    4. Material Design Widgets: Calendar Widget
    • Scrounger
      Scrounger Developer last edited by
      @sigi234 @sveni_lee @Adnim
      Hab das Skript nochmal bissle optimiert:
      • nun werden alle ical instanzen berücksichtigt
      • die Uhrzeiten werden korrekt verwendet
      • skript wird direkt beim start einmal ausgeführt
      // momentjs is required as dependecies in javascript adapter
      const moment = require("moment");
      var instances = $(`[id=ical.*.data.table]`);
      instances.on(ical2CalendarWidget);
      function ical2CalendarWidget() {
          try {
              let calList = [];
              for (var inst = 0; inst <= instances.length - 1; inst++) {
                  let icalObj = getState(instances[inst]).val;
                  if (icalObj) {
                      for (var i = 0; i <= icalObj.length - 1; i++) {
                          let item = icalObj[i];
                          // extract calendar color
                          let calendarName = item._class.split(' ')[0].replace('ical_', '');
                          // create object for calendar widget
                          calList.push({
                              color: getMyCalendarColor(calendarName),
                              colorText: getMyCalendarTextColor(calendarName),
                              start: moment(item._date).format("YYYY-MM-DD HH:mm"),
                              end: moment(item._end).format("YYYY-MM-DD HH:mm")
                      function getMyCalendarColor(calendarName) {
                          // assign colors via the calendar names, use calendar name as set in ical
                          if (calendarName === 'calendar1') {
                              return '#FF0000';
                          } else if (calendarName === 'calendar2') {
                              return '#44739e'
                          } else if (calendarName === 'calendar3') {
                              return '#32a852'
                      function getMyCalendarTextColor(calendarName) {
                              return '#FFFFFF';
                              return '#FFFFFF'
                              return '#FFFFFF'
                  // Enter the destination data point that is to be used as object ID in the widget
                  setState('0_userdata.0.materialdesignwidgets.ical2Calendar', JSON.stringify(calList), true);
          } catch (e) {
              console.error(`ical2MaterialDesignCalendarWidget: message: ${e.message}, stack: {e.stack}`);
      ical2CalendarWidget();
      S W Peoples O 4 Replies Last reply Reply Quote 2
        sveni_lee @Scrounger last edited by sveni_lee
        @Scrounger
        Danke, das klappt jetzt schon sehr gut.
        Jetzt habe ich noch ein "Problem" mit ganztägigen Terminen. In der Wochenübersicht werden diese von 0:00 bis 0:00 dargestellt und reichem auch noch in den nachfolgenden Tag.
        Edit: @Scrounger wie müsste die das Calendar Object aussehen, damit es ganztägiges ereignis angezeigt wird aber eben nur in der Kopfzeile... dann könnte ich das script versuchen dementsprechend anzupassen.
        Scrounger 1 Reply Last reply Reply Quote 1
          Machinima last edited by
          Bei mehreren ganztägigen Terminen werden diese zum Teil bei mir verdeckt dargestellt, siehe der Donnerstag. Ich habe den dem Tag "Abfuhr Papier" und "Abfuhr Leichtverpackungen".
          Browser: Firefox 72.0.2
          Und noch eine Frage habe ich: Wäre es möglich, bei Klick auf einen Termin weitere Details in einem Popup darzustellen? Oder muss ich da evtl. was skripten?
            webseb79 @Scrounger last edited by
            @Scrounger
            ich benutze das Script um die Termine in einer Tabelle anzeigen zulassen.
            Ich habe 3 Instanzen ( Müll , Termine , Geburtstage ) und es wird auch alles korrekt eingelesen.
            In meiner Darstellung als Tabelle ist es jetzt aber so das die Events zeitlich nicht nach Ablauf stehen sondern in Blöcken den Instanzen zugeordnet.
            Kann man im Script noch was einbauen das die Events nach Reihenfolge aufgelistet werden?
            Danke im Voraus
            Gruß Sebastian
            • Scrounger
              Scrounger Developer @sveni_lee last edited by Scrounger
              @sveni_lee, @Machinima
              Mit dem folgenden Skript gehen jetzt auch ganztägige ereignisse:
                  try {
                      let calList = [];
                          if (icalObj) {
                                  let startTime = moment(item._date);
                                  let endTime = moment(item._end);
                                  if (startTime.format('HH:mm') === '00:00' && endTime.format('HH:mm') === '00:00') {
                                      // is full-day event
                                      startTime = startTime.format("YYYY-MM-DD");
                                      endTime = endTime.format("YYYY-MM-DD");
                                  } else {
                                      startTime = startTime.format("YYYY-MM-DD HH:mm");
                                      endTime = endTime.format("YYYY-MM-DD HH:mm");
                                  calList.push({
                                      start: startTime,
                                      end: endTime
                                      return '#FF0000';
                                      return '#44739e'
                                      return '#32a852'
                                      return '#FFFFFF';
                                      return '#FFFFFF'
                                      return '#FFFFFF'
                  } catch (e) {
              @webseb79
              Da deine Frage das Table Widget betrifft, bitte post verschieben nach:
              https://forum.iobroker.net/topic/29658/material-design-widgets-table-widget
                Adnim @Scrounger last edited by Adnim
                @Scrounger sagte in Material Design Widgets: Calendar Widget:
                    try {
                        let calList = [];
                            if (icalObj) {
                                    } else {
                                    calList.push({
                                        start: startTime,
                                        end: endTime
                                        return '#FF0000';
                                        return '#44739e'
                                        return '#32a852'
                                        return '#FFFFFF';
                                        return '#FFFFFF'
                                        return '#FFFFFF'
                    } catch (e) {
                @webseb79
                Hi!
