    4. Stromzähler per Sonoff ESP8266 auslesen
    • RalfTh
      RalfTh @Jaschkopf last edited by
      @Jaschkopf Hier das LOG:
      22:04:21 CMD: sensor53 d1
      22:04:21 MQT: stat/tasmota/RESULT = {"Time":"2020-02-04T22:04:21","SML":{"CMD":"dump: 1"}}
      22:04:30 MQT: tele/tasmota/STATE = {"Time":"2020-02-04T22:04:30","Uptime":"0T00:51:02","UptimeSec":3062,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":6,"RSSI":70,"Signal":-65,"LinkCount":1,"Downtime":"0T00:00:06"}}
      22:04:30 MQT: tele/tasmota/SENSOR = {"Time":"2020-02-04T22:04:30","OBIS":{"Total_in":0.0000,"Total_out":0.0000,"Power_curr":0,"Meter_number":""}}
      22:04:40 MQT: tele/tasmota/STATE = {"Time":"2020-02-04T22:04:40","Uptime":"0T00:51:12","UptimeSec":3072,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":21,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":6,"RSSI":66,"Signal":-67,"LinkCount":1,"Downtime":"0T00:00:06"}}
      22:04:40 MQT: tele/tasmota/SENSOR = {"Time":"2020-02-04T22:04:40","OBIS":{"Total_in":0.0000,"Total_out":0.0000,"Power_curr":0,"Meter_number":""}}
      22:04:50 MQT: tele/tasmota/STATE = {"Time":"2020-02-04T22:04:50","Uptime":"0T00:51:22","UptimeSec":3082,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":6,"RSSI":70,"Signal":-65,"LinkCount":1,"Downtime":"0T00:00:06"}}
      22:04:50 MQT: tele/tasmota/SENSOR = {"Time":"2020-02-04T22:04:50","OBIS":{"Total_in":0.0000,"Total_out":0.0000,"Power_curr":0,"Meter_number":""}}
      22:05:00 MQT: tele/tasmota/STATE = {"Time":"2020-02-04T22:05:00","Uptime":"0T00:51:32","UptimeSec":3092,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":6,"RSSI":68,"Signal":-66,"LinkCount":1,"Downtime":"0T00:00:06"}}
      22:05:00 MQT: tele/tasmota/SENSOR = {"Time":"2020-02-04T22:05:00","OBIS":{"Total_in":0.0000,"Total_out":0.0000,"Power_curr":0,"Meter_number":""}}
        Jaschkopf @RalfTh last edited by
        @RalfTh also außer das alle 10sek die Daten per mqtt gesendet werden passiert da nichts. Ggf sind bei deinem Zähler sende und Empfangs led umgedreht. Prüf das mal mit deiner Handykamera ob dein Zähler überhaupt Daten ausgibt und wenn ja auf welcher Seite. Ich muss meine Lesekopf auch um 180° verdreht aufsetzen (Kabel nach oben) damit er funktioniert.
        RalfTh 1 Reply Last reply Reply Quote 0
        • RalfTh
          @Jaschkopf OK, danke.Ich werde das morgen mal probieren. Bei mir ist links der Lichtsensoreingang und rechts die Datenschnittstelle. Habe dazu ein Bild meines Energieversorgers erhalten.
            @RalfTh ich meine bei mir ist die Schnittstelle genauso angeordnet. Probier mal den Lesekopf um 180° mit dem Kabel nach oben aufzusetzen
              @RalfTh mir ist gerade noch was eingefallen. Wenn du das Skript 1:1 übernommen hast, muss RXD auf Pin 13 liegen. Du bist aber auf GPIO13, was Pin 7 entspricht. Einen Pin 13 hat der D1 ja garnicht. Versuch mal im Skript in Sektion >M die Zeile für die Zählerdefinition zu ändern auf Pin 7:
              >M
              +1,7,s,1,9600,SML
              PS: Wenn du das Debugging mit "sensor53 d1" aktiviert hast wird die Werteausgabe über das Webinterface gestoppt. Wenn du auf der Startseite wieder Werte haben willst musst du entweder den D1 neustarten oder mit "sendor53 d0" das Debugging wieder ausschalten.
