    4. Test Adaper Tado v0.1.x
    • Dutchman
      Dutchman Developer Most Active Administrators @Xandar31 last edited by
      @Xandar31 sagte in Test Adaper Tado v0.1.x:
      @Dutchman die 0.1.6
      ist bereits seit 0.1.3 drin, wen du per git installiert hast mal nog manuel upload ausführen der Fehler sollte aber schon lang behoben sein 🙂
      • X
        Xandar31 @Dutchman last edited by
        @Dutchman
        du meintest einfach das hier, oder:
        $ ./iobroker url "https://github.com/iobroker-community-adapters/ioBroker.tado" --debug
        install https://github.com/iobroker-community-adapters/ioBroker.tado/tarball/29fd46ff3232c36fa48022e5a8f3d72783b2a892
        NPM version: 6.13.4
        npm install https://github.com/iobroker-community-adapters/ioBroker.tado/tarball/29fd46ff3232c36fa48022e5a8f3d72783b2a892 --loglevel error --prefix "/opt/iobroker" (System call)
        > node-aead-crypto@2.1.4 install /opt/iobroker/node_modules/node-aead-crypto> node lib/install.js
        node-aead-crypto is no longer needed on NodeJS 10+
        + iobroker.tado@0.1.6updated 1 package in 19.79s
        10 packages are looking for funding  run `npm fund` for details
        upload [7] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/words.js words.js application/javascript
        upload [6] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/tsconfig.json tsconfig.json application/json
        upload [5] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/tado.png tado.png image/png
        upload [4] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/style.css style.css text/css
        upload [3] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/index_m.html index_m.html text/html
        upload [2] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/button.png button.png image/png
        upload [1] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/admin.d.ts admin.d.ts video/mp2t
        upload [0] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/.DS_Store .DS_Store null
        process exited with code 0
        und
        $ ./iobroker upload tado
        Hab ich mal gemacht.
        Alles klar, danke für die Info / Hilfe / den Adapter
        • Dutchman
          und
          $ ./iobroker upload tado upload [7] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/words.js words.js application/javascript upload [6] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/tsconfig.json tsconfig.json application/json upload [5] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/tado.png tado.png image/png upload [4] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/style.css style.css text/css upload [3] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/index_m.html index_m.html text/html upload [2] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/button.png button.png image/png upload [1] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/admin.d.ts admin.d.ts video/mp2t upload [0] tado.admin /opt/iobroker/node_modules/iobroker.tado/admin/.DS_Store .DS_Store null process exited with code 0
          genau das meinte ich 🙂
          sag bitte Bescheid ob es damit geklappt hat sonst muss ich nochmal ran.
          PS: adapter besser nicht per git installieren sondern den Admin ausser wen anders aufgefordert 🙂
            rehmosch last edited by
            Hey, vielen dank nochmals für den Adpater 😉
            Jetzt bin ich bei vis angekommen, und möchte gerne ein Slider-Widget und habe die Werte auf max. 25 C und min. auf 5 C gestellt. Jedoch zeigt es keine Wirkung wenn ich unter 5C bis = 0C gehe. Da ich keinen ON/OFF Button benutzen möchte und meine Visualisierung minimalistisch halten möchte, wollte ich mal Fragen ob jemand dafür eine Lösung gefunden hatte.
            Ach über jedes schönes Widget für Tado würde ich mich natürlich sehr freuen 😉
              Coffeelover @rehmosch last edited by Coffeelover
              @rehmosch Du hast den Slider zwischen 5 und 25 Grad begrenzt und möchtest auf Null gehen? Warum?
              Die Tado unterstützen doch nur den Temperaturbereich von 5 bis 25.
