    3. Entwicklung
    4. lgtv Adapter zur Steuerung von LG WebOS SmartTVs
    • marcuskl
      marcuskl @sigi234 last edited by
      @sigi234
      Nutze zur Visualisierung Lovelace und da die Button Card
        sigi234 Forum Testing Most Active @marcuskl last edited by
        @marcuskl sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
        @sigi234
        Teste mal das Widget:
        [{"tpl":"tplIconStateBool","data":{"oid":"lgtv.0.remote.1","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"invert_icon":false,"false_text":"","imageHeight":"103","true_text":"","click_value":"true","false_src":"/icons-mfd-svg/edit_numeric_1.svg","true_src":"/icons-mfd-svg/edit_numeric_1.svg"},"style":{"left":"497px","top":"110px","width":"60px","height":"60px","z-index":"1","font-size":"","color":"#d7cec1","text-align":"","text-shadow":"","background-color":"#000000","background":"transparent","border-width":"1px","border-style":"solid","border-color":"#0045db","border-radius":"5px","font-family":"RobotoCondensed-Light","box-shadow":"2px 2px 3px rgba(20, 20, 20, 50)","margin-left":"","padding-left":""},"widgetSet":"jqui"}]
        marcuskl 1 Reply Last reply Reply Quote 0
        • marcuskl
          @sigi234 Ich nutze aber nicht Vis sonder Lovelace
            sonder Lovelace
            Ah ,ok dann weis ich es nicht.
              sigi234 Forum Testing Most Active @SchuetzeSchulz last edited by sigi234
              @SchuetzeSchulz
              Update V 1.1.2
              EDIT: Geht jetzt, einfach noch mal installiert.
              $ ./iobroker upgrade lgtv
              Update lgtv from @1.1.1 to @1.1.2
              NPM version: 6.9.0
              npm install iobroker.lgtv@1.1.2 --loglevel error --prefix "C:/Program Files/iobroker/Test" (System call)
              npm
               ERR! path C:\Program Files\iobroker\Test\node_modules\iobroker.lgtv\node_modules\.websocket.DELETE\build\Release\validation.nodenpm ERR! code EPERMnpm ERR! errno -4048npm ERR! syscall unlink
              npm
               ERR! Error: EPERM: operation not permitted, unlink 'C:\Program Files\iobroker\Test\node_modules\iobroker.lgtv\node_modules\.websocket.DELETE\build\Release\validation.node'npm ERR!  { [Error: EPERM: operation not permitted, unlink 'C:\Program Files\iobroker\Test\node_modules\iobroker.lgtv\node_modules\.websocket.DELETE\build\Release\validation.node']npm ERR!   cause:npm ERR!    { Error: EPERM: operation not permitted, unlink 'C:\Program Files\iobroker\Test\node_modules\iobroker.lgtv\node_modules\.websocket.DELETE\build\Release\validation.node'npm ERR!      errno: -4048,npm ERR!      code: 'EPERM',npm ERR!      syscall: 'unlink',npm ERR!
                    path:npm ERR!       'C:\\Program Files\\iobroker\\Test\\node_modules\\iobroker.lgtv\\node_modules\\.websocket.DELETE\\build\\Release\\validation.node' },
              npm
              ERR!   stack:npm ERR!    'Error: EPERM: operation not permitted, unlink \'C:\\Program Files\\iobroker\\Test\\node_modules\\iobroker.lgtv\\node_modules\\.websocket.DELETE\\build\\Release\\validation.node\'',npm ERR!   errno: -4048,npm
              ERR!   code: 'EPERM',npm ERR!   syscall: 'unlink',npm ERR!   path:npm ERR!    'C:\\Program Files\\iobroker\\Test\\node_modules\\iobroker.lgtv\\node_modules\\.websocket.DELETE\\build\\Release\\validation.node',npm ERR!
                 parent: 'iobroker.lgtv' }npm ERR! npm ERR!
               The operation was rejected by your operating system.npm ERR! It's possible that the file was already in use (by a text editor or antivirus),npm ERR! or that you lack permissions to access it.npm ERR!
              npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator (though this is not recommended).
              npm ERR! A complete log of this run can be found in:npm
              ERR!
                   C:\Program Files\iobroker\Test\env\npm-cache\_logs\2019-12-09T19_50_32_212Z-debug.log
              ERROR: host.Medion(Test) Cannot install iobroker.lgtv@1.1.2: 4294963248
              ERROR: process exited with code 25
                mikiline @deta last edited by mikiline
                @deta sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                Hallo, ich hab da das Problem, das obwohl ich den LG sage erlaube Zugriff, kommt dann immer wieder eine neue Anfrage.
