    4. [Script] Fritz!Box Anrufmonitor incl. Ortansage
    • Uli977
      Uli977 @dslraser last edited by
      @dslraser Also Multiroom-Musik - "Überall"
      • dslraser
        dslraser Forum Testing Most Active @Uli977 last edited by
        @Uli977 sagte in [Script] Fritz!Box Anrufmonitor incl. Ortansage:
        @dslraser Die nutze ich ja auch wenn ich Alexa z.B. frage "sind noch Fenster auf!
        Da Antwortet sie aber auch nicht immer auf allen geräten
        Das sind Multiroom Musikgruppen. Poste mal Dein ganzes Script.
        Uli977 1 Reply Last reply Reply Quote 0
        • Uli977
          @dslraser
            <variables>
              <variable type="undefined" id="timeout3">timeout3</variable>
              <variable type="" id=",}E@OkW_Xp6fl4z$=k8z">caller</variable>
              <variable type="undefined" id="timeout2">timeout2</variable>
              <variable type="" id="]*a#2B4IsFp](y%Z^L[r">On call states</variable>
              <variable type="" id="eojonh*PZ~8frFA8=~W}">callerName</variable>
              <variable type="" id="^vp.rg2cH7kAuk`D@j$F">city</variable>
              <variable type="" id="8ADW~bY`3ni(H?nb@WF)">volume</variable>
              <variable type="" id="jMc+=[hFy[u]?-v!Uq2J">result</variable>
              <variable type="" id="in/X:={_riGAlY!oiiGh">speak</variable>
              <variable type="undefined" id="Intervall">Intervall</variable>
            </variables>
            <block type="on_ext" id="vc?N_0:HH+4*JEH9Uv`*" x="612" y="-313">
              <value name="OID0">
                <shadow type="field_oid" id="xvJr#y|Mtfk^d2GC5;|8">
                <block type="field_oid" id="C=|Bm%a[.%CW2w).Cy2,">
                  <field name="oid">tr-064.0.callmonitor.inbound.json</field>
                <block type="timeouts_settimeout" id="{X+(S1ZsP},trHiu:0$d">
                  <field name="NAME">timeout3</field>
                  <field name="DELAY">500</field>
                  <field name="UNIT">ms</field>
                    <block type="variables_set" id="~tjnz?svl?[3`5bw0You">
                      <field name="VAR" id=",}E@OkW_Xp6fl4z$=k8z" variabletype="">caller</field>
                        <block type="lists_split" id=".*5X{c/Zq#_QeHI/YL+0">
                          <mutation mode="SPLIT"></mutation>
                          <field name="MODE">SPLIT</field>
                          <value name="INPUT">
                            <block type="get_value" id="}y._-@NY7A}A15vB6pQf">
                              <field name="OID">tr-064.0.callmonitor.inbound.json</field>
                          <value name="DELIM">
                            <shadow type="text" id="Qgr-n@Gwi+cb/c)S;:RL">
                              <field name="TEXT">"</field>
                        <block type="variables_set" id=")pnKB4!o9)_myv.02YT(">
                            <block type="lists_getIndex" id="Zej6|F6=;(lB.wx.RYU*">
                                <block type="variables_get" id="Jrb.:gLl$Y2R|PwbPmsZ">
                              <value name="AT">
                                <block type="math_number" id="E(xLVK7@2}hY9$fGYha@">
                                  <field name="NUM">4</field>
                            <block type="debug" id="{OhM^RfQm*s^3/Pakb8k">
                              <value name="TEXT">
                                <shadow type="text" id="h0C.!COO3{4cKMW0#Nk(">
                                <block type="text_join" id="|L:o^vn2ljH9=:8{!OBu">
                                  <value name="ADD0">
                                    <block type="text" id="pV2!/ugNO+PQMF*7h:]3">
                                      <field name="TEXT">Caller ist: </field>
                                  <value name="ADD1">
                                    <block type="variables_get" id="eL%f1-K#H/O=Y^fW345b">
                                <block type="exec" id="6yVjA?LIjfOKa+T!ML4=" disabled="true">
                                  <mutation with_statement="true"></mutation>
                                  <field name="WITH_STATEMENT">TRUE</field>
                                  <field name="LOG"></field>
                                  <value name="COMMAND">
                                    <shadow type="text" id="mX-3^.@M#AGIX^fN#p^9">
