    4. js-controller 2.2 jetzt für Alle im Stable
      crunchip Forum Testing Most Active @apollon77 last edited by crunchip
      @apollon77 sonst gab es im log nichts unauffälliges
      ausser das noch:
      shelly.0	2020-01-29 17:39:44.359	warn	(1869) no connection to objects DB
      info.0	2020-01-29 17:38:59.890	warn	(1316) no connection to states DB
      2020-01-29 17:38:09.773 - warn: backitup.0 (1042) no connection to states DB
      2020-01-29 17:38:11.815 - warn: broadlink2.0 (1096) no connection to objects DB
      2020-01-29 17:38:49.514 - warn: ical.0 (1265) no connection to states DB
      2020-01-29 17:38:49.921 - warn: ical.1 (1276) no connection to states DB
      ansonsten lief dann auch alles wieder ganz normal
      Ich kann es dann nochmal versuchen, nachzustellen
      das ist das komplette simple-api log,von vorhin
      simple-api.0	2020-01-29 17:41:15.404	info	(2481) http server listening on port 8087
      simple-api.0	2020-01-29 17:41:15.398	info	(2481) Allow states only when user is owner: false
      simple-api.0	2020-01-29 17:41:15.397	info	(2481) simpleAPI server listening on port 8087
      simple-api.0	2020-01-29 17:41:15.323	info	(2481) starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.18.0
      simple-api.0	2020-01-29 17:40:42.598	info	(2016) Terminated (NO_ERROR): Without reason
      simple-api.0	2020-01-29 17:40:42.596	info	(2016) terminating
      simple-api.0	2020-01-29 17:40:42.513	info	(2016) terminating http server on port 8087
      simple-api.0	2020-01-29 17:40:42.511	error	at process._tickCallback (internal/process/next_tick.js:68:7)
      simple-api.0	2020-01-29 17:40:42.511	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      simple-api.0	2020-01-29 17:40:42.511	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      simple-api.0	2020-01-29 17:40:42.511	error	at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
      simple-api.0	2020-01-29 17:40:42.511	error	(2016) TypeError: Cannot read property 'common' of null
      simple-api.0	2020-01-29 17:40:42.510	error	(2016) uncaught exception: Cannot read property 'common' of null
      simple-api.0	2020-01-29 17:39:53.624	info	(2016) http server listening on port 8087
      simple-api.0	2020-01-29 17:39:53.617	info	(2016) Allow states only when user is owner: false
      simple-api.0	2020-01-29 17:39:53.616	info	(2016) simpleAPI server listening on port 8087
      simple-api.0	2020-01-29 17:39:53.520	info	(2016) starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.18.0
        @apollon77 bei dem Versuch es nachzustellen, trat der Fehler (leider) nicht mehr auf
        was jedoch noch aufgefallen ist
        alexa2.0, socketio, wiffi-wz, tuya,
        allesamt ---terminated with code 156
        2020-01-29 19:09:24.623 - warn: host.IoBroker instance system.adapter.email.0 terminated due to SIGTERM
        2020-01-29 19:09:24.623 - info: host.IoBroker instance system.adapter.email.0 terminated with code null ()
        2020-01-29 19:09:24.625 - warn: host.IoBroker instance system.adapter.milight.0 terminated due to SIGTERM
        2020-01-29 19:09:24.625 - info: host.IoBroker instance system.adapter.milight.0 terminated with code null ()
        2020-01-29 19:09:24.627 - warn: host.IoBroker instance system.adapter.onkyo.0 terminated due to SIGTERM
        2020-01-29 19:09:24.628 - info: host.IoBroker instance system.adapter.onkyo.0 terminated with code null ()
        2020-01-29 19:09:24.629 - warn: host.IoBroker instance system.adapter.roadtraffic.0 terminated due to SIGTERM
        2020-01-29 19:09:24.630 - info: host.IoBroker instance system.adapter.roadtraffic.0 terminated with code null ()
        2020-01-29 19:09:24.632 - warn: host.IoBroker instance system.adapter.admin.0 terminated due to SIGTERM
        2020-01-29 19:09:24.632 - info: host.IoBroker instance system.adapter.admin.0 terminated with code null ()
        2020-01-29 19:09:24.634 - warn: host.IoBroker instance system.adapter.amazon-dash.0 terminated due to SIGTERM
