    4. Test Adapter tr-064 v3.0.x
    • FredF
      FredF Most Active Forum Testing @apollon77 last edited by FredF
      @apollon77 sagte in Test Adapter tr-064 v3.0.x:
      @FredF Bitte nochmal retesten!
      Update gemacht. Die device active states ändern sich nun.
      Die Instanz wird allerdings nicht grün.
      2020-01-26 12:09:19.022 - info: tr-064.0 (26474) starting. Version 3.1.1 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.18.1
      2020-01-26 12:09:19.494 - error: tr-064.0 (26474) uncaught exception: fndest is not defined
      2020-01-26 12:09:19.494 - error: tr-064.0 (26474) ReferenceError: fndest is not defined
      at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
      at Array.forEach ()
      at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
      at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
      at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
      at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
      at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
      at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
      at Parser. (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18)
      at Parser.emit (events.js:198:13)
      2020-01-26 12:09:19.998 - info: tr-064.0 (26474) terminating
      2020-01-26 12:09:19.999 - info: tr-064.0 (26474) Terminated (NO_ERROR): Without reason
      2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: ReferenceError: fndest is not defined
      2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
      2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at Array.forEach ()
      2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
      2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
      2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
      2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
      2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
      2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
      2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at Parser. (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18)
      2020-01-26 12:09:21.107 - error: host.ioBrokerLife Caught by controller[0]: at Parser.emit (events.js:198:13)
      2020-01-26 12:09:21.108 - info: host.ioBrokerLife instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
      2020-01-26 12:09:21.108 - info: host.ioBrokerLife Restart adapter system.adapter.tr-064.0 because enabled
      2020-01-26 12:09:51.128 - info: host.ioBrokerLife instance system.adapter.tr-064.0 started with pid 26845
      2020-01-26 12:09:52.417 - info: tr-064.0 (26845) starting. Version 3.1.1 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.18.1
      2020-01-26 12:09:52.928 - error: tr-064.0 (26845) uncaught exception: fndest is not defined
      2020-01-26 12:09:52.929 - error: tr-064.0 (26845) ReferenceError: fndest is not defined
      at Array.forEach ()
      2020-01-26 12:09:53.432 - info: tr-064.0 (26845) terminating
      2020-01-26 12:09:53.433 - info: tr-064.0 (26845) Terminated (NO_ERROR): Without reason
      2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: ReferenceError: fndest is not defined
      2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at ar.forEach.fn (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:37)
      2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at Array.forEach ()
      2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at getFunctions (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:149:12)
      2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at Deflections.init (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:156:17)
      2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at new Deflections (/opt/iobroker/node_modules/iobroker.tr-064/lib/deflections.js:21:10)
      2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at tr064Client.init.err (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1144:27)
      2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064/main.js:82:28
      2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
      2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at Parser. (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18)
      2020-01-26 12:09:53.955 - error: host.ioBrokerLife Caught by controller[0]: at Parser.emit (events.js:198:13)
      2020-01-26 12:09:53.955 - info: host.ioBrokerLife instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
      2020-01-26 12:09:53.955 - info: host.ioBrokerLife Restart adapter system.adapter.tr-064.0 because enabled
      Edit: komplett deinstalliert und neu installiert. Instanz grün 👍
      Edit2: Instanz nur grün wenn der Haken bei Rufweiterleitungsoptionen verwenden raus genommen wird
      • SBorg
        @apollon77 Da hat sich wohl ein Fipptehler eingeschlichen. Lt. Log:
        Sollte wohl" tr-064" heißen, nicht "tr-O64" 😉
        • X
          Xyolyp last edited by
          Version 3.1.1 startet bei mir leider nicht.
          JS Controller 2.2.8
            sigi234 Forum Testing Most Active @apollon77 last edited by
            @apollon77
            3.1.1 läuft. Adapter Grün, kein Fehler im Log, DP tr-064.0.callmonitor.ringing funktioniert. Rufumleitung nicht aktiviert.
              apollon77 @SBorg last edited by apollon77
              @SBorg ne kein Schreibfehler. Eine lib heißt so
                apollon77 @Tom63 last edited by
                @Tom63 bitte GitHub issue als Feature request anlegen. War schon so mehr so mit dem verzögerten. Was steht denn bei der verbindungsqualität wenn das Handy weg ist?
