    4. Test Adapter tr-064 v3.0.x
      C-3po last edited by C-3po
      Hi Leuts,
      so richtig sauber scheint der Adapter noch nicht zu laufen.
      jegliche Änderungen zw. ca 0900 und 1500 Uhr an den Devices wurden nicht registriert.
      Erst nach dem Neustart des Adapters stimmten die Zustände wieder.
      Anwesenheitserkennung also fail.
      mag jetzt aber nicht n cron mit alle 15 min restart zu erstellen.
      host.iobroker-master	2020-01-27 16:57:15.655	info	Do not restart adapter system.adapter.tr-064.0 because desired by instance
      host.iobroker-master	2020-01-27 16:57:15.654	error	instance system.adapter.tr-064.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      tr-064.0	2020-01-27 16:57:14.762	info	(7501) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.18.1
      tr-064.0	2020-01-27 16:57:14.564	info	(22811) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      tr-064.0	2020-01-27 16:57:13.673	warn	(22811) Got terminate signal. Checking desired PID: 7501 vs own PID 22811
      tr-064.0	2020-01-27 16:57:13.672	warn	(22811) Got terminate signal. Checking desired PID: 0 vs own PID 22811
      host.iobroker-master	2020-01-27 16:57:13.527	info	instance system.adapter.tr-064.0 started with pid 7501
      host.iobroker-master	2020-01-27 16:57:12.516	info	Restart adapter system.adapter.tr-064.0 because enabled
      host.iobroker-master	2020-01-27 16:57:12.515	error	instance system.adapter.tr-064.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      tr-064.0	2020-01-27 16:57:11.706	warn	(7274) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      tr-064.0	2020-01-27 16:57:11.704	error	(7274) tr-064.0 already running
      tr-064.0	2020-01-27 16:57:10.565	warn	(22811) Got terminate signal. Checking desired PID: 7274 vs own PID 22811
      tr-064.0	2020-01-27 16:57:10.563	warn	(22811) Got terminate signal. Checking desired PID: 0 vs own PID 22811
      host.iobroker-master	2020-01-27 16:57:10.561	info	instance system.adapter.tr-064.0 started with pid 7274
      host.iobroker-master	2020-01-27 16:57:09.048	info	stopInstance system.adapter.tr-064.0 killing pid 22811
      tr-064.0	2020-01-27 16:57:08.046	warn	at processImmediate (timers.js:658:5)
      tr-064.0	2020-01-27 16:57:08.046	warn	at tryOnImmediate (timers.js:676:5)
      tr-064.0	2020-01-27 16:57:08.046	warn	at runCallback (timers.js:705:18)
      tr-064.0	2020-01-27 16:57:08.046	warn	at Immediate.setImmediate [as _onImmediate] (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:227:41)
      tr-064.0	2020-01-27 16:57:08.046	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4712:25)
      tr-064.0	2020-01-27 16:57:08.046	warn	at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7223:22)
      tr-064.0	2020-01-27 16:57:08.046	warn	at Adapter.emit (events.js:198:13)
      tr-064.0	2020-01-27 16:57:08.046	warn	at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.tr-064/main.js:125:13)
      tr-064.0	2020-01-27 16:57:08.046	warn	(22811) ReferenceError: callback is not defined
      tr-064.0	2020-01-27 16:57:08.043	warn	(22811) States system pmessage io.system.adapter.tr-064.0.sigKill {"val":-1,"ack":false,"ts":1580140628040,"q":0,"from":"system.host.iobroker-master","lc":1580140628040} callback is not defined
      host.iobroker-master	2020-01-27 16:57:08.040	info	stopInstance system.adapter.tr-064.0 send kill signal
      tr-064.0	2020-01-27 16:57:08.041	info	(22811) Got terminate signal TERMINATE_YOURSELF
      und das passierte eben nach dem erstellen eines crons
        A Former User @jokerjo1000 last edited by
        @jokerjo1000 hat der User auch Zugriff ?
        Fritzbox neu gestartet?
          ja hat er......alles andere läuft ja auch ??? Echt komisch
            apollon77 @jokerjo1000 last edited by
            @jokerjo1000 Hast DU auch rlaubt das er diese Steuerdinge tun darf? Da musst Du ein Haken setzen in den User einstellungen (Habs grad nicht im Kopf welchen)
            maloross 1 Reply Last reply Reply Quote 0
            • maloross
              maloross @apollon77 last edited by maloross
              @apollon77 sagte in Test Adapter tr-064 v3.0.x:
              Fritzbox-Netzwerk-Netzwerkeinstellung: sind hier beide Optionen aktiviert?
                jokerjo1000 @maloross last edited by
                @maloross
                Ja Haken sind gesetzt.
                • maloross
                  maloross @jokerjo1000 last edited by maloross
                  @jokerjo1000 lief die Vorgängerversion? Vielleicht mal ein downgrade probieren
                  Edit: ggf. den Adapter über die Konsole neu installieren und uploaden.
                    crunchip Forum Testing Most Active @jokerjo1000 last edited by
                    @jokerjo1000 hatte ich auch,
                    statt fritz.box die IP eintragen und Instanz neustarten hat bei mir geholfen
                      jokerjo1000 last edited by jokerjo1000
                      Soooo...es läuft. Habe die Haken bei Anrufmonitor, Telefonbuch und Rufweiterleitung entfernt. Jetzt geht es....komisch oder.
