    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
      tombox @opossum last edited by
      @opossum Installier mal neu via github was da an Fehler kommt.
      • opossum
        opossum last edited by opossum
        Hallo, @tombox ,
        habe via Github neu installiert, aber vorher nicht deinstalliert. Kommen im Log gleiche Fehler wie in meinem Post, untere Box. Installiert ist jetzt die 0.0.10.
        Soll ich vorher mal deinstallieren? Daten kommen aber und sind auch plausibel.
        Habe den Adapter auf debug gestellt. Hier das Log, relevante Daten mit xxx versehen.
        vw-connect.0 2020-01-28 17:44:13.112 debug (15283) error while getting https://msg.volkswagen.de/fs-car/bs/batterycharge/v1/$type/$country/vehicles/$vin/charger
        vw-connect.0 2020-01-28 17:44:13.112 error (15283) 403
        vw-connect.0 2020-01-28 17:44:13.056 debug (15283) {"tripDataList":{"tripData":[{"tripType":"cyclic","tripID":65385844,"averageFuelConsumption":82,"averageSpeed":51,"mileage":532,"startMileage":2265,"traveltime":630,"timestamp":"2017-12-15T13:
        vw-connect.0 2020-01-28 17:44:12.900 debug (15283) {"StoredVehicleDataResponse":{"vin":"xxxxxxxxxxxxxxxxx","vehicleData":{"data":[{"id":"0x0101010001","field":[{"id":"0x0101010001","tsCarSentUtc":"2020-01-28T16:38:49Z","tsCarSent":"2020-01-28T
        vw-connect.0 2020-01-28 17:44:12.695 debug (15283) {"dwaPushHistory":null}
        vw-connect.0 2020-01-28 17:44:12.598 debug (15283) system.adapter.admin.0: logging true
        vw-connect.0 2020-01-28 17:44:12.196 debug (15283) {"CurrentVehicleDataResponse":{"requestId":"xxxxxxxx","vin":"xxxxxxxxxxxxxxxxx"}}
        vw-connect.0 2020-01-28 17:44:11.245 error (15283) 406
        vw-connect.0 2020-01-28 17:44:11.006 debug (15283) {"userVehicles":{"vehicle":["xxxxxxxxxxxxxxxxx"]}}
        vw-connect.0 2020-01-28 17:44:10.786 debug (15283) {"firstName":"xxxxx","lastName":"xxxxx","salutation":"SALUTATION:xxx","dateOfBirth":"xxxxxxxxxx","preferredContactChannel":"MARKETING_BLOCKADES:EMAIL","nickname":"F","businessIdentifierType":
        vw-connect.0 2020-01-28 17:44:10.575 debug (15283) getData
        vw-connect.0 2020-01-28 17:44:10.575 debug (15283) Login successful
        vw-connect.0 2020-01-28 17:44:09.181 debug (15283) {"date":"Tue, 28 Jan 2020 16:44:09 GMT","content-length":"0","connection":"close","cache-control":"no-cache, no-store, max-age=0, must-revalidate","content-language":"en","expires":"0","locat
        vw-connect.0 2020-01-28 17:44:09.181 debug (15283) ""
        vw-connect.0 2020-01-28 17:44:08.791 debug (15283) parsePasswordForm
        vw-connect.0 2020-01-28 17:44:08.376 debug (15283) parseEmailForm
        vw-connect.0 2020-01-28 17:44:07.755 info  (15283) starting. Version 0.0.10 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v10.17.0
        vw-connect.0 2020-01-28 17:44:07.167 debug (15283) statesDB connected
        vw-connect.0 2020-01-28 17:44:07.166 debug (15283) States connected to redis: 127.0.0.1:9000
        vw-connect.0 2020-01-28 17:44:07.155 debug (15283) States create System PubSub Client
        vw-connect.0 2020-01-28 17:44:07.154 debug (15283) States create User PubSub Client
        vw-connect.0 2020-01-28 17:44:07.149 debug (15283) Redis States: Use Redis connection: 127.0.0.1:9000
        vw-connect.0 2020-01-28 17:44:07.148 debug (15283) objectDB connected
        vw-connect.0 2020-01-28 17:44:07.146 debug (15283) Objects connected to redis: 127.0.0.1:9001
        vw-connect.0 2020-01-28 17:44:07.139 debug (15283) Objects client initialize lua scripts
        vw-connect.0 2020-01-28 17:44:07.139 debug (15283) Objects create User PubSub Client
        vw-connect.0 2020-01-28 17:44:07.138 debug (15283) Objects create System PubSub Client
        vw-connect.0 2020-01-28 17:44:07.137 debug (15283) Objects client ready ... initialize now
        vw-connect.0 2020-01-28 17:44:07.125 debug (15283) Redis Objects: Use Redis connection: 127.0.0.1:9001
          @opossum die fehler sollten nicht ausgegeben werden einfach nochmal installieren dann sind sie ausgeblendet.
          • opossum
            Hallo, @tombox ,
            danke für die Information. habe neu installiert. Leider kommt noch eine Fehlermeldung:
            vw-connect.0 2020-01-28 23:25:09.489 error (19482) 406
              @opossum Scheinbar nur die Rechte und Lizenzen das ist nicht so wichtig. Entweder geht das bei deinem Fahrzeug nicht oder sie haben was geändert.
