    4. Test Adapter lovelace v0.2.x
    • RichardIstSauer
      RichardIstSauer last edited by
      Wo finde ich bei accuweather ein summary object "entity: weather.Weather_Summary - your weather entity" ?
        fd_samdi @magiczoom last edited by
        @magiczoom Versuch es mal so:
        type: 'custom:button-card'
        entity: sensor.kontakt_haustuere
        label: |
            if (entity.state == true)
              return "geöffnet";
            else
              return "geschlossen";
        layout: icon_name_state2nd
        show_state: false
        show_name: true
        show_label: true
        icon: 'mdi:door-closed'
        styles:
          label:
            - font-size: small
            - font-style: italic
            - color: '#a1a1a1'
        Den Graph musst dir selber anschauen
        magiczoom 1 Reply Last reply Reply Quote 1
        • Johannes Bauerstatter
          Johannes Bauerstatter last edited by
          bin gerade beim Umsteigen von Iqontrol auf Lovelace und schaff es irgendwie nicht, einen virtuellen Schalter zu triggern:
            "_id": "javascript.0.VirtuelleSchalter.Rollos_zentral_Ab",
            "type": "state",
            "common": {
              "name": "Rollos_zentral_Ab",
              "role": "",
              "type": "number",
              "desc": "Manuell erzeugt",
              "unit": "",
              "min": 0,
              "max": 1,
              "def": 0,
              "read": true,
              "write": true,
              "custom": {
                "iqontrol.0": {
                  "enabled": true,
                  "readonly": false,
                  "invert": false,
                  "confirm": false,
                  "pincode": "",
                  "unit": "",
                  "unit_zero": "",
                  "unit_one": "",
                  "min": 0,
                  "max": 1,
                  "step": "",
                  "type": "number",
                  "role": "switch",
                  "targetValueId": ""
                "lovelace.0": {
                  "enabled": true,
                  "entity": "switch",
                  "name": "VirtuelleSchalterRolloszentralAb"
            "native": {},
            "from": "system.adapter.cloud.0",
            "user": "system.user.admin",
            "ts": 1579173581906,
            "acl": {
              "object": 1636,
              "state": 1636,
              "owner": "system.user.admin",
          Einstellung in Lovelace:
          type: horizontal-stack
          title: Rollos Wohnzimmer
          cards:
            - type: entity-button
              tap_action: toggle
              action: switch.VirtuelleSchalterRolloszentralAuf
              show_icon: true
              show_name: true
              entity: switch.VirtuelleSchalterRolloszentralAuf
              icon: 'mdi:toggle-switch-off'
              tap_action: toggle
              action: switch.VirtuelleSchalterRolloszentralAb
              show_icon: true
              show_name: true
              entity: switch.VirtuelleSchalterRolloszentralAb
          • Garfonso
            Garfonso Developer @Johannes Bauerstatter last edited by
            @Johannes-Bauerstatter
            Ich glaube du machst es zu kompliziert. Mach das mit der "tap_action" usw mal alles weg.. bei mir sieht das z.B. so aus:
            Da ist außer dem grafischen schnickschnak nur das entity eingetragen. Wenn man drauf tabt wird getoggelt und der status wird mit blau/gelb des icons angezeigt.
            (ok, bei mir haben die states auch boolean = true/false als typ, warum nimmst du hier 0/1? Sollte aber so auch gehen).
            Johannes Bauerstatter 1 Reply Last reply Reply Quote 0
            • magiczoom
              magiczoom @fd_samdi last edited by
              @fd_samdi Hammer! Funktioniert hervorragend, vielen Dank!
                Tictactoo last edited by
                Hi zusammen,
                ich hab da ein Problem mit dem Adapter in Kombination mit meinen Thermostaten: Sowohl mit der internen, als auch mit dem simple_thermostat Card bekomme ich leider keine Steuerung meine Heizung im Adapter hin. Ich habe den Datenpunkt, der die Temperatur steuert als climate zu Lovelace als Entity hinzugefügt. Setze ich nun
                type: thermostat
                entity: climate.Thermostat_im_Wohnzimmer_heating_setpnt_current
                name: Thermostat im Wohnzimmer
                als Card in Lovelace, bekomme ich eine leere Karte angezeigt.
