    3. Entwicklung
    4. lgtv Adapter zur Steuerung von LG WebOS SmartTVs
      sigi234 Forum Testing Most Active @marcuskl last edited by
      @marcuskl sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
      sonder Lovelace
      Ah ,ok dann weis ich es nicht.
        sigi234 Forum Testing Most Active @SchuetzeSchulz last edited by sigi234
        @SchuetzeSchulz
        Update V 1.1.2
        EDIT: Geht jetzt, einfach noch mal installiert.
        $ ./iobroker upgrade lgtv
        Update lgtv from @1.1.1 to @1.1.2
        NPM version: 6.9.0
        npm install iobroker.lgtv@1.1.2 --loglevel error --prefix "C:/Program Files/iobroker/Test" (System call)
        npm
         ERR! path C:\Program Files\iobroker\Test\node_modules\iobroker.lgtv\node_modules\.websocket.DELETE\build\Release\validation.nodenpm ERR! code EPERMnpm ERR! errno -4048npm ERR! syscall unlink
        npm
         ERR! Error: EPERM: operation not permitted, unlink 'C:\Program Files\iobroker\Test\node_modules\iobroker.lgtv\node_modules\.websocket.DELETE\build\Release\validation.node'npm ERR!  { [Error: EPERM: operation not permitted, unlink 'C:\Program Files\iobroker\Test\node_modules\iobroker.lgtv\node_modules\.websocket.DELETE\build\Release\validation.node']npm ERR!   cause:npm ERR!    { Error: EPERM: operation not permitted, unlink 'C:\Program Files\iobroker\Test\node_modules\iobroker.lgtv\node_modules\.websocket.DELETE\build\Release\validation.node'npm ERR!      errno: -4048,npm ERR!      code: 'EPERM',npm ERR!      syscall: 'unlink',npm ERR!
              path:npm ERR!       'C:\\Program Files\\iobroker\\Test\\node_modules\\iobroker.lgtv\\node_modules\\.websocket.DELETE\\build\\Release\\validation.node' },
        npm
        ERR!   stack:npm ERR!    'Error: EPERM: operation not permitted, unlink \'C:\\Program Files\\iobroker\\Test\\node_modules\\iobroker.lgtv\\node_modules\\.websocket.DELETE\\build\\Release\\validation.node\'',npm ERR!   errno: -4048,npm
        ERR!   code: 'EPERM',npm ERR!   syscall: 'unlink',npm ERR!   path:npm ERR!    'C:\\Program Files\\iobroker\\Test\\node_modules\\iobroker.lgtv\\node_modules\\.websocket.DELETE\\build\\Release\\validation.node',npm ERR!
           parent: 'iobroker.lgtv' }npm ERR! npm ERR!
         The operation was rejected by your operating system.npm ERR! It's possible that the file was already in use (by a text editor or antivirus),npm ERR! or that you lack permissions to access it.npm ERR!
        npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator (though this is not recommended).
        npm ERR! A complete log of this run can be found in:npm
        ERR!
             C:\Program Files\iobroker\Test\env\npm-cache\_logs\2019-12-09T19_50_32_212Z-debug.log
        ERROR: host.Medion(Test) Cannot install iobroker.lgtv@1.1.2: 4294963248
        ERROR: process exited with code 25
          mikiline @deta last edited by mikiline
          @deta sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
          Hallo, ich hab da das Problem, das obwohl ich den LG sage erlaube Zugriff, kommt dann immer wieder eine neue Anfrage.
          Der LG ist per LAN im Netzwerk, genauso wie der Raspi, wo ioBroker drauf ist.
          Woran könnte es liegen?
          cu Deta
          Habe genau das gleiche Problem.
          Gibt es denn hierzu eine Lösung?
          Danke und Grüsse
          Edit: scheint nach Installation des Adapters von GitHub zu funktionieren (vers. 1.1.3)
            RandyAndy last edited by
            ich würde gerne mit dem Adapter auh Einstellungen ändern.
            Ich bin mir sicher das das irgendwie mit dem setstate... geht, aber wie.
            Ich würde nämlich gerne die Sprache zwischen Deutsch und English auswählen können, bekomme es aber nicht hin.
            Ich habe versucht das über keys zu machen, das ist aber nicht stabil und manchmal funktioniert es, meistens aber nicht.
            Für jeden Tip wäre ich dankbar.
