    4. Test Adapter fb-checkpresence v0.2.x
    • afuerhoff
      afuerhoff Developer @ub.privat last edited by
      @ub-privat sagte in Test Adapter fb-checkpresence v0.2.x:
      @sigi234 @afuerhoff
      Gibst schon was neues zum Thema 'Tabelle'???
      Hallo, ich bin dran.
      ub.privat 1 Reply Last reply Reply Quote 1
        Tobi81 last edited by
        Meine Instanz von dem Adapter stürzt leider immer wieder ab, und es werden keine Datenpunkte angelegt.
        Hier ein Auszug aus meiner Logdatei:
        2020-02-01 23:33:39.026 - info: host.iobroker "system.adapter.fb-checkpresence.0" enabled
        2020-02-01 23:33:39.056 - info: host.iobroker instance system.adapter.fb-checkpresence.0 started with pid 6751
        2020-02-01 23:33:41.289 - info: fb-checkpresence.0 (6751) starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v8.17.0
        2020-02-01 23:33:41.335 - info: fb-checkpresence.0 (6751) start fb-checkpresence: ip-address: 192.168.178.1 polling interval: 1 Min.
        2020-02-01 23:35:51.164 - error: fb-checkpresence.0 (6751) uncaught exception: Cannot read property 'search' of undefined
        2020-02-01 23:35:51.165 - error: fb-checkpresence.0 (6751) TypeError: Cannot read property 'search' of undefined
        at /opt/iobroker/node_modules/iobroker.fb-checkpresence/lib/fb.js:37:57
        at Parser. (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/xml2js/lib/parser.js:308:18)
        at emitOne (events.js:116:13)
        at Parser.emit (events.js:211:7)
        at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/xml2js/lib/parser.js:327:16)
        at Parser.parseString (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/xml2js/lib/parser.js:5:59)
        at exports.parseString (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/xml2js/lib/parser.js:369:19)
        at Request.request [as _callback] (/opt/iobroker/node_modules/iobroker.fb-checkpresence/lib/fb.js:36:17)
        at self.callback (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/request/request.js:185:22)
        2020-02-01 23:35:51.167 - info: fb-checkpresence.0 (6751) cleaned everything up...
        2020-02-01 23:35:51.169 - error: fb-checkpresence.0 (6751) onReady: connect ETIMEDOUT 192.168.178.1:49000
        2020-02-01 23:35:51.178 - info: fb-checkpresence.0 (6751) terminating
        2020-02-01 23:35:51.179 - info: fb-checkpresence.0 (6751) Terminated (NO_ERROR): Without reason
        2020-02-01 23:35:51.704 - error: host.iobroker Caught by controller[0]: TypeError: Cannot read property 'search' of undefined
        2020-02-01 23:35:51.705 - error: host.iobroker Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.fb-checkpresence/lib/fb.js:37:57
        2020-02-01 23:35:51.705 - error: host.iobroker Caught by controller[0]: at Parser. (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/xml2js/lib/parser.js:308:18)
        2020-02-01 23:35:51.705 - error: host.iobroker Caught by controller[0]: at emitOne (events.js:116:13)
        2020-02-01 23:35:51.706 - error: host.iobroker Caught by controller[0]: at Parser.emit (events.js:211:7)
        2020-02-01 23:35:51.706 - error: host.iobroker Caught by controller[0]: at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/xml2js/lib/parser.js:327:16)
        2020-02-01 23:35:51.706 - error: host.iobroker Caught by controller[0]: at Parser.parseString (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/xml2js/lib/parser.js:5:59)
        2020-02-01 23:35:51.706 - error: host.iobroker Caught by controller[0]: at exports.parseString (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/xml2js/lib/parser.js:369:19)
        2020-02-01 23:35:51.706 - error: host.iobroker Caught by controller[0]: at Request.request [as _callback] (/opt/iobroker/node_modules/iobroker.fb-checkpresence/lib/fb.js:36:17)
        2020-02-01 23:35:51.706 - error: host.iobroker Caught by controller[0]: at self.callback (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/request/request.js:185:22)
        2020-02-01 23:35:51.706 - error: host.iobroker Caught by controller[0]: at emitOne (events.js:116:13)
        2020-02-01 23:35:51.706 - info: host.iobroker instance system.adapter.fb-checkpresence.0 terminated with code 0 (NO_ERROR)
        2020-02-01 23:35:51.706 - info: host.iobroker Restart adapter system.adapter.fb-checkpresence.0 because enabled
        Hast du eine Idee woran das liegen könnte?
        afuerhoff 1 Reply Last reply Reply Quote 0
        • afuerhoff
          afuerhoff Developer @Tobi81 last edited by
          @Tobi81
          Kannst Du den Log Level mal auf debug stellen und dann die Ausgabe ab Start nochmal posten.
