    4. Test Adapter tr-064 v3.0.x
    • Chaot
      Chaot @apollon77 last edited by
      @apollon77 Auch bei mir der gleiche Fehler:
      host.ioBroker	2020-01-26 10:34:25.536	error	Caught by controller[0]: at Parser.emit (events.js:198:13)
      host.ioBroker	2020-01-26 10:34:25.535	error	Caught by controller[0]: at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:303:18)
      host.ioBroker	2020-01-26 10:34:25.535	error	Caught by controller[0]: at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
      host.ioBroker	2020-01-26 10:34:25.535	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
      host.ioBroker	2020-01-26 10:34:25.535	error	Caught by controller[0]: at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
      host.ioBroker	2020-01-26 10:34:25.535	error	Caught by controller[0]: at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
      host.ioBroker	2020-01-26 10:34:25.535	error	Caught by controller[0]: at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
      host.ioBroker	2020-01-26 10:34:25.535	error	Caught by controller[0]: at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
      host.ioBroker	2020-01-26 10:34:25.534	error	Caught by controller[0]: at Array.forEach (<anonymous>)
      host.ioBroker	2020-01-26 10:34:25.532	error	Caught by controller[0]: at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
      host.ioBroker	2020-01-26 10:34:25.532	error	Caught by controller[0]: ReferenceError: fndest is not defined
      tr-064.0	2020-01-26 10:34:24.489	error	at Parser.emit (events.js:198:13)
      tr-064.0	2020-01-26 10:34:24.489	error	at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:303:18)
      tr-064.0	2020-01-26 10:34:24.489	error	at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
      tr-064.0	2020-01-26 10:34:24.489	error	at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
      tr-064.0	2020-01-26 10:34:24.489	error	at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
      tr-064.0	2020-01-26 10:34:24.489	error	at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
      tr-064.0	2020-01-26 10:34:24.489	error	at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
      tr-064.0	2020-01-26 10:34:24.489	error	at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
      tr-064.0	2020-01-26 10:34:24.489	error	at Array.forEach (<anonymous>)
      tr-064.0	2020-01-26 10:34:24.489	error	at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
      tr-064.0	2020-01-26 10:34:24.489	error	(2897) ReferenceError: fndest is not defined
      tr-064.0	2020-01-26 10:34:24.487	error	(2897) uncaught exception: fndest is not defined
      wenn ich die Rufweiterleitungsoptionen aktiv habe.
      • vauvau07
        vauvau07 @apollon77 last edited by
        @apollon77
        Mit Rufweiterleitungsoptionen gleicher Fehler
          Prüfen und fixen wir. Danke
            Tom63 last edited by
            Update auf 3.1.1.
            Zunächst erst einmal vielen Dank, dass Ihr Euch diesem Adapter gewidmet habt.
            Ich habe meinen IOBroker auf einem Raspi 4 mit 4GB laufen. Bisher fiel der alter TR-064 sporadisch aus und somit war er mir nicht zuverlässig. Immer musste ich den npm SOEF im entsprechenden Ordner manuell nachinstallieren. Aber dann funktionierte er, vor allem die WLAN Erkennung.
            Nun kamen mehrere Adapterversionen hinter einander. Ich habe aus dem latest Stand diese als normale Updates installiert, schien auch alles super zu laufen, Geräte Erkennung usw. ohne Probleme.
            Gestern Abend dann stellte ich fest, dass mein Scribt zur Lichtsteuerung in Abhängigkeit zum WLAN des Fernsehers nicht mehr reagierte.
            Ich stellte fest, alle Geräte im Device bleiben Active true egale ob im WLAN angemeldet oder nicht.
            Auch den Adapter 3.1.0 deinstallieren funktionierte gestern nicht, es blieb im Scribt hängen.
            Heute stellte ich in diesem aktuellen Forum fest, hier bin ich nicht alleine.
            Habe zunächst die Instanz gelöscht, dann den ganzen Adapter und anschließend den IOBroker offline per Update aktualisiert. Jetzt war der aktuelle Adapter 3.1.1 als letzte Version unter latest auch gelistet.
            Ich habe ihn installiert, die Geräte erneut eingelesen.
            Die WLAN-Abschaltung reagiert sehr langsam - dachte erst gar nicht. Hatte mein Handy mal abgemeldet - keine Reaktion.
            Nun mal meine Feststellung als Hinweis für die Entwicklung...
