    4. Taster press short or long mit blockly
      paul53 @AxelF1977 last edited by
      @AxelF1977 sagte:
      die bleiben so lange auf true, bis der Taster wieder losgelassen wird.
      Dann versuche es mal damit für die linken Taster (AI: Ein/Heller; AO: Aus/Dunkler):
       <variables>
         <variable type="" id=".0n)fPPZ0Vnq@(#OkayL">level</variable>
         <variable type="" id="aJZ]={d,#UG6hNfL+g%q">button</variable>
         <variable type="" id="U0|}x*G;[=9}9Ql;A}WY">ein</variable>
         <variable type="" id="LOUNWT3$L)e!L@xYU#}h">step</variable>
         <variable type="" id="r@NrZq0IZi*lPW#AYK/Q">delta</variable>
         <variable type="" id="R*r}N3kzibH)Apx7BA2q">long</variable>
         <variable type="undefined" id="timeout">timeout</variable>
         <variable type="undefined" id="Intervall">Intervall</variable>
       </variables>
       <block type="variables_set" id="mBjs]l~k+|EXhuQdommL" x="-313" y="-387">
         <field name="VAR" id=".0n)fPPZ0Vnq@(#OkayL" variabletype="">level</field>
           <block type="get_value" id="X`JY{Vb._~,oJne_SWOY">
             <field name="OID">ID auswählen</field>
           <block type="variables_set" id="BZ25)c-VK5Z[3goO6AO@">
             <field name="VAR" id="LOUNWT3$L)e!L@xYU#}h" variabletype="">step</field>
               <block type="math_number" id=";wxnn-=7*b4-c-IMf:=:">
                 <field name="NUM">5</field>
               <block type="comment" id="k5O@A`WZ%=k2SxN%R*eR">
                 <field name="COMMENT">AI</field>
                   <block type="on_ext" id="9A$Wi*GJ.dRaDpyO`/xI">
                     <value name="OID0">
                       <shadow type="field_oid" id="/c7pXjT/I+1ho9^BP9Uz">
                       <block type="variables_set" id="@G{{4oK*6TJZL#zVETGB">
                         <field name="VAR" id="r@NrZq0IZi*lPW#AYK/Q" variabletype="">delta</field>
                           <block type="variables_get" id="o53B6/DeytPJHbI;Mi7O">
                           <block type="procedures_callnoreturn" id="dFHtN~%maUxxB.]?1tcM">
                             <mutation name="licht">
                               <arg name="button"></arg>
                               <arg name="ein"></arg>
                             </mutation>
                             <value name="ARG0">
                               <block type="on_source" id="WE@9|8|/~vvX{OXDYb}[">
                             <value name="ARG1">
                               <block type="logic_boolean" id="Yu9B::0if$v]tT:bxB*U">
                       <block type="comment" id="jSZ/2_c*((aR7,pNt)0y">
                         <field name="COMMENT">AO</field>
                           <block type="on_ext" id="W{d|e4vAl3#[=|KF-G3+">
                             <value name="OID0">
                               <shadow type="field_oid" id="@rAa%8m;](ekf2C:~We8">
                               <block type="variables_set" id="gc~P[z$.$-v%j:u^XOI)">
                                   <block type="math_single" id="j!c[p($INLWaurOn$@GR">
                                     <field name="OP">NEG</field>
                                     <value name="NUM">
                                       <shadow type="math_number" id="J+I;Y,iqn1nqZM15lVe,">
                                         <field name="NUM">9</field>
                                       <block type="variables_get" id="};j080s`b2/m%hM-3JlK">
                                   <block type="procedures_callnoreturn" id="_vI+=tBli*j-/rK10bmF">
                                     </mutation>
                                     <value name="ARG0">
                                       <block type="on_source" id="q-S~S+O0usUFEH29nW-E">
                                     <value name="ARG1">
                                       <block type="logic_boolean" id="$/j)O2ra|t9)h^$@i$!O">
       <block type="procedures_defnoreturn" id="0[(od3jtT2]$A1$a$};A" x="137" y="-363">
         <field name="NAME">dimm</field>
         <statement name="STACK">
           <block type="math_change" id="ay^:v^GMiK8;@C.C{91L">
             <value name="DELTA">
               <shadow type="math_number" id=",p-gkt;Nv8#h2}*;XqVf">
                 <field name="NUM">1</field>
               <block type="variables_get" id="-hl/L_),_!x:MXDb=iyJ">
               <block type="controls_if" id="%kszP{vBYtCwZ/qzTtSa">
