    4. Test Adapter Weatherunderground v3.1.x
      watcherkb last edited by
      @apollon77 bekomme seit gestern Abend keine neuen Daten rein.
      weatherunderground.0	2019-11-14 12:24:34.812	debug	system.adapter.admin.0: logging true
      weatherunderground.0	2019-11-14 12:24:32.707	debug	all forecast values set
      weatherunderground.0	2019-11-14 12:24:32.695	error	No current observation data found in response
      weatherunderground.0	2019-11-14 12:24:32.527	debug	get hourly forecast data: https://api.weather.com/v3/wx/forecast/hourly/15day?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=52.13%2C8.67&units=m&language=de&format=json
      weatherunderground.0	2019-11-14 12:24:32.377	debug	get daily forecast data: https://api.weather.com/v3/wx/forecast/daily/5day?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=52.13%2C8.67&language=de&units=m&format=json
      weatherunderground.0	2019-11-14 12:24:32.376	error	Wunderground reported an error: 204/null
      weatherunderground.0	2019-11-14 12:24:32.069	debug	get current observation data: https://api.weather.com/v2/pws/observations/current?numericPrecision=decimal&apiKey=6532d6454b8aa370768e63d6ba5a832e&units=m&stationId=IHERFORD67&format=json
      weatherunderground.0	2019-11-14 12:24:32.069	debug	Use new API Key 6532d6454b8aa370768e63d6ba5a832e
      weatherunderground.0	2019-11-14 12:24:32.068	debug	Use New API
      weatherunderground.0	2019-11-14 12:24:32.068	debug	location has not changed, reuse extracted URLs
      weatherunderground.0	2019-11-14 12:24:32.065	debug	initialize Hourly Forecast Url: https://api.weather.com/v3/wx/forecast/hourly/15day?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=52.13%2C8.67&units=e&language=en-US&format=json
      weatherunderground.0	2019-11-14 12:24:32.064	debug	initialize Daily Forecast Url: https://api.weather.com/v3/wx/forecast/daily/5day?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=52.13%2C8.67&language=en-US&units=e&format=json
      weatherunderground.0	2019-11-14 12:24:32.062	debug	initialize Current Observation url: https://api.weather.com/v2/pws/observations/current?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&stationId=IHERFORD67&format=json
      weatherunderground.0	2019-11-14 12:24:32.062	debug	initialize Web Key: 6532d6454b8aa370768e63d6ba5a832e
      weatherunderground.0	2019-11-14 12:24:31.987	debug	initialize PWS Station Key: d8585d80376a429e
      weatherunderground.0	2019-11-14 12:24:31.867	debug	init forecast objects
      weatherunderground.0	2019-11-14 12:24:31.866	debug	init conditions objects
      weatherunderground.0	2019-11-14 12:24:31.865	debug	on ready: DL true true true true
      weatherunderground.0	2019-11-14 12:24:31.850	info	starting. Version 3.1.6 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v10.16.3
      weatherunderground.0	2019-11-14 12:24:31.842	debug	statesDB connected
      weatherunderground.0	2019-11-14 12:24:31.835	debug	objectDB connected
      host.IOBroker_Produktiv	2019-11-14 12:24:31.597	info	instance system.adapter.weatherunderground.0 started with pid 29224
      host.IOBroker_Produktiv	2019-11-14 12:24:31.587	info	instance scheduled system.adapter.weatherunderground.0 15 * * * *
      host.IOBroker_Produktiv	2019-11-14 12:24:29.085	warn	stopInstance system.adapter.weatherunderground.0 not scheduled
      host.IOBroker_Produktiv	2019-11-14 12:24:29.085	info	stopInstance system.adapter.weatherunderground.0
      host.IOBroker_Produktiv	2019-11-14 12:24:29.085	info	"system.adapter.weatherunderground.0" enabled
      host.IOBroker_Produktiv	2019-11-14 12:24:29.085	info	object change system.adapter.weatherunderground.0
      Über StationID auf der Website sind die Daten aber aktuell.
      apollon77 2 Replies Last reply Reply Quote 0
        apollon77 @watcherkb last edited by
        @watcherkb sagte in Test Adapter Weatherunderground v3.1.x:
        ja die observation url liefert nix zurück ... hm
          Scheinbar liefert die Station aktuell keine neuen Daten. Das Problem hatten wir schon hier und da mal und hat sich meistens nach gewisser Zeit wieder gegeben - oder restart der Station
            watcherkb @apollon77 last edited by
            @apollon77 alles klar. Hab dann mal ne andere Station angezapft und jetzt sieht es gut aus.
              gerald123 last edited by Negalein
              Hab ein Problem beim Einrichten des WU Adapters.
