    4. Test Adapter tr-064-community v1.0.x
      apollon77 @Horst Böttcher last edited by
      @Horst-Böttcher nimm bitte die npm Version. Warum installiert ihr immer vom GitHub? 😉 gefährlich.
      Ansonsten wären Details zu „geht nicht“ extrem hilfreich
      • kmidt
        kmidt last edited by Negalein
        ich bekomem den Adpater einfach nicht connectet.
        Das hier steht im LOg :
        host.raspberrypi	2020-02-07 16:13:42.562	info	Restart adapter system.adapter.tr-064.0 because enabled
        host.raspberrypi	2020-02-07 16:13:42.562	info	instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
        host.raspberrypi	2020-02-07 16:13:42.562	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
        host.raspberrypi	2020-02-07 16:13:42.561	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        host.raspberrypi	2020-02-07 16:13:42.561	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        host.raspberrypi	2020-02-07 16:13:42.561	error	Caught by controller[0]: at (anonymous function).get (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:77706)
        host.raspberrypi	2020-02-07 16:13:42.560	error	Caught by controller[0]: at objects.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2450:65)
        host.raspberrypi	2020-02-07 16:13:42.560	error	Caught by controller[0]: at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.tr-064/main.js:115:13)
        host.raspberrypi	2020-02-07 16:13:42.559	error	Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1119:49)
        host.raspberrypi	2020-02-07 16:13:42.559	error	Caught by controller[0]: ReferenceError: secret is not defined
        Hat da einer eine Idee ?
        Danke und Gruß,
        Andi
        Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
        Hier gehts zur Hilfe.
        sigi234 bahnuhr 2 Replies Last reply Reply Quote 0
          sigi234 Forum Testing Most Active @kmidt last edited by
          @kmidt
          Wie installiert?
          • Negalein
            Negalein Global Moderator last edited by Negalein
            @apollon77
            eigentlich müsste man dieses Thema hier schliessen und zB auf TR-064 verweisen.
            den tr-064-Community gibts doch nicht mehr.
            Hier wird jetzt so viel vermischt.
            • bahnuhr
              bahnuhr Forum Testing Most Active @kmidt last edited by
              @kmidt sagte in Test Adapter tr-064-community v1.0.x:
              Diesen Fehler hatte ich auch mit der 3.2.0
              Fazit: Dies ist die falsche Version.
              3.1.4. funktioniert und bringt nicht diesen Fehler.
                sigi234 Forum Testing Most Active @Negalein last edited by sigi234
                @Negalein sagte in Test Adapter tr-064-community v1.0.x:
                Kann man den nicht sperren?
                  Jan1 @bahnuhr last edited by
                  @bahnuhr sagte in Test Adapter tr-064-community v1.0.x:
                  Liegt wohl daran, das 3.1.4 die derzeit offizielle Version im lateste ist und alles drüber keine freigegebenen Versionen und damit eventuell auch Bugy. Warum man auch immer von Github direkt installieren muss, bleibt ein Rätsel und das Gejammere danach ist nur die Folge davon 🙂
                  • Negalein
                    Negalein Global Moderator @sigi234 last edited by
                    @sigi234 sagte in Test Adapter tr-064-community v1.0.x:
                    Ich kann das Thema hier sperren, möchte das aber zuerst mit @apollon77 abklären.
                      Das auch aber ich meinte den tr-064-Community Adapter das der nicht mehr installierbar ist.
                      • Negalein
                        In Absprache mit @apollon77 schließen wir nun dieses Thema und bitte euch
                        unter tr-064 v3.1.x (Latest Repo) weiterzumachen.
                        community tr-064
                        88
                        727
                        189350