                                      <field name="TEXT">bash /opt/bin/iobroker/getcity.sh </field>
                                    <block type="text_join" id="DX2s.t0/H[;A#QW)}*o6">
                                      <value name="ADD0">
                                        <block type="text" id="6`~)xWH,5anaH0W9D{2(">
                                          <field name="TEXT">cd /opt/iobroker/ &amp;&amp; bash /opt/iobroker/getcity.sh "</field>
                                      <value name="ADD1">
                                        <block type="variables_get" id="t2%4Nfa*)zVRq;S-lx*`">
                                      <value name="ADD2">
                                        <block type="text" id="2ph3E=5I02WCu|mu%h~]">
                                    <block type="debug" id="i/8r9+OqPC6RH+v#?!om">
                                      <value name="TEXT">
                                        <shadow type="text" id="5IA}J?8fXQI{[e]S+tE^">
                                        <block type="variables_get" id="((/e`jfiz)^9{WQ.HLMm">
                                          <field name="VAR" id="jMc+=[hFy[u]?-v!Uq2J" variabletype="">result</field>
                                        <block type="update" id="[4|zNAFjc6U=[Uq}[YU5">
                                          <field name="OID">javascript.0.Telegram_Benachrichtungen.Anrufer_Stadt</field>
                                            <block type="variables_get" id="/Kvcjib5-aha_$|Txped">
                                    <block type="update" id="nk:DEdFqq*YYUl.7![tk">
                                        <block type="get_value" id="2]H?MMVeb.23=Wtj@fe7">
                                          <field name="OID">javascript.0.Eigene_Datenpunkte.Telefon.Telefon</field>
                                        <block type="variables_set" id=":L(OMuy:*;LxCL2(XNW(">
                                          <field name="VAR" id="^vp.rg2cH7kAuk`D@j$F" variabletype="">city</field>
                                            <block type="get_value" id="{t:J#(Dd7/z(3^dr~_x8">
            <block type="on" id="h;7+(=CcPI7MSx+?g|*5" x="638" y="338">
              <field name="OID">tr-064.0.callmonitor.ringing</field>
                <block type="controls_if" id="jz~%.(W!P/=?kTV_ku7]">
                    <block type="logic_compare" id="5]rou1/.eV:{uyoJ9WBi">
                      <field name="OP">EQ</field>
                        <block type="get_value" id="J3ftE-m#-F!zV++dAb5_">
                          <field name="OID">tr-064.0.callmonitor.toPauseState</field>
                        <block type="text" id="WOlt|:!)g--Ht(ne(RX1">
                          <field name="TEXT">ring</field>
                    <block type="timeouts_settimeout" id="0m=,:GR8{?L9Avi*a4HL">
                      <field name="DELAY">1000</field>
                        <block type="variables_set" id="%Ycmv?OF4|eO*QfNJN8u">
                          <field name="VAR" id="]*a#2B4IsFp](y%Z^L[r" variabletype="">On call states</field>
                            <block type="get_value" id="AyC{YRMU{])q?~ypw3y[">
                            <block type="variables_set" id="xB6cV72gaYVd}tJ|F/F~">
                              <field name="VAR" id="eojonh*PZ~8frFA8=~W}" variabletype="">callerName</field>
                                <block type="get_value" id="@;dhLD{-*)CBugUX1[m,">
                                  <field name="OID">tr-064.0.callmonitor.inbound.callerName</field>
                                <block type="variables_set" id="3AoW?j~#TW0__wz(YSg*">
                                    <block type="get_value" id="Hd$FEsyLCUQvSRS(0Re3">
                                    <block type="variables_set" id="N^d}bwaf7w8K6rG[UE-q">
                                      <field name="VAR" id="8ADW~bY`3ni(H?nb@WF)" variabletype="">volume</field>
                                        <block type="text" id="k`C6ho]n6pc${aLU(`64">
                                          <field name="TEXT">100</field>
                                        <block type="variables_set" id="pEY@ZP|b*bR3rpdEUfG:">
                                          <field name="VAR" id="in/X:={_riGAlY!oiiGh" variabletype="">speak</field>
                                            <block type="get_value" id="2c;4UMfU4.ij*hm}?Btn">