                Auch mit dem Skript werden die Ganztages Termine noch am darauffolgenden Tag angezeigt.
                • Scrounger
                  Scrounger Developer @Adnim last edited by
                  @Adnim
                  Jetzt müsste es gehen:
                      try {
                          let calList = [];
                              if (icalObj) {
                                      let start = startTime.format("YYYY-MM-DD HH:mm");
                                      let end = endTime.format("YYYY-MM-DD HH:mm");
                                          if (endTime.diff(startTime, 'hours') === 24) {
                                              // full-day event, one day
                                              start = startTime.format("YYYY-MM-DD");
                                              end = startTime.format("YYYY-MM-DD");
                                          } else {
                                              // full-day event, multiple days
                                              end = endTime.format("YYYY-MM-DD");
                                      calList.push({
                                          start: start,
                                          end: end
                                          return '#FF0000';
                                          return '#44739e'
                                          return '#32a852'
                                          return '#FFFFFF';
                                          return '#FFFFFF'
                                          return '#FFFFFF'
                      } catch (e) {
                          console.error(`ical2MaterialDesignCalendarWidget: message: ${e.message}, stack: ${e.stack}`);
                  A S 2 Replies Last reply Reply Quote 2
                    @Scrounger
                    Ja! Danke Danke
                      @Scrounger
                      super, so hatte ich mir das vorgestellt.
                        jerzimeik last edited by jerzimeik
                        soweit läuft das widget inkl. scipt. Nur zeigt er mir nicht die Termine aller Instanzen an.
                        Unter den objects steht in der Datei zwar alles drin
                        [{"name":"Rest- & Biomüll","start":"2020-02-06","end":"2020-02-06"},{"name":"Friseur","start":"2020-02-05 09:00","end":"2020-02-05 09:30"},{"name":"Physio","start":"2020-02-06 08:00","end":"2020-02-06 08:30"},{"name":"Training AH","start":"2020-02-06 19:30","end":"2020-02-06 21:30"},{"name":"Vitamin D3","start":"2020-02-07 12:30","end":"2020-02-07 12:30"},]
                        Aber in der vis nicht:
                        Der erste Eintrag steht sogar doppelt.
                        Was muss ich tun?
                        Witzigerweise zeigt er in der Monatsansicht alle Termine an?!?
                        ub.privat 1 Reply Last reply Reply Quote 0
                        • ub.privat
                          ub.privat @jerzimeik last edited by ub.privat
                          Servus und einen schönen guten Abend,
                          ich mach es mir noch ein wenig schwer mit dem CalendarWidget.
                          1. Wo muss das Script eingestellt werden?
                            • zentral unter Scripte "common" , "root-Verzeichnis", oder ...?
                            • oder im Widget unter Scripte?
                          2. Wie kann ich dem Widget mehrere Kalender zuordnen? Habe zwei ical- Instanzen...
                          3. Welchen Datenpunkt der ical-Instanz wähle ich aus?
                          Danke schon mal für eure sicher hilfreichen Tipps!
                          Agria4800 1 Reply Last reply Reply Quote 0
                          • Agria4800
                            Agria4800 @ub.privat last edited by
                            @ub-privat zu 1: unter javascript Adapter, der muss natürlich installiert sein!
                            dann unter:
                            zu 2: entweder machst du ein Widget per Instanz ( dann bitte den * aus Punkt 3 mit der ical 0 oder 1 ändern), oder lässt dir wie unter Punkt 3 alle in einem anzeigen!
                            und zu 3:
                            mit dem * sucht er alle ical Instanzen ab!
                            • ub.privat
                              ub.privat @Agria4800 last edited by ub.privat
                              @Agria4800
                              Danke für deine Hilfe, leider bekomme ich immer noch keine Kalendereinträge angezeigt.
                              Script ist wie folgt hinterlegt:
                              Nun muss ich ja im Widget den DP angeben:
                              HIer kann ich nun die Kalender = ical-Instanzen auswählen:
                              Ich denke, genau hier habe ich mein Verständisproblem!