            In meiner Fritzbox 7490 kann man ja alle Geräte unter Heimnetz anzeigen lassen. Hier wird unter
            aktive Verbindungen und ungenutzte Verbindungen unterschieden.
            Die Fritzbox schmeißt mein Handy erst nach ca. 10 Minuten aus der aktiven Verbindung in die ungenutzte Verbindung.
            Genau diesen Vorgang habt ihr in State active des Devices hinterlegt.
            Ist es möglich aus dem TR-064 zu dem Device auch die Eigenschaften des aktuellen Zustandes auszuwerten?
            Hier sind die Angaben zum aktuellen WLAN eingetragen, also welches Netz und wie hoch die Übertragungsrate ist.
            Bei LAN- Anschlüssen steht dort aber auch nichts weiter drin.
            Nur dieser Wert ist für die aktuelle Anbindung im WLAN der einzige schnelle Trigger beim Abmelden.
            Insgesamt bin ich jetzt aber erst mal sehr dankbar und hoffe der weiteren Entwicklung geholfen zu haben.
            Vielen Dank und macht weiter - es macht mir sogar Spaß beim ausprobieren !!!
              frankyboy73 last edited by
              Hi, 3.1.1 läuft bei mir, Zustände Callmonitor und Devices werden passend aktualisiert. Zu Rufweiterleitung kann ich nichts sagen, da ich die nicht verwende.
              Allerdings wurde mir die 3.1.1, auch mit Latest, nicht angezeigt, als verfügbare Version stand bei mir nur die 0.4.18.
              Ich habe die Instanz und den Adapter dann gelöscht und per GitHub Link die aktuelle Version eingespielt. Installierte Version ist jetzt 3.1.1, Verfügbare Version steht aber immer noch auf 0.4.18
              • FredF
                FredF Most Active Forum Testing @apollon77 last edited by FredF
                @apollon77 sagte in Test Adapter tr-064 v3.0.x:
                @FredF Bitte nochmal retesten!
                Update gemacht. Die device active states ändern sich nun.
                Die Instanz wird allerdings nicht grün.
                2020-01-26 12:09:19.022 - info: tr-064.0 (26474) starting. Version 3.1.1 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.18.1
                2020-01-26 12:09:19.494 - error: tr-064.0 (26474) uncaught exception: fndest is not defined
                2020-01-26 12:09:19.494 - error: tr-064.0 (26474) ReferenceError: fndest is not defined
                at Array.forEach ()
                at Parser. (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18)
                2020-01-26 12:09:19.998 - info: tr-064.0 (26474) terminating
                2020-01-26 12:09:19.999 - info: tr-064.0 (26474) Terminated (NO_ERROR): Without reason
                2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: ReferenceError: fndest is not defined
                2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
                2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at Array.forEach ()
                2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
                2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
                2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
                2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
                2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
                2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
                2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at Parser. (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18)
                2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at Parser.emit (events.js:198:13)
                2020-01-26 12:09:21.108 - info: host.ioBrokerLife instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
                2020-01-26 12:09:21.108 - info: host.ioBrokerLife Restart adapter system.adapter.tr-064.0 because enabled
                2020-01-26 12:09:51.128 - info: host.ioBrokerLife instance system.adapter.tr-064.0 started with pid 26845
                2020-01-26 12:09:52.417 - info: tr-064.0 (26845) starting. Version 3.1.1 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.18.1
                2020-01-26 12:09:52.928 - error: tr-064.0 (26845) uncaught exception: fndest is not defined
                2020-01-26 12:09:52.929 - error: tr-064.0 (26845) ReferenceError: fndest is not defined
                at Array.forEach ()
                2020-01-26 12:09:53.432 - info: tr-064.0 (26845) terminating
                2020-01-26 12:09:53.433 - info: tr-064.0 (26845) Terminated (NO_ERROR): Without reason
                2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: ReferenceError: fndest is not defined
                2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
                2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at Array.forEach ()
                2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
                2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
                2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
                2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
                2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
                2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
                2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at Parser. (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18)
                2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at Parser.emit (events.js:198:13)
                2020-01-26 12:09:53.955 - info: host.ioBrokerLife instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
                2020-01-26 12:09:53.955 - info: host.ioBrokerLife Restart adapter system.adapter.tr-064.0 because enabled
                Edit: komplett deinstalliert und neu installiert. Instanz grün 👍
                Edit2: Instanz nur grün wenn der Haken bei Rufweiterleitungsoptionen verwenden raus genommen wird
                • SBorg
                  @apollon77 Da hat sich wohl ein Fipptehler eingeschlichen. Lt. Log:
                  Sollte wohl" tr-064" heißen, nicht "tr-O64" 😉
                  • X
                    Xyolyp last edited by
                    Version 3.1.1 startet bei mir leider nicht.