              • opossum
                Hallo, @tombox ,
                Daten kommen ja, daher kann ich mit der Meldung leben. Danke Dir.
                • opossum
                  mal den ersten Entwurf für meine VIS fertiggestellt:
                  Hat jemand eine Lösung für die Großbuchstaben im Datum? Gibt es da vielleicht schon ein Script oder ähnliches?
                  Sollte ich einige Rubriken oder Statie falsch beschriftet haben, wäre ich dankbar, wenn Ihr mir die richtigen Bezeichner geben würdet.
                  Türen: Sind wohl immer die Values 1, 2, 3. Leider noch nicht ergründet, welcher Status zu welchem Value gehört.
                  Fenster: In der Garage mal eines offen gelassen, es wird dann der Status 2 gelesen und es wird eine Prozentzahl des Öffnungsgrades übermittelt.
                  T Wszene B F 4 Replies Last reply Reply Quote 0
                    @opossum
                    1 = open 2 = Locked 3 = Closed
                    also in javascript könnte folgendes gehen
                    createState("xxxDatum", "",{});
                    on('vwconnect.0.xxx.xxxxx.xxxx',function(obj){
                       setState("xxxDatum", new Date(obj.state.val).toLocaleDateString());
                    • opossum
                      Hallo, @tombox , danke für die Info, da kann ich die VIS mit den Türen ja fertigstellen.
                        Sneak-L8 last edited by
                        Hallo zusammen, bisher lief der Adapter einwandfrei. Heute hab ich entdeckt, dass der SoC unter "status" nicht mehr passt. Er ist seit gestern nicht mehr aktualisiert. SoC unter charger.status ist aber aktuell. Dann fiel mir auf, dass es auch unter status.data06.field01 Ungereimtheiten gibt. Da sollte ja die Außentemperatur stehen. value is aber 2, das wäre - 272°C. Und bei textId steht: "status_parking_light_off".
                        Ist da irgendwas verrutscht? Oder werden die datas/fields im We connect umsortiert?
                        Die textId finde ich z.B. auch unter status.data05.field01.
                          tombox @Sneak-L8 last edited by
                          @Sneak-L8
                          Ich würde dir empfehlen mal status zu löschen. Denn wenn bestimmten daten felder nicht mehr gesendet werden dann werden die aus dem iobroker nicht gelöscht und bleiben bei den alten werten stehen. Werde ich wohl mal einführen das er bei adapter start der status gelöscht wird.
                            Danke, das hat funktioniert. Jetzt kommen die Werte wieder (und den bisherigen Namen). Allerdings sind damit die geloggten Werte weg. Die Verknüpfung mit sql-Adapter ist dann weg und muss neu gesetzt werden.
                            Je nachdem wie Du im Adapter das umsetzen willst, sollte man drauf achten, dass das nicht passiert.
                              @Sneak-L8 Aber sind das die ursprüngliche Pfade? Denn die müssten sich geändert haben.
                                Also ich sehe keinen Unterschied in den Pfaden
                                  @Sneak-L8 eigenartig und den Sox stand gibt es unter Status immer noch?
                                    Ja, genau da, wo er vorher auch war.
                                    • pmunck86
                                      pmunck86 last edited by pmunck86
                                      vielleicht kann mir jemand weiterhelfen. Ich nutze den Adapter jetzt schon ein paar Wochen als Informationsquelle für die Fahrzeugdaten. Jetzt hab ich mich dran gemacht die Standheizung steuern zu wollen, da komme ich nicht weiter... Ich habe schon einiges probiert aber sie lässt sich weder von
                                      vw-connect.0.Xxx.remote.climatisation = umschalten
                                      vw-connect.0.Xxx.remote.standheizung = true
                                      vw-connect.0.Xxx.remoteStandheizung.climatisationStateReport.climatisationState = heating
                                      noch von den Datenpunkten kombiniert starten. Ich nutze den Adapter für einen Skoda Octavia Kombi.
                                      Viele Grüße
                                        tombox @pmunck86 last edited by tombox
                                        @pmunck86 nimm mal die lange Nummer aus dem Post. Es reicht den Datenpunkt auf true zu setzen. Was ist die Ausgabe im log? S-Pin in den Optionen nicht vergessen.
                                        pmunck86 1 Reply Last reply Reply Quote 0
                                        • pmunck86
                                          pmunck86 @tombox last edited by
                                          @tombox S-Pin ist angegeben. Im log steht folgendes
                                          vw-connect.0	2020-02-14 19:43:50.575	error	(2910) 429
                                          javascript.0	2020-02-14 19:43:49.111	info	(2491) script.js.Standheizung_starten_stoppen: Standheizung wird angeschaltet
                                          vw-connect.0	2020-02-14 19:43:43.942	error	(2910) 429
                                          vw-connect.0	2020-02-14 19:43:11.537	info	(2910) {"performActionResponse":{"requestId":"12218185","vin":"xxx"}}
                                            @pmunck86 429 könnte bedeuteten das du die Zündung des Fahrzeugs einschalten musst eh er wieder Anfrage entgegennimmt
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            399
                                            3091
                                            1605741
