    4. You are sending to fast error im Log & CCU2 deswegen tot…
    • etv
      etv last edited by
      [emoji1]
      • etv
        etv last edited by
        @Bluefox:
        In den neuen Versionen von admin und js-controller es gibt max-ram zu steuern. Ob es hilft weiß ich nicht. `
        Hallo Bluefox,
        hab ich gerade eingespielt - wo kann man das einstellen?
        tom
        • etv
          etv last edited by
          @etv:
          @Bluefox:
          Hallo Bluefox,
          tom `
          OK - da hat's was mit den neuen Updates
          2016-01-22 17:02:43.122  - info: web.0 socket.io server listening on port 8082
          2016-01-22 17:02:43.119  - error:  ReferenceError: adapter is not defined
              at ObjectsInMemServer.setObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:683:13)
              at ObjectsInMemServer. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:676:33)
              at checkObjectRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:532:16)
              at ObjectsInMemServer.setObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:672:13)
              at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2505:28)
              at Socket.emit (events.js:118:17)
              at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/lib/socket.js:330:8)
              at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/lib/socket.js:290:12)
              at Client.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/lib/client.js:193:14)
              at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
          2016-01-22 17:02:43.241  - info: hm-rega.0 got 6 programs</anonymous></anonymous>
          …hab ich nun beim Start von iobroker, bzw. auch beim reboot des Raspi...
          tom
          • etv
            etv last edited by
            …die alte JavaScript Sicherung von heute Mittag eingespielt...geht wieder...
            D.h. da ist im neuen JavaScript Update der Wurm drinnen...
            tom
              wortmann30 last edited by
              Hi zusammen
              habe ich das jetzt richtig gelesen das das Speicher Problem und die Abstürz sowie eventuell das Aufhängen der CCU 2 auf einen Fehler im JavaScrip update liegt der die Tage kam?
              Wie kann ich den auf eine alte Version von JavaScrip zurück gehen? Warscheinlich nur wenn ich vor dem Update ein Image von der SD Karte gezogen habe oder?
              • Jey Cee
                So wie ich das mitbekommen hab wurde der javascript adapter schon gefixt.
                Gesendet von meinem Jolla mit Tapatalk
                305_heizungsscript_220_b07_temp.txt
                  @Jey Cee:
                  So wie ich das mitbekommen hab wurde der javascript adapter schon gefixt. `
                  Ok aber ich habe so um den 21.01. ein Update auf aufgezogen auch im Zusammenhang mit dem was wir hier hatten:
                  http://forum.iobroker.net/viewtopic.php … 241#p18241
                  Seit her hatte ich diesen Fehler mit dem "you are sending too fast".
                  Das da was neues gekommen sein soll, habe ich nicht mit bekommen.
                  • Jey Cee
                    Laut Changelog gab es am 22.01. eine neue Version.
                      OK… Danke
                      aber ich steh grade echt auf dem Schlauch... wo finde ich diesen Adapter und seine Version nochmal?
                      421_view.txt
                      • Jey Cee
                        1 Adapter informationen Aktualisieren
                        2 Der Adapter JavaScript
                        3 Links (grün hinterlegt) installierte Version, rechts verfügbare Version
                          Aha jetzt werde ich draus schlau, den habe ich gar nicht installiert außerdem wird bei mir schon die Version 1.1.5 angeboten.
                          Kann das sein das der auf jeden fall zur Grund Installation gehört und ich daher die Probleme habe?
                          Oder besser gesagt muss man noch zusätzliche Adapter installieren außer den Admin, HM-rega und pro funk, RS485 und CUxD einen hm-rcp Adapter.
                          Sorry das ist off Topic und bitte verweist mich auf einen anderen tread und dann werde ich da weiter schauen. Di,e suche hat nix erbracht.
                          Denn mein Fehler hier äußert sich ähnlich wie hier beschrieben ich bekomme den Fehler "you are sending too fast" und dann hängt die CCU2 sich auf.