        2020-01-29 19:09:24.635 - info: host.IoBroker instance system.adapter.amazon-dash.0 terminated with code null ()
        2020-01-29 19:09:24.637 - warn: host.IoBroker instance system.adapter.backitup.0 terminated due to SIGTERM
        2020-01-29 19:09:24.637 - info: host.IoBroker instance system.adapter.backitup.0 terminated with code null ()
        2020-01-29 19:09:24.639 - warn: host.IoBroker instance system.adapter.ble.0 terminated due to SIGTERM
        2020-01-29 19:09:24.639 - info: host.IoBroker instance system.adapter.ble.0 terminated with code null ()
        2020-01-29 19:09:24.641 - warn: host.IoBroker instance system.adapter.broadlink2.0 terminated due to SIGTERM
        2020-01-29 19:09:24.641 - info: host.IoBroker instance system.adapter.broadlink2.0 terminated with code null ()
        2020-01-29 19:09:24.643 - info: host.IoBroker instance system.adapter.alexa2.0 terminated with code 156 (156)
        2020-01-29 19:09:24.646 - warn: host.IoBroker instance system.adapter.discovery.0 terminated due to SIGTERM
        2020-01-29 19:09:24.646 - info: host.IoBroker instance system.adapter.discovery.0 terminated with code null ()
        2020-01-29 19:09:24.648 - warn: host.IoBroker instance system.adapter.fullybrowser.0 terminated due to SIGTERM
        2020-01-29 19:09:24.648 - info: host.IoBroker instance system.adapter.fullybrowser.0 terminated with code null ()
        2020-01-29 19:09:24.650 - warn: host.IoBroker instance system.adapter.info.0 terminated due to SIGTERM
        2020-01-29 19:09:24.650 - info: host.IoBroker instance system.adapter.info.0 terminated with code null ()
        2020-01-29 19:09:24.653 - warn: host.IoBroker instance system.adapter.iogo.0 terminated due to SIGTERM
        2020-01-29 19:09:24.653 - info: host.IoBroker instance system.adapter.iogo.0 terminated with code null ()
        2020-01-29 19:09:24.655 - warn: host.IoBroker instance system.adapter.iot.0 terminated due to SIGTERM
        2020-01-29 19:09:24.655 - info: host.IoBroker instance system.adapter.iot.0 terminated with code null ()
        2020-01-29 19:09:24.657 - warn: host.IoBroker instance system.adapter.mihome.0 terminated due to SIGTERM
        2020-01-29 19:09:24.657 - info: host.IoBroker instance system.adapter.mihome.0 terminated with code null ()
        2020-01-29 19:09:24.659 - warn: host.IoBroker instance system.adapter.pollenflug.0 terminated due to SIGTERM
        2020-01-29 19:09:24.660 - info: host.IoBroker instance system.adapter.pollenflug.0 terminated with code null ()
        2020-01-29 19:09:24.662 - warn: host.IoBroker instance system.adapter.radar2.0 terminated due to SIGTERM
        2020-01-29 19:09:24.662 - info: host.IoBroker instance system.adapter.radar2.0 terminated with code null ()
        2020-01-29 19:09:24.664 - warn: host.IoBroker instance system.adapter.shelly.0 terminated due to SIGTERM
        2020-01-29 19:09:24.664 - info: host.IoBroker instance system.adapter.shelly.0 terminated with code null ()
        2020-01-29 19:09:24.667 - info: host.IoBroker instance system.adapter.socketio.0 terminated with code 156 (156)
        2020-01-29 19:09:24.669 - warn: host.IoBroker instance system.adapter.sonoff.0 terminated due to SIGTERM
        2020-01-29 19:09:24.669 - info: host.IoBroker instance system.adapter.sonoff.0 terminated with code null ()
        2020-01-29 19:09:24.671 - warn: host.IoBroker instance system.adapter.sourceanalytix.0 terminated due to SIGTERM
        2020-01-29 19:09:24.671 - info: host.IoBroker instance system.adapter.sourceanalytix.0 terminated with code null ()
        2020-01-29 19:09:24.674 - warn: host.IoBroker instance system.adapter.tankerkoenig.0 terminated due to SIGTERM
        2020-01-29 19:09:24.674 - info: host.IoBroker instance system.adapter.tankerkoenig.0 terminated with code null ()
        2020-01-29 19:09:24.676 - warn: host.IoBroker instance system.adapter.telegram.0 terminated due to SIGTERM