                    JS Controller 2.2.8
                      sigi234 Forum Testing Most Active @apollon77 last edited by
                      @apollon77
                      3.1.1 läuft. Adapter Grün, kein Fehler im Log, DP tr-064.0.callmonitor.ringing funktioniert. Rufumleitung nicht aktiviert.
                        apollon77 @SBorg last edited by apollon77
                        @SBorg ne kein Schreibfehler. Eine lib heißt so
                          apollon77 @Tom63 last edited by
                          @Tom63 bitte GitHub issue als Feature request anlegen. War schon so mehr so mit dem verzögerten. Was steht denn bei der verbindungsqualität wenn das Handy weg ist?
                          • SBorg
                            SBorg Forum Testing Most Active @apollon77 last edited by SBorg
                            Habe ich eben auch gemerkt ^^
                            Er läuft aber nicht:
                            host.Ubuntu	2020-01-26 13:04:02.512	error	Caught by controller[0]: Error: Cannot find module './tr-064'
                            Dort liegt kein tr-O64. Ein Verzeichnis höher schon.
                            EDIT Der Code-Tag macht doch tatsächlich aus O64 ein 064 😞
                            • smarteule
                              smarteule last edited by
                              ich bin zwar Anfänger, aber ich möchte Euch mitteilen, dass ich mit dem tr064 ebenfalls Probleme bei der Einstellung bzw. Hakensetzung "Rufweiterleitung verwenden" habe. Wenn der Haken raus ist, bleibt die Inatnz grün. Ist er drin, bleibt die Instanz rot und im Log erscheint folgende Meldung:
                              tr064 v 3.1.1
                              js.controller v 2.2.8
                              node js v 10.18.1
                              npm v 6.13.4
                                sigi234 Forum Testing Most Active @smarteule last edited by
                                @smarteule sagte in Test Adapter tr-064 v3.0.x:
                                • JB_Sullivan
                                  JB_Sullivan last edited by JB_Sullivan
                                  Bei mir verbindet sich der Adapter nach dem Updaten von 3.1.0 auf 3.1.1 nicht mehr. Die Instanz flasht zwar kurzeitig grün auf, geht dann aber auf rot. (persönliche Informationen sind ge-X-t)
                                  host.GLT	2020-01-26 14:26:40.028	info	Restart adapter system.adapter.tr-064.0 because enabled
                                  host.GLT	2020-01-26 14:26:40.028	info	instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
                                  host.GLT	2020-01-26 14:26:40.028	error	Caught by controller[0]: at Parser.emit (events.js:198:13)
                                  host.GLT	2020-01-26 14:26:40.028	error	Caught by controller[0]: at Parser.<anonymous> (C:\iobroker\GLT\node_modules\iobroker.tr-064\node_modules\xml2js\lib\parser.js:304:18)
                                  host.GLT	2020-01-26 14:26:40.028	error	Caught by controller[0]: at C:\iobroker\GLT\node_modules\iobroker.tr-064\node_modules\tr-O64\lib\Service.js:267:17
                                  host.GLT	2020-01-26 14:26:40.028	error	Caught by controller[0]: at C:\iobroker\GLT\node_modules\iobroker.tr-064\main.js:82:28
                                  host.GLT	2020-01-26 14:26:40.028	error	Caught by controller[0]: at tr064Client.init.err (C:\iobroker\GLT\node_modules\iobroker.tr-064\main.js:1144:27)
                                  host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: at new Deflections (C:\iobroker\GLT\node_modules\iobroker.tr-064\lib\deflections.js:21:10)
                                  host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: at Deflections.init (C:\iobroker\GLT\node_modules\iobroker.tr-064\lib\deflections.js:156:17)
                                  host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: at getFunctions (C:\iobroker\GLT\node_modules\iobroker.tr-064\lib\deflections.js:149:12)
                                  host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: at Array.forEach (<anonymous>)
                                  host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: at ar.forEach.fn (C:\iobroker\GLT\node_modules\iobroker.tr-064\lib\deflections.js:149:37)
                                  host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: ReferenceError: fndest is not defined