              Gruß Jaschkopf
              • RalfTh
                @Jaschkopf Oh, das hatte ich übersehen, bzw. falsch interpretiert. Ist schon ein bisschen verwirrend mit den PINs und deren Bezeichnung. Habe jetzt das Skript hier geändert.
                Jetzt lässt es sich nicht mehr aktivieren??!!
                Muss ich das Ganze jetzt noch mal in Atom.io machen? Das kann doch eigentlich nicht sein.!?
                  @RalfTh Ok jetzt hab ich mich selbst verwirrt. D7 am D1 war schon richtig als GPIO13 im Skript. Musste selbst nochmal nachschlagen gerade.
                  Aber das sich dein Skript immer wieder deaktiviert ist nicht richtig. Ich hatte den Fall bei mir auch mal und musste die Firmware neu flashen. Scheint ein Bug zu sein. Vergiss nur nicht den CFG_HOLDER zu verändern bevor du neu compilierst, wie in der Anleitung beschrieben.
                  Gruß Jaschkopf
                    mpl1338 last edited by mpl1338
                    Kann mir jemand sagen wo das problem bei mir liegt?
                    19:57:34 RSL: tele/tasmota/RESULT = {"Time":"2020-02-06T19:57:34","IrReceived":{"Protocol":"UNKNOWN","Bits":50,"Hash":"0xD87B604E"}}
                    19:57:35 RSL: tele/tasmota/RESULT = {"Time":"2020-02-06T19:57:35","IrReceived":{"Protocol":"UNKNOWN","Bits":50,"Hash":"0x70E7939E"}}
                    19:57:36 RSL: tele/tasmota/RESULT = {"Time":"2020-02-06T19:57:36","IrReceived":{"Protocol":"UNKNOWN","Bits":50,"Hash":"0xDDE94BCF"}}
                    19:57:37 RSL: tele/tasmota/RESULT = {"Time":"2020-02-06T19:57:37","IrReceived":{"Protocol":"UNKNOWN","Bits":50,"Hash":"0x49A6AF84"}}
                    19:57:37 RSL: tele/tasmota/STATE = {"Time":"2020-02-06T19:57:37","Uptime":"0T00:29:07","UptimeSec":1747,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Wifi":{"AP":2,"SSId":"FRITZ!Box 7590 CJ","BSSId":","Channel":1,"RSSI":100,"Signal":-47,"LinkCount":1,"Downtime":"0T00:00:06"}}
                    19:57:37 RSL: tele/tasmota/SENSOR = {"Time":"2020-02-06T19:57:37","OBIS":{"Total_in":0.0000,"Total_out":0.0000,"Power_curr":0,"Meter_number":""}}
                    19:57:38 RSL: tele/tasmota/RESULT = {"Time":"2020-02-06T19:57:38","IrReceived":{"Protocol":"UNKNOWN","Bits":50,"Hash":"0x41150F2B"}}
                    19:57:39 RSL: tele/tasmota/RESULT = {"Time":"2020-02-06T19:57:39","IrReceived":{"Protocol":"UNKNOWN","Bits":50,"Hash":"0x70E7939E"}}
                    19:57:40 RSL: tele/tasmota/RESULT = {"Time":"2020-02-06T19:57:40","IrReceived":{"Protocol":"UNKNOWN","Bits":50,"Hash":"0xCE7EA1E4"}}
                    19:57:41 RSL: tele/tasmota/RESULT = {"Time":"2020-02-06T19:57:41","IrReceived":{"Protocol":"UNKNOWN","Bits":50,"Hash":"0x4A92522B"}}
                    19:57:42 RSL: tele/tasmota/RESULT = {"Time":"2020-02-06T19:57:42","IrReceived":{"Protocol":"UNKNOWN","Bits":50,"Hash":"0x41150F2B"}}
                    19:57:43 RSL: tele/tasmota/RESULT = {"Time":"2020-02-06T19:57:43","IrReceived":{"Protocol":"UNKNOWN","Bits":50,"Hash":"0x29724952"}}
                    bekomme zwar daten gelesen aber werden nicht umgewandelt?
