    4. Test Adapter tr-064 v3.0.x
    • Feuersturm
      Feuersturm last edited by
      Ich habe gerade von 3.1.1 auf 3.1.4 aktualisiert und habe die gleichen Fehler wie @Leviathan09
      host.beebox(iobrokerMaster)	2020-01-27 19:43:09.029	info	Restart adapter system.adapter.tr-064.0 because enabled
      host.beebox(iobrokerMaster)	2020-01-27 19:43:09.029	info	instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
      host.beebox(iobrokerMaster)	2020-01-27 19:43:09.029	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
      host.beebox(iobrokerMaster)	2020-01-27 19:43:09.029	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      host.beebox(iobrokerMaster)	2020-01-27 19:43:09.029	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      host.beebox(iobrokerMaster)	2020-01-27 19:43:09.029	error	Caught by controller[0]: at (anonymous function).get (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:77706)
      host.beebox(iobrokerMaster)	2020-01-27 19:43:09.028	error	Caught by controller[0]: at objects.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2450:65)
      host.beebox(iobrokerMaster)	2020-01-27 19:43:09.028	error	Caught by controller[0]: at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.tr-064/main.js:115:13)
      host.beebox(iobrokerMaster)	2020-01-27 19:43:09.028	error	Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1119:49)
      host.beebox(iobrokerMaster)	2020-01-27 19:43:09.027	error	Caught by controller[0]: ReferenceError: secret is not defined
      tr-064.0	2020-01-27 19:43:08.496	info	(20555) Terminated (NO_ERROR): Without reason
      tr-064.0	2020-01-27 19:43:08.494	info	(20555) terminating
      tr-064.0	2020-01-27 19:43:08.460	error	(20555) ReferenceError: secret is not defined at main (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1119:49) at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.tr-064/main.
      tr-064.0	2020-01-27 19:43:08.458	error	(20555) uncaught exception: secret is not defined
      tr-064.0	2020-01-27 19:43:08.356	info	(20555) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.18.1
      host.beebox(iobrokerMaster)	2020-01-27 18:43:06.271	info	instance system.adapter.tr-064.0 started with pid 20555
      host.beebox(iobrokerMaster)	2020-01-27 18:43:06.235	info	"system.adapter.tr-064.0" enabled
      Mit der 3.1.1 gab es keine Probleme
        apollon77 @Feuersturm last edited by
        @Feuersturm ok. Schaue nachher gleich.
        • Feuersturm
          @apollon77 Gibt es eine Möglichkeit über einen Link auch die 3.1.3 bwz. eine beliebige Version, welche veröffentlict wurde zu installieren?
          • smarteule
            smarteule last edited by
            vielleicht ist es nicht so wichtig, aber bei 3.1.1 ging es nicht mit "Rufweiterleitung" doch mit 3.1.4 geht jetzt alles.
            tr064 v 3.1.4
            js.controller v 2.2.8
            node js v 10.18.1
            npm v 6.13.4
            • Negalein
              Negalein Global Moderator @Guest last edited by Negalein
              @Yetiberg sagte in Test Adapter tr-064 v3.0.x:
              Und was willst Du mit dem Adapter jetzt noch machen wenn alles deaktiviert ist?
              jetzt nicht lachen, aber ich hab ihn NUR für die Anwesenheitskontrolle.
              Bei uns gibt es schon sicher 7 Jahre kein Festnetz mehr.
                apollon77 last edited by
                Bitte installiert jetzt nicht mehr von GitHub. Das ist der Grund für die Fehler. Bitte ladet die 3.1.4 von npm. Und ja GitHub ist aktuell „broken“ und wird für die nächste Version nen breaking Change beinhalten.
                • Feuersturm
                  Feuersturm last edited by Feuersturm
                  @apollon77 Ok. Kannst du mir kurz sagen, wie ich die aktuelle Version dann über npm installieren kann?
                  Was bedeutet für dich "nen breaking Change beinhalten"?
                    A Former User @Negalein last edited by
                    @Negalein
                    Nee, da lache ich nicht. Kann ich verstehen.
                    Aber für Anwesenheitskontrolle benutze ich nur den Radar2 Adapter.
                    Dieses ständige ein und ausloggen aus dem WLAN mit den neuesten Android oder IOs Versionen hat mich hier kirre gemacht.
                    Lasse das nun mit Bluetooth kontrollieren und funzt gut.
                    C L 2 Replies Last reply Reply Quote 0
                      C-3po @Guest last edited by C-3po
                      @Yetiberg
                      Hi, kurz ot.
                      wie machst Du das mit Radar2 und Bluetooth.
                      Die Androids ändern doch ständig die Bluetooth Mac.
                      • Feuersturm
                        Hab hier die Doku gefunden, wie ich über npm einen Adapter installiere (https://www.iobroker.net/docu/index-197.htm?page_id=14&lang=de)
                        @apollon77 Mit der Installation der 3.1.4 über npm gibt es bei mir keine Probleme. Die Anwesenheitserkennung der Handy funktioniert auch 🙂
                          Leviathan09 @Guest last edited by
                          @Yetiberg ich nutze den Adapter zb nur für mein Gäste WLAN
                            Leviathan09 @Feuersturm last edited by Leviathan09
                            @Feuersturm dann werde ich direkt Mal auch die Installation über npm durchführen
                            Edit: Funktioniert, Installation über npm lief problemlos, keine Fehler mehr
                            Danke @apollon77 für die Info es so zu machen
                              Jan1 @Leviathan09 last edited by Jan1
                              @Leviathan09
                              Bist Du nicht auf latest? Denn dann könntest due Version auch ganz normal über den Admin installieren.
                                Leviathan09 @Jan1 last edited by
                                @Jan1 bin auf latest aber mir wurde der Adapter unter admin nicht angezeigt um ihn zu installieren
                                Frag mich nicht warum...
                                Jedenfalls geht jetzt alles
                                  @Leviathan09
                                  Nein anscheinend nicht, sonst würde er auch angezeigt werden.
                                  Hast Du irgend wann mal ein manuelles Backup eingespielt?
                                    A Former User @C-3po last edited by
                                    @C-3po
                                    Schau Dir das mal an:
                                    Anwesenheit Bluetooth
                                      @Yetiberg
                                      mach ich THX
                                      • Feuersturm
                                        Feuersturm @Jan1 last edited by
                                        @Jan1 Wenn ich auf latest umstelle wird mir auch nur die 3.1.0 angezeigt. Die Version 3.1.1 hab ich auch manuell über Github installiert. Siehst du bei dir die 3.1.4?
                                        J ostseereiter 2 Replies Last reply Reply Quote 0
                                          Jan1 @Feuersturm last edited by
                                          @Feuersturm verstehe ich nicht, wurde bei mir angezeigt und macht es auch immer noch.
                                            iobroker upgrade tr-064@3.1.4
                                            in der Console wirkt wunder
                                            tr-064
                                            46
                                            158
                                            18129
