    4. JavaScript
    5. Energieanzeige (kWh) über HTML Tabelle - vis
      liv-in-sky @Nordischerjung last edited by
      @Nordischerjung gibt es
      poste bitte den json export der datenpunkte für meross.0 und auch fritzdect.0 mit den steckdosen
      • N
        Nordischerjung @liv-in-sky last edited by
        @liv-in-sky sagte in Energieanzeige (kWh) über HTML Tabelle - vis:
         "fritzdect.0.DECT200_087610439476": {
           "type": "channel",
           "common": {
             "name": "FRITZ!DECT 200 #1",
             "role": "switch"
           "native": {
             "aid": "087610439476"
           "from": "system.adapter.fritzdect.0",
           "ts": 1544640387823,
           "_id": "fritzdect.0.DECT200_087610439476",
           "acl": {
             "object": 1636,
             "owner": "system.user.admin",
         "fritzdect.0.DECT200_087610439476.devicelock": {
           "type": "state",
           "common": {
             "name": "Switch Button lock",
             "type": "boolean",
             "read": true,
             "write": false,
             "role": "indicator"
           "native": {},
           "ts": 1544640387875,
           "_id": "fritzdect.0.DECT200_087610439476.devicelock",
           "acl": {
             "object": 1636,
             "state": 1636,
         "fritzdect.0.DECT200_087610439476.energy": {
           "type": "state",
           "common": {
             "name": "Switch total energy",
             "type": "number",
             "unit": "Wh",
             "min": 0,
             "read": true,
             "write": false,
             "role": "value.power.consumption",
             "desc": "Switch total energy"
           "native": {},
           "ts": 1544640387872,
           "_id": "fritzdect.0.DECT200_087610439476.energy",
           "acl": {
             "object": 1636,
             "state": 1636,
         "fritzdect.0.DECT200_087610439476.fwversion": {
           "type": "state",
           "common": {
             "name": "FW version",
             "type": "string",
             "read": true,
             "write": false,
             "role": "text",
             "desc": "firmware version"
           "native": {},
           "ts": 1544640387828,
           "_id": "fritzdect.0.DECT200_087610439476.fwversion",
           "acl": {
             "object": 1636,
             "state": 1636,
         "fritzdect.0.DECT200_087610439476.id": {
           "type": "state",
           "common": {
             "name": "ID",
             "type": "string",
             "read": true,
             "write": false,
             "role": "text",
             "desc": "ID"
           "native": {},
           "ts": 1544640387825,
           "_id": "fritzdect.0.DECT200_087610439476.id",
           "acl": {
             "object": 1636,
             "state": 1636,
         "fritzdect.0.DECT200_087610439476.lock": {
           "type": "state",
           "common": {
             "name": "Switch UI/API lock",
             "type": "boolean",
             "read": true,
             "write": false,
             "role": "indicator"
           "native": {},
           "ts": 1544640387869,
           "_id": "fritzdect.0.DECT200_087610439476.lock",
           "acl": {
             "object": 1636,
             "state": 1636,
         "fritzdect.0.DECT200_087610439476.manufacturer": {
           "type": "state",
           "common": {
             "name": "Manufacturer",
             "type": "string",
             "read": true,
             "write": false,
             "role": "text",
             "desc": "Manufacturer"
           "native": {},
           "ts": 1544640387829,
           "_id": "fritzdect.0.DECT200_087610439476.manufacturer",
           "acl": {
             "object": 1636,
             "state": 1636,
         "fritzdect.0.DECT200_087610439476.mode": {
           "type": "state",
           "common": {
             "name": "Switch mode",
             "type": "string",
             "read": true,
             "write": false,
             "role": "text",
             "desc": "Switch mode"
           "native": {},
           "ts": 1544640387868,
           "_id": "fritzdect.0.DECT200_087610439476.mode",
           "acl": {
             "object": 1636,
             "state": 1636,
         "fritzdect.0.DECT200_087610439476.name": {
           "type": "state",
           "common": {
             "name": "Name",
             "type": "string",
             "read": true,
             "write": false,
             "role": "text",
             "desc": "Name"
           "native": {},
           "ts": 1544640387827,
           "_id": "fritzdect.0.DECT200_087610439476.name",
           "acl": {
             "object": 1636,
             "state": 1636,
         "fritzdect.0.DECT200_087610439476.power": {
           "type": "state",
           "common": {
             "name": "Switch act power",
