    4. JavaScript
    5. Sonoff Geräte als HTML Tabelle - Vis
      liv-in-sky @Latzi last edited by
      @Latzi geändert - im ersten post
      Latzi Chaot 2 Replies Last reply Reply Quote 1
      • Latzi
        Latzi @liv-in-sky last edited by
        @liv-in-sky
        Perfekt! Ich bin begeistert und beeindruckt von deiner Geschwindigkeit 👍 🚀
        • Chaot
          Chaot @liv-in-sky last edited by
          @liv-in-sky
          Ich war ein paar Tage nicht bei der Sache.
          Was läuft hier verkehrt:
          javascript.0	2020-01-30 22:28:40.025	warn	(530) at Timer.processTimers (timers.js:223:10)
          javascript.0	2020-01-30 22:28:40.025	warn	(530) at listOnTimeout (timers.js:263:5)
          javascript.0	2020-01-30 22:28:40.025	warn	(530) at tryOnTimeout (timers.js:300:5)
          javascript.0	2020-01-30 22:28:40.025	warn	(530) at ontimeout (timers.js:436:11)
          javascript.0	2020-01-30 22:28:40.024	warn	(530) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
          javascript.0	2020-01-30 22:28:40.024	warn	(530) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
          javascript.0	2020-01-30 22:28:40.024	warn	(530) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
          javascript.0	2020-01-30 22:28:40.024	warn	(530) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1319:34)
          javascript.0	2020-01-30 22:28:40.024	warn	(530) at Object.<anonymous> (script.js.Systeminfo.Tasmota2:1513:3)
          javascript.0	2020-01-30 22:28:40.024	warn	(530) at writeHTML (script.js.Systeminfo.Tasmota2:445:31)
          javascript.0	2020-01-30 22:28:40.023	warn	(530) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
          javascript.0	2020-01-30 22:28:40.023	warn	(530) at script.js.Systeminfo.Tasmota2:460:23
          javascript.0	2020-01-30 22:28:40.022	warn	(530) getState "sonoff.0.Sender.POWER" not found (3) states[id]=null
          javascript.0	2020-01-30 22:28:32.530	warn	(530) at script.js.Systeminfo.Tasmota2:1516:3
          javascript.0	2020-01-30 22:28:32.529	warn	(530) at writeHTML (script.js.Systeminfo.Tasmota2:445:31)
          javascript.0	2020-01-30 22:28:32.529	warn	(530) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
          javascript.0	2020-01-30 22:28:32.529	warn	(530) at script.js.Systeminfo.Tasmota2:460:23
          javascript.0	2020-01-30 22:28:32.528	warn	(530) getState "sonoff.0.Sender.POWER" not found (3) states[id]=null
            liv-in-sky @Chaot last edited by
            @Chaot sieht nach fehlenden datenpunkt aus
            probieren wir mal das:
            • script stoppen
            • sonoff instanzen stoppen
            • alle sonoff dp löschen - den ganzen sonoff.x ordner oder aber mindestens sonoff.0.Sender
            • sonoff instanz wieder starten
            • scipt wieder starten
            • chucky666
              chucky666 last edited by
              Hallo
              danke für das script, leider bekomme ich es nicht ans laufen
              javascript.0	2020-01-31 04:25:07.237	error	(937) at Script.runInContext (vm.js:133:20)
              javascript.0	2020-01-31 04:25:07.237	error	(937) at script.js.Sonoffliste:1407:2
              javascript.0	2020-01-31 04:25:07.237	error	(937) at writeHTML (script.js.Sonoffliste:521:30)
              javascript.0	2020-01-31 04:25:07.237	error	(937) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:771:29)
              javascript.0	2020-01-31 04:25:07.237	error	(937) at script.js.Sonoffliste:534:67
              javascript.0	2020-01-31 04:25:07.236	error	(937) TypeError: Cannot read property 'toString' of null
              javascript.0	2020-01-31 04:25:07.236	error	(937) ^
              javascript.0	2020-01-31 04:25:07.236	error	(937) val3=getState(id.replace("INFO.Module","Wifi_RSSI")).val.toString()+" %";
              javascript.0	2020-01-31 04:25:07.236	error	(937) script.js.Sonoffliste: script.js.Sonoffliste:534
              • Chaot
                @liv-in-sky Danke für den Tip.
                Ich habe den Fehler gefunden.
                Das Modul "Sender" ist generic und hat gar keinen Datenpunkt Power sondern nur Power1 und Power2.
                Ich muss mir mal überlegen wie ich das löse, da ich ja noch andere Generic habe bei denen das anders ist.
                  @Chaot ich habe mir schon gedacht, das generic irgendwann ärger machen wird - ich nehme das power wieder raus - bzw werde bei generic eine existiert-power abfrage reinbasteln
                    liv-in-sky @chucky666 last edited by
                    @chucky666 schau doch mal nach, welcher deiner sonoff's keinen "Wifi_RSSI" datenpunkt hat
                      @Chaot teste mal das script im ersten post - ich frage da POWER ab bevor ich es ausgebe
                      • Chaot
                        @liv-in-sky Jup! Schaut besser aus. Keine Fehlermeldung mehr.
                        • Chaot
                          @liv-in-sky
                          Ähem, ich will jetzt nicht nörgeln, aber macht es viel Arbeit die tollen Zeilenfarben auch hier umzusetzen wie du das in der Tabelle für Batteriezustaände gemacht hast.
                          Übrigens: Saugeile Sache was duhier machst! Ganz herzlichen Dank dafür!
                            @Chaot bin gerade dabei meine templates alle umzustellen - dauert ein wenig - werde es aber dann aber auch da rein tun
                            bei 8 spalten verliert man leicht den überblick, wie das html aufzubauen ist 😞
                              MyMeyer last edited by
                              Hallo, ich habe gerade das Problem das ein Sonoff gefunden wird und einer nicht, obwohl alle im Netz sind sich auch schalten lassen. Und auch unter Objekte ist alles normal.
                                liv-in-sky @MyMeyer last edited by
                                @MyMeyer rot wird er , wenn das auf false steht
                                  Er steht ja auf True !
                                    Läuft jetzt...habe mal alle Objekte gelöscht und neue eingelesen. Jetzt sind ist alles da.
                                    Danke.
                                      crunchip Forum Testing Most Active @MyMeyer last edited by
                                      @MyMeyer achte mal auf die IP!
                                      dein .92 steht auf true, im script hast du .25
                                        MyMeyer @crunchip last edited by
                                        @crunchip sagte in Sonoff Geräte als HTML Tabelle - Vis - Iqontrol:
                                        .92 ist von @liv-in-sky nicht von mir 🙂 Aber jetzt läuft es ja wieder Danke für die Hilfe...
                                          @MyMeyer du weißt, du kannst die überschriften ohne geräte wegbekommen, wenn du sie deaktivierst im setting ?
                                            MyMeyer @liv-in-sky last edited by
                                            @liv-in-sky Jo...👍 bekannt.
                                            1.0k
                                            javascript monitoring template
                                            34
                                            632
                                            130872
