    4. Backitup Probleme nach Update "Nodejs 10.18.1"
    SOLVED Backitup Probleme nach Update "Nodejs 10.18.1"
      MyMeyer last edited by
      @simatec Habe ich gemacht alles gelöscht. Iobroker neu gestartet und nochmal installiert. Konfiguration wieder rein gezogen. Fehler bleibt:
      host.iobroker 2020-02-02 12:09:15.773 info instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
      host.iobroker 2020-02-02 12:09:15.773 error Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
      host.iobroker 2020-02-02 12:09:15.773 error Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      host.iobroker 2020-02-02 12:09:15.773 error Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      host.iobroker 2020-02-02 12:09:15.772 error Caught by controller[0]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:580:17)
      host.iobroker 2020-02-02 12:09:15.772 error Caught by controller[0]: at options.adapter.getState (/opt/iobroker/node_modules/iobroker.backitup/lib/scripts/92-history.js:25:44)
      host.iobroker 2020-02-02 12:09:15.772 error Caught by controller[0]: TypeError: historyList.split is not a function
      backitup.0 2020-02-02 12:09:15.260 info (27285) Terminated (NO_ERROR): Without reason
      backitup.0 2020-02-02 12:09:15.259 info (27285) terminating
      backitup.0 2020-02-02 12:09:14.756 error at process._tickCallback (internal/process/next_tick.js:68:7)
      backitup.0 2020-02-02 12:09:14.756 error at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      backitup.0 2020-02-02 12:09:14.756 error at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      backitup.0 2020-02-02 12:09:14.756 error at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:580:17)
      backitup.0 2020-02-02 12:09:14.756 error at options.adapter.getState (/opt/iobroker/node_modules/iobroker.backitup/lib/scripts/92-history.js:25:44)
      backitup.0 2020-02-02 12:09:14.756 error (27285) TypeError: historyList.split is not a function
      backitup.0 2020-02-02 12:09:14.755 error (27285) uncaught exception: historyList.split is not a function
      • simatec
        simatec Developer Most Active @MyMeyer last edited by
        @MyMeyer
        Hast du auch den Adapter gelöscht oder Backitup nur unter Instanzen entfernt?
        Das „false“ kommt definitiv nicht vom Adapter im Objekt „html“ man sieht es auch daran, dass der Wert rot ist (nicht bestätigt).
        Hast du irgendwelche Scripts für die VIS oder so laufen?
        Lösche mal den kompletten Ordner backitup.0 und starte dann mal Backitup neu
          MyMeyer @simatec last edited by
          @simatec sagte in Backitup Probleme nach Update "Nodejs 10.18.1":
          @MyMeyer
          Unter Instanzen gelöscht und Adapter auch gelöscht.
          Okay.
          Unter VIS habe ich das von Dir laufen wo man das Backup starten kann.
          Mache ich jetzt und melde ich mich wieder... Ich setzte Ihnen jetzt komplett neu auf ohne die alte Konfiguration.
          Und dann schauen wir mal...
            MyMeyer @simatec last edited by MyMeyer
            @simatec Also ich habe alles gemacht wie du geschrieben hast. Bringt nichts. Er macht das Backup auf die NAS dort stehen die Daten , aber unter Objekte aktualisiert er auch nichts.
            Und das Log zeigt immer noch den Fehler:
            host.iobroker 2020-02-02 13:17:43.332 info instance system.adapter.backitup.0 started with pid 7514
            host.iobroker 2020-02-02 13:17:13.322 info Restart adapter system.adapter.backitup.0 because enabled
            host.iobroker 2020-02-02 13:17:13.322 info instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
            host.iobroker 2020-02-02 13:17:13.322 error Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
            host.iobroker 2020-02-02 13:17:13.322 error Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
            host.iobroker 2020-02-02 13:17:13.322 error Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
            host.iobroker 2020-02-02 13:17:13.322 error Caught by controller[0]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:580:17)
            host.iobroker 2020-02-02 13:17:13.322 error Caught by controller[0]: at options.adapter.getState (/opt/iobroker/node_modules/iobroker.backitup/lib/scripts/92-history.js:20:40)
            host.iobroker 2020-02-02 13:17:13.321 error Caught by controller[0]: TypeError: historyList.split is not a function
            backitup.0 2020-02-02 13:17:12.809 info (6063) Terminated (NO_ERROR): Without reason
            backitup.0 2020-02-02 13:17:12.809 info (6063) terminating
            heatingcontrol.0 2020-02-02 13:17:12.385 info (15201) handle actors Schlafzimmer current 18.2 target 16
            backitup.0 2020-02-02 13:17:12.305 error at process._tickCallback (internal/process/next_tick.js:68:7)
            backitup.0 2020-02-02 13:17:12.305 error at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
            backitup.0 2020-02-02 13:17:12.305 error at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
            backitup.0 2020-02-02 13:17:12.305 error at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:580:17)
            backitup.0 2020-02-02 13:17:12.305 error at options.adapter.getState (/opt/iobroker/node_modules/iobroker.backitup/lib/scripts/92-history.js:20:40)
            backitup.0 2020-02-02 13:17:12.305 error (6063) TypeError: historyList.split is not a function
            backitup.0 2020-02-02 13:17:12.305 error (6063) uncaught exception: historyList.split is not a function
            Was mich wundert das er das Fenster im Iobroker auch nicht schließt wenn ich das Backup manuell aus dem Adapter startet. Habe bereits mal eine alte Version versucht , aber auch das brachte keine Besserung.