                        Leviathan09 last edited by
                        Habe gerade den Adapter in der Version 3.1.4 installiert und bekomme folgende Fehler:
                        tr-064.0	2020-01-27 19:30:40.993	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                        tr-064.0	2020-01-27 19:30:40.993	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                        tr-064.0	2020-01-27 19:30:40.993	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                        tr-064.0	2020-01-27 19:30:40.993	error	at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:65119)
                        tr-064.0	2020-01-27 19:30:40.993	error	at objects.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2450:65)
                        tr-064.0	2020-01-27 19:30:40.993	error	at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.tr-064/main.js:115:13)
                        tr-064.0	2020-01-27 19:30:40.993	error	at main (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1119:49)
                        tr-064.0	2020-01-27 19:30:40.993	error	(11472) ReferenceError: secret is not defined
                        tr-064.0	2020-01-27 19:30:40.992	error	(11472) uncaught exception: secret is not defined
                        Benutzer sowie Passwort stimmen, kann mich darüber ganz normal an der FritzBox anmelden.
                        Der tr-64-community Adapter funktioniert problemlos.
                        Habe sowohl versucht den nativ part rüber zu kopieren als auch den tr-64 ohne kopieren neu einzurichten.
                        In beiden Fällen funktioniert es leider nicht.
                          @jokerjo1000 sagte in Test Adapter tr-064 v3.0.x:
                          Und was willst Du mit dem Adapter jetzt noch machen wenn alles deaktiviert ist?
                          • Feuersturm
                            Feuersturm last edited by
                            Ich habe gerade von 3.1.1 auf 3.1.4 aktualisiert und habe die gleichen Fehler wie @Leviathan09
                            host.beebox(iobrokerMaster)	2020-01-27 19:43:09.029	info	Restart adapter system.adapter.tr-064.0 because enabled
                            host.beebox(iobrokerMaster)	2020-01-27 19:43:09.029	info	instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
                            host.beebox(iobrokerMaster)	2020-01-27 19:43:09.029	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
                            host.beebox(iobrokerMaster)	2020-01-27 19:43:09.029	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                            host.beebox(iobrokerMaster)	2020-01-27 19:43:09.029	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                            host.beebox(iobrokerMaster)	2020-01-27 19:43:09.029	error	Caught by controller[0]: at (anonymous function).get (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:77706)
                            host.beebox(iobrokerMaster)	2020-01-27 19:43:09.028	error	Caught by controller[0]: at objects.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2450:65)
                            host.beebox(iobrokerMaster)	2020-01-27 19:43:09.028	error	Caught by controller[0]: at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.tr-064/main.js:115:13)
                            host.beebox(iobrokerMaster)	2020-01-27 19:43:09.028	error	Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1119:49)
                            host.beebox(iobrokerMaster)	2020-01-27 19:43:09.027	error	Caught by controller[0]: ReferenceError: secret is not defined
                            tr-064.0	2020-01-27 19:43:08.496	info	(20555) Terminated (NO_ERROR): Without reason
                            tr-064.0	2020-01-27 19:43:08.494	info	(20555) terminating
                            tr-064.0	2020-01-27 19:43:08.460	error	(20555) ReferenceError: secret is not defined at main (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1119:49) at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.tr-064/main.
                            tr-064.0	2020-01-27 19:43:08.458	error	(20555) uncaught exception: secret is not defined
                            tr-064.0	2020-01-27 19:43:08.356	info	(20555) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.18.1
                            host.beebox(iobrokerMaster)	2020-01-27 18:43:06.271	info	instance system.adapter.tr-064.0 started with pid 20555
                            host.beebox(iobrokerMaster)	2020-01-27 18:43:06.235	info	"system.adapter.tr-064.0" enabled
                            Mit der 3.1.1 gab es keine Probleme
                              apollon77 @Feuersturm last edited by
                              @Feuersturm ok. Schaue nachher gleich.
                              • Feuersturm
                                @apollon77 Gibt es eine Möglichkeit über einen Link auch die 3.1.3 bwz. eine beliebige Version, welche veröffentlict wurde zu installieren?
                                • smarteule
                                  smarteule last edited by
                                  vielleicht ist es nicht so wichtig, aber bei 3.1.1 ging es nicht mit "Rufweiterleitung" doch mit 3.1.4 geht jetzt alles.
                                  tr064 v 3.1.4
                                  js.controller v 2.2.8
                                  node js v 10.18.1
                                  npm v 6.13.4
                                  • Negalein
                                    Negalein Global Moderator @Guest last edited by Negalein
                                    @Yetiberg sagte in Test Adapter tr-064 v3.0.x:
                                    jetzt nicht lachen, aber ich hab ihn NUR für die Anwesenheitskontrolle.
                                    Bei uns gibt es schon sicher 7 Jahre kein Festnetz mehr.
                                      Bitte installiert jetzt nicht mehr von GitHub. Das ist der Grund für die Fehler. Bitte ladet die 3.1.4 von npm. Und ja GitHub ist aktuell „broken“ und wird für die nächste Version nen breaking Change beinhalten.
                                      • Feuersturm
                                        Feuersturm last edited by Feuersturm
                                        @apollon77 Ok. Kannst du mir kurz sagen, wie ich die aktuelle Version dann über npm installieren kann?
                                        Was bedeutet für dich "nen breaking Change beinhalten"?
                                          A Former User @Negalein last edited by
                                          @Negalein
                                          Nee, da lache ich nicht. Kann ich verstehen.
                                          Aber für Anwesenheitskontrolle benutze ich nur den Radar2 Adapter.
                                          Dieses ständige ein und ausloggen aus dem WLAN mit den neuesten Android oder IOs Versionen hat mich hier kirre gemacht.
                                          Lasse das nun mit Bluetooth kontrollieren und funzt gut.
                                          C L 2 Replies Last reply Reply Quote 0
                                            C-3po @Guest last edited by C-3po
                                            @Yetiberg
                                            Hi, kurz ot.
                                            wie machst Du das mit Radar2 und Bluetooth.
                                            Die Androids ändern doch ständig die Bluetooth Mac.
                                            tr-064
                                            46
                                            158
                                            18129