                                              <field name="OID">alexa2.0.Echo-Devices.e3cc7d4739f747618c15edb4a89f1f09.Commands.speak</field>
                                            <block type="controls_if" id="qWhnWk.9%-W7`Ll-9Oia">
                                              <mutation elseif="2"></mutation>
                                                <block type="logic_operation" id="2R93jg?p}dgZfWDQu(=N">
                                                  <field name="OP">AND</field>
                                                    <block type="logic_compare" id="w?Y@t3ad/lfjM.AEPJ9|">
                                                        <block type="variables_get" id="`S-*DoS|%=MTavNbqu3N">
                                                        <block type="text" id="l6GW=4LEvh:Uhk/=-WI/">
                                                          <field name="TEXT"></field>
                                                    <block type="logic_compare" id="3{6|M/I`cRN#o6ew4o]P">
                                                        <block type="variables_get" id="w,Vj)e0MR#;:IH6x`j7r">
                                                        <block type="text" id=")2-LlV1(xiY??#tVSG-%">
                                                <block type="control" id="+{R|3o_d}lv_7z|DtjEY">
                                                  <field name="OID">alexa2.0.Echo-Devices.e3cc7d4739f747618c15edb4a89f1f09.Player.volume</field>
                                                    <block type="variables_get" id="C.StMz=bwff!{YV*,lNC">
                                                    <block type="control" id="c)g3y.{=8ObMYgm0sFq}">
                                                        <block type="text" id="_Pf|e@+:q+tMM?+PMXUH">
                                                          <field name="TEXT">Unbekannte Nummer ruft an</field>
                                              <value name="IF1">
                                                <block type="logic_compare" id="Id8Pm4pTL~6rzUGpO[PQ">
                                                    <block type="variables_get" id="U;u}p|tsVd5eMZQa3`]o">
                                                    <block type="text" id="Wt#uS@Wsw.?FfZ32AYcr">
                                              <statement name="DO1">
                                                <block type="control" id="X7x9p2n^CFx._c;`I`Tn">
                                                    <block type="variables_get" id="eielG,Luwv#R4;DDDiCW">
                                                    <block type="controls_if" id="VTqMsN/90m*;gQJ,70_k">
                                                        <block type="logic_compare" id="K$_aGy^M*S|zNMBiVQl]">
                                                            <block type="text_indexOf" id="I#A*3T%IcR?$P(btGX6H">
                                                              <field name="END">FIRST</field>
        <block type="variables_get" id="s[;cYRe~:z;u(,ckjSW.">
                                                              <value name="FIND">
        <shadow type="text" id="O*KqyH6[aTE^|kX9%0y~">
        <field name="TEXT">abc</field>
        <block type="text" id="JF2Yua~Ck%Gr+j[gi01[">
        <field name="TEXT">Handynummer</field>
                                                            <block type="math_number" id="STb|[s+ZDZ7mN,h,n*?G">
                                                              <field name="NUM">0</field>
                                                        <block type="control" id="{KV#]dIN(^+wrG*6RVxj">
                                                            <block type="text_join" id="YpC=g*@Vs^J#ZkJw_a%b">
                                                              <mutation items="4"></mutation>
                                                              <value name="ADD0">
        <block type="text" id="rCblWLIuGh%Du.vNJ!5u">
        <field name="TEXT">Anruf aus  </field>
                                                              <value name="ADD1">
        <block type="variables_get" id=",hkMeXv{vHCiNHT_^!dR">
                                                              <value name="ADD2">
        <block type="text" id="%Hqrz;-zU0x_#UOdT_0}">
        <field name="TEXT"> mit der Nummer </field>
