    4. Neuer Adapter: SMA Wechselrichter mit sbfspot
    • Rene_HM
      Rene_HM Developer @wm20320 last edited by
      @wm20320 schau mal, was im browser in der web-console steht, vielleicht hilft das...
      • Rene_HM
        Rene_HM Developer @Tottbeck last edited by
        @Tottbeck sagte in Neuer Adapter: SMA Wechselrichter mit sbfspot:
        Das muß doch zwingend im iobroker.sbfsport-Verzeichnis sind, oder ?
        ja.
          Tottbeck @Rene_HM last edited by Tottbeck
          @Rene_HM
          2020-01-12T14_53_55_158Z-debug.log
          Habe versucht npm nochmal zu installieren, klappt aber nicht.
          root@raspberrypi:/opt/iobroker/node_modules/iobroker.sbfspot# sudo npm clean-install
          npm WARN prepare removing existing node_modules/ before installation
          > sqlite3@4.1.1 install /opt/iobroker/node_modules/iobroker.sbfspot/node_module/sqlite3
          > node-pre-gyp install --fallback-to-build
          node-pre-gyp info it worked if it ends with ok
          node-pre-gyp info using node-pre-gyp@0.11.0
          node-pre-gyp info using node@8.16.0 | linux | arm
          node-pre-gyp WARN Using request for node-pre-gyp https download
          node-pre-gyp info check checked for "/opt/iobroker/node_modules/iobroker.sbfspo/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite3.node" (not fond)
          node-pre-gyp http GET https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.1./node-v57-linux-arm.tar.gz
          node-pre-gyp http 403 https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.1./node-v57-linux-arm.tar.gz
          node-pre-gyp WARN Tried to download(403): https://mapbox-node-binary.s3.amazonas.com/sqlite3/v4.1.1/node-v57-linux-arm.tar.gz
          node-pre-gyp WARN Pre-built binaries not found for sqlite3@4.1.1 and node@8.16. (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
          node-pre-gyp http 403 status code downloading tarball https://mapbox-node-binar.s3.amazonaws.com/sqlite3/v4.1.1/node-v57-linux-arm.tar.gz
          gyp info using node-gyp@3.8.0
          gyp info ok
          gyp info spawn /usr/bin/python2
          gyp info spawn args [ '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_ain.py',
          gyp info spawn args   'binding.gyp',
          gyp info spawn args   '-f',
          gyp info spawn args   'make',
          gyp info spawn args   '-I',
          gyp info spawn args   '/opt/iobroker/node_modules/iobroker.sbfspot/node_modulessqlite3/build/config.gypi',
          gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gyi',
          gyp info spawn args   '/root/.node-gyp/8.16.0/include/node/common.gypi',
          gyp info spawn args   '-Dlibrary=shared_library',
          gyp info spawn args   '-Dvisibility=default',
          gyp info spawn args   '-Dnode_root_dir=/root/.node-gyp/8.16.0',
          gyp info spawn args   '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/noe-gyp',
          gyp info spawn args   '-Dnode_lib_file=/root/.node-gyp/8.16.0/<(target_arch)/noe.lib',
          gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.sbspot/node_modules/sqlite3',
          gyp info spawn args   '-Dnode_engine=v8',
          gyp info spawn args   '--depth=.',
          gyp info spawn args   '--no-parallel',
          gyp info spawn args   '--generator-output',
          gyp info spawn args   'build',
          gyp info spawn args   '-Goutput_dir=.' ]
          gyp info ok
          gyp info spawn make
          gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
          make: Entering directory '/opt/iobroker/node_modules/iobroker.sbfspot/node_modues/sqlite3/build'
            ACTION deps_sqlite3_gyp_action_before_build_target_unpack_sqlite_dep Release/bj/gen/sqlite-autoconf-3300100/sqlite3.c
            TOUCH Release/obj.target/deps/action_before_build.stamp
            CC(target) Release/obj.target/sqlite3/gen/sqlite-autoconf-3300100/sqlite3.o
          cc: internal compiler error: Killed (program cc1)
          Please submit a full bug report,
          with preprocessed source if appropriate.
