    4. Test Adapter fb-checkpresence v0.2.x
    • ub.privat
      ub.privat @afuerhoff last edited by
      @afuerhoff
      👍 👍 👍 👍 sehr schön!
        Tobi81 @afuerhoff last edited by
        @afuerhoff
        Hab nun ein Debug-Log gemacht. Beim ersten Start habe ich die MAC Adresse angegeben, nachdem der Adapter aber gecrashed ist, habe ich die IP Adresse verwendet.
        Hab die Version 0.2.2 installiert.
        Hoffe das Logfile hilft. 🙂
        2020-02-02 15:24:36.535 - info: host.iobroker "system.adapter.fb-checkpresence.0" enabled
        2020-02-02 15:24:36.560 - info: host.iobroker instance system.adapter.fb-checkpresence.0 started with pid 27081
        2020-02-02 15:24:38.028 - debug: fb-checkpresence.0 (27081) Redis Objects: Use Redis connection: 0.0.0.0:9001
        2020-02-02 15:24:38.070 - debug: fb-checkpresence.0 (27081) Objects client ready ... initialize now
        2020-02-02 15:24:38.075 - debug: fb-checkpresence.0 (27081) Objects create System PubSub Client
        2020-02-02 15:24:38.076 - debug: fb-checkpresence.0 (27081) Objects create User PubSub Client
        2020-02-02 15:24:38.077 - debug: fb-checkpresence.0 (27081) Objects client initialize lua scripts
        2020-02-02 15:24:38.100 - debug: fb-checkpresence.0 (27081) Objects connected to redis: 0.0.0.0:9001
        2020-02-02 15:24:38.107 - debug: fb-checkpresence.0 (27081) objectDB connected
        2020-02-02 15:24:38.111 - debug: fb-checkpresence.0 (27081) Redis States: Use Redis connection: 0.0.0.0:9000
        2020-02-02 15:24:38.122 - debug: fb-checkpresence.0 (27081) States create User PubSub Client
        2020-02-02 15:24:38.126 - debug: fb-checkpresence.0 (27081) States create System PubSub Client
        2020-02-02 15:24:38.170 - debug: fb-checkpresence.0 (27081) States connected to redis: 0.0.0.0:9000
        2020-02-02 15:24:38.171 - debug: fb-checkpresence.0 (27081) statesDB connected
        2020-02-02 15:24:39.035 - info: fb-checkpresence.0 (27081) starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v8.17.0
        2020-02-02 15:24:39.107 - info: fb-checkpresence.0 (27081) start fb-checkpresence: ip-address: 192.168.178.1 polling interval: 1 Min.
        2020-02-02 15:24:39.108 - debug: fb-checkpresence.0 (27081) configuration user: smarthome
        2020-02-02 15:24:39.108 - debug: fb-checkpresence.0 (27081) configuration history:
        2020-02-02 15:24:39.109 - debug: fb-checkpresence.0 (27081) configuration dateformat: yyyy.mm.dd hh:MM:ss
        2020-02-02 15:24:39.109 - debug: fb-checkpresence.0 (27081) configuration familymembers: [{"familymember":"Tobias","macaddress":"192.168.174.145","comment":"12","enabled":true}]
        2020-02-02 15:24:39.585 - debug: fb-checkpresence.0 (27081) system.adapter.admin.0: logging false
        2020-02-02 15:24:40.391 - debug: fb-checkpresence.0 (27081) system.adapter.admin.0: logging true
        2020-02-02 15:26:48.623 - error: fb-checkpresence.0 (27081) uncaught exception: Cannot read property 'search' of undefined
        2020-02-02 15:26:48.624 - error: fb-checkpresence.0 (27081) TypeError: Cannot read property 'search' of undefined
        at /opt/iobroker/node_modules/iobroker.fb-checkpresence/lib/fb.js:37:57
        at Parser. (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/xml2js/lib/parser.js:308:18)
        at emitOne (events.js:116:13)
        at Parser.emit (events.js:211:7)
        at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/xml2js/lib/parser.js:327:16)
        at Parser.parseString (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/xml2js/lib/parser.js:5:59)
        at exports.parseString (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/xml2js/lib/parser.js:369:19)
        at Request.request [as _callback] (/opt/iobroker/node_modules/iobroker.fb-checkpresence/lib/fb.js:36:17)
        at self.callback (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/request/request.js:185:22)
        2020-02-02 15:26:48.625 - info: fb-checkpresence.0 (27081) cleaned everything up...