                Benutze ich
                type: 'custom:simple-thermostat'
                name: Heizung im Wohnzimmer
                step_size: 0.5
                sensors:
                  - entity: climate.Thermostat_im_Wohnzimmer_local_temp
                    name: Aktuelle Temperatur
                wird mir zumindest die Karte mit der aktuellen Temperatur angezeigt, aber schalten lässt sich dann auch nix.
                Versuche ich bei N/A die Buttons zu drücken, bekomme ich folgende Meldung im Log:
                lovelace.0	2020-02-02 17:43:28.450	warn	(6896) Cannot find attribute temperature in climate.Thermostat_im_Wohnzimmer_heating_setpnt_current
                lovelace.0	2020-02-02 17:41:29.477	warn	(6896) Unknown entity: undefined
                Wird irgendjemand daraus schlau und kann mir vielleicht erklären, was genau ich falsch eingerichtet hab?
                Danke schon Mal!
                  fd_samdi @Tictactoo last edited by
                  @Tictactoo Hmm... damit kenne ich mich gerade gar nicht aus, trotzdem ein paar Möglichkeiten:
                  1. Start lovelace neu, ab und an kommt bei mir auch was durcheinander
                  2. Wähl mal den entity-Namen kürzer (unwahrscheinlich, aber wer weiß ^^)
                  3. Du hast sowohl limate.Thermostat_im_Wohnzimmer_heating_setpnt_current als auch climate.Thermostat_im_Wohnzimmer_local_temp als entity?
                  4. wenn mich nicht alles täuscht, erkennt doch der type-detector den Thermostat? D.h. entities wieder rauswerfen, dem kompletten Thermostat-Datenpunkt einen Raum und eine Funktion hinzufügen, dann sollte doch lovelace das automatisch als Thermostat erkennen.
                    Aber wie gesagt, mit Thermostate fehlt mir die Erfahrung.
                    Tictactoo @fd_samdi last edited by
                    @fd_samdi Danke für deine Antwort! Hier mal kurz meine Antworten dazu:
                    1. Hab ich mehrfach gemacht. Half leider nix.
                    2. Hatte testweise auch schon nur "Test1" und "Test2" als Namen, brachte auch nix.
                    3. Ja, local_temp ist die gemessene Temperatur am Thermostat, heating_setpnt_current ist die gewünschte Temperatur.
                    4. Das hat es auch erkannt, in der Tat, wenn ich es aber als Entity auswähle, zeigt es mir nur den Wert von local_temp an und man kann leider nix schalten...
                    • Garfonso
                      Garfonso Developer @Tictactoo last edited by
                      @Tictactoo
                      Dann zeig doch mal die attribute bzw. guck sie dir an. Ein Thermostat kann nach aktuellem code die folgenden Attribute erhalten: current_temperature, temperature.
                        Tictactoo @Garfonso last edited by
                        @Garfonso So sehen die States aus.
                        F Garfonso 2 Replies Last reply Reply Quote 0
                          fd_samdi @Tictactoo last edited by fd_samdi
                          @Tictactoo ich habs grad nicht vor Augen aber value.temperature ist ja die Rolle. Die kann man ja ändern.
                          heating_setpnt_current ist die Soll-Temperatur.
                          local_temp ist die Ist-Temperatur.
                          Die Frage ist, wie ist es mit den Attributen. Wenn current_temperature die IST-Temperatur ist, dann würde ich die Rolle von local_temp von value.temperature auf value.current_temperature ändern
                          und die Rollen von heating_setpnt_occupied, heating_setpnt_unoccupied und local_temp_calibration auf irgendwas anderes, ich denk das checkt der Type_Detector auch nicht wenn zu oft value.temperature vorkommt.
                          UND natürlich die Zuweisung der Datenpunkte zu lovelace auch wieder rauswerfen.