          See <file:///usr/share/doc/gcc-6/README.Bugs> for instructions.
          deps/sqlite3.target.mk:129: recipe for target 'Release/obj.target/sqlite3/gen/slite-autoconf-3300100/sqlite3.o' failed
          make: *** [Release/obj.target/sqlite3/gen/sqlite-autoconf-3300100/sqlite3.o] Eror 4
          make: Leaving directory '/opt/iobroker/node_modules/iobroker.sbfspot/node_moduls/sqlite3/build'
          gyp ERR! build error
          gyp ERR! stack Error: `make` failed with exit code: 2
          gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_moduls/node-gyp/lib/build.js:262:23)
          gyp ERR! stack     at emitTwo (events.js:126:13)
          gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_proces.js:198:12)
          gyp ERR! System Linux 4.14.98-v7+
          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_mdules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/node-v57-linux-arm/nodesqlite3.node" "--module_name=node_sqlite3" "--module_path=/opt/iobroker/node_moules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/node-v57-linux-arm" "--npi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_labe=node-v57"
          gyp ERR! cwd /opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3
          gyp ERR! node -v v8.16.0
          gyp ERR! node-gyp -v v3.8.0
          gyp ERR! not ok
          node-pre-gyp ERR! build error
          node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_mdules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --modle=/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/lib/bindingnode-v57-linux-arm/node_sqlite3.node --module_name=node_sqlite3 --module_path=/pt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/nodev57-linux-arm --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --noe_napi_label=node-v57' (1)
          node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modles/iobroker.sbfspot/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
          node-pre-gyp ERR! stack     at emitTwo (events.js:126:13)
          node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
          node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:915:16)
          node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/chld_process.js:209:5)
          node-pre-gyp ERR! System Linux 4.14.98-v7+
          node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/iobroker.bfspot/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
          node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.sbfspot/node_modules/qlite3
          node-pre-gyp ERR! node -v v8.16.0
          node-pre-gyp ERR! node-pre-gyp -v v0.11.0
          node-pre-gyp ERR! not ok
          Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gy/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/obroker.sbfspot/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite.node --module_name=node_sqlite3 --module_path=/opt/iobroker/node_modules/iobroer.sbfspot/node_modules/sqlite3/lib/binding/node-v57-linux-arm --napi_version=4--node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! sqlite3@4.1.1 install: `node-pre-gyp install --fallback-to-build`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the sqlite3@4.1.1 install script.
          npm ERR! This is probably not a problem with npm. There is likely additional loging output above.
          npm ERR!     /root/.npm/_logs/2020-01-12T14_53_55_158Z-debug.log
          • Rene_HM
            @Tottbeck nein, das liegt an den Abhängigkeiten und dem installer von sqlite3...
            Ich werde bei den Entwicklern von sqlite ein issue aufmachen, dafür brauche ich aber weitere Infos und Zeit...
            Kannst du bitte mal folgenden Versuch machen?
            Bitte mal bei dir auf dem Zielsystem (Raspi) irgendwo (evtl. im home) ein Verzeichnis anlegen und dort eine package.json mit folgendem Inhalt anlegen:
            cd ~
            mkdir sqlite_test
            cd sqlite_test
            nano package.json
            und dort hineinkopieren:
              "name": "test",
              "license": "MIT",
              "optionalDependencies": {
                "sqlite3": "^4.1.1"
              "dependencies": {
                "mysql": "^2.17.1"
              "devDependencies": {
                "gulp": "^4.0.0",
                "mocha": "^6.0.2",
                "chai": "^4.2.0"
            mit SRG-O speichern und STRG-X nano verlassen.
            und dann
            npm install
            aufrufen. Wenn das fehlerfrei läuft, könntest du versuchen, den node_modules - Ordner in das iobroker.sbfspot-Verzeichnis zu kopieren. Ich habe das hier bei mir probiert, da geht es. Ob das immer funktioniert, kann ich nicht sagen... Im Fehlerfall bin ich auch an diesem log interessiert...
              wm20320 @Rene_HM last edited by
              @Rene_HM Danke für den Tipp, hilft mir leider nicht sehr weiter, da kenn ich mich skriptmäßig zu wenig aus. Das einzige, was ich da feststellen kann, dass das sbfspot-Widget Fehler erzeugt und alls paar Sekunden "need to wait" ausgibt.
              Komisch ist, dass das auf 2 Systemen mit unterschiedlichen Browsern im Edit-Modus so ist. An den Endgeräten erscheint natürlich logischerweise auch nichts.
              • Rene_HM
                @wm20320 poste doch mal das log. Am besten im vis-Editor und dann einfach mal die Instanz neu eingeben. Das triggert das widget intern. Dann finden wir schon den Fehler...