            Andreas
              R1Snake last edited by
              Kann man sich bei dem Popup auch Bilder anzeigen lassen?
              S arteck 2 Replies Last reply Reply Quote 0
                SchuetzeSchulz @RandyAndy last edited by
                @RandyAndy
                Hi, das geht leider nicht 😞
                  SchuetzeSchulz @R1Snake last edited by
                  @R1Snake sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                  Das könnte klappen.
                  Einfach mal ein Bild mittels <img> HTML-Tag versuchen einzubinden.
                    arteck Developer Most Active @R1Snake last edited by
                    ja das geht
                      Habs gerade mal ausprobiert mit einem Bild aus Google.
                      <img>https://imgr1.auto-motor-und-sport.de/VW-e-Golf-gallerySquareTeaser-d749540f-1199274.jpg</img>
                      Leider hat der Fernseher nur die URL angezeigt
                      • Jey Cee
                        Jey Cee Developer @R1Snake last edited by
                        @R1Snake kein wunder ist ja auch falsch.
                        <img src="url">
                        Nur url ersetzen die " müssen bleiben.
                          RandyAndy @SchuetzeSchulz last edited by
                          @SchuetzeSchulz
                          Schade, gibt es eigentlich irgend eine Beschreibung der API (Link oder ähnliches).
                          ANdreas
                            sigi234 Forum Testing Most Active @Jey Cee last edited by sigi234
                            @Jey-Cee sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                            <img src="url">
                            Getestet, geht nicht. Gib das so in ein Input-Widget ein:
                            <img src="http://192.168.178.20:8107/vis.0/Wettericons/Wetter Hd/3.pngl">
                            • Jey Cee
                              Jey Cee Developer @sigi234 last edited by
                              @sigi234 ach beim LG muss mann noch die Bildgröße angeben und es gab eine Beschränkung der größe.
                              <img src="url" width="100px" height="100px">
                                @Jey-Cee said in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                                Ausprobiert und funktioniert. Danke für die schnelle Hilfe.
                                Eine kleine Sache noch. Wenn der TV ausgeschaltet ist, dann ist der Adapter gelb, da der Fernseher nicht erreichbar ist. Wenn ich den TV einschalte bleibt der Adapter gelb obwohl die Einstellung jede Sekunde nach dem TV "sucht". Wenn ich den Adapter neustarte ist er direkt grün.
                                Muss ich noch irgendwas einstellen? Kann man im Tv einstellen das er immer erreichbar ist?
                                  Geht, und wenn ich vom Pc ein Bild anzeigen möchte wie geht das?
                                    Die Festplatte wo das Bild liegt, muss von deinem TV aus erreichbar sein. Beispiele wären
                                    • NAS
                                    • Festplatte an deinem router
                                    • Oder eine Freigabe an deinem PC
                                    Wenn das gegeben ist, musst du einfach nur den Pfad ändern in:
                                    <img src=""C:\Users\Peter\Pictures\Bild.png"" width="100px" height="100px">
                                      sigi234 Forum Testing Most Active @R1Snake last edited by
                                      • NAS
                                      Ok, Danke, mein vorhaben ist es das ich wenn ein Anruf reinkommt das eine Nachricht mit dem Anruferbild angezeigt wird.
                                      • Jey Cee
                                        @sigi234 du könntest das Bild auch in base64 codieren und den code statt der url verwenden. Dann muss das Bild nicht auf einem Netzlaufwerk liegen auf das der TV zugriff hat.
                                          liv-in-sky last edited by
                                          @R1Snake
                                          super idee mit dem bilds anzeigen - hat geklappt
                                            dirkhe Developer last edited by dirkhe
                                            schon mal besten Dank für den Adapter. Ich habe mal eine Frage poll vs. subscribe. Gibt es einen Grund, dass du die Applikation via poll abfragst und es nicht subscribst? Das gleiche gilt für die anderen pollings. Ich vermute ja mal, dass es mit den WS erst später kam?
                                            Der Hintergrund meiner Frage ist, dass ich gerne auf das App change reagieren möchte, ich meinen Intervall aber nicht auf 10 sec oder tiefer stellen möchte, dafür gibt es ja die Werbservices.
                                            Ich habe das hier mal umgesetzt:
                                            https://github.com/dirkhe/ioBroker.lgtv
                                            Wenn du magst, kann ich ja einen PR stellen?
                                            gruss
                                            Dirk
                                            lgtv
                                            113
                                            861
                                            315118