                                                              <value name="ADD3">
        <block type="variables_get" id="uk]k`_=P7Z`bCb3RoT-M">
                                                      <value name="IF1">
                                                        <block type="logic_compare" id="sDwTdRBZQ:AvZh^iGU?L">
                                                          <field name="OP">GT</field>
                                                            <block type="text_indexOf" id="2`a%dAOg]:a=|S.b:[q|">
        <block type="variables_get" id="N,V,ZB)0Eeg7t7yoH}^P">
                                                              <value name="FIND">
        <block type="text" id="x3(JMn);F^nuJ_*(2XxW">
                                                            <block type="math_number" id="0^*sx@#*`=c@%MT*E.3m">
                                                        <block type="control" id="~iSd^neX(+(JJ!fE{PE+">
                                                            <block type="text_join" id="NXgXq9-*lV%XcVAOC-kF">
                                                              <value name="ADD0">
        <block type="text" id="$T?EIUY%^5cD?;RSwb-I">
        <field name="TEXT">Ein Anruf mit der Nummer </field>
                                                              <value name="ADD1">
        <block type="variables_get" id="kbY`n@+E/E(bI{TG@z!-">
                                              <value name="IF2">
                                                <block type="logic_compare" id=".SPH-wnl,Ggyv^K(EB?5">
                                                  <field name="OP">NEQ</field>
                                                    <block type="variables_get" id="FNC7Ui|N(XQL_r3vQ-~u">
                                                    <block type="text" id="?7c}zrB02lQ@}_kYT01=">
                                              <statement name="DO2">
                                                <block type="control" id="#jy%Gup{T9NYA9ii8:Xf">
                                                    <block type="variables_get" id="s4[5%k%=~B0FcKAf9NBW">
                                                    <block type="control" id="dkpf|36YXjYE;I#=E{/j">
                                                        <block type="text_join" id="[J5,Xv05{NVoesX?X{)^">
                                                          <value name="ADD0">
                                                            <block type="variables_get" id="JTv1,B#9IQ.6WXs~BiC^">
                                                          <value name="ADD1">
                                                            <block type="text" id="TsxCXnXUiJWE5+hzN?W4">
                                                              <field name="TEXT">ruft an</field>
                                                <block type="timeouts_setinterval" id="v_Bqgg{C;}*SlNxMx+{v">
                                                  <field name="NAME">Intervall</field>
                                                  <field name="INTERVAL">8000</field>
                                                    <block type="variables_set" id=":+L^L#%w}TaZ,oF%%Hee">
                                                        <block type="get_value" id="/jrF]ty4e!p+AvASy8G)">
                                                        <block type="controls_if" id="j87.ZsAyGl(mU8^*6Tr;">
                                                          <mutation elseif="3"></mutation>
                                                            <block type="logic_operation" id="*u%zOMGy%F@!-}CJQlsp">
                                                              <field name="OP">OR</field>
        <block type="logic_compare" id="Ia?0)w*#[cTW9d%,3*^w">
        <block type="variables_get" id="^jM5pL6QJBLg%]o:C#PW">
        <block type="text" id="w5`CFx@zd-,jjjDnp0~`">
        <field name="TEXT">end</field>
        <block type="logic_compare" id="#M!]E7h3!{o=E*ekb|xy">
        <block type="variables_get" id=")3Ks~V`4HOPFyOMc`yLm">
        <block type="text" id="It4NApphzKDp+{e4ch!w">
        <field name="TEXT">connect</field>
                                                            <block type="control" id="}R~N3@uq}FDl0Z62!^Vw">
        <block type="text" id="F.Di%NWzTMz71Kg+])l,">
        <block type="control" id="5yGux~{xs{gf=a+U0%,H">