             "type": "number",
             "unit": "W",
             "min": 0,
             "max": 4000,
             "read": true,
             "write": false,
             "role": "value.power",
             "desc": "Switch act power",
             "custom": {
               "sourceanalytix.0": {
                 "enabled": true,
                 "alias": "Sprudelwasser",
                 "state_type": "kWh_consumption",
                 "state_unit": "automatically",
                 "costs": true,
                 "consumption": true,
                 "meter_values": true,
                 "start_day": -0.7576769199999999,
                 "start_week": 0,
                 "start_month": 0,
                 "start_quarter": 0,
                 "start_year": 0
           "native": {},
           "from": "system.adapter.sourceanalytix.0",
           "ts": 1580425200083,
           "_id": "fritzdect.0.DECT200_087610439476.power",
           "acl": {
             "object": 1636,
             "state": 1636,
           "user": "system.user.admin"
         "fritzdect.0.DECT200_087610439476.present": {
           "type": "state",
           "common": {
             "name": "Switch present",
             "type": "boolean",
             "read": true,
             "write": false,
             "role": "indicator.connected",
             "desc": "Switch present"
           "native": {},
           "_id": "fritzdect.0.DECT200_087610439476.present",
           "acl": {
             "object": 1636,
             "state": 1636,
         "fritzdect.0.DECT200_087610439476.prodname": {
           "type": "state",
           "common": {
             "name": "Product Name",
             "type": "string",
             "read": true,
             "write": false,
             "role": "text",
             "desc": "Product Name"
           "native": {},
           "ts": 1544640387830,
           "_id": "fritzdect.0.DECT200_087610439476.prodname",
           "acl": {
             "object": 1636,
             "state": 1636,
         "fritzdect.0.DECT200_087610439476.state": {
           "type": "state",
           "common": {
             "name": "Switch on/off",
             "type": "boolean",
             "read": true,
             "write": true,
             "role": "switch",
             "desc": "Switch on/off"
           "native": {},
           "ts": 1544640387831,
           "_id": "fritzdect.0.DECT200_087610439476.state",
           "acl": {
             "object": 1636,
             "state": 1636,
         "fritzdect.0.DECT200_087610439476.temp": {
           "type": "state",
           "common": {
             "name": "actual Temp",
             "type": "number",
             "unit": "°C",
             "read": true,
             "write": false,
             "role": "value.temperature",
             "desc": "actual Temp"
           "native": {},
           "ts": 1544640387873,
           "_id": "fritzdect.0.DECT200_087610439476.temp",
           "acl": {
             "object": 1636,
             "state": 1636,
         "fritzdect.0.DECT200_087610439476.voltage": {
           "type": "state",
           "common": {
             "name": "Switch act voltage",
             "type": "number",
             "unit": "V",
             "min": 0,
             "max": 250,
             "read": true,
             "write": false,
             "role": "value.voltage",
             "desc": "Switch act voltage"
           "native": {},
           "ts": 1544640387876,
           "_id": "fritzdect.0.DECT200_087610439476.voltage",
           "acl": {
             "object": 1636,
             "state": 1636,
        meinst du das? Von meross hab ich zur Zeit nur Outdoor Steckdosen ohne Messung. Die mit Messung bekomme ich erst Montag
          @Nordischerjung nein ich meine den ganzen pfad https://forum.iobroker.net/post/355793 und dann die ganze datei hier posten (einfach in den post ziehen -
            @Nordischerjung sorry -alles gut - war schon richtig so
              bäuchte eure hilfe bei 2 themen - homee user und mihome user
              es geht um den wert , ob das device online ist - ich muss noch mal ein update machen, weil die werte für die beiden maken nicht klar sind
              mihome: ws steht in state_in_use - ist das eine zahl oder boolean - wenn zahl, steht dann 0 und 1 oder kann da was anderes stehen
              homee: wie kann ich herausfinden, ob das gerät online ist
              problem - sind sie offline, werden die daten zum berechnen weiter mitgezälht, obwohl nicht aktiv
              O crunchip 2 Replies Last reply Reply Quote 0
                @Nordischerjung fritzdect ist drin (beim nächsten update dabei)
                meross: machen wir wenn du die datenpunkte hast
                • O
                  Oli @liv-in-sky last edited by
                  @liv-in-sky
                  mit dem homee Adapter derzeit leider gar nicht.