                  @Rene_HM
                  Habe das als user "pi" per "sudo npm install" installiert. Hat als root aber auch nicht geklappt.
                  pi@raspberrypi:~ $ cd ~
                  pi@raspberrypi:~ $ mkdir sqlite_test
                  pi@raspberrypi:~ $ cd sqlite_test
                  pi@raspberrypi:~/sqlite_test $ nano package.json
                  pi@raspberrypi:~/sqlite_test $ sudo npm install
                  > sqlite3@4.1.1 install /home/pi/sqlite_test/node_modules/sqlite3
                  node-pre-gyp WARN Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.1.1/node-v57-linux-arm.tar.gz
                  node-pre-gyp WARN Pre-built binaries not found for sqlite3@4.1.1 and node@8.16.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
                  gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.16.0"
                  gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
                  make: Entering directory '/home/pi/sqlite_test/node_modules/sqlite3/build'
                    ACTION deps_sqlite3_gyp_action_before_build_target_unpack_sqlite_dep Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c
                  deps/sqlite3.target.mk:129: recipe for target 'Release/obj.target/sqlite3/gen/sqlite-autoconf-3300100/sqlite3.o' failed
                  make: *** [Release/obj.target/sqlite3/gen/sqlite-autoconf-3300100/sqlite3.o] Error 4
                  make: Leaving directory '/home/pi/sqlite_test/node_modules/sqlite3/build'
                  gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                  gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
                  gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/home/pi/sqlite_test/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=/home/pi/sqlite_test/node_modules/sqlite3/lib/binding/node-v57-linux-arm" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v57"
                  gyp ERR! cwd /home/pi/sqlite_test/node_modules/sqlite3
                  gyp ERR! not ok
                  node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/home/pi/sqlite_test/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite3.node --module_name=node_sqlite3 --module_path=/home/pi/sqlite_test/node_modules/sqlite3/lib/binding/node-v57-linux-arm --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)
                  node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/home/pi/sqlite_test/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                  node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
                  node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/sqlite_test/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                  node-pre-gyp ERR! cwd /home/pi/sqlite_test/node_modules/sqlite3
                  npm notice created a lockfile as package-lock.json. You should commit this file.
                  npm WARN test@ No description
                  npm WARN test@ No repository field.
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sqlite3@4.1.1 (node_modules/sqlite3):
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sqlite3@4.1.1 install: `node-pre-gyp install --fallback-to-build`
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                  added 405 packages from 735 contributors and audited 6882 packages in 907.574s
                  found 0 vulnerabilities
                  • Rene_HM
                    @Tottbeck hab ein issue bei den Entwicklern von sqlite3 erstellt...
                      @Rene_HM
                      Danke Dir.
                      Ich habe zwischenzeitlich u.a. das iobroker fix-script laufen lassen, weil das Update auf sbfspot 2.4.0 auch nicht klappte wegen irgendwelchen npm-Abhängigkeiten.
                      Nach dem fix ging das 2.4.0-update. Danach gab ab es beim "sudo npm install" im sbfspot-Ordner zwar auch viele komische Meldungen aber jetzt geht der Adapter wieder. 😲
                        jonnz last edited by
                        ich bin recht neu bei IoBroker und habe mich die letzten Wochen über Google und das Forum durchgekämpft. Hat auch prima geklappt und die erste Version steht. Nun habe ich aber seit Tagen ein Thema mit SBFspot und komme selber nicht weiter (und finde leider trotz intensiver Suche die Lösung nicht).
                        Zu meinem System:
                        Habe IoBroker (Buanet.Iobroker) auf meiner Synology 218+ im Docker laufen.
                        SQL läuft als über MariaDB und Zugriff über Iobroker SQL-Adapter ist installiert, verbunden…alles grün.
                        Wechelrichter ist ein SMA 5000 TL-21
                        Habe jetzt SBFspot installiert und auch die Daten für den Datenbankzugriff eingetragen…….nur es tut sich rein gar nichts.
                        Im Widget ist Instanz als SBFspot.0 eingetragen, Seriennummer ist auch drin.
                        Bei der Suche über das Terminal finde ich aber nur einen Ordner Iobroker.Sbfspot – z.B. die SBFspot.cfg ist nicht zu finden…..
                        Soweit ich das verstehe, muss ich auch noch irgendwie die Bluetooth-MAC usw. eintragen?
                        Wäre für Unterstützung echt dankbar…
                        Grüße jonnz
                        • Rene_HM
                          Rene_HM Developer @jonnz last edited by
                          @jonnz hast du sbfspot selbst auch installiert?
