	instance system.adapter.dwd.0 started with pid 7231
      host.raspberrypi	2020-01-23 19:45:00.043	info	instance system.adapter.tvspielfilm.0 started with pid 7189
      host.raspberrypi	2020-01-23 19:41:07.283	info	instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
      javascript.0	2020-01-23 19:40:31.061	info	(1487) script.js.Wohnzimmer.Energie.Smartphones_laden: registered 4 subscriptions and 0 schedules
      javascript.0	2020-01-23 19:40:31.049	info	(1487) Start javascript script.js.Wohnzimmer.Energie.Smartphones_laden
      javascript.0	2020-01-23 19:40:30.922	info	(1487) Stop script script.js.Wohnzimmer.Energie.Smartphones_laden
      host.raspberrypi	2020-01-23 19:40:07.436	info	instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
      host.raspberrypi	2020-01-23 19:40:04.092	info	instance system.adapter.tvspielfilm.0 started with pid 6475
      javascript.0	2020-01-23 19:40:00.238	error	(1487) at Timer.processTimers (timers.js:223:10)
      javascript.0	2020-01-23 19:40:00.238	error	(1487) at listOnTimeout (timers.js:263:5)
      javascript.0	2020-01-23 19:40:00.237	error	(1487) at tryOnTimeout (timers.js:300:5)
      javascript.0	2020-01-23 19:40:00.237	error	(1487) at ontimeout (timers.js:436:11)
      javascript.0	2020-01-23 19:40:00.237	error	(1487) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
      javascript.0	2020-01-23 19:40:00.236	error	(1487) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
      javascript.0	2020-01-23 19:40:00.234	error	(1487) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
      javascript.0	2020-01-23 19:40:00.229	error	(1487) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1319:34)
      javascript.0	2020-01-23 19:40:00.229	error	(1487) at Object.<anonymous> (script.js.java.sonstige.Batterien:1687:1)
      javascript.0	2020-01-23 19:40:00.228	error	(1487) at writeHTML (script.js.java.sonstige.Batterien:1671:52)
      javascript.0	2020-01-23 19:40:00.227	error	(1487) Error in callback: ReferenceError: wantAmessage is not defined
      host.raspberrypi	2020-01-23 19:40:00.053	info	instance system.adapter.dwd.0 started with pid 6420
      javascript.0	2020-01-23 19:37:38.711	info	(1487) script.js.Wohnzimmer.Energie.Smartphones_laden: registered 4 subscriptions and 0 schedules
      javascript.0	2020-01-23 19:37:38.699	info	(1487) Start javascript script.js.Wohnzimmer.Energie.Smartphones_laden
      javascript.0	2020-01-23 19:37:38.585	info	(1487) Stop script script.js.Wohnzimmer.Energie.Smartphones_laden
      host.raspberrypi	2020-01-23 19:36:05.127	info	instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
      host.raspberrypi	2020-01-23 19:35:09.089	info	instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
      host.raspberrypi	2020-01-23 19:35:04.703	info	instance system.adapter.dwd.0 started with pid 5688
      host.raspberrypi	2020-01-23 19:35:00.668	info	instance system.adapter.tvspielfilm.0 started with pid 5667
      host.raspberrypi	2020-01-23 19:31:07.615	info	instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
      host.raspberrypi	2020-01-23 19:30:25.138	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
      host.raspberrypi	2020-01-23 19:30:08.192	info	instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
      host.raspberrypi	2020-01-23 19:30:08.110	info	instance system.adapter.daswetter.0 started with pid 4925
      host.raspberrypi	2020-01-23 19:30:04.077	info	instance system.adapter.tvspielfilm.0 started with pid 4905
      javascript.0	2020-01-23 19:30:00.257	error	(1487) at Timer.processTimers (timers.js:223:10)
      javascript.0	2020-01-23 19:30:00.256	error	(1487) at listOnTimeout (timers.js:263:5)
      javascript.0	2020-01-23 19:30:00.256	error	(1487) at tryOnTimeout (timers.js:300:5)
      javascript.0	2020-01-23 19:30:00.255	error	(1487) at ontimeout (timers.js:436:11)
      javascript.0	2020-01-23 19:30:00.255	error	(1487) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
      javascript.0	2020-01-23 19:30:00.254	error	(1487) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
      javascript.0	2020-01-23 19:30:00.254	error	(1487) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
      javascript.0	2020-01-23 19:30:00.253	error	(1487) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1319:34)
      javascript.0	2020-01-23 19:30:00.253	error	(1487) at Object.<anonymous> (script.js.java.sonstige.Batterien:1687:1)
      javascript.0	2020-01-23 19:30:00.252	error	(1487) at writeHTML (script.js.java.sonstige.Batterien:1671:52)
      javascript.0	2020-01-23 19:30:00.251	error	(1487) Error in callback: ReferenceError: wantAmessage is not defined
        liv-in-sky @Meister Mopper last edited by
        @Meister-Mopper hast du das ?