        2020-02-02 15:26:48.627 - error: fb-checkpresence.0 (27081) onReady: connect ETIMEDOUT 192.168.178.1:49000
        2020-02-02 15:26:48.632 - debug: fb-checkpresence.0 (27081) system.adapter.admin.0: logging false
        2020-02-02 15:26:48.636 - info: fb-checkpresence.0 (27081) terminating
        2020-02-02 15:26:48.637 - info: fb-checkpresence.0 (27081) Terminated (NO_ERROR): Without reason
        2020-02-02 15:26:49.160 - error: host.iobroker Caught by controller[0]: TypeError: Cannot read property 'search' of undefined
        2020-02-02 15:26:49.161 - error: host.iobroker Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.fb-checkpresence/lib/fb.js:37:57
        2020-02-02 15:26:49.161 - error: host.iobroker Caught by controller[0]: at Parser. (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/xml2js/lib/parser.js:308:18)
        2020-02-02 15:26:49.161 - error: host.iobroker Caught by controller[0]: at emitOne (events.js:116:13)
        2020-02-02 15:26:49.161 - error: host.iobroker Caught by controller[0]: at Parser.emit (events.js:211:7)
        2020-02-02 15:26:49.161 - error: host.iobroker Caught by controller[0]: at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/xml2js/lib/parser.js:327:16)
        2020-02-02 15:26:49.161 - error: host.iobroker Caught by controller[0]: at Parser.parseString (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/xml2js/lib/parser.js:5:59)
        2020-02-02 15:26:49.162 - error: host.iobroker Caught by controller[0]: at exports.parseString (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/xml2js/lib/parser.js:369:19)
        2020-02-02 15:26:49.162 - error: host.iobroker Caught by controller[0]: at Request.request [as _callback] (/opt/iobroker/node_modules/iobroker.fb-checkpresence/lib/fb.js:36:17)
        2020-02-02 15:26:49.162 - error: host.iobroker Caught by controller[0]: at self.callback (/opt/iobroker/node_modules/iobroker.fb-checkpresence/node_modules/request/request.js:185:22)
        2020-02-02 15:26:49.162 - error: host.iobroker Caught by controller[0]: at emitOne (events.js:116:13)
        2020-02-02 15:26:49.162 - info: host.iobroker instance system.adapter.fb-checkpresence.0 terminated with code 0 (NO_ERROR)
        2020-02-02 15:26:49.162 - info: host.iobroker Restart adapter system.adapter.fb-checkpresence.0 because enabled
        afuerhoff 1 Reply Last reply Reply Quote 0
        • afuerhoff
          afuerhoff Developer @Tobi81 last edited by
          @Tobi81
          Hallo, was für eine Fritzbox mit welcher Firmware Version hast Du?
          PS: Was ich noch gesehen habe, dass Du keinen History Adapter in der Konfiguration ausgewählt hast. Der ist aber für vollen Funktionsumfang notwendig.
            Malz1902 @afuerhoff last edited by
            @afuerhoff said in Test Adapter fb-checkpresence v0.2.x:
            @Malz1902 sagte in Test Adapter fb-checkpresence v0.2.x:
            @Malz1902
            so müsste es funktionieren:
            var anwesenheit = getState('fb-checkpresence.0.Galaxy-S10').val;
            klappt leider nicht 😞
            Hallo, bei mir funktioniert es so. Ist denn Galaxy-S10 der richtig Member Name?
            Wie sieht denn die Konfiguration aus oder die angelegten Objekte.
            habs jetzt war mein Fehler in meiner Abfrage sollte man true/false auch richtig schreiben 😄
              @afuerhoff
              Ich habe eine FritzBox 7590 mit der aktuellsten Firmware 07.12
              Ich hab auch den Fehler gefunden: 🤕
              Bei mir stand im Adapter bei der FritzBox IP schon eine IP: 192.168.178.1
              Die habe ich nicht weiter beachtet. Aber ich habe ein anderes Subnetz: 192.168.174.*
              Ich hab das geändert und nun funktioniert es...
              Danke!
              • afuerhoff
                @Tobi81
                Die Fritzbox IP ist mit einem default Wert vorbefüllt. Evtl. sollte ich den entfernen.
                  @Tobi81
                  Stell den doch auf fritz.box
                  • afuerhoff
                    afuerhoff Developer @Malz1902 last edited by
                    @Malz1902
                    Gute Idee.
                    • MathiasJ
                      MathiasJ last edited by MathiasJ
                      ich war auch mal so frei, den Adapter zu installieren, um die Anwesenheit im Gastnetz zu überwachen.
                      Anfangs lief der Adapter super nur jetzt schaltet der beim Neustart gleich von rot auf gelb und bringt folgende Meldung:
                      fb-checkpresence.0	2020-02-06 06:21:39.535	error	(19682) checkPresence: TypeError: Cannot read property 'message' of undefined
                      Mehr kann ich dem Adapter im Debug nicht entlocken.
                      bevor Fragen auftauchen:
                      Konfig der Adresse:
                      Fritzbox per fritz.box
                      Fritzox per IP-Adresse
                      immer das gleiche Resultat.
                      Oder liegt es vielleicht damit zusammen, weil ich den Adapter TR-064 auch nutze, um bei Abwesenheit meine eingehenden Anrufe umzuleiten?
                      Gruß,
                      Mathias
                      • afuerhoff
                        afuerhoff Developer @MathiasJ last edited by
                        @MathiasJ
                        Du könntest mal auf Loglevel debug schalten. Dann sollten mehr Ausgaben kommen. Hast du noch von Github installiert oder direkt über admin?