                • SBorg
                  SBorg Forum Testing Most Active @apollon77 last edited by SBorg
                  Habe ich eben auch gemerkt ^^
                  Er läuft aber nicht:
                  host.Ubuntu	2020-01-26 13:04:02.512	error	Caught by controller[0]: Error: Cannot find module './tr-064'
                  Dort liegt kein tr-O64. Ein Verzeichnis höher schon.
                  EDIT Der Code-Tag macht doch tatsächlich aus O64 ein 064 😞
                  • smarteule
                    smarteule last edited by
                    ich bin zwar Anfänger, aber ich möchte Euch mitteilen, dass ich mit dem tr064 ebenfalls Probleme bei der Einstellung bzw. Hakensetzung "Rufweiterleitung verwenden" habe. Wenn der Haken raus ist, bleibt die Inatnz grün. Ist er drin, bleibt die Instanz rot und im Log erscheint folgende Meldung:
                    tr064 v 3.1.1
                    js.controller v 2.2.8
                    node js v 10.18.1
                    npm v 6.13.4
                      sigi234 Forum Testing Most Active @smarteule last edited by
                      @smarteule sagte in Test Adapter tr-064 v3.0.x:
                      Prüfen und fixen wir. Danke
                      • JB_Sullivan
                        JB_Sullivan last edited by JB_Sullivan
                        Bei mir verbindet sich der Adapter nach dem Updaten von 3.1.0 auf 3.1.1 nicht mehr. Die Instanz flasht zwar kurzeitig grün auf, geht dann aber auf rot. (persönliche Informationen sind ge-X-t)
                        host.GLT	2020-01-26 14:26:40.028	info	Restart adapter system.adapter.tr-064.0 because enabled
                        host.GLT	2020-01-26 14:26:40.028	info	instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
                        host.GLT	2020-01-26 14:26:40.028	error	Caught by controller[0]: at Parser.emit (events.js:198:13)
                        host.GLT	2020-01-26 14:26:40.028	error	Caught by controller[0]: at Parser.<anonymous> (C:\iobroker\GLT\node_modules\iobroker.tr-064\node_modules\xml2js\lib\parser.js:304:18)
                        host.GLT	2020-01-26 14:26:40.028	error	Caught by controller[0]: at C:\iobroker\GLT\node_modules\iobroker.tr-064\node_modules\tr-O64\lib\Service.js:267:17
                        host.GLT	2020-01-26 14:26:40.028	error	Caught by controller[0]: at C:\iobroker\GLT\node_modules\iobroker.tr-064\main.js:82:28
                        host.GLT	2020-01-26 14:26:40.028	error	Caught by controller[0]: at tr064Client.init.err (C:\iobroker\GLT\node_modules\iobroker.tr-064\main.js:1144:27)
                        host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: at new Deflections (C:\iobroker\GLT\node_modules\iobroker.tr-064\lib\deflections.js:21:10)
                        host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: at Deflections.init (C:\iobroker\GLT\node_modules\iobroker.tr-064\lib\deflections.js:156:17)
                        host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: at getFunctions (C:\iobroker\GLT\node_modules\iobroker.tr-064\lib\deflections.js:149:12)
                        host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: at Array.forEach (<anonymous>)
                        host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: at ar.forEach.fn (C:\iobroker\GLT\node_modules\iobroker.tr-064\lib\deflections.js:149:37)
                        host.GLT	2020-01-26 14:26:40.027	error	Caught by controller[0]: ReferenceError: fndest is not defined
                        tr-064.0	2020-01-26 14:26:39.822	debug	(3364) Phonebook 0: {"NewPhonebookName":"Telefonbuch","NewPhonebookExtraID":"","NewPhonebookURL":"http://xx.xxx.xxx.xxx:49000/phonebook.lua?sid=xxxxxxxxxxx&pbid=0"} / err=null
                        tr-064.0	2020-01-26 14:26:39.799	debug	(3364) Phonebook.read: NewPhonebookList=0
                        tr-064.0	2020-01-26 14:26:39.782	debug	(3364) Phonebook.read
                        tr-064.0	2020-01-26 14:26:39.781	debug	(3364) getVoIPCommonAreaCode: 0xxxx
                        tr-064.0	2020-01-26 14:26:39.766	debug	(3364) getVoIPCommonCountryCode: 0049
                        tr-064.0	2020-01-26 14:26:39.750	debug	(3364) forEachConfiguredDevice: i=3 xxxxxx active=0
                        tr-064.0	2020-01-26 14:26:39.713	debug	(3364) forEachConfiguredDevice: i=2 xxxxxx active=1
                        tr-064.0	2020-01-26 14:26:39.682	debug	(3364) forEachConfiguredDevice: i=1 xxxxxx active=1