            MartyBr @afuerhoff last edited by
            @afuerhoff
            Hallo, ich habe ca. 30 Geräte in der Whitelist:
            Hier meine DPs:
            Ich vermisse einen Ordner ** Whitelist** mit den in der Liste enthaltenen Geräte. Der Ordner Blacklist ist ja vorhanden. Damit könnte der Zustand Online/Offline direkt abgegriffen werden. Alternativ auch wie n der Blacklist eine JSON-Tabelle.
            Ich hoffe, ich habe mich verständlich ausgedrückt.
            • ub.privat
              ub.privat @afuerhoff last edited by
              @afuerhoff
              👍 👍 👍 👍 sehr schön!
                Tobi81 @afuerhoff last edited by
                @afuerhoff
                Hab nun ein Debug-Log gemacht. Beim ersten Start habe ich die MAC Adresse angegeben, nachdem der Adapter aber gecrashed ist, habe ich die IP Adresse verwendet.
                Hab die Version 0.2.2 installiert.
                Hoffe das Logfile hilft. 🙂
                2020-02-02 15:24:36.535 - info: host.iobroker "system.adapter.fb-checkpresence.0" enabled
                2020-02-02 15:24:36.560 - info: host.iobroker instance system.adapter.fb-checkpresence.0 started with pid 27081
                2020-02-02 15:24:38.028 - debug: fb-checkpresence.0 (27081) Redis Objects: Use Redis connection: 0.0.0.0:9001
                2020-02-02 15:24:38.070 - debug: fb-checkpresence.0 (27081) Objects client ready ... initialize now
                2020-02-02 15:24:38.075 - debug: fb-checkpresence.0 (27081) Objects create System PubSub Client
                2020-02-02 15:24:38.076 - debug: fb-checkpresence.0 (27081) Objects create User PubSub Client
                2020-02-02 15:24:38.077 - debug: fb-checkpresence.0 (27081) Objects client initialize lua scripts
                2020-02-02 15:24:38.100 - debug: fb-checkpresence.0 (27081) Objects connected to redis: 0.0.0.0:9001
                2020-02-02 15:24:38.107 - debug: fb-checkpresence.0 (27081) objectDB connected
                2020-02-02 15:24:38.111 - debug: fb-checkpresence.0 (27081) Redis States: Use Redis connection: 0.0.0.0:9000
                2020-02-02 15:24:38.122 - debug: fb-checkpresence.0 (27081) States create User PubSub Client
                2020-02-02 15:24:38.126 - debug: fb-checkpresence.0 (27081) States create System PubSub Client
                2020-02-02 15:24:38.170 - debug: fb-checkpresence.0 (27081) States connected to redis: 0.0.0.0:9000
                2020-02-02 15:24:38.171 - debug: fb-checkpresence.0 (27081) statesDB connected
                2020-02-02 15:24:39.035 - info: fb-checkpresence.0 (27081) starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v8.17.0
                2020-02-02 15:24:39.107 - info: fb-checkpresence.0 (27081) start fb-checkpresence: ip-address: 192.168.178.1 polling interval: 1 Min.
                2020-02-02 15:24:39.108 - debug: fb-checkpresence.0 (27081) configuration user: smarthome
                2020-02-02 15:24:39.108 - debug: fb-checkpresence.0 (27081) configuration history:
                2020-02-02 15:24:39.109 - debug: fb-checkpresence.0 (27081) configuration dateformat: yyyy.mm.dd hh:MM:ss
                2020-02-02 15:24:39.109 - debug: fb-checkpresence.0 (27081) configuration familymembers: [{"familymember":"Tobias","macaddress":"192.168.174.145","comment":"12","enabled":true}]
                2020-02-02 15:24:39.585 - debug: fb-checkpresence.0 (27081) system.adapter.admin.0: logging false
                2020-02-02 15:24:40.391 - debug: fb-checkpresence.0 (27081) system.adapter.admin.0: logging true
                2020-02-02 15:26:48.623 - error: fb-checkpresence.0 (27081) uncaught exception: Cannot read property 'search' of undefined
                2020-02-02 15:26:48.624 - error: fb-checkpresence.0 (27081) TypeError: Cannot read property 'search' of undefined
                2020-02-02 15:26:48.625 - info: fb-checkpresence.0 (27081) cleaned everything up...
