Adapter: ebus
Nun ist die frage hast du in den Adapter auch Werte eingetragen die abgefragt werden sollen? Du kannst ja erst mal schauen welche Werte verfügbar sind am Raspi http://IP:8890/data
@markus397 Ja, hatte mir mir die json Daten im Browser (ip:8890/data) angeschaut.
Kommt halt durch die fehlende Zuordnung der dazugehörigen *.csv Daten.
So sehen die Json Daten aus:{ "broadcast": { "messages": { "datetime": { "name": "datetime", "passive": true, "write": false, "lastup": 1578671548, "zz": 254, "fields": { "outsidetemp": {"value": null}, "time": {"value": "17:03:10"}, "date": {"value": "10.01.2020"} } }, "error": { "name": "error", "passive": true, "write": false, "lastup": 1578671358, "zz": 254, "fields": { "error": {"value": "E000 17:00"} } }, "id-u": { "name": "id", "passive": true, "write": false, "lastup": 1578671238, "zz": 254, "fields": { "manufacturer": {"value": "Kromschröder"}, "id": {"value": " "}, "software": {"value": "0204"}, "hardware": {"value": null} } }, "signoflife": { "name": "signoflife", "passive": true, "write": false, "lastup": 0 } } }, "scan.04": { "messages": { "": { "name": "", "passive": false, "write": false, "lastup": 0 } } }, "scan.08": { "messages": { "": { "name": "", "passive": false, "write": false, "lastup": 0 } } }, "scan.15": { "messages": { "": { "name": "", "passive": false, "write": false, "lastup": 0 } } }, "scan.1c": { "messages": { "": { "name": "", "passive": false, "write": false, "lastup": 0 } } }, "scan.35": { "messages": { "": { "name": "", "passive": false, "write": false, "lastup": 0 } } }, "scan.3c": { "messages": { "": { "name": "", "passive": false, "write": false, "lastup": 1578647958, "zz": 60, "fields": { "MF": {"value": "Kromschroeder"}, "ID": {"value": " "}, "SW": {"value": "0208"}, "HW": {"value": null} } } } }, "scan.51": { "messages": { "": { "name": "", "passive": false, "write": false, "lastup": 0 } } }, "scan.54": { "messages": { "": { "name": "", "passive": false, "write": false, "lastup": 0 } } }, "scan.75": { "messages": { "": { "name": "", "passive": false, "write": false, "lastup": 1578648678, "zz": 117, "fields": { "MF": {"value": "Kromschroeder"}, "ID": {"value": " "}, "SW": {"value": "0208"}, "HW": {"value": null} } } } }, "scan.76": { "messages": { "": { "name": "", "passive": false, "write": false, "lastup": 0 } } }, "scan.f5": { "messages": { "": { "name": "", "passive": false, "write": false, "lastup": 0 } } }, "scan.f6": { "messages": { "": { "name": "", "passive": false, "write": false, "lastup": 0 } } }, "global": { "version": "3.4.v3.4-8-g177568c", "updatecheck": "revision v3.4 available", "signal": true, "symbolrate": 35, "maxsymbolrate": 142, "reconnects": 0, "masters": 10, "messages": 23, "lastup": 1578671548 } } -
Also das ist in der tat sehr wenig.
@Knallochse für mich sieht das so aus, als ob die csv's zur ebusd-Konfiguration nicht zum Gerät passen...
@Rene_HM kann ich daran was ändern. Ich bin mit meiner eigenen Suche nicht weiter vorangekommen. Ich hatte auch versucht, die csv Dateien herunterzuladen und aus dem Raspi zu laden. Dabei stützt aber der ebusd service ab.
@Knallochse Ich würde direkt auf den ebusd von john30 verweisen:
https://github.com/john30/ebusd/wiki
bzw.
https://github.com/john30/ebusd-configuration
Ich selbst habe zu wenig Erfahrung mit den csv... -
Ich komme gerade nicht weiter. Entweder funktioniert das was ich möchte nicht oder ich habe ein Brett vorm Kopf
Der EBUS-Adapter läuft prima und ich habe 100derte Werte in der Objektübersicht, welche ich teilweise über VIS darstelle. Bis hier hin alles schick.
Nun gibt es bei meiner Vaillant Therme u.a. den Modus "Stoßlüften", welchen ich gelegentlich nutze. Nur wie kann ich den Modus über den Ebus realisieren? Um herauszufinden was sich ändert, habe ich die Werte vor dem Aktivieren und nach dem Deaktivieren des Modus Stoßlüften verglichen. Prinzipiell würde ich vermuten, dass die Sollvorlauftemperatur (flowtempdesired) auf 0 Grad gesetzt wird. Mit "disablehc" wird dann wahrscheinlich der Heizkreis 1 aktiviert oder deaktiviert.
Stoßlüften inaktiv
ebus.0.bai.messages.SetMode.fields.flowtempdesired.value = 30.0 ebus.0.bai.messages.SetMode.fields.disablehc.value = 0Stoßlüften aktiv
ebus.0.bai.messages.SetMode.fields.flowtempdesired.value = 0.0 ebus.0.bai.messages.SetMode.fields.disablehc.value = 1Ist es iiiirgendwie möglich das Stoßlüften zu aktivieren?
