    4. JavaScript
    5. Energieanzeige (kWh) über HTML Tabelle - vis
    • N
      Nordischerjung @liv-in-sky last edited by
      @liv-in-sky sagte in Energieanzeige (kWh) über HTML Tabelle - vis:
      json export der datenpunkte
       "fritzdect.0.DECT200_087610439476": {
         "type": "channel",
         "common": {
           "name": "FRITZ!DECT 200 #1",
           "role": "switch"
         "native": {
           "aid": "087610439476"
         "from": "system.adapter.fritzdect.0",
         "ts": 1544640387823,
         "_id": "fritzdect.0.DECT200_087610439476",
         "acl": {
           "object": 1636,
           "owner": "system.user.admin",
       "fritzdect.0.DECT200_087610439476.devicelock": {
         "type": "state",
         "common": {
           "name": "Switch Button lock",
           "type": "boolean",
           "read": true,
           "write": false,
           "role": "indicator"
         "native": {},
         "ts": 1544640387875,
         "_id": "fritzdect.0.DECT200_087610439476.devicelock",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.energy": {
         "type": "state",
         "common": {
           "name": "Switch total energy",
           "type": "number",
           "unit": "Wh",
           "min": 0,
           "read": true,
           "write": false,
           "role": "value.power.consumption",
           "desc": "Switch total energy"
         "native": {},
         "ts": 1544640387872,
         "_id": "fritzdect.0.DECT200_087610439476.energy",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.fwversion": {
         "type": "state",
         "common": {
           "name": "FW version",
           "type": "string",
           "read": true,
           "write": false,
           "role": "text",
           "desc": "firmware version"
         "native": {},
         "ts": 1544640387828,
         "_id": "fritzdect.0.DECT200_087610439476.fwversion",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.id": {
         "type": "state",
         "common": {
           "name": "ID",
           "type": "string",
           "read": true,
           "write": false,
           "role": "text",
           "desc": "ID"
         "native": {},
         "ts": 1544640387825,
         "_id": "fritzdect.0.DECT200_087610439476.id",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.lock": {
         "type": "state",
         "common": {
           "name": "Switch UI/API lock",
           "type": "boolean",
           "read": true,
           "write": false,
           "role": "indicator"
         "native": {},
         "ts": 1544640387869,
         "_id": "fritzdect.0.DECT200_087610439476.lock",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.manufacturer": {
         "type": "state",
         "common": {
           "name": "Manufacturer",
           "type": "string",
           "read": true,
           "write": false,
           "role": "text",
           "desc": "Manufacturer"
         "native": {},
         "ts": 1544640387829,
         "_id": "fritzdect.0.DECT200_087610439476.manufacturer",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.mode": {
         "type": "state",
         "common": {
           "name": "Switch mode",
           "type": "string",
           "read": true,
           "write": false,
           "role": "text",
           "desc": "Switch mode"
         "native": {},
         "ts": 1544640387868,
         "_id": "fritzdect.0.DECT200_087610439476.mode",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.name": {
         "type": "state",
         "common": {
           "name": "Name",
           "type": "string",
           "read": true,
           "write": false,
           "role": "text",
           "desc": "Name"
         "native": {},
         "ts": 1544640387827,
         "_id": "fritzdect.0.DECT200_087610439476.name",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.power": {
         "type": "state",
         "common": {
           "name": "Switch act power",
           "type": "number",
           "unit": "W",
           "min": 0,
           "max": 4000,
           "read": true,
           "write": false,
           "role": "value.power",
           "desc": "Switch act power",
           "custom": {
             "sourceanalytix.0": {
               "enabled": true,
               "alias": "Sprudelwasser",
               "state_type": "kWh_consumption",
               "state_unit": "automatically",
               "costs": true,
               "consumption": true,
               "meter_values": true,
               "start_day": -0.7576769199999999,
               "start_week": 0,
               "start_month": 0,
               "start_quarter": 0,
               "start_year": 0
         "native": {},
         "from": "system.adapter.sourceanalytix.0",
         "ts": 1580425200083,
         "_id": "fritzdect.0.DECT200_087610439476.power",
         "acl": {
           "object": 1636,
           "state": 1636,
         "user": "system.user.admin"
       "fritzdect.0.DECT200_087610439476.present": {
         "type": "state",
         "common": {
           "name": "Switch present",
           "type": "boolean",
           "read": true,
           "write": false,
           "role": "indicator.connected",
           "desc": "Switch present"
         "native": {},
         "_id": "fritzdect.0.DECT200_087610439476.present",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.prodname": {
         "type": "state",
         "common": {
           "name": "Product Name",
           "type": "string",
           "read": true,
           "write": false,
           "role": "text",
           "desc": "Product Name"
         "native": {},
         "ts": 1544640387830,
         "_id": "fritzdect.0.DECT200_087610439476.prodname",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.state": {
         "type": "state",
         "common": {
           "name": "Switch on/off",
           "type": "boolean",
           "read": true,
           "write": true,
           "role": "switch",
           "desc": "Switch on/off"
         "native": {},
         "ts": 1544640387831,
         "_id": "fritzdect.0.DECT200_087610439476.state",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.temp": {
         "type": "state",
         "common": {