                2020-02-02 15:26:48.627 - error: fb-checkpresence.0 (27081) onReady: connect ETIMEDOUT 192.168.178.1:49000
                2020-02-02 15:26:48.632 - debug: fb-checkpresence.0 (27081) system.adapter.admin.0: logging false
                2020-02-02 15:26:48.636 - info: fb-checkpresence.0 (27081) terminating
                2020-02-02 15:26:48.637 - info: fb-checkpresence.0 (27081) Terminated (NO_ERROR): Without reason
                2020-02-02 15:26:49.160 - error: host.iobroker Caught by controller[0]: TypeError: Cannot read property 'search' of undefined
                2020-02-02 15:26:49.161 - error: host.iobroker Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.fb-checkpresence/lib/fb.js:37:57
                2020-02-02 15:26:49.161 - error: host.iobroker Caught by controller[0]: at Parser. (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/xml2js/lib/parser.js:308:18)
                2020-02-02 15:26:49.161 - error: host.iobroker Caught by controller[0]: at emitOne (events.js:116:13)
                2020-02-02 15:26:49.161 - error: host.iobroker Caught by controller[0]: at Parser.emit (events.js:211:7)
                2020-02-02 15:26:49.161 - error: host.iobroker Caught by controller[0]: at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/xml2js/lib/parser.js:327:16)
                2020-02-02 15:26:49.161 - error: host.iobroker Caught by controller[0]: at Parser.parseString (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/xml2js/lib/parser.js:5:59)
                2020-02-02 15:26:49.162 - error: host.iobroker Caught by controller[0]: at exports.parseString (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/xml2js/lib/parser.js:369:19)
                2020-02-02 15:26:49.162 - error: host.iobroker Caught by controller[0]: at Request.request [as _callback] (/opt/iobroker/node_modules/iobroker.fb-checkpresence/lib/fb.js:36:17)
                2020-02-02 15:26:49.162 - error: host.iobroker Caught by controller[0]: at self.callback (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/request/request.js:185:22)
                2020-02-02 15:26:49.162 - error: host.iobroker Caught by controller[0]: at emitOne (events.js:116:13)
                2020-02-02 15:26:49.162 - info: host.iobroker instance system.adapter.fb-checkpresence.0 terminated with code 0 (NO_ERROR)
                2020-02-02 15:26:49.162 - info: host.iobroker Restart adapter system.adapter.fb-checkpresence.0 because enabled
                • afuerhoff
                  @Tobi81
                  Hallo, was für eine Fritzbox mit welcher Firmware Version hast Du?
                  PS: Was ich noch gesehen habe, dass Du keinen History Adapter in der Konfiguration ausgewählt hast. Der ist aber für vollen Funktionsumfang notwendig.
                    Malz1902 @afuerhoff last edited by
                    @afuerhoff said in Test Adapter fb-checkpresence v0.2.x:
                    @Malz1902 sagte in Test Adapter fb-checkpresence v0.2.x:
                    @Malz1902
                    so müsste es funktionieren:
                    var anwesenheit = getState('fb-checkpresence.0.Galaxy-S10').val;
                    klappt leider nicht 😞
                    Hallo, bei mir funktioniert es so. Ist denn Galaxy-S10 der richtig Member Name?
                    Wie sieht denn die Konfiguration aus oder die angelegten Objekte.
                    habs jetzt war mein Fehler in meiner Abfrage sollte man true/false auch richtig schreiben 😄
                      @afuerhoff
                      Ich habe eine FritzBox 7590 mit der aktuellsten Firmware 07.12
                      Ich hab auch den Fehler gefunden: 🤕
                      Bei mir stand im Adapter bei der FritzBox IP schon eine IP: 192.168.178.1
                      Die habe ich nicht weiter beachtet. Aber ich habe ein anderes Subnetz: 192.168.174.*
                      Ich hab das geändert und nun funktioniert es...
                      Danke!