        2020-01-29 19:09:24.676 - info: host.IoBroker instance system.adapter.telegram.0 terminated with code null ()
        2020-01-29 19:09:24.678 - warn: host.IoBroker instance system.adapter.telegram.1 terminated due to SIGTERM
        2020-01-29 19:09:24.678 - info: host.IoBroker instance system.adapter.telegram.1 terminated with code null ()
        2020-01-29 19:09:24.681 - warn: host.IoBroker instance system.adapter.text2command.0 terminated due to SIGTERM
        2020-01-29 19:09:24.681 - info: host.IoBroker instance system.adapter.text2command.0 terminated with code null ()
        2020-01-29 19:09:24.683 - warn: host.IoBroker instance system.adapter.upnp.0 terminated due to SIGTERM
        2020-01-29 19:09:24.683 - info: host.IoBroker instance system.adapter.upnp.0 terminated with code null ()
        2020-01-29 19:09:24.685 - warn: host.IoBroker instance system.adapter.virtualpowermeter.0 terminated due to SIGTERM
        2020-01-29 19:09:24.686 - info: host.IoBroker instance system.adapter.virtualpowermeter.0 terminated with code null ()
        2020-01-29 19:09:24.688 - warn: host.IoBroker instance system.adapter.web.0 terminated due to SIGTERM
        2020-01-29 19:09:24.688 - info: host.IoBroker instance system.adapter.web.0 terminated with code null ()
        2020-01-29 19:09:24.690 - info: host.IoBroker instance system.adapter.wiffi-wz.0 terminated with code 156 (156)
        2020-01-29 19:09:24.692 - warn: host.IoBroker instance system.adapter.fullcalendar.0 terminated due to SIGTERM
        2020-01-29 19:09:24.693 - info: host.IoBroker instance system.adapter.fullcalendar.0 terminated with code null ()
        2020-01-29 19:09:24.695 - warn: host.IoBroker instance system.adapter.chromecast.0 terminated due to SIGTERM
        2020-01-29 19:09:24.695 - info: host.IoBroker instance system.adapter.chromecast.0 terminated with code null ()
        2020-01-29 19:09:24.698 - warn: host.IoBroker instance system.adapter.tr-064.0 terminated due to SIGTERM
        2020-01-29 19:09:24.698 - info: host.IoBroker instance system.adapter.tr-064.0 terminated with code null ()
        2020-01-29 19:09:24.700 - warn: host.IoBroker instance system.adapter.simple-api.0 terminated due to SIGTERM
        2020-01-29 19:09:24.701 - info: host.IoBroker instance system.adapter.simple-api.0 terminated with code null ()
        2020-01-29 19:09:24.703 - warn: host.IoBroker instance system.adapter.javascript.0 terminated due to SIGTERM
        2020-01-29 19:09:24.704 - info: host.IoBroker instance system.adapter.javascript.0 terminated with code null ()
        2020-01-29 19:09:24.706 - warn: host.IoBroker instance system.adapter.javascript.1 terminated due to SIGTERM
        2020-01-29 19:09:24.706 - info: host.IoBroker instance system.adapter.javascript.1 terminated with code null ()
        2020-01-29 19:09:25.742 - info: tuya.0 (2167) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2020-01-29 19:09:26.270 - info: host.IoBroker instance system.adapter.tuya.0 terminated with code 156 (156)
          apollon77 @crunchip last edited by
          @crunchip bei was kam Das? Beim
          Stoppen? Da wurden die Prozesse gekillt.
            @crunchip zu simple api ist bei mir eher die Frage was ggf für ein Zugriff über die api reinkam. Der Fehler kommt einige Zeit nachdem der Adapter Gestartet wurde. wenn du es nachstellen kannst können wir tiefer reinschauen wines genau knallt. Vllt hilft dir das ne Idee zu kriegen ? Was könnte es gewesen sein? Vllt anhand des zeitstempels?
              @apollon77 ja das war das stoppen.
              Leider kenn ich die einzelnen codes und ihre Bedeutung nicht. Da alle mit sigterm ...code null beendet wurden, bis auf die 4 genannten
                @crunchip der Unterschied ist nur bissl wie schnell sie stoppen und so. Also alles ok.
                  @apollon77 wie schon geschrieben, konnte es leider nicht nachstellen,
                  ich wüsste auch gar nicht wo, wie und nach was ich suchen sollte.