                              Egal was ich anwähle, es folgt kein Ergebnis.
                              Mache ich etwas falsch?
                              Gemäß Beschreibung;
                              wird ein JSON-String als Object-ID benötigt.
                              Nur in meiner Objekt-Liste ist kein JSON-String, maximal ein HTML und Tabelle...!
                              Wie gesagt, es ist GUTER RAT TEUER!?
                              • Agria4800
                                @ub-privat naja, bist auf den richtigen Weg 🙂
                                im Script wird ein Datenpunkt angelegt (recht weit unten...)
                                        setState('0_userdata.0.materialdesignwidgets.ical4Calendar', JSON.stringify(calList), true);
                                diesen Datenpunkt musst du in dem Widget, welches du schon hast, eintragen, dann passt es 😉
                                • ub.privat
                                  @Agria4800
                                  Dankeschöne, wieder einen kleinen Schritt weiter:
                                  Leider ist deser DP nicht erzeugt!
                                  Ergo, es muss noch etwas falsch sein...???😢 😠
                                    sigi234 Forum Testing Most Active @Scrounger last edited by sigi234
                                    @Scrounger
                                    Altes Widget funktioniert einwandfrei!
                                    J.A.R.V.I.S. Scrounger 2 Replies Last reply Reply Quote 0
                                    • J.A.R.V.I.S.
                                      J.A.R.V.I.S. Developer @sigi234 last edited by J.A.R.V.I.S.
                                      @sigi234 ich vermute mal stark, dass der Calendar Adapter (noch?) nicht unterstützt wird und das Widget derzeit nur auf iCal ausgelegt ist.
                                      • Scrounger
                                        Scrounger Developer @sigi234 last edited by Scrounger
                                        @sigi234 sagte in Material Design Widgets: Calendar Widget:
                                        Das kann auch nicht gehen, da du ein Objekt String (de: Zeichenkette) mit einem JSON-String als Objekt verwenden musst und nicht so wie du das gemacht hast eine Datenstruktur.
                                        Das ging auch nicht in einer vorherigen Version.
                                        Hab jetzt das skript nochmal angepasst, damit es hoffentlich wirklich out of the box funktioniert:
                                        // remove this, if you know to use your own datapoint
                                        let datapointId = 'materialdesignwidgets.calendar.ical2calendar'
                                        createState(datapointId, "[]", {
                                          read: true,
                                          write: false,
                                          desc: "JSON String for Calendar Widget",
                                          type: "string",
                                          def: "[]"
                                            try {
                                                let calList = [];
                                                    if (icalObj) {
        } else {
                                                            calList.push({
        start: start,
        end: end
        return '#FF0000';
        return '#44739e'
        return '#32a852'
        return '#FFFFFF';
        return '#FFFFFF'
        return '#FFFFFF'
                                                    setState(datapointId, JSON.stringify(calList), true);
                                            } catch (e) {
                                        Es wird euch jetzt autmoatisch ein Datenpunkt in der Javascript instanz angelegt.
                                        Im Calendar Wigdet dann unter Objekt Id diesen Datenpunkt auswählen, da muss dann folgendes drin stehen javascript.0.materialdesignwidgets.calendar.ical2calendar
                                        J.A.R.V.I.S. ub.privat 2 Replies Last reply Reply Quote 0
                                        • J.A.R.V.I.S.
                                          J.A.R.V.I.S. Developer @Scrounger last edited by J.A.R.V.I.S.
                                          @Scrounger er verwendet den Calendar Adapter. Dieser hat allerdings eine andere Struktur und das Skript müsste daraufhin angepasst werden.
                                          Deswegen funktioniert das Skript bei @sigi234 auch nicht.
                                            syryna last edited by syryna
                                            @Scrounger
                                            Erstmal vielen Dank für deine Tollen UI Widgets. Durch dich ist sogar ein Laie wie ich fähig ein UI zusammenzubsateln. Tolle Arbeit !
                                            Ich hätte jedoch noch 2 Wünsche:
                                            1. Der Rot markierte Bereich läßt sich nicht färben. Vermutlich geht es über CSS aber da wäre ebenfalls eine Einstellung gut. ich nehme an es ist follende Klasse: class="v-calendar-daily__scroll-area".
                                              -> Korrektur: die Klasse alleine reicht nicht aus. dann wird der untere Teil schwarz, nicht aber die Scrolbar und ebenfalls nicht der schmale Balken oberhalb der Scrollbar. Ich schätze mal am besten wäre das Scrollen zu deaktivieren. Bei mir gäbe es nichts zu scrollen.
                                            2. Wäre es möglich parallele Termine nicht überlappend anzuzeigen sondern nebeneinander?
                                              -> Korrektur: Das geht schon mit Modusüberlappung : Column
                                            Grüße, Micha
                                            vis
                                            45
                                            200
                                            31378