                        sigi234 MathiasJ 2 Replies Last reply Reply Quote 0
                          sigi234 Forum Testing Most Active @afuerhoff last edited by
                          @afuerhoff sagte in Test Adapter fb-checkpresence v0.2.x:
                          @MathiasJ
                          Habe ich auch teilweise.
                          fb-checkpresence.0	2020-02-06 09:32:51.914	error	(10528) checkPresence: TypeError: Cannot read property 'message' of undefined
                          M M 2 Replies Last reply Reply Quote 0
                            Malz1902 @sigi234 last edited by
                            irgendwie klappt das immer noch nicht, fb-checkpresence.0.Stephen-Galaxy-S10 steht auf true, aber die Abfrage springt immer in den else if Zweig
                            var anwesenheitStephen = getState('fb-checkpresence.0.Stephen-Galaxy-S10').val; // true = anwesend, false = abwesend
                                schedule('{"time":{"exactTime":true,"start":"10:35"},"period":{"days":1}}', function () {
                                     if (anwesenheitStephen === true) {
                                        var text = 'da';
                                    } else if (anwesenheitStephen === false) {
                                        var text = 'nicht da';
                                    } else {
                                        var text = 'blubb';
                                    sendTo("pushover.0", {
                                        message: text,
                                        title: wochentag,
                                        priority: 1
                            • SBorg
                              SBorg Forum Testing Most Active @Malz1902 last edited by
                              @Malz1902 Musst du "strict" prüfen? Sonst ändere mal anwesenheitStephen === true in anwesenheitStephen == "true" (false natürlich auch ^^)
                              • MathiasJ
                                MathiasJ @afuerhoff last edited by
                                @MathiasJ
                                Tja, steht aber schon auf Loglevel debug, kommt trotzdem nicht mehr 🙄
                                • afuerhoff
                                  afuerhoff Developer @MathiasJ last edited by afuerhoff
                                  @MathiasJ
                                  Es wäre hilfreich auch die Ausgaben vor der Fehlermeldung zu kennen. Gibt es da nichts?
                                  Ist die Funktion in irgendeiner Weise beeinträchtigt?
                                  Werden z.B. die Objekte nicht befüllt?
                                  Ich habe eine Vermutung, aber weitere Angaben wären hilfreich. Hast du von Github oder admin installiert.
                                  MathiasJ 1 Reply Last reply Reply Quote 0
                                  • MathiasJ
                                    @afuerhoff
                                    ich habe von Github installiert.
                                    wie bereits geschrieben, es kommen keine weiteren Fehlermeldungen. 😞
                                    • afuerhoff
                                      @MathiasJ
                                      Es geht nicht um die Fehlermeldungen . Ich benötige die debug Ausgaben. Kommt der Fehler direkt nach Start der Instanz? Ich brauche mal das Log vom Start bis zum Fehler.
                                      Bitte aus admin installieren. Der Adapter ist im latest zu finden. Auf Github können Entwicklungsstände sein, die noch nicht fertig sind.
                                        mameier1234 @sigi234 last edited by mameier1234
                                        @sigi234 sagte in Test Adapter fb-checkpresence v0.2.x:
                                        @MathiasJ
                                        Hab ich auch..
                                        Debug:
                                        fb-checkpresence.0	2020-02-08 15:12:27.519	debug	(2392) checkPresence first run
                                        fb-checkpresence.0	2020-02-08 15:12:27.518	error	(2392) checkPresence: TypeError: Cannot read property 'message' of undefined
                                        fb-checkpresence.0	2020-02-08 15:12:27.517	debug	(2392) body response: {"statusCode":500,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"
                                        fb-checkpresence.0	2020-02-08 15:12:27.495	debug	(2392) history: false time: Sat Feb 08 2020 15:10:21 GMT+0100 (GMT+01:00)
                                        fb-checkpresence.0	2020-02-08 15:12:27.495	debug	(2392) history: false time: Sat Feb 08 2020 15:05:20 GMT+0100 (GMT+01:00)
                                        fb-checkpresence.0	2020-02-08 15:12:27.495	debug	(2392) history: false time: Sat Feb 08 2020 15:00:20 GMT+0100 (GMT+01:00)
                                        • afuerhoff
                                          afuerhoff Developer @mameier1234 last edited by
                                          @mameier1234
                                          Hast Du aus dem latest über admin installiert?
                                            mameier1234 @afuerhoff last edited by
                                            @afuerhoff
                                            Das kann ich gar nicht mehr so genau sagen...
                                            aktuell die 0.2.2
                                            Die Meldung kam schon mit 1-2 Versionen vorher .. Es kann gut sein, dass ich dann auch mal von Github drüber installiert habe, in der Hoffnung, dass es besser wird.
                                            31.7k
                                            79.8k
                                            avm fb-checkpresence fritzbox soap tr-064
                                            26
                                            259
                                            27672
