    4. can't find python
    UNSOLVED can't find python
    • bahnuhr
      bahnuhr Forum Testing Most Active @sigi234 last edited by
      @sigi234 sagte in can't find python:
      @bahnuhr
      Windows Version installieren.
      https://www.python.org/downloads/release/python-2710/
      Habs trotzdem mal installiert, keine Veränderung.
      Weiterhin folgende Fehlermeldung!
      $ ./iobroker add sql  --host HP-Prodesk-400
      NPM version: 6.4.1
      npm install iobroker.sql@1.9.4 --loglevel error --prefix "C:/iobroker" (System call)
      gyp
       ERR! configure error gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp ERR! stack     at PythonFinder.failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:484:19)gyp ERR! stack     at PythonFinder.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:509:16)gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:284:29gyp ERR! stack     at FSReqWrap.oncomplete (fs.js:153:21)
      gyp ERR! System Windows_NT 10.0.18363gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\iobroker\node_modules\iobroker.sql\node_modules\mmmagicgyp ERR! node -v v10.15.3
      gyp ERR! node-gyp -v v3.8.0gyp ERR!
       not ok
      npm
       ERR! code ELIFECYCLEnpm ERR! errno 1
      npm
       ERR! mmmagic@0.5.3 install: `node-gyp rebuild`npm ERR! Exit status 1
      npm ERR!
       npm
      ERR! Failed at the mmmagic@0.5.3 install script.npm
       ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:npm ERR!     C:\Windows\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2020-01-26T07_26_25_684Z-debug.log
      ERROR: host.HP-Prodesk-400 Cannot install iobroker.sql@1.9.4: 1
      ERROR: process exited with code 25
      • bahnuhr
        habe es auch mit verschiedenen node Versionen (8.15, 10.18, etc) probiert.
        Klappt nicht.
        Noch jemand eine Idee ?
        • SBorg
          SBorg Forum Testing Most Active @bahnuhr last edited by SBorg
          @bahnuhr Taucht Python denn auch im Pfad auf? DOS-Eingabe: path
          Falls nicht, versuche mal:
          • WIN + Pause
          • Erweiterte Systemeinstellungen
          • Umgebungsvariablen
          • bei "Systemvariablen" Path anklicken + bearbeiten
          • C:\Users\Dieter.windows-build-tools\python27\python.exe hinzufügen
          Soweit ich mich noch erinnern kann übernimmt er "Systemvariablen" nur beim Start? --> reboot
          • bahnuhr
            bahnuhr Forum Testing Most Active @SBorg last edited by
            @SBorg sagte in can't find python:
            • WIN + Pause
            Bei Win+Pause tut sich gar nichts.
            In den Umgebungsvariablen hab ich dieses:
            Sieht doch ok aus.
            Noch ne Idee ?
            • AlCalzone
              AlCalzone Developer @bahnuhr last edited by
              @bahnuhr sagte in can't find python:
              Noch ne Idee ?
              Im ioBroker-Ordner eine Datei .npmrc anlegen, falls sie nicht schon existiert und folgende Zeile einfügen:
              python=C:\Users\Dieter.windows-build-tools\python27\python.exe
              Klappt so zumindest auf FreeBSD, daher schätze ich, dass es auf Windows auch klappt.
              Aber sollte das nicht auch ohne manuelles Eingreifen funktionieren? @Stabilostick
              bahnuhr 2 Replies Last reply Reply Quote 0
              • bahnuhr
                bahnuhr Forum Testing Most Active @AlCalzone last edited by bahnuhr
                @AlCalzone sagte in can't find python:
                Das dachte ich auch.
                Und der Hinweis kam auch nur bei der Installation von "sql". Die anderen Adapter liefen einwandfrei durch.
                Wäre schön wenn wir dies lösen könnte.
                @Homoran
                @apollon77
                @AlCalzone
                @Stabilostick
                Würde auch anbieten, dass ich die Beschreibung "manuelle Installation" auf iobroker.de mal überarbeiten könnte (wenn gewünscht). Denn diese funktioniert ja nicht.
                • bahnuhr
                  Und wie ihr hier seht:
                  https://forum.iobroker.net/topic/29244/iob-auf-win-10-manuelle-installation/4
                  klappt die manuelle Installation bei node 10.18. und npm 6.13 nicht mehr.