            Was ich jetzt noch machen könnte wäre eine Image Copie von Proxmox aufsetzen. Dann wäre wieder beim 31.01.2020 ohne history Daten... 😖
            • simatec
              @MyMeyer
              Ich schaue mir den Code noch einmal an, aber mich wundert der Wert true bzw. false.
              Das schreibt da Backitup nicht rein.
              Ich habe das Gefühl, dass dies irgendwo aus deinem System kommt.
              Muss ich aber schauen.
              • simatec
                simatec Developer Most Active @simatec last edited by simatec
                @simatec
                Was steht im Objekt html, wenn du den Ordner backitup.0 inkl. aller Unterordner löschst und Backitup neu startest?
                Bitte kein backup ausführen... nur Backitup neustarten
                  @simatec
                  • simatec
                    @MyMeyer
                    Genau so soll es aussehen ...
                    Wie du siehst, ist auch der Wert vom Adapter bestätigt und dementsprechend nicht rot.
                    Wenn nun bei einem Backup jetzt da wieder ein roter Wert mit true oder false steht, dann prüfe mal deine Scripte oder VIS, ob da eventuell was passiert.
                    So wie der Wert jetzt ist, dürfte da beim Backup auch kein Error kommen.
                      @simatec Upps wat denn nun... 🤕 Ich dachte jetzt startet ich noch mal ein Backup aus dem Adapter und siehe da...es ist alles da... 🤔 wie kann das sein ? Ich habe nichts anderes gemacht...
                      Nur Objekte gelöscht .. Adapter neugestartet und nun ist es okay ?!?!
                      • simatec
                        @MyMeyer
                        Wie gesagt, wo die Werte unter html hergekommen sind, kann ich dir nicht beantworten. Von Backitup ist rein vom Code her unmöglich dort einen Wert mit true oder false zu bekommen.
                        Welche Version von Backitup ist installiert?
                          @MyMeyer
                          Zumindest kann ich damit sehen ob Backitup alles korrekt macht beim Start.👍
                          Ich habe jetzt 1.30 am laufen und lasse es die nächsten Tage so. Wer erst mal meine Scripte prüfen. 🙂
                          Sollte nach dem Update auf V1.36 keine Probleme auftreten werde ich den Thread als GELÖST kennzeichnen.
                          • Basti97
                            Basti97 Most Active last edited by
                            Und zwar habe ich nach dem Update von JS- Controller bzw Nodejs Probleme mit dem Backitup. Und zwar werden keine Backups mehr erstellt und auf meine Nas gespeichert folgende Fehlermeldungen kommen.
                            Backitup in der Version 3.1.6.
                            Ich hoffe ihr könnt mir helfen.
                            Gruß Basti97
                            • simatec
                              simatec Developer Most Active @Basti97 last edited by
                              @Basti97
                              Bitte lasse den Installer Fix drüberlaufen.
                              Siehe Signatur...
                              • Basti97
                                Okay Danke für die schnelle Hilfe es hat funktioniert und geht wieder.
                                Eine Frage ich habe auf einem Slave den Zigbee Adapter laufen.
                                Wenn ich nun den Master mit Backitup sichere wird die Zigbee Datenbank vom Slave auch mit gesichert oder nicht?
                                Da wenn ich den Haken bei "Zigbee Datenbank" auf den Master anklicke wird das Backup nicht beendet sobald ich den wegnehme wird mein Backup fertiggestellt und gespeichert.
                                Muss ich nun auf dem Slave auch Backitup installieren um die Zigbee Datenbank zusichern oder nicht?
                                Danke Gruß Basti
                                • simatec
                                  @Basti97
                                  Wenn auf dem Slave zigbee läuft u d auf dem Master nicht, dann musst du eine zweite Instanz auf dem Slave installieren.
                                  Soweit ich aber das im Kopf habe, wird nun auch im iobroker Backup zigbee gesichert.
                                  Schaue dir mal das Backup an und entpacke es mal. Wenn dies der Fall ist, kannst du zigbee deaktivieren.
                                  Basti97 1 Reply Last reply Reply Quote 0
                                  • Basti97
                                    Basti97 Most Active @simatec last edited by
                                    @simatec ok werde ich mal gucken. Danke für die Hilfe.
                                    Gruß Basti
                                    backitup nodejs 10
                                    892