                          Und leider bin ich noch nicht wirklich fit in IO.Broker und stachse oft im dunkeln…
                          (Auf die Gefahr hin das jetzt gleich Steine fliegen hab ich die Frage gestellt... :oops: )
                          • Jey Cee
                            @wortmann30:
                            Kann das sein das der auf jeden fall zur Grund Installation gehört und ich daher die Probleme habe? `
                            Das Update auf 1.1.5 ist kurz Nachdem ich hier gepsotet hab verfügbar gewesen 🙂
                            Also bei den meisten dürfte er zur Grundausstattung gehören, da man damit sehr viel Steueraufgaben erledigt. Aber prinzipiell läuft ioBroker ohne und das fehlen kann nichts mit den fehlern zu tun haben.
                            Ich hab mal alle deine Beiträge aufgerufen und kurz Überflogen, bisher scheint es so das du die ioBroker installation nur für history, Flot charts und vis nutzt. Oder hast du noch weitere Adapter installiert?
                              Ich scheine Gläsern zu sein 😄
                              Ja so ist es, ich habe nur noch zusätzlich gestern den RPI Monitor installiert. Und ich habe die Tage die History eingestellt sprich die Daten angeklickt zum Monitoren die ich möchte. So ca. 2 Stück pro Gerät und derzeit sind es rund 140 Geräte und dann noch bei ca. 80 Variablen.
                              Wenn ich mich recht erinnere kam einmal der Fehler als ich die Sachen zusammengeklickt habe und irgend wann hat IO.Broker die Änderungen nicht mehr übernommen. Das heißt ich habe auf das Uhren Symbol geklickt, aktiviert und gespeichert aber die Uhr wurde nicht mehr blau.
                              Aber eigentlich dachte ich das die CCU2 die Daten so oder so dem IO.Broker zur Verfügung stellt und IO.Broker sich einfach nur die rauspickt die archiviert werden sollen, oder habe ich das falsch verstanden? Das einzige was da zu Problemen führe kann sind die häufigen schreib zugriffe auf die SD Karte, daher habe ich nicht pauschal alle aktiviert. Ist das richtig?
                              Aber nun zurück zum Fehler, passt das hier ins Bild?
                              • Jey Cee
                                Der Fehlermeldung nach bist du im richtigen thread. Und deine annahme das die CCU2 die Daten an ioBroker sendet ist auch richtig. ioBroker sendet nur wenn es neues vom ioBroker gibt.
                                Irgendwie ergibt das keinen Sinn.
                                Wie oft kommt der fehler den?
                                Wenn er oft kommt und du eine neuere FritzBox im einsatz hast, könntest du den Netzwerk verkehr mit schneiden. Vielleicht sieht man was da an die CCU gesendet wird.
                                  Also gestern war er ein paar mal da, einmal ungefähr zu dem Zeitpunkt als ich die Historie eingestellt habe.
                                  Ein Ausschnitt aus dem Protokoll ist hier zu sehen:
                                  http://forum.iobroker.net/viewtopic.php … 463#p18463
                                  Eine Fritz box habe ich nicht nur so ein schrottiges Teil von Unity Media eine Technikolor box, die kann gar nichts…
                                  Letzte Nacht ist die CCU 2 mal abgestürzt einmal um 2:34 und dann nochmal um 4:15 da war sie wieder da. Habe einen Watch Dog am laufen.
                                  Am morgen habe ich das Log heruntergeladen und da war allerdings ein anderer Fehler sichtbar, zumindest um 4:09. dann später nochmal aber ohne Neustart der CCU. Um kurz vor sieben Habe ich dann neu gestartet aber warum er dann nochmal not connected bringt??? Da lief IO.Broker und die CCU die wurde da nicht neu gestartet...
                                  hm-rpc-0 2016-01-25 06:55:46 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:54:16 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:52:46 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:51:16 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:49:46 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:48:16 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:46:46 error Error: not connected
                                  admin-0 2016-01-25 06:46:08 info Repository received successfully.
                                  admin-0 2016-01-25 06:45:59 info received all states
                                  host-raspberrypi 2016-01-25 06:45:59 info Update repository "default" under "conf/sources-dist.json"
                                  admin-0 2016-01-25 06:45:59 info received all objects
                                  admin-0 2016-01-25 06:45:54 info Use link "http://localhost:8081" to configure.
                                  admin-0 2016-01-25 06:45:54 info http server listening on port 8081
                                  admin-0 2016-01-25 06:45:54 info Request actual repository...