        <field name="OID">tr-064.0.callmonitor.inbound.caller</field>
        <block type="text" id="*T{w@^.{ju_Y,3467f2B">
        <block type="timeouts_clearinterval" id="YV5b]tFF(N3}/Lm)NYs(">
                                                          <value name="IF1">
                                                            <block type="logic_operation" id=")acAXba{I:?)mwY3FQ5M">
        <block type="logic_compare" id="TW9fh_{`g@VCF%A[XfCq">
        <block type="variables_get" id="E5o!zD)|PmZcj2Pd=]fi">
        <block type="text" id="Ji[:io{=QH_Pjfl-[;eB">
        <block type="logic_compare" id="1l.]F[voVkI.Ip:8:2[q">
        <block type="variables_get" id="8#-f}ub^-tzPf#%Der3i">
        <block type="text" id="OAqQ.JTGuNcQN-=!rb%U">
                                                            <block type="control" id="2^.c]$0}n(cyjCzTz;3X">
        <block type="variables_get" id="R?q5@,u~EkGIZA|cc0*y">
        <block type="control" id="xZSRRHYE],He4Q7er=)%">
        <block type="text" id="1OnbUqQlKCyVrjnS=*^l">
                                                          <value name="IF2">
                                                            <block type="logic_compare" id="}Ts:wbNat#zfS[n*z;b:">
        <block type="variables_get" id="O0Dws_Q#Y)mm~xb(@A3X">
        <block type="text" id="^!^KZ!ubH3AzTa+!-k;R">
                                                            <block type="control" id="O:[(6j%l|(hs.)d46uS|">
        <block type="variables_get" id="X)[QK{c:WMMfz4oi0D#U">
        <block type="controls_if" id="sVBk/^uA]t,~^Nzb=Zfa">
        <block type="logic_compare" id="x?{sMo$C0+Ni=cGQ.6J)">
        <block type="text_indexOf" id="JH#6]@7EY+ndf:~TNg$G">
        <block type="variables_get" id="[|*6p;IQLVxy;qO#,:!t">
        <value name="FIND">
        <block type="text" id="}4Ej@eshPHN1mTV|7GeV">
        <block type="math_number" id="BVLMShFRJ~`vvvtNbV^`">
        <block type="control" id="A[#=rD/0r$*V9$1Eo}6d">
        <block type="text_join" id="X-KmEI?v;8h%y#b|n{BQ">
        <value name="ADD0">
        <block type="text" id="{fdtYn1NcRx/kT4h=-g/">
        <field name="TEXT">Ein Anruf aus  </field>
        <value name="ADD1">
        <block type="variables_get" id="16HJmm1*Ef)i+1vGUaL*">
        <value name="ADD2">
        <block type="text" id="CPx#mg[T1G~_r#Kgubpk">
        <value name="ADD3">
        <block type="variables_get" id="DL1,J^xa}`r#jy?w5Fru">
        <value name="IF1">
        <block type="logic_compare" id="9?dq*cEy?5z*jB=IjABT">
        <block type="text_indexOf" id="{{N%4o9m,;GJlhF]E]~O">
        <block type="variables_get" id="on[#!LiD`Yd^rvUPC:s;">
        <value name="FIND">
        <block type="text" id="]B`Q.*vLO|S`IP{B2WKG">
        <block type="math_number" id="s!rE^59A5Dt={~njy6{A">
        <block type="control" id="_A{0LW.[eT=80Ai$$Kb8">
        <block type="text_join" id="@9vHH%5tVM9syqKA2Uz?">
        <value name="ADD0">
        <block type="text" id="qhw6j%*bT{TJd_PM{+VC">
        <value name="ADD1">
        <block type="variables_get" id=":Jc*ZxS-Bx~S6H^J9Sof">
                                                          <value name="IF3">
                                                            <block type="logic_compare" id="B^(=1b~0d-~WUK.OMhk]">
        <block type="variables_get" id="O0HAfh;q;n6j|g}u_(he">
        <block type="text" id="q-/pp:e@(F6A)ETnVBYj">
                                                          <statement name="DO3">
                                                            <block type="control" id="96y:F1wL.iTuSZz}J+m-">
        <block type="text_join" id="xF3bryAsT6V^`U~lsIj]">
        <value name="ADD0">
        <block type="variables_get" id="jHwoqHPN%dHtS7q9psKS">
        <value name="ADD1">
        <block type="text" id="-Rt9?+F[-Xv2f@i2YZ;@">
          • dslraser
            dslraser Forum Testing Most Active @Uli977 last edited by dslraser
            @Uli977
            Was mir so auf die Schnelle aufgefallen ist (ich kann Dein Blockly aber nicht testen, da ich den Community installiert habe)
            Volume sollte eine Zahl sein (ist bei Dir Text)
            und speak hast Du zwar angelegt, nutzt es aber nicht. (kommt nicht vor in Deinem Blockly)
            Speak könntest Du so nutzen
            • Uli977
              @dslraser Ok, das mit dem Wert habe ich korrigiert.