                          @Garfonso Soweit steig ich leider noch nicht durch was dein Code und was der Type-Detector erkennt. Wenn ich da rein schaue: https://github.com/algar42/ioBroker.type-detector/blob/master/index.js müsste es ja zwei Rollen level.temperature und value.temperature geben. Wo kommt das Attribut current_temperature her, oder hat das nichts mit der Rolle sondern mit dem Attribut-Namen selber zu tun?
                          Dann würde ich die Rolle von heating_setpnt_current von value.temperature auf level.temperature ändern und oben mein ganzes Geschwätz verwerfen.
                          • Garfonso
                            @Tictactoo
                            das sind die ioBroker states. Ich meinte die (Homeassistant) Attribute, die Lovelace erkennt -> instanzen -> lovelace -> "Entitäten" tab (letzter Tab), auf "Attribute anzeigen" klicken und dann in der Tabelle den automatisch generierten Eintrag (manuell geht das leider (noch) nicht mit mehreren attributen) für das Thermostat mal anzeigen.
                              @Garfonso Oh sry, dass war mir net ganz klar. Es scheint, als würde er einen anderen State als temperature erkennen. Vermutlich zeigt er deshalb nix?
                                Johannes Bauerstatter @Garfonso last edited by
                                @Garfonso Danke. Hab´s anscheinend zu kompliziert gemacht. Funktioniert wie du beschrieben hast.
                                  allgrind @magiczoom last edited by
                                  @magiczoom
                                  Hey,
                                  konntest du das mit dem Hintergrund lösen?
                                  Ich habe jetzt die 1.0.9 drauf und leider den gleichen Fehler 😞
                                  Viele Grüße!
                                  • Garfonso
                                    @Tictactoo said in Test Adapter lovelace v0.2.x:
                                    Naja, er hat ja auch ziemlich viele zur Auswahl, da wundert mich das kaum... wie soll er da den richtigen erkennen? Versuch mal die Rollen zu ändern so dass es nur zwei mit einer Role mit "temperatur" im Namen gibt und derjenige zum einstellen "write": true hat und der für die anzeige der aktuellen Temperatur "write": false hat. Dann "müsste" er die Attribute richtig füllen (siehe auch hier: https://github.com/ioBroker/ioBroker.type-detector/blob/master/index.js#L300 -> da muss man allerdings regExp lesen können 😉 ).
                                    @fd_samdi said in Test Adapter lovelace v0.2.x:
                                    Hehe. Das ist nicht "mein Code", zum größten Teil. Ich hab nur das Licht erkennen gebaut (für Licht mit mehr als Dimmer). Aber ich hab es mittlerweile halbwegs durchschaut. Also was passiert ist, dass der type-detector nach den Regeln, die du verlinkt hast Gruppen von States baut. Also z.B. für das Thermostat ein State sucht mit dem man eine Temperatur setzen kann (role enthält "temperature" und der State ist Schreibbar), den nennt er dann "SET". Dann gibt es noch Optional States die die Temperatur anzeigen ("temperature" in Rolle und nur lesbar) (heißt "ACTUAL"), Luftfeuchtigkeit (HUMIDITY) usw... -> damit kann dann der Lovelace Adapter überlegen, wie er die states in die Attribute einsortiert. Für das thermostat passiert das hier: https://github.com/ioBroker/ioBroker.lovelace/blob/master/lib/server.js#L1892 -> da werden dann die Zuordnung SET -> temperature und ACTUAL -> current_temperature gemacht.
                                    Der Name der Attribute kommt dabei aus Lovelace/Homeassistant selber, das kann man in der Homeassistant Dokumentation (für das Thermostat wäre da offensichtlich auch noch Luft nach oben, Light wird mittlerweile recht viel unterstützt) nachlesen -> wir wollen ja nicht Lovelace hier komplett selber nachbauen, sondern den Code da von Homeassistant wieder verwenden. Daher lohnt es sich, wenn man sicher ist, dass die attribute stimmen, bei Problemen / Merkwürdigkeiten dann auch nach Tips für Lovelace/Homeassistant zu googeln. (Wobei die Implementation der Attribute natürlich auch noch nicht perfekt ist).