                    liv-in-sky @Oli last edited by
                    @Oli wie oft werden den die daten upgedatet - evtl geht was über last_change irgendeines datenpunktes - wobei es da am adapter selbst liegt, ob er updated, wenn keine oder keine veränderten daten kommen - kannst du bitte mal testen
                    kurzscript - datenpunkt kannst du ändern auf deine geräte - müßte aber eh von dir sein
                    alle 20 sekunden wird die zeit diff gemessen - wann er das letzte mal gändert wurde
                    wir suchen den unterschied zw. gerät ist aktiv ( also wie oft liest der adapter die daten und macht update) und was geschieht mit dieser zeitdifferenz, wenn gerät offline - also nicht im netzwerk erreichbar
                     schedule(' */20 * * * * *',  function () {
                    var ddd=getState("homee.0.MeteringPlug-20.CurrentEnergyUse-190").lc
                    log(parseInt((new Date().getTime())) - new Date(ddd))
                    O N 3 Replies Last reply Reply Quote 0
                    • O
                      @liv-in-sky
                      Kann ich aber leider erst Montag Abend testen.
                        @Oli kein thema
                          crunchip Forum Testing Most Active @liv-in-sky last edited by
                          @liv-in-sky was brauchst du zwecks mihome?
                            liv-in-sky @crunchip last edited by
                            @crunchip hi M
                            hast du mihome steckdosen, die eine energieanzeige haben
                            crunchip ? 2 Replies Last reply Reply Quote 0
                              @liv-in-sky hab ich selbst grad gemerkt🤦 sind ja im Energie script. Nein leider nix mit Strom von Mihome
                                @crunchip dann warte ich halt bis montag
                                  A Former User @liv-in-sky last edited by
                                  @crunchip hi M
                                  Hi, ich hab so eine, unter anderem...
                                  Was brauchst du davon? ( Konnte hier noch nicht soviel mitlesen die letzten Wochen..)
                                    liv-in-sky @Guest last edited by
                                    @ilovegym hi - eigentlich nur das hier - ich muss irgendwie rausfinden, wenn das ding offline ist
                                    https://forum.iobroker.net/post/368458
                                    O vauvau07 2 Replies Last reply Reply Quote 0
                                    • O
                                      @liv-in-sky
                                      Ich glaube nicht, dass der homee Adapter sowas abbildet
                                      https://forum.iobroker.net/topic/26083/wünsche-für-den-homee-adapter
                                      • vauvau07
                                        vauvau07 @liv-in-sky last edited by
                                        @liv-in-sky
                                        ist es möglich folgendes Gerät einzubinden
                                        zigbee.0.00158d0003893df5.json
                                          @Oli deshalb versuche ich den dp-update-cyclus zu finden und ob der adapter diese updates auch macht, wenn das gerät nicht online ist
                                            liv-in-sky @vauvau07 last edited by liv-in-sky
                                            @vauvau07 sind schön längst drin - hat das script sofort erkannt
                                            vauvau07 1 Reply Last reply Reply Quote 0
                                            javascript template
                                            37
                                            696
                                            130732