                                  admin-0 2016-01-25 06:45:54 info requesting all objects
                                  admin-0 2016-01-25 06:45:54 info requesting all states
                                  admin-0 2016-01-25 06:45:54 info starting. Version 0.7.3 in /opt/iobroker/node_modules/iobroker.admin
                                  host-raspberrypi 2016-01-25 06:45:46 info instance system.adapter.admin.0 started with pid 26743
                                  rpi-0 2016-01-25 06:45:20 warn Reconnection to DB.
                                  rpi-0 2016-01-25 01:50:37 warn Reconnection to DB.
                                  hm-rpc-2 2016-01-25 06:45:20 warn Reconnection to DB.
                                  hm-rpc-1 2016-01-25 06:45:20 info binrpc -> 221 devices
                                  hm-rpc-0 2016-01-25 06:45:20 warn Reconnection to DB.
                                  hm-rpc-1 2016-01-25 06:45:19 warn Reconnection to DB.
                                  hm-rpc-0 2016-01-25 06:45:19 warn Reconnection to DB.
                                  history-0 2016-01-25 06:45:18 warn Reconnection to DB.
                                  hm-rpc-1 2016-01-25 06:45:17 warn Reconnection to DB.
                                  history-0 2016-01-25 06:45:17 warn Reconnection to DB.
                                  hm-rega-0 2016-01-25 06:45:17 warn Reconnection to DB.
                                  web-0 2016-01-25 06:45:16 warn Reconnection to DB.
                                  host-raspberrypi 2016-01-25 06:45:16 info Restart adapter system.adapter.admin.0 because enabled
                                  host-raspberrypi 2016-01-25 06:45:16 warn instance system.adapter.admin.0 terminated due to SIGKILL
                                  hm-rpc-1 2016-01-25 06:45:16 info binrpc <- system.listMethods ["hm-rpc.1"]
                                  hm-rpc-0 2016-01-25 06:45:16 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:42:06 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:36:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:34:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:33:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:31:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:30:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:28:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:27:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:25:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:24:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:22:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:21:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:19:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:18:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:16:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:15:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:13:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:12:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:10:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:09:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:07:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:06:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:04:48 error Error: not connected
                                  history-0 2016-01-25 06:04:42 info moving 961 entries from system.adapter.rpi.0.memRss to file
                                  hm-rpc-0 2016-01-25 06:03:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:01:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 06:00:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:58:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:57:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:55:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:54:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:52:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:51:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:49:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:48:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:46:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:45:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:43:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:42:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:40:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:39:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:37:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:36:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:34:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:33:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:31:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:30:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:28:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:27:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:25:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:24:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:22:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:21:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:19:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:18:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:16:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:15:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:13:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:12:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:10:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:09:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:07:48 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:06:18 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:04:48 error Error: not connected
                                  admin-0 2016-01-25 05:04:41 info Repository received successfully.
                                  admin-0 2016-01-25 05:04:31 info received all states
                                  host-raspberrypi 2016-01-25 05:04:31 info Update repository "default" under "conf/sources-dist.json"
                                  admin-0 2016-01-25 05:04:31 info received all objects
                                  admin-0 2016-01-25 05:04:26 info Use link "http://localhost:8081" to configure.
                                  admin-0 2016-01-25 05:04:26 info http server listening on port 8081
                                  admin-0 2016-01-25 05:04:26 info Request actual repository...