                    Zähler(MT691) ist freigeschaltet
                    20:01:37 CMD: sensor53 d1
                    20:01:37 RSL: stat/tasmota/RESULT = {"Time":"2020-02-06T20:01:37","SML":{"CMD":"dump: 1"}}
                      Jaschkopf @mpl1338 last edited by
                      @mpl1338 also laut Internet Sender der Zähler 1x pro Sekunde die Daten unaufgefordert. Wenn du den dump mit sensor53 d1 aktiviert hast sollte jede Sekunde ein riesiges Datenpakete mit hex Werten rein kommen. Das ist bei dir offensichtlich nicht der Fall wie ich auch deinem log sehe. Der Fehler muss wo anders liegen. Postete sich mal deinen Aufbau und dein Skript.
                      Gruß Jaschkopf
                        habs gefunden
                        einstellungen -> gerät konfigurieren -> D7 GPIO13 Led1i "none" hatte hier zuvor "IRrecv"
                        jetzt kommen die Daten.
                        Ist es möglich die einzelnen Phasen zu sehen? (Leistung/Strom)
                        J mkrobe 2 Replies Last reply Reply Quote 0
                          @mpl1338 der Gerätetyp muss auf Generic stehen, sonst muss nichts verändert werden. Ob dein Zähler die Leistung pro Phase ausgibt musst du mal im Datenblatt nachlesen. Postete doch mal ein dump deiner Rohwerte aus der Konsole mit aktiviertem Debugging.
                          Gruß Jaschkopf
                            mpl1338 @Jaschkopf last edited by
                            22:00:39 CMD: sensor53 d1
                            22:00:39 RSL: stat/tasmota/RESULT = {"Time":"2020-02-06T22:00:39","SML":{"CMD":"dump: 1"}}
                            22:00:40 : ca 1b 1b 1b 1b 01 01 01 01 76 05 03 dd a0 6f 62 00 62 00 72 63 01 01 76
                            22:00:40 : 01 01 05 01 49 e0 25 0b 0a 01 49 53 4b 00 04 42 5a 58 72 62 01 65 01 49 df 24 62 01 63 a0 9a 00 76 05 03 dd a0 70 62 00 62 00 72 63 07 01
                            22:00:40 : 77 01 0b 0a 01 49 53 4b 00 04 42 5a 58 07 01 00 62 0a ff ff 72 62 01 65 01 49 df 24 74
                            22:00:40 : 77 07 01 00 60 32 01 01 01 01 01 01 04 49 53 4b 01
                            22:00:40 : 77 07 01 00 60 01 00 ff 01 01 01 01 0b 0a 01 49 53 4b 00 04 42 5a 58 01
                            22:00:40 : 77 07 01 00 01 08 00 ff 65 00 1c 01 04 01 62 1e 52 ff 65 03 1c 46 73 01
                            22:00:40 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 53 02 b2 01 01 01 63 7b 62 00 76 05 03 dd a0 71 62 00 62 00 72 63 02 01 71
                            22:00:40 RSL: tele/tasmota/STATE = {"Time":"2020-02-06T22:00:40","Uptime":"0T00:42:47","UptimeSec":2567,"Heap":24,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":52,"MqttCount":0,"Wifi":{"AP":2,"SSId":"FRITZ!Box 7590 CJ","BSSId":"44:4E:6D:52:0C:91","Channel":1,"RSSI":100,"Signal":-47,"LinkCount":1,"Downtime":"0T00:00:06"}}
                            22:00:40 RSL: tele/tasmota/SENSOR = {"Time":"2020-02-06T22:00:40","SML":{"DJ_TPWRIN":5218.469,"DJ_TPWROUT":0.000,"DJ_TPWRCURR":0.701}}
                            22:00:41 : ae 1b 1b 1b 1b 01 01 01 01 76 05 03 dd a0 72 62 00 62 00 72 63 01 01 76 01 01 05 01 49 e0
                            22:00:41 : 26 0b 0a 01 49 53 4b 00 04 42 5a 58 72 62 01 65 01 49 df 25 62 01 63 7f a0 00 76 05 03 dd a0 73 62 00 62 00 72 63 07 01