              Edit: mein Vis hilft dir vermutlich nicht viel - ich steuere darüber nicht, sondern lasse nur anzeigen. Die Steuerung erfolgt automatisch.
                rehmosch @Coffeelover last edited by
                @Coffeelover Warum? Wenn die Batterien zu schwach oder leer sind dann bollern bei mir die Tado Thermostate wenn diese nicht auf OFF gestellt sind. Ich habe es über ein Script gelöst, dass wenn ich den Slider auf 5C stelle (ja, niedrigste mögliche Temperatur wegen Frostschutz) dann sollen die Thermostate auf OFF gestellt werden. Trotzdem Danke 😉
                  @rehmosch das ist ja auch etwas anderes. Damit setzt du die Temperatur ja immernoch nicht auf 0. Und das stand in deinem Post oben. Meine Tados waren noch nie leer. Ich hätte erwartet, dass sie bei der zuvor eingestellten Temperatur bleiben.
                  Vg
                    Beogradjanin last edited by
                    Hi, ich hätte zu dem Adapter folgende Fragen:
                    1. wo oder wie kann ich den Modus ändern?
                      Z.B. wenn ich manuell die Temperatur verändert habe möchte ich durch die Änderung wieder auf den "Automatik" Modus switchen.
                    2. Fenster offen Erkennung: mir ist aufgefallen, dass die Zeit runterzählt. Wenn diese bei 0 angelangt ist sind die Felder im Reiter "openWindow" leer.
                    Wie löst ihr das?
                    1. bei mir steht der Modus eigentlich immer auf "Heating". Wie kommt denn ein anderer Modus dahin?
                      Coffeelover @Beogradjanin last edited by
                      Hi @Beogradjanin,
                      ich versuche es mal mit deinen Fragen:
                      1. Direkt: Garnicht. Du kannst nur über tado.0.000000.Rooms.1.overlay.clearZoneOverlay zurück auf die "Standardeinstellung" springen.
                      2. Nach meinem Verständnis ist dieser Countdown relevant für die Meldung. Was genau willst du "lösen"? Da liegt doch kein Fehler vor.
                      3. Soweit ich es verstanden habe, sind die anderen Modus nicht zum Umschalten, sondern für den Fall, dass du über Tado zB eine Klimaanlage steuerst. Wenn in der App von Tado nichts angeboten wird, wirst du es auch über iobroker nicht hinbekommen, von Heating auf Cooling zu ändern. Falls du ein entsprechendes Gerät hast, würde ich mal in Tado umschalten und den Adapter beobachten.
                      VG
                        Beogradjanin @Coffeelover last edited by Beogradjanin
                        @Coffeelover
                        zu 1:
                        a) Was sind die Gründe warum man den Modus nicht vorwählen kann?
                        b) Und was sind für dich genau Standardeinstellungen?
                        Beispiel: mein Wohnzimmer wird von dem Automatikprogramm auf 22°C geheizt. Jetzt möchte ich aber mal an einem bestimmten Tag manuell 23°C vorgeben.... Der Modus ist dann "Manuell" und die Solltemperatur beträgt 23°C. Jetzt würde ich gerne eine Automatisierungsfunktion so verknüpfen, dass bei geöffnetem Fenster der Sollwert auf 5°C eingestellt wird. Das sollte auch problemlos klappen.
                        Wenn das Fenster dann geschlossen wird ist die Frage, welcher Wert dann für die Solltemperatur eingestellt wird... die 23°C oder die 22°C aus dem Automatikprogramm? In beiden Fällen ist man aber bei dem clearZoneOverlay aber im "Manuell" Betrieb.
                        Zu 2:
                        Ich wollte ein Blockly Skript damit verknüpfen, so bald der Tado ein "offenes Fenster" erkannt hat, dass eine Meldung ausgegeben wird bzw. wenn das Fenster nicht mehr "offen" ist eine weitere Meldung (über den Sinn lässt sich erst einmal streiten, mir geht es hier erst einmal um die Möglichkeit für die Abfrage des Wertes)
                        Zu 3:
                        Ok. Verstehe. Und wenn ich den Heizkörperregler auf "AUS" stelle zeigt er mir weiterhin ein "Heating" an. Irgendwie wäre es meiner Meinung nach sinnvoller, wenn z.B. die Stellung des Regelventils >= 0 ist, dass dann "Heating" angezeigt wird, ansonsten "not Heating" (oder was auch immer).