                          siehe https://github.com/SBFspot/SBFspot und https://github.com/SBFspot/SBFspot/wiki
                          Der Adapter greift nur auf die Datenbank zu, gefüllt wird sie von sbfspot...
                            @Rene_HM
                            Danke für die schnelle Antwort - mit dem letzten Satz ist es mir etwas klarer geworden. Ich habe zwar die Datenbank am laufen und auch den Adapter installiert aber sbfspot an sich nicht.
                            Muss jetzt erstmal schauen wie ich das unter Iobroker im Docker heruntergeladen und installiert bekomme.....bin nicht so Linuxerfahren und der psftp hat so seine Probleme. Zumindest die Ordner habe ich aber mal gemäß Anleitung angelegt.
                            Es geht voran.....
                              Hab SBFspot heruntergeladen und installiert - nur mit dem editieren der SBFspot.cfg komme ich nicht weiter.
                              Bin nicht in der Lage einen Editor zu öffnen oder zu installieren um da die Werte zu ändern.
                              Dachte ich änder dann die Datei unter Windows und kopier es "einfach" rüber aber Dateiaustausch bekomme ich über putty auch nicht hin - lande auf meiner NAS.
                              Jemand ne Ahnung was ich falsch machen?
                              Danke vorab..
                              • Rene_HM
                                Rene_HM Developer @jonnz last edited by Rene_HM
                                @jonnz z.Bsp. mit nano
                                sudo nano /usr/local/bin/sbfspot.3/SBFspot.cfg
                                  jonnz last edited by jonnz
                                  Guten Abend,
                                  erstmal danke die bisherige Unterstützung...da ich bei Iobroker so nicht weitergekommen bin -
                                  bin ich jetzt umgestiegen und habe SBFspot auf nem Raspi installiert. Soweit so gut...bekomme aber folgende Meldung (en)...
                                  Wollte eigentlich folgende Konfiguration:
                                  • Iobroker läuft auf Synology unter Docker
                                  • MySQL auf Synology
                                  • SBFspot auf Raspi
                                  • Daten werden von Raspi auf MySQL-DB geschrieben
                                  • SBFspot-Adapter liest Daten in MySQL aus..
                                  Hab jetzt oben schon gesehen, dass ich mit sudo make install_mysql eine neue DB erstellen muss...aber mir ist nicht ganz klar wo/wie....bekomme "No rule to make target 'install_mysql'. Stop"...
                                  Gruß und Danke..
                                  • Rene_HM
                                    @jonnz sagte in Neuer Adapter: SMA Wechselrichter mit sbfspot:
                                    Dann bist du nicht im richtigen Verzeichnis.... Für den Raspi gibt es doch auf den wiki-Seiten von sbfspot eine gute Anleitung...
                                      Ja die Docu ist wirklich gut - hab´s jetzt auch am Laufen - SBFSpot hat den WR und es werden Daten in die SQLite-Datenbank auf dem Raspberry geschrieben.
                                      Ich krieg´s allerdings nicht hin, dass ich vom IObroker (Synology) auf die Daten (Raspi) zugreife.....das ist grad die große Herausforderung...
                                      • Rene_HM
                                        @jonnz ich habe bei mir auf dem System, auf dem sbfspot läuft, auch iobroker (als slave) installiert und lasse dort den Adapter laufen.
                                          @Rene_HM
                                          Die Frage ist was muss ich da einstellen oder vielmehr freigeben...hab im Adapter folgendes probiert..
                                          http://192.168.178.105/home/pi/smadata/SBFspot.db (die IP vom Raspi).....aber SBFspot hat keine Daten...wobei ich ja für den Raspi ohne Login & Passwort brauche.
                                          Gebe ich nur mal die IP im Browser ein, dann meldet sich der Apache-Server....in der Apache2.config habe ich das o.a. Verzeichnis mal auf die Whitelist gesetzt. Auch ohne Effekt....
                                          • Nutzt Du dann auch SQLite?
                                          • Wie hast Du das zwischen Master und Slave freigegeben?
                                          Danke Dir schonma....
                                          • Rene_HM
                                            Eine einfache Freigabe wird nicht funktionieren...
                                            ich habe beides (mariaDB und SQLite) im Einsatz.. mariaDB könnte man über das Netzwerk erreichen, SQLite ist lokal...
                                            Das findest du unter
                                            https://www.iobroker.net/docu/index-24.htm?page_id=3068&lang=de
                                            248
                                            40935