           "name": "actual Temp",
           "type": "number",
           "unit": "°C",
           "read": true,
           "write": false,
           "role": "value.temperature",
           "desc": "actual Temp"
         "native": {},
         "ts": 1544640387873,
         "_id": "fritzdect.0.DECT200_087610439476.temp",
         "acl": {
           "object": 1636,
           "state": 1636,
       "fritzdect.0.DECT200_087610439476.voltage": {
         "type": "state",
         "common": {
           "name": "Switch act voltage",
           "type": "number",
           "unit": "V",
           "min": 0,
           "max": 250,
           "read": true,
           "write": false,
           "role": "value.voltage",
           "desc": "Switch act voltage"
         "native": {},
         "ts": 1544640387876,
         "_id": "fritzdect.0.DECT200_087610439476.voltage",
         "acl": {
           "object": 1636,
           "state": 1636,
      meinst du das? Von meross hab ich zur Zeit nur Outdoor Steckdosen ohne Messung. Die mit Messung bekomme ich erst Montag
        liv-in-sky @Nordischerjung last edited by
        @Nordischerjung nein ich meine den ganzen pfad https://forum.iobroker.net/post/355793 und dann die ganze datei hier posten (einfach in den post ziehen -
          @Nordischerjung sorry -alles gut - war schon richtig so
            bäuchte eure hilfe bei 2 themen - homee user und mihome user
            es geht um den wert , ob das device online ist - ich muss noch mal ein update machen, weil die werte für die beiden maken nicht klar sind
            mihome: ws steht in state_in_use - ist das eine zahl oder boolean - wenn zahl, steht dann 0 und 1 oder kann da was anderes stehen
            homee: wie kann ich herausfinden, ob das gerät online ist
            problem - sind sie offline, werden die daten zum berechnen weiter mitgezälht, obwohl nicht aktiv
            O crunchip 2 Replies Last reply Reply Quote 0
              @Nordischerjung fritzdect ist drin (beim nächsten update dabei)
              meross: machen wir wenn du die datenpunkte hast
              • O
                Oli @liv-in-sky last edited by
                @liv-in-sky
                mit dem homee Adapter derzeit leider gar nicht.
                  liv-in-sky @Oli last edited by
                  @Oli wie oft werden den die daten upgedatet - evtl geht was über last_change irgendeines datenpunktes - wobei es da am adapter selbst liegt, ob er updated, wenn keine oder keine veränderten daten kommen - kannst du bitte mal testen
                  kurzscript - datenpunkt kannst du ändern auf deine geräte - müßte aber eh von dir sein
                  alle 20 sekunden wird die zeit diff gemessen - wann er das letzte mal gändert wurde
                  wir suchen den unterschied zw. gerät ist aktiv ( also wie oft liest der adapter die daten und macht update) und was geschieht mit dieser zeitdifferenz, wenn gerät offline - also nicht im netzwerk erreichbar
                   schedule(' */20 * * * * *',  function () {
                  var ddd=getState("homee.0.MeteringPlug-20.CurrentEnergyUse-190").lc
                  log(parseInt((new Date().getTime())) - new Date(ddd))
                  O N 3 Replies Last reply Reply Quote 0
                  • O
                    @liv-in-sky
                    Kann ich aber leider erst Montag Abend testen.
                      @Oli kein thema
                        crunchip Forum Testing Most Active @liv-in-sky last edited by
                        @liv-in-sky was brauchst du zwecks mihome?
                          liv-in-sky @crunchip last edited by
                          @crunchip hi M
                          hast du mihome steckdosen, die eine energieanzeige haben
                          crunchip ? 2 Replies Last reply Reply Quote 0
                            @liv-in-sky hab ich selbst grad gemerkt🤦 sind ja im Energie script. Nein leider nix mit Strom von Mihome
                              @crunchip dann warte ich halt bis montag
                                A Former User @liv-in-sky last edited by
                                @crunchip hi M
                                Hi, ich hab so eine, unter anderem...
                                Was brauchst du davon? ( Konnte hier noch nicht soviel mitlesen die letzten Wochen..)
                                  liv-in-sky @Guest last edited by
                                  @ilovegym hi - eigentlich nur das hier - ich muss irgendwie rausfinden, wenn das ding offline ist
                                  https://forum.iobroker.net/post/368458
                                  O vauvau07 2 Replies Last reply Reply Quote 0
                                  • O
                                    @liv-in-sky
                                    Ich glaube nicht, dass der homee Adapter sowas abbildet
                                    https://forum.iobroker.net/topic/26083/wünsche-für-den-homee-adapter
                                    • vauvau07
                                      vauvau07 @liv-in-sky last edited by
                                      @liv-in-sky
                                      ist es möglich folgendes Gerät einzubinden
                                      zigbee.0.00158d0003893df5.json
                                        @Oli deshalb versuche ich den dp-update-cyclus zu finden und ob der adapter diese updates auch macht, wenn das gerät nicht online ist
                                          liv-in-sky @vauvau07 last edited by liv-in-sky
                                          @vauvau07 sind schön längst drin - hat das script sofort erkannt
                                          vauvau07 1 Reply Last reply Reply Quote 0
                                          • vauvau07
                                            vauvau07 @liv-in-sky last edited by vauvau07
                                            @liv-in-sky
                                            neustes Script ? , alles true, keine Anzeige
                                            das momentane testscript ist nicht das Neuste
                                            javascript template
                                            37
                                            696
                                            130730