          liv-in-sky last edited by
          gibt es ein problem mit der anzeige - überschneidet sich etwas bei homeatic ?
            liv-in-sky @tugsi last edited by
            @tugsi im ersten post mit zwave
            tugsi 1 Reply Last reply Reply Quote 0
            • Meister Mopper
              Meister Mopper @liv-in-sky last edited by
              @liv-in-sky sagte in Script fürTabelle der Batterie Zustände:
              Jetzt ja, hatte beim letzten mal den Beginn nicht mitkopiert. Es ändert sich ja in den kürzesten Zeitabständen 😁
              Fehler ist weg!
                @Meister-Mopper die updates werden weniger mit der zeit
                • O
                  Oli @liv-in-sky last edited by
                  @liv-in-sky
                  ist es möglich die Hintergrundfarbe Zeile für Zeile zu definieren, also zB
                  Gerade Zeilennummern Schwarz und ungeraden Zeilennummern Grau?
                    liv-in-sky @Oli last edited by
                    @Oli nein - habe ich auch schon überlegt aber die mehrtabellenanzeige macht es problematisch - wenn mir mal eine math. formel einfällt, die ich anwenden kann, gebe ich bescheid
                    • O
                      @liv-in-sky
                      Würde es bei einer einzelnen Tabellenansicht gehen?
                      liv-in-sky Glasfaser 2 Replies Last reply Reply Quote 0
                        @Oli habe geheime formel gefunden - muss das noch umsetzen - geht mit allen spalten instellungen und farbe werden über var iable eingestellt
                        update später - muss jetzt weg
                        beidspiel meiner test tabelle
                        • O
                          @liv-in-sky
                          Cool
                          • tugsi
                            tugsi @liv-in-sky last edited by
                            @liv-in-sky
                            Danke! Hat geklappt! 1a.
                            Hast oben im ersten Post noch kein ZWave mit angegeben 😉
                            • Glasfaser
                              Glasfaser @Oli last edited by Glasfaser
                              @Oli
                              Du kannst es auch über CSS verändern ….
                              mdui-table mdui-table-ascard-r250-l mdui-table-striped noSwipe
                              • Negalein
                                Negalein Global Moderator @Glasfaser last edited by
                                @Glasfaser sagte in Script fürTabelle der Batterie Zustände:
                                Cool
                                Danke für den Tipp
                                • Z
                                  zahnheinrich @Negalein last edited by
                                  @liv-in-sky
                                  Betreibe einige CuxD Geräte in einer separaten hm-rpc Instanz.
                                  Diese Geräte haben sämtlich, da virtuell, KEINE Werte für Spannung o.ä.
                                  Da sie aber zu den HM Geräten sortiert werden, kommen bei Skripterstellung entsprechende Fehlermeldungen.
                                  Kannst du diese Geräte oder besser/einfacher die ganze Instanz ausklammern?
                                  Die Werte:
                                  hm-rpc.0.json
                                  Das Bild:
                                  Homoran liv-in-sky 2 Replies Last reply Reply Quote 0
                                    Homoran Global Moderator Administrators @zahnheinrich last edited by Homoran
                                    @zahnheinrich sagte in Script fürTabelle der Batterie Zustände:
                                    Dazu gäbe es das Filter-Array ganz zu Beginn.
                                    Ob das einfach mit wildcards klappt um sich Schreibarbeit zu ersparen habe ich noch nicht getestet
                                    var filterArray=["hm-rpc.0.MEQ1097293.0.LOWBAT","hm-rpc.0.LEQ0397071.0.LOWBAT","hm-rpc.0.MEQ0082816.0,LOWBAT",...
                                    Was mich allerdings wundert ist dass diese Geräte gefunden werden, obwohl sie kinene LOWBAT Datenpunkt haben
                                    Z Homoran 3 Replies Last reply Reply Quote 0
                                    • Z
                                      zahnheinrich @Homoran last edited by
                                      @Homoran
                                      Ahh ja, guter Hinweis! Danke
                                        liv-in-sky @zahnheinrich last edited by
                                        @zahnheinrich ich sehe kein LOW_BAT und kein BATTERY_STATE - oder übersehe ich da was
                                        das script sollte diese geräte garnicht finden und aufnehmen
                                          Homoran Global Moderator Administrators @Homoran last edited by
                                          @Homoran sagte in Script fürTabelle der Batterie Zustände:
                                          Mein Reden!
                                            @zahnheinrich zeig mal die fehlermeldung vom log, wenn das script startet
                                            javascript monitoring template
                                            67
                                            1379
                                            487009