                  Es kommt da ständig der Hinweis "semver".
                  Vielleicht könnten wir auch dies lösen.
                  Würde mich als Tester anbieten.
                  apollon77 AlCalzone 2 Replies Last reply Reply Quote 0
                    apollon77 @bahnuhr last edited by
                    Sehr gern!
                    Du kannst es auf https://github.com/ioBroker/ioBroker.docs/blob/master/docs/de/install/windows.md (ist es das was du meinst) bzw über den Edit link auf der Webseite editieren und als PR einreichen 🙂
                      @bahnuhr Ich habe dort mal was geantwortet. Das hat mit ioBrokewr nix zu tun ... das ist npm magie und sowas 😞
                      • bahnuhr
                        bahnuhr Forum Testing Most Active @apollon77 last edited by
                        @apollon77 sagte in can't find python:
                        --logevel=error
                        Müsste dies nicht "loglevel" heißen.
                          @bahnuhr Ja, sollte es 🙂
                          • AlCalzone
                            @bahnuhr Meinen Vorschlag mal probiert?
                            • bahnuhr
                              Klappt erst heute abend.
                              Melde mich dann.
                              • bahnuhr
                                Noch ne Idee ?
                                So, Rückinfo von mir:
                                Datei war auf meinem Win10 Rechner nicht da (auf Win7 schon ?!)
                                Dienst gestoppt.
                                Datei angelegt und Zeile eingefügt (hinter Dieter noch \ eingefügt).
                                Dienst gestartet.
                                Browser geöffnet und versucht sql zu installieren. Dienst wurde gestoppt (warum auch immer).
                                Nochmal probiert (Dienst gestartet und versucht sql zu installieren).
                                Das hat dann geklappt. Error 0
                                Dann versucht sql mal zu löschen.
                                Dies klappt dann nicht (Kreis dreht durch; dienst ist aber noch aktiv).
                                Fazit:
                                Installation hat dann geklappt. Löschen geht aber nicht mehr -> scheint irgendwas noch zu stören.
                                Lösche nun mal die komplette FP und installieren Win10 neu.
                                mfg
                                • bahnuhr
                                  So:
                                  Win10 Pro neu aufgespielt
                                  Node 10.15.3 und npm 6.4.1 drauf.
                                  cmd als admin ausgefuhrt.
                                  windows-build-tools
                                  iobroker installiert
                                  Dienst gestartet.
                                  iob läuft
                                  browser mit 8081 aufgerufen.
                                  versuch sql zu installieren.
                                  -> klappt nicht - wieder fehler mit python !
                                  Datei erstellt: .npmsc
                                  PC neu gestartet
                                  klappt
                                  Versuch sql zu deinstallieren.
                                  blauer Balken läuft und läuft. Fenster schließt sich nicht. Meldung mit error 0 kommt nicht.
                                  Irgendwas hängt da.
                                  Browser neu geladen. Sql ist weg.
                                  Fazit:
                                  Installieren ging dann.
                                  löschen hat nicht geklappt.
                                  Wie schon erwähnt wäre es schön wenn das manuelle installieren klappen würde.
                                  (oder stabilo.. bekommt dies hin, dass multihost als data eingelesen werden können).
                                  mfg
                                  Dieter
                                  • AlCalzone
                                    Welcher JS-Controller + Admin?
                                    • bahnuhr
                                      ganz neu installiert mit:
                                      etc.
                                      js-controller: 2.2.8 (ist das nicht zu hoch ?, wurde aber installiert mit npm...)
                                      admin: 3.7.8
                                      • AlCalzone
                                        @bahnuhr Das sind seit heute die latest-Versionen. Kannst du andere Adapter löschen - sprich, hängt es nur bei sql?
                                        • bahnuhr
                                          Ja, andere gehen einwandfrei (probiert eben mit vis.0 und vis-bars)
                                          Diese brauchen aber auch nicht python, oder ?
                                          • AlCalzone
                                            @bahnuhr Nein, aber beim Löschen sollte auch sql kein Python brauchen
                                            python sql windows
                                            1697