                            22:00:41 : 77 01 0b 0a 01 49 53 4b 00 04 42 5a 58 07 01 00 62 0a ff ff 72 62 01 65 01 49 df 25 74
                            22:00:41 : 77 07 01 00 60 32 01 01 01 01 01 01 04 49 53 4b 01
                            22:00:41 : 77 07 01 00 60 01 00 ff 01 01 01 01 0b 0a 01 49 53 4b 00 04 42 5a 58 01
                            22:00:41 : 77 07 01 00 01 08 00 ff 65 00 1c 01 04 01 62 1e 52 ff 65 03 1c 46 75 01
                            22:00:41 : 77 07 01 00 10 07 00 ff 01 01 62 1b 52 00 53 00 76 05 03 dd a0 74 62 00 62 00 72 63 02 01 71 01 63 98 df 00 00 1b 1b
                            22:00:42 : 1b 1b 1b 1b 01 01 01 01 76 05 03 dd a0 75 62 00 62 00 72 63 01 01 76 01 01 05 01 49 e0 27 0b 0a 01 49 53 4b 00 04 42 5a 58 72 62 01 65 01 49 df 26 62 01 63 0d aa 00 76 05 03 dd a0 76 62
                            22:00:42 : 00 62 00 72 63 07 01
                            22:00:42 : 77 01 0b 0a 01 49 53 4b 00 04 42 5a 58 07 01 00 62 0a ff ff 72 62 01 65 01 49 df 26 74
                            22:00:42 : 77 07 01 00 60 32 01 01 01 01 01 01 04 49 53 4b 01
                            22:00:42 : 77 07 01 00 60 01 00 ff 01 01 01 01 0b 0a 01 49 53 4b 00 04 42 5a 58 01
                            22:00:42 : 77 07 01 00 01 08 00 ff 65 00 1c 01 04 01 62 1e 52 ff 65 03 1c 46 07 00 ff 01 01 62 1b 52 00 53 02 b3 01 01 01 63 b1
                            22:00:43 : bf 1b 1b 1b 1b 01 01 01 01 76 05 03 dd a0 78 62
                            22:00:43 : 00 62 00 72 63 01 01 76 01 01 05 01 49 e0 28 0b 0a 01 49 53 4b 00 04 42 5a 58 72 62 01 65 01 49 df 27 62 01 63 13 bb 00 76 05 03 dd a0 79 62 00
                            22:00:43 CMD: sensor53 d0
                            da wäre mal was
                              @mpl1338 sieht nicht so aus als würde er die Leistung pro Phase ausgeben. Muss zuhause nochmal in meine Dokumente gucken aber sieht so aus als würde er nur die zählerstände und aktuelle wirkleistung ausgeben. Wenn der Zähler die Werte nicht im Display anzeigt dann kann er sie auch nicht über die Schnittstelle ausgeben.
                              Gruß jaschkopf
                              • mkrobe
                                mkrobe @mpl1338 last edited by
                                @mpl1338 sagte in Stromzähler per Sonoff ESP8266 auslesen:
                                habs gefunden
                                Kann mir nicht vorstellen, dass das möglich ist!
                                Ist doch nur ein Lesekopf der die Summe ausliest.
                                Da musst Du wohl auf den neuen Shelly EM30 (?) warten, da kommt dann über jede Phase ein Adapter.
                                  Jaschkopf @mkrobe last edited by
                                  @mkrobe es gibt schon Stromzähler die diese Daten messen und über die Schnittstelle ausgeben. Hab ich in einem anderen Forum schon gesehen 😉
                                    fruehwi @Jaschkopf last edited by fruehwi
                                    Danke @Jaschkopf für die sehr gute Anleitung. Dank dieser Anleitung habe ich ATOM zum laufen gebraucht und hab auch die ersten Sonoff POW R2 geflashed.