                                  admin-0 2016-01-25 05:04:26 info requesting all objects
                                  admin-0 2016-01-25 05:04:26 info requesting all states
                                  admin-0 2016-01-25 05:04:26 info starting. Version 0.7.3 in /opt/iobroker/node_modules/iobroker.admin
                                  host-raspberrypi 2016-01-25 05:04:18 info instance system.adapter.admin.0 started with pid 23510
                                  host-raspberrypi 2016-01-25 05:03:48 info Restart adapter system.adapter.admin.0 because enabled
                                  host-raspberrypi 2016-01-25 05:03:48 warn instance system.adapter.admin.0 terminated due to SIGKILL
                                  hm-rpc-0 2016-01-25 05:03:18 error Error: not connected
                                  hm-rega-0 2016-01-25 05:03:02 error post request error: socket hang up
                                  hm-rega-0 2016-01-25 05:02:51 error post request error: socket hang up
                                  hm-rega-0 2016-01-25 05:02:39 error post request error: socket hang up
                                  hm-rpc-0 2016-01-25 05:01:47 error Error: not connected
                                  hm-rpc-0 2016-01-25 05:00:17 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:58:47 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:57:17 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:55:47 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:54:17 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:52:47 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:51:17 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:49:47 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:48:17 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:46:47 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:45:17 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:43:47 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:42:17 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:40:47 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:39:17 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:37:47 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:36:17 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:34:47 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:33:17 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:31:47 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:30:17 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:28:47 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:27:17 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:25:47 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:24:17 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:22:47 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:21:17 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:19:47 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:18:17 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:16:47 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:15:17 error Error: not connected
                                  hm-rpc-0 2016-01-25 04:13:47 error Error: not connected
                                  history-0 2016-01-25 04:12:44 info moving 961 entries from system.adapter.rpi.0.memHeapUsed to file
                                  hm-rega-0 2016-01-25 04:12:18 error post request error: connect ECONNREFUSED
                                  hm-rega-0 2016-01-25 04:12:17 error post request error: connect ECONNREFUSED
                                  hm-rega-0 2016-01-25 04:11:17 error post request error: connect ECONNREFUSED
                                  hm-rpc-0 2016-01-25 04:12:17 error Error: not connected
                                  hm-rega-0 2016-01-25 04:11:48 error post request error: connect ECONNREFUSED
                                  hm-rega-0 2016-01-25 04:11:47 error post request error: connect ECONNREFUSED
                                  hm-rega-0 2016-01-25 04:10:48 error post request error: connect ECONNREFUSED
                                  hm-rega-0 2016-01-25 04:10:47 error post request error: connect ECONNREFUSED
                                  hm-rpc-0 2016-01-25 04:10:47 error Error: not connected
                                  hm-rega-0 2016-01-25 04:10:18 error post request error: connect ECONNREFUSED
                                  hm-rega-0 2016-01-25 04:10:17 error post request error: connect ECONNREFUSED
                                  hm-rega-0 2016-01-25 04:09:48 error post request error: connect ECONNREFUSED
                                  hm-rega-0 2016-01-25 04:09:47 error post request error: connect ECONNREFUSED
                                  hm-rega-0 2016-01-25 04:09:18 error post request error: connect ECONNREFUSED
                                  hm-rega-0 2016-01-25 04:09:17 error post request error: connect ECONNREFUSED
                                  hm-rpc-0 2016-01-25 04:09:17 error Error: not connected
                                  hm-rega-0 2016-01-25 04:08:48 error post request error: connect ECONNREFUSED
                                  hm-rega-0 2016-01-25 04:08:47 error post request error: connect ECONNREFUSED
                                  hm-rega-0 2016-01-25 04:08:27 info Got unexpected ID: hm-rpc.2.updated
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002004.3.STATE extended
                                  history-0 2016-01-25 04:08:27 info enabled logging of hm-rpc.2.CUX9002004.3.STATE
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002004.2.SET_INVERT extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002004.2.LEVEL extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002004.2.STATE extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002004.2.SETPOINT extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002004.1.SET_HUMIDITY extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002004.1.SET_TEMPERATURE extended
                                  history-0 2016-01-25 04:08:27 info enabled logging of hm-rpc.2.CUX9002004.2.STATE
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002004.1.HUM_MAX_24H extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002004.1.HUM_MIN_24H extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002004.1.TEMP_MAX_24H extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002004.1.TEMP_MIN_24H extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002004.1.ABS_HUMIDITY extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002004.1.DEW_POINT extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002004.1.HUMIDITY extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002004.1.TEMPERATURE extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002003.3.STATE extended
                                  history-0 2016-01-25 04:08:27 info enabled logging of hm-rpc.2.CUX9002003.3.STATE
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002003.2.SET_INVERT extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002003.2.LEVEL extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002003.2.STATE extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002003.2.SETPOINT extended
                                  history-0 2016-01-25 04:08:27 info enabled logging of hm-rpc.2.CUX9002003.2.STATE