                        C K 2 Replies Last reply Reply Quote 0
                          @Beogradjanin Viele deiner Fragen müssten im langen Verlauf dieser Adapterdiskussion hier stehen - ich habe meine Infos auch von hier.
                          zu 1. Wenn du dem Verlauf der Diskussion folgst, gibt es hier sehr unterschiedliche Anwendungsprofile. Manche nutzen die Tado -Automatik überhaupt nicht mehr, andere setzen diese nur kurz aus.
                          1a) weil es die Tado-Schnittstelle nicht vorsieht. Dutchman hat nur umgesetzt, was die Schnittstelle liefert. Der Modus ist ein read-only Merkmal.
                          1b) Mein Anwendungsszenario weicht von deinem ab, da ich händisch nicht gegensteuere. Ich habe eine Fußbodenheizung - deren Einstellung passt mir, abhängig davon, ob ich zuhause bin oder nicht. Nach meinem Verständnis sollte das ClearZone zurück auf die Automatik springen. -> meine Vermutung: Durch deine händischen 23° springt er zurück in "manuell".
                          Zu 2. Das ist über Tado alleine nicht möglich. Dafür braucht es Fenstersensoren. Tado bemerkt nur die plötzliche Veränderung der Temperatur & Luftfeuchtigkeit und weiß deswegen, dass Lüften angefangen hat. Das Ende liefert das Thermostat nicht.
                          Zu 3. Sinnvoller oder nicht -> das hängt auch an der Tado Schnittstelle. Tado braucht den Modus des Geräts vermutlich, um die Anzeige in der App korrekt zu steuern. Wenn du da was auswerten möchtest, nimm doch Heating Power oder Power.
                            K_o_bold @Beogradjanin last edited by K_o_bold
                            @Beogradjanin sagte in Test Adaper Tado v0.1.x:
                            @Coffeelover
                            zu 1:
                            mit "clearzoneOverlay" springst du wieder auf den Wert zurück, der in deiner App als Zeitplan hinterlegt wurde!. Also in deinem Fall geht die Temp dann auf 22.
                            Ich nutze das z.B. gar nicht mehr. Habe alle Zeitpläne deaktiviert und mache sämtliche Scenarien über Skript und Scenen Adapter..
                            Genau deinen Anwendungsfall habe ich umgesetzt. Bei Bedarf kann ich dir mein Skript zeigen..
                            DAs mit den Zeitplänen in der App ist so eine Sache für sich...Wenn du Zeitpläne in der App aktivierst und aber auch über Iobroker skriptest, dann kann man schnell den Überblick verlieren, bzw. beißen die sich eventuell gegenseitig. Deswegen habe ich mich für auschließlich skripten entschieden. (Home/Away Modus und Steuerung bei Fenster offen usw. )
                            • Dutchman
                              verwechselt bitte auch adapter logic nicht mit Tado logic.
                              Wir koennen hier viel, aber z.b. die Sachen wie es in der app. von Tado aussieht ja das liegt an Tado.
                              Ich kan nur per API die daten von dr API auswerten und verständlich in iobroker bringen.
                              Zaubern das es anders laufen bei Tado kan auch ich nicht 🐷
                                @Dutchman
                                Tado muss dafür aber eine Schnittstelle bieten, da auch die App diese Funktion bietet...
                                Durch das Klicken auf das X wechselt Tado wieder in seinen alten Modus, also entweder "Home" oder "Away".
                                @Coffeelover
                                Gerne schaue ich mir dein Skript mal an, dann kann ich sehen, in wie fern ich mein Szenario damit abdecken kann 🙂
                                Nochmal zum Fenster:
                                Ich weiß, dass Tado entweder mittels drastischem Temperaturabfall und/oder Feuchtigkeitsabfall ein "offenes" Fenster erkennt. Ich würde nun mal gerne diesen Status anzeigen. Aktuell ist es bei dem Adapter so, dass erst wenn ein offenes Fenster erkannt wird die Werte angezeigt werden.
                                Also z.B. 900s (für 15min)... und dann gibt es eine weitere Zeit, die von 900 Richtung 0 runterzählt. Danach verschwinden alle Werte. Wenn diese weiterhin sichtbar wären könnte man einfach den Wert, der irgendwann bei 0 ist abfragen und als Zustand "Fenster ist zu" annehmen.