                                  tr-064.0	2020-01-26 14:26:39.822	debug	(3364) Phonebook 0: {"NewPhonebookName":"Telefonbuch","NewPhonebookExtraID":"","NewPhonebookURL":"http://xx.xxx.xxx.xxx:49000/phonebook.lua?sid=xxxxxxxxxxx&pbid=0"} / err=null
                                  tr-064.0	2020-01-26 14:26:39.799	debug	(3364) Phonebook.read: NewPhonebookList=0
                                  tr-064.0	2020-01-26 14:26:39.782	debug	(3364) Phonebook.read
                                  tr-064.0	2020-01-26 14:26:39.781	debug	(3364) getVoIPCommonAreaCode: 0xxxx
                                  tr-064.0	2020-01-26 14:26:39.766	debug	(3364) getVoIPCommonCountryCode: 0049
                                  tr-064.0	2020-01-26 14:26:39.750	debug	(3364) forEachConfiguredDevice: i=3 xxxxxx active=0
                                  tr-064.0	2020-01-26 14:26:39.713	debug	(3364) forEachConfiguredDevice: i=2 xxxxxx active=1
                                  tr-064.0	2020-01-26 14:26:39.682	debug	(3364) forEachConfiguredDevice: i=1 xxxxxx active=1
                                  tr-064.0	2020-01-26 14:26:39.594	debug	(3364) forEachConfiguredDevice: i=0 xxxxxx active=1
                                  Wie @FredF oben geschrieben hat - bei mir das gleiche
                                  "Edit2: Instanz nur grün wenn der Haken bei Rufweiterleitungsoptionen verwenden raus genommen wird"
                                    Mit der 3.1.2 die gerade auf GitHub und npm gelandet ist (und bald im Ltest auftauchen sollte) müsste das Rufumleitungsthema wieder gehen
                                    vauvau07 1 Reply Last reply Reply Quote 1
                                    • vauvau07
                                      3.1.2
                                      bei mir jetzt alles im grünen Bereich (v3.1.2)
                                        AM besten gleich auf die 3.1.3 gehen ... hab noch was gefunden und gefixt
                                        J FredF 2 Replies Last reply Reply Quote 2
                                          Jan1 @apollon77 last edited by
                                          @apollon77
                                          läuft👍
                                            Hardy6 last edited by
                                            Mein Ergebnis von: TR-064 -> Update 3.1.3 : noch mit Fehlern
                                            $ ./iobroker upgrade tr-064
                                            Update tr-064 from @3.1.1 to @3.1.3
                                            NPM version: 6.11.3
                                            npm install iobroker.tr-064@3.1.3 --loglevel error --prefix "C:/Program Files/iobroker/SmartHome" (System call)
                                            npm
                                             ERR! code ENOENTnpm ERR! syscall renamenpm ERR! path C:\Program Files\iobroker\SmartHome\node_modules\.staging\yargs-c393c15bnpm ERR! dest C:\Program Files\iobroker\SmartHome\node_modules\yargsnpm ERR! errno -4058
                                            npm ERR!
                                             enoent ENOENT: no such file or directory, rename 'C:\Program Files\iobroker\SmartHome\node_modules\.staging\yargs-c393c15b' -> 'C:\Program Files\iobroker\SmartHome\node_modules\yargs'npm ERR! enoent This is related to npm not being able to find a file.npm ERR! enoent
                                            npm ERR! A complete log of this run can be found in:npm ERR!     C:\Program Files\iobroker\SmartHome\env\npm-cache\_logs\2020-01-26T14_30_53_253Z-debug.log
                                            ERROR: host.IT-SERVER(SmartHome) Cannot install iobroker.tr-064@3.1.3: 4294963238
                                            ERROR: process exited with code 25
                                            Ich habe alles soweit auf aktuellen Stand (lastest), ioBroker 2.2.8
                                            bis auf
                                            Node.js 10.17
                                            Admin 3.6.12
                                            weil beim letzten update Versuch nix mehr ging(jedenfalls für mich als Neueinstiger war das nicht mehr ohne Neuinstallation des kompletten ioBroker in Funktion zu bringen.
                                            Gruß,...
                                            Hartmut
                                            1.0k
                                            tr-064
                                            46
                                            158
                                            18092