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002003.1.SET_HUMIDITY extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002003.1.SET_TEMPERATURE extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002003.1.HUM_MAX_24H extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002003.1.HUM_MIN_24H extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002003.1.TEMP_MAX_24H extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002003.1.TEMP_MIN_24H extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002003.1.ABS_HUMIDITY extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002003.1.DEW_POINT extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002003.1.HUMIDITY extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002003.1.TEMPERATURE extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002002.3.STATE extended
                                  history-0 2016-01-25 04:08:27 info enabled logging of hm-rpc.2.CUX9002002.3.STATE
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002002.2.SET_INVERT extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002002.2.LEVEL extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002002.2.STATE extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002002.2.SETPOINT extended
                                  history-0 2016-01-25 04:08:27 info enabled logging of hm-rpc.2.CUX9002002.2.STATE
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002002.1.SET_HUMIDITY extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002002.1.SET_TEMPERATURE extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002002.1.HUM_MAX_24H extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002002.1.HUM_MIN_24H extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002002.1.TEMP_MAX_24H extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002002.1.TEMP_MIN_24H extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002002.1.ABS_HUMIDITY extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002002.1.DEW_POINT extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002002.1.HUMIDITY extended
                                  hm-rpc-2 2016-01-25 04:08:27 info object hm-rpc.2.CUX9002002.1.TEMPERATURE extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX9002001.3.STATE extended
                                  history-0 2016-01-25 04:08:26 info enabled logging of hm-rpc.2.CUX9002001.3.STATE
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX9002001.2.SET_INVERT extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX9002001.2.LEVEL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX9002001.2.STATE extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX9002001.2.SETPOINT extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX9002001.1.SET_HUMIDITY extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX9002001.1.SET_TEMPERATURE extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX9002001.1.HUM_MAX_24H extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX9002001.1.HUM_MIN_24H extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX9002001.1.TEMP_MAX_24H extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX9002001.1.TEMP_MIN_24H extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX9002001.1.ABS_HUMIDITY extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX9002001.1.DEW_POINT extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX9002001.1.HUMIDITY extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX9002001.1.TEMPERATURE extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.RAND extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.SET_STATE extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.CONTROL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.WORKING extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.CMD_QUERY_RET extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.CMD_RETL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.CMD_RETS extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.CMD_SETL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.CMD_SETS extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.SYSLOG extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.LOGIT extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.CMD_EXEC extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.CMD_KILL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.CMD_RUNL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.CMD_RUNS extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.PRESS_LONG extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.PRESS_SHORT extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.STATE extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.STOP extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.OLD_LEVEL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.16.LEVEL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.RAND extended
                                  history-0 2016-01-25 04:08:26 info enabled logging of hm-rpc.2.CUX9002001.2.STATE
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.SET_STATE extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.CONTROL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.WORKING extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.CMD_QUERY_RET extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.CMD_RETL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.CMD_RETS extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.CMD_SETL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.CMD_SETS extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.SYSLOG extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.LOGIT extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.CMD_EXEC extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.CMD_KILL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.CMD_RUNL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.CMD_RUNS extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.PRESS_LONG extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.PRESS_SHORT extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.STATE extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.STOP extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.OLD_LEVEL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.15.LEVEL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.RAND extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.SET_STATE extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.CONTROL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.WORKING extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.CMD_QUERY_RET extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.CMD_RETL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.CMD_RETS extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.CMD_SETL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.CMD_SETS extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.SYSLOG extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.LOGIT extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.CMD_EXEC extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.CMD_KILL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.CMD_RUNL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.CMD_RUNS extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.PRESS_LONG extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.PRESS_SHORT extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.STATE extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.STOP extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.OLD_LEVEL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.14.LEVEL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.RAND extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.SET_STATE extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.CONTROL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.WORKING extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.CMD_QUERY_RET extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.CMD_RETL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.CMD_RETS extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.CMD_SETL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.CMD_SETS extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.SYSLOG extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.LOGIT extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.CMD_EXEC extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.CMD_KILL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.CMD_RUNL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.CMD_RUNS extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.PRESS_LONG extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.PRESS_SHORT extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.STATE extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.STOP extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.OLD_LEVEL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.13.LEVEL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.RAND extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.SET_STATE extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.CONTROL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.WORKING extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.CMD_QUERY_RET extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.CMD_RETL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.CMD_RETS extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.CMD_SETL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.CMD_SETS extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.SYSLOG extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.LOGIT extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.CMD_EXEC extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.CMD_KILL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.CMD_RUNL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.CMD_RUNS extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.PRESS_LONG extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.PRESS_SHORT extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.STATE extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.STOP extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.OLD_LEVEL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.12.LEVEL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.RAND extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.SET_STATE extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.CONTROL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.WORKING extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.CMD_QUERY_RET extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.CMD_RETL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.CMD_RETS extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.CMD_SETL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.CMD_SETS extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.SYSLOG extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.LOGIT extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.CMD_EXEC extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.CMD_KILL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.CMD_RUNL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.CMD_RUNS extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.PRESS_LONG extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.PRESS_SHORT extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.STATE extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.STOP extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.OLD_LEVEL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.11.LEVEL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.10.RAND extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.10.SET_STATE extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.10.CONTROL extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.10.WORKING extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.10.CMD_QUERY_RET extended
                                  hm-rpc-2 2016-01-25 04:08:26 info object hm-rpc.2.CUX2801002.10.CMD_RETL extended
                                  • Jey Cee
                                    Im Log kann ich keinen Zusammenhang erkennen weder für den fehler Sending to fast noch für not connected.
                                    Ich hab eine möglichket gefunden den Netzwerk verkehr direkt auf dem raspberry mit zu schneiden, hier ist die Anleitung: https://www.elektronik-kompendium.de/si … 912131.htm
                                      Hi
                                      danke aber ich glaube an dem Punkt steige ich aus… Das ist zu hoch für mich.
                                      Danke trotzdem
                                      • etv
                                        etv last edited by
                                        Liebe Leute,
                                        zu diesem Thema wiedermal ein Update von mir.
                                        Also nach dem "weg mit dem Speck" auf dem Raspi scheint nun alles wieder ohne Probleme zu laufen, d.h. es ist sehr wahrscheinlich ein Memory Problem gewesen!
                                        in den letzten Tagen sind folgende Adapter auf dem Raspi 2B gelaufen:
                                        • admin
                                        • flot
                                        • hm-rega & hm-rpc
                                        • zwei ical Instanzen
                                        • javascript
                                        • vis
                                        • web
                                        Nach einem Start hatte ich immer um die 50% freien Speicher und nach ein paar Stunden Laufzeit um die 35%, nach einigen Tagen dann 25%, aber das bleibt dann stabil! Den Parameter memoryLimitMB hab ich im iobroker.json auf 80 gesetzt.
                                        Als nächsten Adapter hab ich nun Pushbullet aktiviert - nach dem Start merkt man keinen Speichermehrverbrauch - mal die kommenden Tage abwarten, aber der Adapter scheint nicht viel zu brauchen, bzw. anscheinend erst wenn er aktiv wird….mal sehen - Waschmaschine und Trockner laufen gerade, also sollten in den kommenden Stunden auf jeden Fall man zwei Nachrichten gepusht werden 😄
                                        Ich halte euch auf dem Laufenden...
                                        etv
                                          holgerwolf last edited by
                                          ich habe nach dem Update aller Module auf meinem Banana auch das Problem das der controller nach ein paar Stunden überläuft und der Prozess gekillt wird. Auch bleibt irgendwann später die CCU hängen.
                                          Habe jetzt hier gelesen, dass man den Memory des controllers begrenzen kann. Habe also in der conf vom controller das MemoryLimit auf 100 (MB) eingestellt und alles neu gestartet. Jetzt nach einer guten Stunde ist auch schon wieder auf 130 MB angewachsen.
                                          Hab ich die falsche Stelle erwischt, oder funktioniert das nicht wie gewünscht.
                                          Holger
                                            aquapro last edited by
                                            Hallo Holger,
                                            die Angabe des Limits von 100MB betrifft wohl nicht die Gesamtgröße für den Adapter. Steht hier irgendwo in einem der Posts.
                                            Tino
                                            2716_contpage_heizung.txt
                                            2716_d_heizung_bad.txt
                                            2716_hz_heizung_bad.txt
                                            102
                                            16999