              Ich habe eine WS3500 Wetterstation die bei Wunderground registriert ist und dort auch die Werte anzeigt.
              Jetzt wollte ich eine zweite WU Instanz anlegen und habe da auch den API Key eingetragen.
              Leider bekomme ich in den Objekten keine Werte angezeigt.
              Im Log wird folgendes Angezeigt:
              weatherunderground.1	2020-01-25 20:12:05.034	info	(31582) Terminated (NO_ERROR): Without reason
              weatherunderground.1	2020-01-25 20:12:02.527	error	(31582) No forecast data found in response
              weatherunderground.1	2020-01-25 20:12:02.527	error	(31582) No current observation data found in response
              weatherunderground.1	2020-01-25 20:12:02.524	error	(31582) Wunderground reported an error: --/Error: options.uri is a required argument
              weatherunderground.1	2020-01-25 20:12:02.522	error	(31582) Wunderground reported an error: --/Error: options.uri is a required argument
              weatherunderground.1	2020-01-25 20:12:02.520	error	(31582) Wunderground reported an error: --/Error: options.uri is a required argument
              weatherunderground.1	2020-01-25 20:12:01.672	info	(31582) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v10.18.1
              Kann mir jemand weiterhelfen was bei den Einstellungen noch fehlt
                crunchip Forum Testing Most Active @gerald123 last edited by
                @gerald123
                • für was eine 2. Instanz?
                • Einstellungen alle ausgefüllt? DE Koordinaten NamederStation
                also kleiner Hinweis noch, für diejenigen, die eine eigene Wetterstation haben und sich die Daten direkt holen wollen
                https://forum.iobroker.net/post/350116
                  Ich habe erst seit einer Woche meine eigene Wetterstation, vorher habe ich eine in meiner Nähe abgefragt.
                  Daher die zwei Instanzen.
                  Ausgefüllt habe ich alles mit meinen Daten, leider kommt da nichts.
                  Den anderen Post habe ich auch schon gelesen, aber habe noch nicht ganz verstanden was da alles wo installiert werden muss.
                    @gerald123 deine 1. Instanz ist also ohne Api Key und funktioniert?
                    hast du die anderen Möglichkeiten auch mal getestet? Bei Ort, die Stadt bzw Wetterstation-ID
                      Zeig mal die Konfig bitte (Screenshot oder so)
                        gerald123 @crunchip last edited by
                        @crunchip Ja, die 1. Instanz ist ohne API und funktioniert.
                        Bei der 2ten habe ich alle Varianten getestet aber leider funktioniert es nicht mit meinen Daten
                          apollon77 @gerald123 last edited by
                          @gerald123 Ute konfig Screenshot und Adapter logging auf debug stelle und log Posten. Danke. Wenn du wegen dem api key nicht willst dann kannst du mir das auch als email an iobroker@fischer-ka.de schicken
                            MartyBr last edited by
                            @apollon77
                            Bei mir wirft der Wunderrground Adapter seit einigen Tagen Fehler aus.