                   <block type="logic_compare" id="-.%Q*lZ}FCy~^wP+p[:1">
                     <field name="OP">GT</field>
                       <block type="variables_get" id="UA:CC7Vx~omd?~j2gEKs">
                       <block type="math_number" id="99D.}K4,`E`IF@EOxgvF">
                         <field name="NUM">100</field>
                   <block type="variables_set" id="v0aJHm1a3E.+HF6~ocI$">
                       <block type="math_number" id="EtU#raSrJ7YV0iWJf:5J">
                   <block type="controls_if" id="beN!nf7!FvW*:[ddES,]">
                       <block type="logic_compare" id="79QUCa4(?d3Oot-2GPSk">
                         <field name="OP">LT</field>
                           <block type="variables_get" id="~ZX5X]P$m)=9n4?B@8~-">
                           <block type="math_number" id="3:t:FbgDD?xLq~RgPObL">
                             <field name="NUM">0</field>
                       <block type="variables_set" id="6-eEI]Ym2;J;X:G_J6rv">
                           <block type="math_number" id=")Y-{eso01`GWZ-YsFUf;">
                       <block type="control" id="[Ly(jC0qvD44B2M,`N;q">
                           <block type="variables_get" id="Zxd5^AHW3x`7Y(^h!Z?{">
       <block type="procedures_defnoreturn" id="NWZF^.s##C!,EL2.W.0%" x="137" y="-88">
         <mutation>
           <arg name="button" varid="aJZ]={d,#UG6hNfL+g%q"></arg>
           <arg name="ein" varid="U0|}x*G;[=9}9Ql;A}WY"></arg>
         </mutation>
         <field name="NAME">licht</field>
           <block type="controls_if" id="8oO0{BL}4az$9-8hSj?N">
               <block type="variables_get" id="lYX/%Zr4$W!`HeoKa0|7">
                 <field name="VAR" id="aJZ]={d,#UG6hNfL+g%q" variabletype="">button</field>
               <block type="variables_set" id="dbYw|pz[1kS)^NPuNqE|">
                 <field name="VAR" id="R*r}N3kzibH)Apx7BA2q" variabletype="">long</field>
                   <block type="logic_boolean" id="`A80q|79.cVrAN3@zzkX">
                   <block type="timeouts_settimeout" id="c#ncZp7EQ8*QJ=XCRZ8Q">
                     <field name="DELAY">500</field>
                     <field name="UNIT">ms</field>
                       <block type="variables_set" id="TeeqM~uQR#SuLH3?:V?j">
                           <block type="logic_boolean" id="llYi+Cqf.bt/).4]RgFz">
                           <block type="procedures_callnoreturn" id=",b+2?RiSiTW:]fvU7,.6">
                             <mutation name="dimm"></mutation>
                               <block type="timeouts_setinterval" id=".3yOZ$x;4,sop[Q(rj8#">
                                 <field name="NAME">Intervall</field>
                                 <field name="INTERVAL">250</field>
                                   <block type="procedures_callnoreturn" id="ORqY8t}R;isC4Qbus(+^">
             <statement name="ELSE">
               <block type="timeouts_cleartimeout" id="Zx?~y{}iOq-zpH-/|j;[">
                   <block type="timeouts_clearinterval" id="R.=w_d*Xk3h6nUuanj51">
                       <block type="controls_if" id="Dir-(XSm)akkXs3-Y^xH">
                           <block type="logic_negate" id="N,HqW]LM,^8!@tY0P)wK">
                             <value name="BOOL">
                               <block type="variables_get" id=".{q|vn^g`}@9EpN{;zsZ">
                           <block type="control" id="G)M!#H6*^$UaGALg/o7I">
                               <block type="variables_get" id="WEi5d_diWt-*v)6q.f5R">
                                 <field name="VAR" id="U0|}x*G;[=9}9Ql;A}WY" variabletype="">ein</field>
      AxelF1977 1 Reply Last reply Reply Quote 1
      • AxelF1977
        AxelF1977 @paul53 last edited by
        @paul53 said in Taster press short or long mit blockly:
        @AxelF1977 sagte:
         <variables>
         </variables>
                       <value name="OID0">
                               </mutation>
                               <value name="ARG0">
                               <value name="ARG1">
                               <value name="OID0">
                                       <value name="NUM">
                                       </mutation>
                                       <value name="ARG0">
                                       <value name="ARG1">
           <mutation>
           </mutation>
                               <value name="BOOL">
        Wie krass! Das funktioniert, unglaublich.