                    @crunchip also meine Vermutung ist das es mit dem Start nichts zu tun hatte sondern irgendein api request an den Adapter das verursacht hat.
                      @apollon77 einzige was ich die letzte Zeit installiert habe, ist das Projekt https://github.com/SBorg2014/WLAN-Wetterstation/wiki/Installation---Teil-2
                      • umbm
                        umbm last edited by
                        Ich habe seit dem Update ständige Neustarts ca alle 2 Minuten
                        im Log:
                        admin.0	2020-01-29 20:24:33.044	info	(6054) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        admin.0	2020-01-29 20:24:33.043	info	(6054) terminating
                        admin.0	2020-01-29 20:24:33.043	info	(6054) terminating http server on port 8081
                        admin.0	2020-01-29 20:24:33.041	warn	(6054) Got terminate signal. Checking desired PID: vs own PID 6054
                        habe schon alle Schritte aus Post 1 versucht, ohne Erfolg.
                          apollon77 @umbm last edited by
                          @umbm stoppe Info mal. Lass paar mins aus und aktiviere ihn wieder.
                          • umbm
                            umbm last edited by umbm
                            Leider keine Änderung nach 5 Minuten ohne info-adapter
                            Aufgefallen ist es mir nach dem Update eigentlich nur, weil das Tablet mit dem VIS regelmäßig weiß wurde.
                            Nachtrag:
                            Kann ich eigentlich ohne weiteres auf die Vorversion zurück gehen?
                            • umbm
                              umbm last edited by
                              @apollon77 sagte in js-controller 2.2 jetzt für Alle im Stable:
                              Moment, oben steht:
                              iqontrol 0.2.15
                              Mir wird aber bisher nur iqontrol 0.2.14 angeboten.
                              Kann das die Ursache sein?
                                @umbm mal js-Controller neu gestartet bzw rebootet?
                                umbm 1 Reply Last reply Reply Quote 0
                                • umbm
                                  umbm @apollon77 last edited by
                                  Ja, natürlich.
                                  Habe jetzt aus dem Latest iqontrol 0.2.16 installiert.
                                  Der Fehler besteht aber auch damit weiterhin.
                                    @umbm nein das kann es nicht sein.
                                    Also bei Dir wird in den "sigKill" Datenpunkt scheinbar ein leerer Wert geschrieben ... das Thema ist: Das sollte niemand tun. Da sollten nur Zahlen drin landen. Die Frage ist halt wer und warum da diese Werte reinschreibt. Du hast kein Script was da irgendwas tut?
                                    Ich hätte jetzt gesagt aktiviere mal history adater für system.adapter.admin.0 (sorry war ja admin und nicht info) und zeig mal was da so geloggt wird.
                                    An sich wird da zum Adapterstart eine Zahl reingschrieben und ggf spöter auf 0 gesetzt oder -1 ... aber das sollte es gewesen sein.
                                    • umbm
                                      Stimmt!
                                      Durch deinen Tipp habe ich das gefunden:
                                      Ich habe aber keine Ahnung, woher mqtt das bekommen könnte, ein script darauf gibt es definitiv nicht.
                                      Vor dem Update des js-controllers ist es nie aufgetreten. 😕
                                        @umbm Also alle system.adapter.* States sollten nur sehr mit vorsicht beschrieben werden. Aber das ist mal mindestens der Grund warum es passiert. Vor allem was macht da ein Leerzeichen drin 🙂
                                        • umbm
                                          @apollon77
                                          Ich lasse es definitiv nicht reinschreiben!
                                          Wie gesagt, begann das Prob nach dem Update.
                                          Inzwischen habe ich festgestellt, dass auch diverse andere Adapter permanent gekillt und wieder gestartet werden.
                                          Nach jedem Neustart von ioBroker trifft es anscheinend andere Adapter, im Moment wird mqtt, admin, telegram, javascript reihum immer wieder gekillt. 😵
                                          Admin ist immer dabei und macht die Diagnose nicht einfacher.
                                            @umbm Das es vor dem Update nicht so war mag ja so sein aber am Ende wurde an der Art und weise wie sigKill tut was optimiert. Dennoch: Die Ursache ist wie Du selbst gesehen hast das dein mqtt.0 da Werte reinschreibt. Finde heraus warum und unterbinde es und das Problem ist weg.
                                            Und wenn du mqtt.0 mal ausschaltest? beruhigt es sich dann?
                                            js-controller
                                            28
                                            142
                                            16622