                Der LG ist per LAN im Netzwerk, genauso wie der Raspi, wo ioBroker drauf ist.
                Woran könnte es liegen?
                cu Deta
                Habe genau das gleiche Problem.
                Gibt es denn hierzu eine Lösung?
                Danke und Grüsse
                Edit: scheint nach Installation des Adapters von GitHub zu funktionieren (vers. 1.1.3)
                  RandyAndy last edited by
                  ich würde gerne mit dem Adapter auh Einstellungen ändern.
                  Ich bin mir sicher das das irgendwie mit dem setstate... geht, aber wie.
                  Ich würde nämlich gerne die Sprache zwischen Deutsch und English auswählen können, bekomme es aber nicht hin.
                  Ich habe versucht das über keys zu machen, das ist aber nicht stabil und manchmal funktioniert es, meistens aber nicht.
                  Für jeden Tip wäre ich dankbar.
                  Andreas
                    R1Snake last edited by
                    Kann man sich bei dem Popup auch Bilder anzeigen lassen?
                    S arteck 2 Replies Last reply Reply Quote 0
                      SchuetzeSchulz @RandyAndy last edited by
                      @RandyAndy
                      Hi, das geht leider nicht 😞
                        SchuetzeSchulz @R1Snake last edited by
                        @R1Snake sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                        Das könnte klappen.
                        Einfach mal ein Bild mittels <img> HTML-Tag versuchen einzubinden.
                          arteck Developer Most Active @R1Snake last edited by
                          ja das geht
                            Habs gerade mal ausprobiert mit einem Bild aus Google.
                            <img>https://imgr1.auto-motor-und-sport.de/VW-e-Golf-gallerySquareTeaser-d749540f-1199274.jpg</img>
                            Leider hat der Fernseher nur die URL angezeigt
                            • Jey Cee
                              Jey Cee Developer @R1Snake last edited by
                              @R1Snake kein wunder ist ja auch falsch.
                              <img src="url">
                              Nur url ersetzen die " müssen bleiben.
                                RandyAndy @SchuetzeSchulz last edited by
                                @SchuetzeSchulz
                                Schade, gibt es eigentlich irgend eine Beschreibung der API (Link oder ähnliches).
                                ANdreas
                                  sigi234 Forum Testing Most Active @Jey Cee last edited by sigi234
                                  @Jey-Cee sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                                  <img src="url">
                                  Getestet, geht nicht. Gib das so in ein Input-Widget ein:
                                  <img src="http://192.168.178.20:8107/vis.0/Wettericons/Wetter Hd/3.pngl">
                                  • Jey Cee
                                    Jey Cee Developer @sigi234 last edited by
                                    @sigi234 ach beim LG muss mann noch die Bildgröße angeben und es gab eine Beschränkung der größe.
                                    <img src="url" width="100px" height="100px">
                                      @Jey-Cee said in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                                      Ausprobiert und funktioniert. Danke für die schnelle Hilfe.
                                      Eine kleine Sache noch. Wenn der TV ausgeschaltet ist, dann ist der Adapter gelb, da der Fernseher nicht erreichbar ist. Wenn ich den TV einschalte bleibt der Adapter gelb obwohl die Einstellung jede Sekunde nach dem TV "sucht". Wenn ich den Adapter neustarte ist er direkt grün.
                                      Muss ich noch irgendwas einstellen? Kann man im Tv einstellen das er immer erreichbar ist?
                                        Geht, und wenn ich vom Pc ein Bild anzeigen möchte wie geht das?
                                          Die Festplatte wo das Bild liegt, muss von deinem TV aus erreichbar sein. Beispiele wären
                                          • NAS
                                          • Festplatte an deinem router
                                          • Oder eine Freigabe an deinem PC
                                          Wenn das gegeben ist, musst du einfach nur den Pfad ändern in:
                                          <img src=""C:\Users\Peter\Pictures\Bild.png"" width="100px" height="100px">
                                            sigi234 Forum Testing Most Active @R1Snake last edited by
                                            • NAS
                                            Ok, Danke, mein vorhaben ist es das ich wenn ein Anruf reinkommt das eine Nachricht mit dem Anruferbild angezeigt wird.
                                            lgtv
                                            113
                                            861
                                            311780