                            Habe das Loggin auf debug gestellt:
                            weatherunderground.0	2020-02-01 16:08:50.798	info	(8465) Terminated (NO_ERROR): Without reason
                            weatherunderground.0	2020-02-01 16:08:48.296	debug	(8465) all forecast values set
                            weatherunderground.0	2020-02-01 16:08:48.244	error	(8465) No current observation data found in response
                            weatherunderground.0	2020-02-01 16:08:48.018	debug	(8465) get hourly forecast data: https://api.weather.com/v3/wx/forecast/hourly/15day?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=52.679%2C13.322&units=m&language=de&format=json
                            weatherunderground.0	2020-02-01 16:08:47.836	debug	(8465) get daily forecast data: https://api.weather.com/v3/wx/forecast/daily/5day?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=52.679%2C13.322&language=de&units=m&format=json
                            weatherunderground.0	2020-02-01 16:08:47.835	error	(8465) Wunderground reported an error: 204/null
                            weatherunderground.0	2020-02-01 16:08:47.494	debug	(8465) get current observation data: https://api.weather.com/v2/pws/observations/current?numericPrecision=decimal&apiKey=6532d6454b8aa370768e63d6ba5a832e&units=m&stationId=IHOHENNE60&format=json
                            weatherunderground.0	2020-02-01 16:08:47.494	debug	(8465) Use new API Key 6532d6454b8aa370768e63d6ba5a832e
                            weatherunderground.0	2020-02-01 16:08:47.494	debug	(8465) Use New API
                            weatherunderground.0	2020-02-01 16:08:47.493	debug	(8465) location has not changed, reuse extracted URLs
                            weatherunderground.0	2020-02-01 16:08:47.492	debug	(8465) initialize Hourly Forecast Url: https://api.weather.com/v3/wx/forecast/hourly/15day?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=52.679%2C13.322&units=e&language=en-US&format=json
                            weatherunderground.0	2020-02-01 16:08:47.491	debug	(8465) initialize Daily Forecast Url: https://api.weather.com/v3/wx/forecast/daily/15day?apiKey=6532d6454b8aa370768e63d6ba5a832e&geocode=52.679%2C13.322&language=en-US&units=e&format=json
                            weatherunderground.0	2020-02-01 16:08:47.489	debug	(8465) initialize Current Observation url: https://api.weather.com/v2/pws/observations/current?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&stationId=IHOHENNE60&format=json
                            weatherunderground.0	2020-02-01 16:08:47.487	debug	(8465) initialize Web Key: 6532d6454b8aa370768e63d6ba5a832e
                            weatherunderground.0	2020-02-01 16:08:47.474	debug	(8465) initialize PWS Station Key: d8585d80376a429e
                            weatherunderground.0	2020-02-01 16:08:47.431	debug	(8465) init forecast objects
                            weatherunderground.0	2020-02-01 16:08:47.429	debug	(8465) init conditions objects
                            weatherunderground.0	2020-02-01 16:08:47.427	debug	(8465) on ready: DL true true true true
                            weatherunderground.0	2020-02-01 16:08:47.418	info	(8465) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v10.18.1
                            host.iobroker	2020-02-01 16:08:46.472	info	instance system.adapter.weatherunderground.0 started with pid 8465
                            Der Key ist okay. Hast du eine Idee?
                            M apollon77 2 Replies Last reply Reply Quote 0
                              MartyBr @MartyBr last edited by
                              Hier Infos zu meinem System:
                                PrinzEisenherz1 last edited by
                                Die haben was am Server gemacht. Da war nämlich eine Meldung das die API für 3 Tage nicht erreichbar ist.
                                Gruß Johnny
                                  MartyBr @PrinzEisenherz1 last edited by
                                  @PrinzEisenherz1
                                  Hallo Johnny, vielen Dank für die Antwort.
                                  Gruß aus Berlin
                                  Martin
                                  • integer63
                                    integer63 last edited by
                                    Nur zur Info (ist wahrscheinlich ein alter Hut): Nach den drei Tagen Maintenance musste ich bei meinem Skript (Hochladen von Daten zu WU) beim Aufruf von curl noch ein -k einfügen, da sich wohl etwas beim SSL Handling geändert hat (to allow curl to perform "insecure" SSL connections and transfers) - danach ging es wieder. Eventuell hat es ja etwas damit zu tun.
                                      apollon77 @MartyBr last edited by
                                      @MartyBr 204 heißt üblicherweise das keine neuen Daten vorliegen. Und ja es gab die letzten Tagen wohl mehrere Probleme.
                                      Mal schauen ob danach wieder alles im Eimer ist ... wir werden sehen.
                                        apollon77 @integer63 last edited by
                                        @integer63 ja es gab Meldungen in einem anderen Forum das die wohl jetzt ein ungültiges ssl Zertifikat haben whyever.
                                          MartyBr @apollon77 last edited by
                                          @apollon77 Danke für die Info.
                                          • Negalein
                                            @apollon77
                                            Ist das normal, dass in weatherunderground.0.currentObservationUrl eine andere Station und ApiKey aufscheint, als es im Adapter eingetragen ist? https://api.weather.com/v2/pws/observations/current?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&stationId=IGAMPE3&format=json
                                            Meine Station heißt IWERNS10 und nicht IGAMPE3 wie in currentObservationUrl
                                            Auch passt der Api-Key von currentObservationUrl nicht mit meinem Key.
                                            In weatherunderground.0.forecast.current sind die Werte meiner Station. Das passt.
                                            31.7k
                                            79.8k
                                            weatherunderground weatherunderground adapter
                                            2912