                                Dutchman K 2 Replies Last reply Reply Quote 0
                                  @Beogradjanin Vermutlich möchtest du eher das Script von @K_o_bold Ich nutze ja die Automatik in Tado.
                                  Wenn du eh nur den Tado-Status annehmen willst, kannst du auch einfach im Script runterzählen. Oder du triggerst auf Wert="". In meinen Augen macht das keinen Unterschied. Und so wirklich sinnig ist es auch nicht, da es ja überhaupt keinen Bezug gibt zwischen real geschlossen oder nicht. Oder ich verstehe dich falsch... 🙂
                                  • Dutchman
                                    Dutchman Developer Most Active Administrators @Beogradjanin last edited by Dutchman
                                    ja, ist aper kein dokumentierter API - endpoint.
                                    wen jemand zeit / mühe macht mit wireshar zu decrypten und endcoden finden wir es vielleicht.
                                    Ich kan das nicht, habe die Geräte nicht und bin kein reverse engineerer 🙂
                                    Bitte beachtet : die komplette API ist NICHT dokumentiert vom Hersteller, wir machen alles reverse engineering mit Leuten weltweit die allen einen teil beitragen
                                    • maximal1981
                                      maximal1981 last edited by
                                      mein Log zeigt folgendes an, kann mir wer sagen was das Problem sein könnte?
                                      host.raspberrypi	2020-02-06 20:49:34.278	info	Restart adapter system.adapter.tado.0 because enabled
                                      host.raspberrypi	2020-02-06 20:49:34.278	error	instance system.adapter.tado.0 terminated with code 156 (156)
                                      tado.0	2020-02-06 20:49:33.255	warn	(8456) Got terminate signal. Checking desired PID: 8504 vs own PID 8456
                                      tado.0	2020-02-06 20:49:33.246	info	(8456) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                      tado.0	2020-02-06 20:49:33.244	info	(8456) terminating
                                      tado.0	2020-02-06 20:49:33.242	info	(8456) cleaned everything up...
                                      tado.0	2020-02-06 20:49:33.240	warn	(8456) Got terminate signal. Checking desired PID: 0 vs own PID 8456
                                      host.raspberrypi	2020-02-06 20:49:33.234	info	instance system.adapter.tado.0 started with pid 8504
                                      tado.0	2020-02-06 20:49:06.686	info	(8456) Connected to Tado cloud, initialyzing ...
                                      tado.0	2020-02-06 20:49:05.721	info	(8456) starting. Version 0.1.6 in /opt/iobroker/node_modules/iobroker.tado, node: v10.18.1
                                      host.raspberrypi	2020-02-06 20:49:03.212	info	Restart adapter system.adapter.tado.0 because enabled
                                      maximal1981 1 Reply Last reply Reply Quote 0
                                        So wie ich das hier raus lese, benutzt du die Tadoeigene Fenster offen Erkennung, oder?
                                        Ich habe die Funktion in der App deaktiviert und nutze Fensterkontakte in meinen Skripten.
                                        Dennoch hier mal ein Beispiel:
                                        • maximal1981
                                          maximal1981 @maximal1981 last edited by maximal1981
                                          @maximal1981 said in Test Adaper Tado v0.1.x:
                                          nach einem Neustart funktionierte alles richtig 🤡
                                          verstehe ich richtig, dass "Clear Zone Overlay" immer in den aktuellen Heizplan zurückwechselt?
                                          Da ich noch die V3 und nicht die V3+ Bridge habe, würde ich meines Erachtens alles die Bridge via "Geo Tracking Enabled" steuern lassen, außer Fenster öffnen/schließen.
                                          • Dutchman
                                            Dutchman Developer Most Active Administrators @maximal1981 last edited by
                                            @maximal1981 sagte in Test Adaper Tado v0.1.x:
                                            jup, clear ist lösche "override"
                                            79.9k
                                            adapter tado testing team
                                            62
                                            868
                                            198727
