    4. [How-to] Node.js für ioBroker richtig updaten
      TDCroPower last edited by
      Kann mir jemand einen Tipp geben woran rpm rebuild scheitert?
      Ich habe meinen OrangePi mit Armbian laut Anleitung erst einmal NodeJS von 8 auf 10 updaten wollen.
      Nach dem Nodejs habe ich zunächst die fix.sh durch laufen lassen.
      Danach habe ich mit rpm rebuild versucht die Module zu korrigieren und erhalte am Ende folgende Fehler...
      ../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        fd = info[0]->Int32Value();
      In file included from /root/.cache/node-gyp/10.18.1/include/node/v8.h:26:0,
                      from /root/.cache/node-gyp/10.18.1/include/node/node.h:63,
                      from ../node_modules/nan/nan.h:47,
                      from ../src/unix_dgram.cc:5:
      /root/.cache/node-gyp/10.18.1/include/node/v8.h:2478:46: note: declared here
        V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
      /root/.cache/node-gyp/10.18.1/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
        declarator __attribute__((deprecated(message)))
      unix_dgram.target.mk:101: recipe for target 'Release/obj.target/unix_dgram/src/unix_dgram.o' failed
      make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Error 1
      make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 4.19.62-sunxi
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
      gyp ERR! node -v v10.18.1
      gyp ERR! node-gyp -v v5.0.5
      gyp ERR! not ok
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! unix-dgram@0.2.3 install: `node-gyp rebuild`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the unix-dgram@0.2.3 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /root/.npm/_logs/2020-01-29T22_59_58_436Z-debug.log
      root@OrangePi:/opt/iobroker#
        apollon77 @TDCroPower last edited by
        @TDCroPower Unix dgram ist ok das das als Fehler kommt.
        • MathiasJ
          MathiasJ last edited by
          komisch...
          ich mache meine updates mit
          apt update && apt upgrade
          und sonst nichts. Hier wird die neueste Node bzw NodeJS gleich mit installiert.
          manchmal noch den Installations-Fixer hinterher jagen.
          Bisher Null Problemo.
          Gruß,
          Mathias
            apollon77 @MathiasJ last edited by
            @MathiasJ naja das ist einfach: dabei bleibst du üblicherweise (wenn du das Repo von nodesource nutzt wie üblich) immer auf einer Major Version. Dabei gibts auch keine Probleme. Welche nodejs Version hast du denn?
            Wenn du aber von zb node 8 auf 10 willst musst du ein anderes Repo einstellen von nodesource und dann bist du genau beim Thema von diesem thread. Alles hier diskutierte ist nur bei Major versions Änderungen relevant.
            • MathiasJ
              ok, ok dann bin ich hier wohl falsch.
              Bin seit meiner Neuinstallation gleich auf die 10.
                leider hat es meine iobroker Installation irgendwie nicht überlebt nach dem Update von NodeJS.
                Habe daher das fehlerhafte iobroker Verzeichnis unter /opt einfach umbenannt und iobroker von neu installiert.
                Danach mein iobroker Backup vor dem Update eingespielt und soweit habe ich wieder fast alles am laufen.
                Leider haben alle meine ZigBee Geräte wohl keine Verbindung...
                weiß jemand wie ich das fixen kann ohne alle Geräte erneut anmelden zu müssen?
                Falls alternativ jemand eine Idee hat wie ich meine defekte Instanz checken kann nehme ich auch die Tipps an 😜
                Habe ja das komplette Verzeichnis gesichert.
                  @TDCroPower am besten frag dazu mal eher in zigbee threads nach. Ich erinnere mich das irgendwo das shepperd dB file liegt was du dann mit kopieren musst. Vllt in iobroker-data/zigbee.0 oder so?
                    TDCroPower @apollon77 last edited by
                    @apollon77 vielen Dank das hat das Problem gelöst und die zigbee senden/empfangen wieder Daten 👍
                    • Z
                      zgadgeter @TDCroPower last edited by
                      @TDCroPower said in [How-to] Node.js für ioBroker richtig updaten:
                      Hi, und was genau hast Du gemacht?
                      • Basti97
                        Basti97 Most Active last edited by
                        Beim updaten ist bei mir folgender Fehler aufgetreten was kann ich machen der findet den JS Verzeichnis oder so nicht mehr
                        Unbenannt nn.JPG image url)
                          apollon77 @Basti97 last edited by
                          @Basti97 Kannst versuchen den installation fixer laufen zu lassen. Wenn das auch nichts hilft musst Du mal schauen was lso ist und ggf den controller manuell drüber installieren
                          Basti97 1 Reply Last reply Reply Quote 0
                          • Basti97
                            Basti97 Most Active @apollon77 last edited by
                            @apollon77 Habe ich gemacht funktioniert wieder. Auch mein Master habe ich jetzt aktualisiert das ging besser als die Slaves. Das einzige Problem was ich noch habe ist das der Zigbee Adapter noch nicht geht aber der ist jetzt nichts so schlimm. Das größere Problem ist das er auf den Master meine Adapter liste nicht mehr lädt. Es Kreiselt nur. An was kann es liegen.
                            Gruß Sebastian
                              @Basti97 Lösche mal den Browser Cache inkl. LocalStorage und sowas.
                              • Basti97
                                Danke Es hat funktoniert. Die Anleitung ist auch super. Ich habe noch einen kleinen Tipp. Bei folgenden Abschnitt.
                                Und zwar gibt es ja eine neue JS- Controller Version und zwar 2.2.8. Oder hat es eine besondere bewandnis das dort noch 1.5.11 steht.
                                Danke apollon
                                AlCalzone apollon77 2 Replies Last reply Reply Quote 0
                                • AlCalzone
                                  AlCalzone Developer @Basti97 last edited by
                                  @Basti97 Ich zitiere:
                                  hier zum Beispiel 1.5.11, der aktuell (zum Zeitpunkt dem Erstellen der Doku, Anm. d. Red.) die Stable-Version ist.
                                  Sollte also mit ein wenig Mitdenken klar sein. Du hast aber Recht, dass es für eine leider recht große Nutzergruppe nicht unmissverständlich genug formuliert ist.
                                    @Basti97 Ich aktualisiere
                                    • Basti97
                                      Basti97 Most Active @AlCalzone last edited by
                                      @AlCalzone Na ich habe es gewusst das es eine neue gibt. Aber manche gehen 1 und 1 vor und geben die Befehle ein und bemerken nicht das es eine neue Version gibt.
                                      • Basti97
                                        @apollon77 Danke war nur ein Tipp. Aber super Anleitung hat alles genau so funktioniert. Version läuft auch stabil bisher ohne ein einzige Fehlermeldung.
                                        • marcuskl
                                          marcuskl last edited by
                                          Weiß jemand wie ich von NodeJS 10.18.1 auf 10.19.0 aktualisieren kann ?
                                          Sonst ging das immer mit apt-get update & upgrade, mit der Anleitung geht es auch nicht ?
                                          Homoran MathiasJ 2 Replies Last reply Reply Quote 0
                                            Homoran Global Moderator Administrators @marcuskl last edited by
                                            @marcuskl sagte in [How-to] Node.js für ioBroker richtig updaten:
                                            jetzt nicht? - sollte aber.
                                            Was kommt den bei apt-update und apt updateablean Informationen zu node
                                            marcuskl 1 Reply Last reply Reply Quote 1
                                            installation linux node node.js nodejs windows
                                            106
                                            1105
                                            737674