              Das mit dem speak ist mir nicht ganz klar..... hab das Skipt ja auch übernommen.
              • dslraser
                geht ja auch so wie Du es hast, aber speak wird nicht genutzt, sehe ich nirgends, dann kannst Du es auch deaktivieren oder löschen.
                Ich sehe hier kein verwendetes speak als Variable...
                • Uli977
                  @dslraser Ja, verstanden!
                    amsernat last edited by
                    ich habe den tr-064.0 durch Community-Adapter ersetzt, und die Datenpunkte habe ich alle aktualisiert.
                    nun funktioniert den Anruf Monitor von Elzershark nicht mehr.
                    der Adapter an sich funktioniert nur der Befehl an Alexa-Echo geht nicht durch.
                    tr-064-community.0.callmonitor.ringing => zeigt true wenn ich anrufe.
                    tr-064-community.0.callmonitor.toPauseState => zeigt ring wenn ich anrufe.
                    inbound.caller und .callerName werde auch aktualisiert.
                    im Log ist kein Fahler:
                    javascript.0	2019-12-25 10:34:25.441	info	(13687) script.js.Geräte.Anrufmonitor: registered 1 subscription and 0 schedules
                    javascript.0	2019-12-25 10:34:25.431	info	(13687) Start javascript script.js.Geräte.Anrufmonitor
                    javascript.0	2019-12-25 10:34:17.725	info	(13687) Stop script script.js.Geräte.Anrufmonitor
                    javascript.0	2019-12-25 10:34:15.894	info	(13687) script.js.Geräte.AnrufmonitorStudio: registered 1 subscription and 0 schedules
                    javascript.0	2019-12-25 10:34:15.871	info	(13687) Start javascript script.js.Geräte.AnrufmonitorStudio
                    tuya.0	2019-12-25 10:32:33.447	info	(21147) bf1xxx90xxxp19m Init with IP=addr:192.168.178.75, Key=1f8dxxxxxxxxx74, Version=3.2
                    tuya.0	2019-12-25 10:29:28.367	info	(21147) bfxxxxx76xx13p19m Init with IP=addr:192.168.178.75, Key=1f8xxxxxxxxe074, Version=3.2
                    kann mir bitte jemand sagen woran es liegen könnte?
                    Patchwork 3001 1 Reply Last reply Reply Quote 1
                    • Patchwork 3001
                      Patchwork 3001 @amsernat last edited by
                      @amsernat
                      konntest du das Problem löse?
                      habe das selbe Problem
                      • Patchwork 3001
                        Patchwork 3001 last edited by
                        Für matze19999
                        15802211110702152428750969910933.jpg 15802211508627628450050981694250.jpg 15802211739884751994368958647983.jpg
                          matze19999 last edited by
                          [UPDATE]
                          ich habe eine neue Version der getcity.sh hochgeladen, welche nun immer die richtigen Ortsnamen ausspuckt. Die alte Version hat den falschen Ort gewählt wenn eine Vorwahl in einer anderen Vorwahl nochmal vorkam, z.B. 821 in 8821
                          Viele Grüße
                          Matze19999
                          Uli977 1 Reply Last reply Reply Quote 1
                          • Uli977
                            Uli977 @matze19999 last edited by Uli977
                            @matze19999 Hi!