                      • afuerhoff
                        @Tobi81
                        Die Fritzbox IP ist mit einem default Wert vorbefüllt. Evtl. sollte ich den entfernen.
                          @Tobi81
                          Stell den doch auf fritz.box
                          • afuerhoff
                            afuerhoff Developer @Malz1902 last edited by
                            @Malz1902
                            Gute Idee.
                            • MathiasJ
                              MathiasJ last edited by MathiasJ
                              ich war auch mal so frei, den Adapter zu installieren, um die Anwesenheit im Gastnetz zu überwachen.
                              Anfangs lief der Adapter super nur jetzt schaltet der beim Neustart gleich von rot auf gelb und bringt folgende Meldung:
                              fb-checkpresence.0	2020-02-06 06:21:39.535	error	(19682) checkPresence: TypeError: Cannot read property 'message' of undefined
                              Mehr kann ich dem Adapter im Debug nicht entlocken.
                              bevor Fragen auftauchen:
                              Konfig der Adresse:
                              Fritzbox per fritz.box
                              Fritzox per IP-Adresse
                              immer das gleiche Resultat.
                              Oder liegt es vielleicht damit zusammen, weil ich den Adapter TR-064 auch nutze, um bei Abwesenheit meine eingehenden Anrufe umzuleiten?
                              Gruß,
                              Mathias
                              • afuerhoff
                                afuerhoff Developer @MathiasJ last edited by
                                @MathiasJ
                                Du könntest mal auf Loglevel debug schalten. Dann sollten mehr Ausgaben kommen. Hast du noch von Github installiert oder direkt über admin?
                                sigi234 MathiasJ 2 Replies Last reply Reply Quote 0
                                  sigi234 Forum Testing Most Active @afuerhoff last edited by
                                  @afuerhoff sagte in Test Adapter fb-checkpresence v0.2.x:
                                  @MathiasJ
                                  Habe ich auch teilweise.
                                  fb-checkpresence.0	2020-02-06 09:32:51.914	error	(10528) checkPresence: TypeError: Cannot read property 'message' of undefined
                                  M M 2 Replies Last reply Reply Quote 0
                                    Malz1902 @sigi234 last edited by
                                    irgendwie klappt das immer noch nicht, fb-checkpresence.0.Stephen-Galaxy-S10 steht auf true, aber die Abfrage springt immer in den else if Zweig
                                    var anwesenheitStephen = getState('fb-checkpresence.0.Stephen-Galaxy-S10').val; // true = anwesend, false = abwesend
                                        schedule('{"time":{"exactTime":true,"start":"10:35"},"period":{"days":1}}', function () {
                                             if (anwesenheitStephen === true) {
                                                var text = 'da';
                                            } else if (anwesenheitStephen === false) {
                                                var text = 'nicht da';
                                            } else {
                                                var text = 'blubb';
                                            sendTo("pushover.0", {
                                                message: text,
                                                title: wochentag,
                                                priority: 1
                                    • SBorg
                                      SBorg Forum Testing Most Active @Malz1902 last edited by
                                      @Malz1902 Musst du "strict" prüfen? Sonst ändere mal anwesenheitStephen === true in anwesenheitStephen == "true" (false natürlich auch ^^)
                                      • MathiasJ
                                        MathiasJ @afuerhoff last edited by
                                        @MathiasJ
                                        Tja, steht aber schon auf Loglevel debug, kommt trotzdem nicht mehr 🙄
                                        • afuerhoff
                                          afuerhoff Developer @MathiasJ last edited by afuerhoff
                                          @MathiasJ
                                          Es wäre hilfreich auch die Ausgaben vor der Fehlermeldung zu kennen. Gibt es da nichts?
                                          Ist die Funktion in irgendeiner Weise beeinträchtigt?
                                          Werden z.B. die Objekte nicht befüllt?
                                          Ich habe eine Vermutung, aber weitere Angaben wären hilfreich. Hast du von Github oder admin installiert.
                                          MathiasJ 1 Reply Last reply Reply Quote 0
                                          • MathiasJ
                                            @afuerhoff
                                            ich habe von Github installiert.
                                            wie bereits geschrieben, es kommen keine weiteren Fehlermeldungen. 😞
                                            31.7k
                                            79.8k
                                            avm fb-checkpresence fritzbox soap tr-064
                                            26
                                            259
                                            27656