        Ein wenig zickig ist es noch, nach loslassen der Tasten dimmt er noch weiter hoch oder runter, mal einen Schritt, mal mehrere, ich glaube je nachdem wie lange gedrückt war.
        Wo muss ich was ändern, dass er bei langem Drücken nicht so weit runter dimmt, dass das Licht ausgeht, sondern bis max 10%
        Ich habe mal die Anordnung der Button geändert, A0 ist oben und AI unten
        Sonst scheint das sehr gut zu laufen.
        Ich bin mehr als beeindruckt.
          paul53 @AxelF1977 last edited by paul53
          @AxelF1977 sagte:
          falls level < 10 setze level auf 10
          @AxelF1977 sagte in Taster press short or long mit blockly:
          Reagieren die Datenpunkte AI, AO nicht sofort auf den Taster ?
          AxelF1977 1 Reply Last reply Reply Quote 0
          • AxelF1977
            @AxelF1977 sagte:
            falls level < 10 setze level auf 10 funktioniert perfekt, DANKE!
            Es gibt ca. eine Verzögerung von 1 sek, dann kann aber an der HUE Bridge liegen. Die Taster reagieren teils etwas träge, auch beim normalen Schalten. Das Signal muss über einen USB Stick an den Raspi gesendet werden, dort vom Adapter verabeitet und an die Bridge gesendet werden.
            An und aus hat auch eine Verzögerung.
              @AxelF1977 sagte:
              Dann ist der Intervallzyklus von 250 ms wohl etwas zu kurz. Verdopple ihn mal auf 500 ms.
              • AxelF1977
                @AxelF1977 sagte:
                500 ist so langsam, das man das Gefühl bekommt, es dimmt nicht. Ich habs mit 350ms probiert, das scheint zu passen. Zwischendurch pausiert das Dimmen immer mal wieder, als wenn ein cache zu läuft durch die Daten.
                Was mir noch auffällt, wenn ich hoch dimme, geht das Licht erst auf die 10% zurück, und dimmt dann hoch.
                Das alles als Feedback, denn wenn das richtig funktioniert, haben da sicherlich mehrere User Interesse dran.
                  @AxelF1977 sagte:
                  Dieses Verhalten gibt das Skript nicht her.
                  • AxelF1977
                    @AxelF1977 sagte:
                    Passiert aber komischer weise, ich kann es mir anhand des Scripts auch nicht erklären. Aber wie gesagt, sowas kann auch an der Hue Bridge liegen
                    • AxelF1977
                      Ein gutes Ergebnis liefern ein Intervall von 700ms und steps mit 9
                      • sainthein
                        sainthein last edited by sainthein
                        Bekommt das ganze auch mit einem Tradfri On/Off Taster gebacken?
                        Dimmen läuft, nur an und aus mit kurzem Tastendruck läuft nicht.
                        6662