@Sandmanyz melde dich mal mit telnet auf dem ebusd an...
da gibt es dann die read (das macht der iobroker adapter) und vor allem auch write kommandos..
Nicht alle Parameter sind beschreibbar.. ausprobieren...
find -c bai dann kommen alle parameter von bai ... und dann versuchen diese gezielt mit write -c bai "paramter" 1 (Beispiel !!!) zu beschreiben..
Wenn Du dann den richtigen Befehl (write) gefunden hast, dann kannst Du den per Script in den Datenpunkt cmd vom ioBroker ebus Adapter schreiben.. der wird einmal pro Minute an den ebusd geschickt..
@mameier1234
Ich habe die Werte die ich schreiben möchte ja prinzipiell gefunden....ebus.0.bai.messages.SetMode.fields.flowtempdesired.value = 30.0 ebus.0.bai.messages.SetMode.fields.disablehc.value = 0Also habe ich....
read -c bai SetMode...eingegeben und dieses Ergebnis erhalten...
auto;0.0;-;-;1;0;0;0;0;0 /Stoßlüften aktiv auto;27.5;-;-;0;0;0;0;0;0 /Stoßlüften nicht aktivDa Stoßlüften gerade nicht aktiv war, habe ich...
write -c bai SetMode auto;0.0;-;-;1;0;0;0;0;0...ausgeführt. Das Ergebnis ist...
ERR: element not found -
@Sandmanyz ich sag ja... die richtigen Werte finden... ist irgendwie eine Sysiphus-Arbeit..
ich mache das mit
write -c mc setmode autooder
write -c mc setmode offein read -c mc setmode bringt auch:
read -c mc Status 0;off;49.19;23Rausbekommen habe ich das, indem ich im telnet "listen" eingeschaltet habe.. Da sieht man dann die Meldungen die kommen... Dann eben an der Heizung direkt den entsprechenden Wert geändert und dann kam z.B. die Meldung..
mc Status set to auto
Um zum Beispiel von Winter auf Sommerbetrieb umzuschalten...
hallo,
ich habe heute den ebus adapter (esera) installiert, am iobroker läuft der ebus adapter. wenn ich im browser ip:port/data eingebe, bekomme ich nur verschlüsselte daten. jemand eine ahnung warum?
nur das ich das richtig verstehe, ebus koppler an die vaillant anhängen, und mit dem ebus adapter die werte empfangen. oder brauche ich noch einen extra ebusd??
noch eine frage, woher bekomme ich die liste der datenpunkte?
ebus.0 2020-04-17 21:40:01.885 error (2453) exception in ebusd_ReceiveData [TypeError: Cannot read property 'statusCode' of undefined]
sind die daten verschlüsselt? oder was bedeutet der error
@MassiveAttack sagte in Adapter: ebus:
hallo,
Du siehst jetzt vermutlich nur die Rohdaten auf dem Bus.
Du benötigst den ebus Daemon weil der die Daten vom Bus in, für dich lesbare, Daten umwandelt. -
@Sandmanyz
ich verstehe, danke!
hab mir mal den ebusd von john als docker installiert. was muss ich da jetzt noch konfigurieren? -
kann mir da bitte jemand helfen? ich komme nicht weiter...
am ebus koppler habe ich nun eingestellt, tcp server mit 192.168.0.65:8888
ebusd hat 192.168.0.87 (default port ist 8888)
ebus client: ziel ip ist die vom ebusd (87) oder? target http port = 8888 /telnet port auch?wie bekomme ich die vaillant konfig auf den ebusd? muss ich da noch was konfigurieren? bitte um hilfe für newbies
@MassiveAttack Zeig mal, wie du den ebusd aurufts.. komplette config-zeile !
http Port ist was ganz anderes als der Telnet Port.. Muss beim ebusd konfiguriert werden...bei mir steht in der /etc/default/ebusd das hier drin:
EBUSD_OPTS="--configpath=/etc/ebusd -d /dev/ttyebus -p 8888 --latency=0 --recei vetimeout=100000 -l /var/log/ebusd.log --scanconfig=full --httpport=8889 --htm lpath=/var/www/"Also Port 8888, http-Port = 8889
Im Ebus Adapter:
@mameier1234
ich hab den ebusd grad mal als docker installiert, ohne irgendeine config zu ändern. um ehrlich zu sein, hab ich mich noch nicht eingelesen bzw auf die schnelle nix gefunden.
wie komme ich zu dieser ausgabe? was muss ich alles konfigurieren, und wie?
möchte dann damit meine vaillant vwf 87/4 steuern, wie bekomme ich die datenpunktliste? -
@MassiveAttack Sorry, das ich das so hart sage... aber ohne einlesen geht es nicht. Das Thema ist komplex und es lohnt sich im Thread vorne anzufangen.
bei mir ist die config leer. ich brauch ja nur mehr die richtige config und die DP-liste, wäre nett wenn du mir dabei behilflich sein könntest
