    4. Test Installer ioBroker Windows v1.5.14.x
      DrBest @DrBest last edited by
      @DrBest bekomme irgendwie einige errors mit denen ich nix anfangen kann...ist das schlimm? habe JS geupdated, da kam da hier:C:\Program Files\iobroker\SmartBerghuette>iobroker upgrade self
      Update js-controller from @1.5.14 to @2.1.1
      NPM version: 6.9.0
      npm install iobroker.js-controller@2.1.1 --unsafe-perm --production --save --prefix "C:/Program Files/iobroker/SmartBerghuette" (System call)
      npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
      gyp ERR! build error
      gyp ERR! stack Error: C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe failed with exit code: 1
      gyp ERR! stack at ChildProcess.onExit (C:\Program Files\iobroker\SmartBerghuette\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)
      gyp ERR! stack at ChildProcess.emit (events.js:198:13)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Windows_NT 10.0.18363
      gyp ERR! command "C:\Program Files\iobroker\SmartBerghuette\nodejs\node.exe" "C:\Program Files\iobroker\SmartBerghuette\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
      gyp ERR! cwd C:\Program Files\iobroker\SmartBerghuette\node_modules\iobroker.js-controller\node_modules\unix-dgram
      gyp ERR! node -v v10.16.3
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      (node:11508) UnhandledPromiseRejectionWarning: ParserError: Protocol error, got "H" as reply type byte. Please report this.
      at handleError (C:\Program Files\iobroker\SmartBerghuette\node_modules\iobroker.js-controller\node_modules\redis-parser\lib\parser.js:190:15)
      at parseType (C:\Program Files\iobroker\SmartBerghuette\node_modules\iobroker.js-controller\node_modules\redis-parser\lib\parser.js:304:14)
      (node:11508) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
      (node:11508) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      (node:11508) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
      npm WARN ws@7.2.1 requires a peer of bufferutil@^4.0.1 but none is installed. You must install peer dependencies yourself.
      npm WARN ws@7.2.1 requires a peer of utf-8-validate@^5.0.2 but none is installed. You must install peer dependencies yourself.
      npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules\iobroker.js-controller\node_modules\fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.3 (node_modules\iobroker.js-controller\node_modules\unix-dgram):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.3 install: node-gyp rebuild
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      Host "DESKTOP-O5PFU3U(SmartBerghuette)" (win32) updated
      Starting node restart.js
      Stabilostick 1 Reply Last reply Reply Quote 0
      • Stabilostick
        Stabilostick @DrBest last edited by
        @DrBest
        Wenn noch alles läuft, können diese Warnungen ignoriert werden.
        sigi234 D 2 Replies Last reply Reply Quote 0
          sigi234 Forum Testing Most Active @Stabilostick last edited by
          @Stabilostick
          Ist der neue Installer schon fertig?
            DrBest @Stabilostick last edited by
            @Stabilostick denke auch 🙂 danke
              DrBest @sigi234 last edited by
              @sigi234 ja der war zügig durch...läuft auf nem i5 mit dampf 🙂
                MarkusL last edited by
                ich setze gerade IOBroker auf Windows neu auf.
                Oben ist von einer Installer-Version 2.1.0b die Rede. Auf der Downloadseite und oben im Text finde ich die Version 1.5.14.x. und wenn ich die Forensuche nutze, zeigt er mir diesen Beitrag an.
                Wo kann ich denn die neueste (stable) Installerversion herunterladen?
                Danke und VG
                Markus
                • Stabilostick
                  Stabilostick @MarkusL last edited by
                  @MarkusL
                  https://www.iobroker.net/#de/download
                  Und dann unter „Windows“.
                  sigi234 M 2 Replies Last reply Reply Quote 0
                    @Stabilostick sagte in Test Installer ioBroker Windows v1.5.14.x:
                    @MarkusL
                    Ist das schon die Neue? 2.1.0b
                      MarkusL @Stabilostick last edited by
                      @Stabilostick Danke. Aber da steht als Datum noch der 23.11. und es gibt keinen INFO Button. Ist das dann der Neue dort? Danke.