                                    Also es ist ein zweistufiger Process, zuerst erkennet der type-detector Geräte und sortiert die States standarisiert ein (oder versucht sein bestes das zu erreichen) und danach verknüpft der Lovelace Adapter diese erkannten States mit Attributen. Dabei ist, soweit ich das hier beobachte, das größte Problem, das der Type-Detector die Geräte "richtig" erkennt.
                                    Es gibt übrigens den devices-Adapter, wenn man den installiert, bekommt man rechts im Admin einen neuen Geräte-Eintrag und darunter kann man die Geräte, so wie der Typedetector sie erkennt, zusammen klicken (also die Ids für SET, ACTUAL, HUMIDITY usw. im Fall des thermostats aus der Liste der IDs frei auswählen und da im Grunde auch aus verschiedenen Geräten was basteln und damit wird dann in alias.0 ein Gerät erstellt -> damit könnte man die Problem des Detectors auch umgehen @Tictactoo - wäre in deinem Fall ggf. auch eine Lösung, wenn du nicht die Rollen umstellen willst -> dann Raum & Funktion beim Gerät in alias.0 einstellen und beim anderen weg).
                                      Tictactoo @Garfonso last edited by Tictactoo
                                      @Garfonso Danke fürs reinfuchsen. Nach der Änderung der Rollen hats geklappt. Leider gehen so Sachen wie das mit dem Boost auch net. Wenn ich es richtig lese, dann wohl, weil da eine Nummer erwartet wird, und bei mir ist ein ein boolean? Evtl. muss ich mich da mal genauer mit auseinandersetzen und das Skript für mich etwas anpassen, da auch meine Aqara-BWM nicht vom Motion Pattern erkannt werden.
                                        poyo @allgrind last edited by
                                        @allgrind said in Test Adapter lovelace v0.2.x:
                                        @magiczoom
                                        Hey,
                                        Viele Grüße!
                                        Ich habe auch Probleme mit dem Hintergrund gehabt, wurde einfach nicht angezeigt.
                                        Das war bei mir die Lösung :
                                         #Background image
                                            lovelace-background: 'center / cover no-repeat url("/cards/wall.jpg") fixed'
                                        Hab nur diese Zeichen ' vor center und hinter fixed gesetzt.
                                        Probiere es mal.
                                        Viele Grüße
                                        G 1 Reply Last reply Reply Quote 2
                                          g.polat @poyo last edited by
                                          @poyo sagte in Test Adapter lovelace v0.2.x:
                                          @magiczoom
                                          Hey,
                                          Viele Grüße!
                                           #Background image
                                          Probiere es mal.
                                          Viele Grüße
                                          Genau das ist es, vielen Dank 👍
                                          • Benjamin Stelzner
                                            Benjamin Stelzner last edited by
                                            Hi, erstmal vielen Dank an alle die Hier Ihre Erfahrung austauschen, hat mich wirklich motiviert meine vis neu aufzubauen 🙂
                                            Bei mir funktioniert alles soweit wie gewünscht, nur leider das wetter von accuweather nicht.
                                            Was Ich bereits gemacht habe:
                                            • wie hier weiter oben beschrieben -> Summary (unter den Objekten des AccuAdapters)
                                              Wetter - enum.functions.weather
                                              Any - enum.rooms.any
                                            sind die Zuordnungen bei Raum und Funktion
                                            zusätzlich habe ich die index.js aktualisiert von:
                                            https://raw.githubusercontent.com/algar42/ioBroker.type-detector/master/index.js
                                            unter:
                                            /opt/iobroker/node_modules/iobroker.type-detector/index.js
                                            nur taucht bei mir unter Entitäten leider nichts auf 😞
                                            hat jemand noch einen Vorschlag ?
                                            call for action lovelace test visualisierung
                                            131
                                            1051
                                            377756