                                    Der Sonoff POW R2 funktioniert mit Tasmota sehr gut, aber leider habe ich das auslesen per SML nicht hinbekommen.
                                    Ich habe eine BPW40 mit Poti am RX ( natürlich auch 3,3V und GND) wie im Bild beschrieben Bild der Schaltung im Punkt Singalaufbereitung
                                    angeschlossen. Aber leider bekomme aber leider keine Daten.
                                    Nun ist die Frage, welcher GPIO ist der richtige für einen Sonoff POW R2 oder Sonoff RF?
                                    Viele Grüße,
                                      Jaschkopf @fruehwi last edited by
                                      @fruehwi ich kann das Bild leider nicht öffnen. Musst rausfinden an welchem gpio du mit rx dran bist und den dann in Skript angeben.
                                      Gruß Jaschkopf
                                      • RalfTh
                                        @Jaschkopf Also ich bin ziemlich frustriert. Habe jetzt schon einen zweiten Wemos Nano D1 geflasht und trotzdem geht nichts. Den Lesekopf habe ich auch schon gedreht, aber auch Fehlanzeige.
                                        Mir fehlt auch irgendwie eine Beschreibung, was dieser Lesekopf und der ESP alles macht. Ich kann das Verhalten meines Zählers überhaupt nicht nachvollziehen.
                                        Nochmal meine Konfiguration:
                                        Mein Zähler
                                        Wenn ich mit der Taschenlampe die PIN eingebe erscheint in der zweiten Zeile des Display die aktuelle Leistung , also P. Setze ich jetzt den Lesekopf auf, beginnt das Infofeld (zweite Zeile des Displays) plötzlich zwischen den einzelnen Informationen hin und her zu schalten. Irgendwann endet dies bei der PIN-Eingabe und der wahllosen Eingabe eines PIN. Dies führt letztendlich dazu, dass der Zähler, wegen fehlender korrekter PIN das Infofeld sperrt. Ich habe meinen Lesekopf so positioniert, dass T1 auf die Datenschnittstelle "schaut" und D1 auf den Lichtsensoreingang. (Siehe Bild 2) Das habe ich auch mehrmals kontrolliert.
                                        Dieses Verhalten zeigt der Zähler, sobald ich den Lesekopf am Zähler montiere und diesen, ohne Rx, lediglich an die Versorgungsspannung anschließe.
                                        Hat noch jemand einen solchen Zähler im Einsatz?
                                          @RalfTh wenn dein Zähler eine Eingabe registriert muss er ja über die optische Taste Impulse bekommen die vom Lesekopf kommen müssen. Wenn du tx und rx nicht angeschlossen hast und es trotzdem passiert hast du vermutlich beim Zusammenbau des Lesekopf einen Fehler gemacht. Vielleicht irgendwo ein Kurzschluss oder ein Bauteil durch zu hohe Temperatur beim löten beschädigt. Guck man durch deine Handy Kamera auf den Lesekopf ob die ir led leuchtet bzw blinkt. Wenn du tx nicht angeschlossen hast und die led trotzdem leuchtet muss der Fehler in der Hardware des Lesekopf liegen.
                                          Gruß Jaschkopf
                                          mkrobe 1 Reply Last reply Reply Quote 0
                                          • mkrobe
                                            mkrobe @Jaschkopf last edited by
                                            @Jaschkopf ...bekomme auch keine Daten mit dem Lesekopf. Ist es normal, dass OBIS angezeigt wird, obwohl SML comiliert ist ?
                                            Liegt es vielleicht daran? Habe einen EMH ED300L mit dem USB-Lesekopf an einem Raspi funktionierte das bislang einwandfrei.
                                            d0-schnittstelle esp8266 sml sonoff stromzähler stromzähler auslesen tasmota volkszähler
                                            83
                                            562
                                            198066