                        tr-064.0	2020-01-26 14:26:39.594	debug	(3364) forEachConfiguredDevice: i=0 xxxxxx active=1
                        Wie @FredF oben geschrieben hat - bei mir das gleiche
                        "Edit2: Instanz nur grün wenn der Haken bei Rufweiterleitungsoptionen verwenden raus genommen wird"
                          Mit der 3.1.2 die gerade auf GitHub und npm gelandet ist (und bald im Ltest auftauchen sollte) müsste das Rufumleitungsthema wieder gehen
                          vauvau07 1 Reply Last reply Reply Quote 1
                          • vauvau07
                            vauvau07 @apollon77 last edited by
                            3.1.2
                            bei mir jetzt alles im grünen Bereich (v3.1.2)
                              AM besten gleich auf die 3.1.3 gehen ... hab noch was gefunden und gefixt
                              J FredF 2 Replies Last reply Reply Quote 2
                                Jan1 @apollon77 last edited by
                                @apollon77
                                läuft👍
                                  Hardy6 last edited by
                                  Mein Ergebnis von: TR-064 -> Update 3.1.3 : noch mit Fehlern
                                  $ ./iobroker upgrade tr-064
                                  Update tr-064 from @3.1.1 to @3.1.3
                                  NPM version: 6.11.3
                                  npm install iobroker.tr-064@3.1.3 --loglevel error --prefix "C:/Program Files/iobroker/SmartHome" (System call)
                                  npm
                                   ERR! code ENOENTnpm ERR! syscall renamenpm ERR! path C:\Program Files\iobroker\SmartHome\node_modules\.staging\yargs-c393c15bnpm ERR! dest C:\Program Files\iobroker\SmartHome\node_modules\yargsnpm ERR! errno -4058
                                  npm ERR!
                                   enoent ENOENT: no such file or directory, rename 'C:\Program Files\iobroker\SmartHome\node_modules\.staging\yargs-c393c15b' -> 'C:\Program Files\iobroker\SmartHome\node_modules\yargs'npm ERR! enoent This is related to npm not being able to find a file.npm ERR! enoent
                                  npm ERR! A complete log of this run can be found in:npm ERR!     C:\Program Files\iobroker\SmartHome\env\npm-cache\_logs\2020-01-26T14_30_53_253Z-debug.log
                                  ERROR: host.IT-SERVER(SmartHome) Cannot install iobroker.tr-064@3.1.3: 4294963238
                                  ERROR: process exited with code 25
                                  Ich habe alles soweit auf aktuellen Stand (lastest), ioBroker 2.2.8
                                  bis auf
                                  Node.js 10.17
                                  Admin 3.6.12
                                  weil beim letzten update Versuch nix mehr ging(jedenfalls für mich als Neueinstiger war das nicht mehr ohne Neuinstallation des kompletten ioBroker in Funktion zu bringen.
                                  Gruß,...
                                  Hartmut
                                    apollon77 @Hardy6 last edited by
                                    @Hardy6 Lass mal den Installation Fixer laufen bitte. Der Fehler hat mit dem Adater nix zu tun. Dein npm meckert wegen was ...
                                    • FredF
                                      @apollon77
                                      läuft
                                        Hardy6 @apollon77 last edited by
                                        @apollon77 Wie? iobroker fix ? / vorher stoppen nehme ich an
                                          A Former User @apollon77 last edited by
                                          @apollon77 3.1.3 benimmt sich unauffällig bis jetzt 😁👍👍
                                          Dankeschön 🙂
                                          Homer.J. 1 Reply Last reply Reply Quote 0
                                          • Homer.J.
                                            Homer.J. @Guest last edited by Homer.J.
                                            Bei mir läuft jetzt die Anwesenheit wieder nicht mehr.
                                            Kommando zurück Datenpunkte mal alle gelöscht und funktioniert. 😊
                                            tr-064
                                            46
                                            158
                                            18093