                      • UweRLP
                        UweRLP last edited by
                        Ist die 2.1.0b. Installiert wird iobroker mit
                        Node.js v10.17.0 (Es gibt eine neuere Version: v10.18.1)
                        NPM 6.11.3
                        JS controller 2.1.1
                          aleks-83 last edited by
                          Ich habe mal eine generelle Frage:
                          Ist es gewollt dass sich der JS Controller auf einem Windows System durch ein Windows Update updated?
                          Bei mir am WE so passiert.
                            klassisch Most Active @aleks-83 last edited by
                            @aleks-83 Mein Win 10 Pro ist auch aktuell. aber Meldung:
                            Dein Host (js-controller) ist veraltet!  1.5.14    -> 2.2.8
                              ich habe den Windows installer 2.1.b benutzt, um IObroker neu aufzusetzen. Basierend auf der Datenübernahme einer alten Installation. Konnte auch alles schön auswählen, die Installation startete, dann brach er ab. Fehlermeldung lautet:
                              Warte auf Webadmin
                              Fehler beim Ausführen eines Post-Installationsschrittes
                              Die Installation wird möglicherweise nicht korrekt abgeschlossen
                              Kritischer Installationsfehler. Keine aktive ioBroker Admin-Instanz auf Port 8081. Abbruch
                              Was läuft falsch bzw was muss ich tun?
                              Danke!
                              • Stabilostick
                                Stabilostick @MarkusL last edited by Stabilostick
                                @MarkusL
                                Kannst Du Logdateien der Installation zur Verfügung stellen? Sind im setup-Ordner der iobroker-Instanz oder im %temp%-Ordner und heißen bitrock_installer_xxxx.log
                                  @Stabilostick Aber klar doch. Hier ist es. Danke für die Hilfe:
                                  bitrock_installer_7788.log
                                  • Stabilostick
                                    @MarkusL
                                    Hast Dur Redis auf dem Rechner, auf dem Du die neue Instanz installieren möchtest, laufen? In der neuen ist Redis aufgrund der Konfig der Migrationsquelle nämlich eingeschaltet.
                                    Die andere Instanz, die schon da ist, nutzt die evtl. die gleichen Ports, wie die, die Du migrieren möchtest?
                                      @Stabilostick ich denke nein. Der Rechner/VM war komplett neu aufgesetzt. Hätte ich Redis vorher installieren sollen? Wenn ja, wie?
                                      Die 2.Instanz hatte ich dann testweise einmal installiert. Da lief der Installer komplett durch. Die von ihr verwendeten Ports sind andere.
                                        Matdos last edited by Matdos
                                        @Stabilostick
                                        Hay, richtig cool der Installer, ist einwandfrei durchgelaufen bei mir und auch der Broker selber läuft tip top auf dem Rechner.
                                        Aber wie deinstalliere ich den (rein Interesse halber) wieder 😁 unter Programme findet man die Installation nicht.
                                          klassisch Most Active @Matdos last edited by
                                          @matdos1gmx-de der neue, aktuelle Installer von der Homepage https://www.iobroker.net/#de/download hat eine Option zum Löschen einer vorhandenen Installation
                                            MarkusL @MarkusL last edited by
                                            @MarkusL said in Test Installer ioBroker Windows v1.5.14.x:
                                            @Stabilostick Ich glaube Du hast recht und es liegt an der Redis Umstellung. Ich habe keine Ahnung mehr, wann und warum ich irgendwann umgestellt habe. Es macht bei meinem Setup eigentlich keinen Sinn (wenn ich die Redis Beschreibungen so lese). Kann ich bei der Migration irgendwie zurückwechseln? Das Problem ist, dass die IOBroker Installation, die ich migrieren will zwar läuft, aber keine Eingaben mehr über das Terminal/die Oberfläche annimmt. So kann ich es nicht in der alten Version umstellen und dann ein Backup des data Ordners für die Migration machen.
                                            Kann ich während der Migration die Redis Variante auf die normale umstellen? Oder vor der Migration etwas im data Folder umstellen?
                                            Danke!
                                            31.7k
                                            79.9k
                                            installation iobroker installation node node npm windows npm windows windows 10
                                            23
                                            236
                                            31442