                            Sag mal wo bezieht das Skript den Namen des Anrufers her?
                            Viele Grüße,
                            Uli
                            EDIT: Hat sich erledigt, hätte ich auch selber drauf kommen können. FritzBox Telefonbuch!
                            • D3ltoroxp
                              D3ltoroxp @liv-in-sky last edited by D3ltoroxp
                              @liv-in-sky Hallo, Danke erst mal das du das geteilt hast. Würde das gerne mal probieren. Ich bin nicht so fit in der ganzen Materie und würde da gerne die einfachere Variante nutzten. Woher bezieht dein Script die passende Stadt zur Vorwahl ? In deinem Script habe ich schon Vorwahlen und deren Städte gesehen, ist das dann alles ? Wird das automatisch erweitert, oder müsste ich dort alles von Hand eintragen ?
                              Noch was, ich nutze ja auch das original Script von ElzerShark. Hat ja bis jetzt geklappt. Wenn ich nun die Infos aus deinem Script mit einbinde läuft es auch wunderbar, nur klingt es dann etwas komisch wenn z..b nicht die Stadt im Datenpunkt steht sondern Handy Vorwahl oder 0800 Nummer, da meine Ansage ja wäre : Ein unbekannter Anruf aus "Handy Vorwahl" mit der Nummer 01520 xxxxxx
                              Wie hast du das gelöst, das der Text quasi zum Datenpunkt passt ? Ich müsste das Filtern und mehr Aussagen basteln, je nachdem was zutrifft. Indem Fall müsste dann kommen "Ein unbekannter Handy Anruf mit der Nummer 01520 xxxx " Hier wäre das Netz vllt noch eine Zusatzinfo, vllt könnte man sich da eine Liste anlegen oder in deinem Script noch mit erstellen, wenn die und die Vorwahl dann Handy Nummer aus dem Vodafone Netz z.b.
                                liv-in-sky @D3ltoroxp last edited by
                                @D3ltoroxp
                                die vorwahl und die städte sind im script enthalten - falls neue städte entstehen oder sich darin etwas ändert, mußt du dies im script anpassen - bzw die zuweisungen ändern - ansonsten müßte man eine offizielle vorwahl-datenbank über eine api anfragen - ist nicht geplant
                                ich denke mal du mußt die ansage nach nummer filtern - ich lasse mir das nicht ausgeben sondern nur in der vis anzeigen - sollte aber mit einer oder 2 if-abfragen zu machen sein - einfach abfragen was drinsteht und dann eine andere ansage nutzen
                                die zusatzanzeige zu welchen netz gehört die handy nummer macht für mich keinen sinn, da wir unsere nummern mitnehmen können und es dadurch keine nummernzuweisung zu einem netz gibt - deshalb steht da nur handynummer
                                • D3ltoroxp
                                  @liv-in-sky said in [Script] Fritz!Box Anrufmonitor incl. Ortansage:
                                  Ja stimmt auch wieder, ganz vergessen. Dann schau ich mal wie ich das mit der Ansage hin bekomme, das sie immer passend spricht.
                                  matze55 1 Reply Last reply Reply Quote 0
                                  • matze55
                                    matze55 @D3ltoroxp last edited by matze55
                                    Hallo...ist schon lange her das Thema man möge mir verzeihen...ich habe mir das Script von liv-in-sky angeschaut. Habe mir den Datenpunkt unter 0_userdata.0 erstellt.
                                    In javascript habe ich mir sein Script eingefügt. Läuft auch alles super. Gibt auch keine Fehler ect..
                                    Nun Folgendes Problem, gebe ich im Anrufmonitor den Ich aus einem Post hier habe(Danke an Sigi234-Tolle Arbeit was ihr hier macht) die Vorwahl von Magdeburg ein(0391)...sollte doch eigentlich die Abfrage ergeben Ort: Magdeburg.
                                    Also Eingabe Ort im Widgets---Ausgabe
                                    6987
