    4. Fehlerschleife im Info-Adapter
    SOLVED Fehlerschleife im Info-Adapter
      kaifu last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi 4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: Ubuntu
      Node-Version: 10.19.0
      Nodejs-Version: 10.19.0
      NPM-Version: 6.13.0
      Installationsart: Manuell
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link
      Aus dem nichts habe ich seit ca. 17 Uhr heute plötzlich folgenden Fehler:
      host.raspberrypi	2020-02-06 20:55:40.989	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      host.raspberrypi	2020-02-06 20:55:40.989	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:90593)
      host.raspberrypi	2020-02-06 20:55:40.989	error	Caught by controller[0]: at adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:264:21)
      host.raspberrypi	2020-02-06 20:55:40.988	error	Caught by controller[0]: at instances (/opt/iobroker/node_modules/iobroker.info/main.js:160:26)
      host.raspberrypi	2020-02-06 20:55:40.988	error	Caught by controller[0]: at Array.forEach (<anonymous>)
      host.raspberrypi	2020-02-06 20:55:40.988	error	Caught by controller[0]: at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:172:57)
      host.raspberrypi	2020-02-06 20:55:40.987	error	Caught by controller[0]: at Array.forEach (<anonymous>)
      host.raspberrypi	2020-02-06 20:55:40.987	error	Caught by controller[0]: at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:185:46)
      host.raspberrypi	2020-02-06 20:55:40.987	error	Caught by controller[0]: at checkConditions (/opt/iobroker/node_modules/iobroker.info/main.js:138:25)
      host.raspberrypi	2020-02-06 20:55:40.986	error	Caught by controller[0]: at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23)
      host.raspberrypi	2020-02-06 20:55:40.985	error	Caught by controller[0]: TypeError: Cannot read property 'split' of undefined
      info.0	2020-02-06 20:55:40.866	error	(17985) TypeError: Cannot read property 'split' of undefined at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23) at checkConditions (/opt/iobroker/node_modules/iobroker.i
      info.0	2020-02-06 20:55:40.862	error	(17985) uncaught exception: Cannot read property 'split' of undefined
      Könnte mir bitte jemand helfen???
      Danke!
        Falls es noch jemandem hilft: Update des Admins auf 4.0 (nicht unter "default", sondern nur unter "latest" verfügbar!) hat schließlich geholfen.
        • junees
          junees last edited by junees
          Ich habe genau das gleiche Problem. Bei mir fing es gestern aus heiterem Himmel an.
          Da ich noch recht neu in dem Thema bin, was meinst du mit Update findet man unter "latest"? Kann das nicht wirklich finden. Danke schonmal!
            RalfEngelberth @junees last edited by Negalein
            @junees sagte in Fehlerschleife im Info-Adapter:
            gehe mal ins System,
            da findest du folgende Verwahrungsorte
            Dann in "Aktiver Verwahrungsort" latest auswählen.
            Nach dem Update von Admin über latest ist der Fehler bei mir weg.
            Zur Info:
            https://www.iobroker.net/#de/documentation/admin/settings.md?verwahrungsorte
            junees 1 Reply Last reply Reply Quote 0
            • junees
              junees @RalfEngelberth last edited by
              @RalfEngelberth Super, vielen Dank! Muss gleich mal ein Backup ziehen und dann schauen, ob es das Problem bei mir auch behebt.
              • junees
                Seit update auf 4.0.1 ist der Fehler bei mir jetzt auch weg.
                • N
                  Newbie12 last edited by Newbie12
                  wollte den Fehler nach dieser Anleitung behegben. Allerdings erscheinen keine verfügbaren Versionen,
                  wenn ich den aktuellen Aufbewahrungsort auf latest wechsle.
                  Ich kann daher den admin-Adapter nicht auf 4... updaten.
                  Das logfile sagt:
                  host.raspberrypi 2020-06-11 15:41:24.955 warn warning: empty repo received!
                  host.raspberrypi 2020-06-11 15:41:24.954 warn warning: Cannot read "http://download.iobroker.net/sources-dist-latest.json"
                  Hat jemand eine Idee?
                  Mfg
                  Ferdi
                  INFO:
                  raspberrypi
                  Betriebssystem
                  linux
                  Architektur
                  arm
                  CPUs
                  Geschwindigkeit
                  1500 MHz
                  Modell
                  ARMv7 Processor rev 3 (v7l)
                  RAM
                  1.89 GB
                  System Betriebszeit
                  06:20:17
                  Node.js
                  v12.18.0
                  NPM
                  6.14.4
                  Festplatte Größe
                  7.02 GB
                  Festplatte frei
                  4.6 GB
                  Betriebszeit
                  04:48:00
                  Aktive Instanzen
                  Hostname
                  raspberrypi
                    Thomas Braun Most Active @Newbie12 last edited by Thomas Braun
                    @Newbie12
                    Füg mal als alternative Quelle für latest das ein
                    http://iobroker.live/repo/sources-dist-latest.json
                    Wobei in 'default' auch die Version 4.0.10 liegt. Du hast da wohl ein Problem mit der Verbindung zu den Verwahrorten.
                    Ich würde als alternative 'default' das mal versuchen und nicht auf 'latest' gehen.
                    http://iobroker.live/repo/sources-dist.json
                    • N
                      Newbie12 @Thomas Braun last edited by
                      @Thomas-Braun
                      Vielen Dank! Konnte den mit der alternativen Quelle auf 4.1.1 updaten.
                      Die Fehlerschleife taucht im log danach auch nicht mehr auf.
                      mfG
                      Ferdi
                      5afca979-e072-425b-b8b8-27548f667e92-grafik.png Admin-Adapter
                        @Newbie12
                        Dann würde ich jetzt wieder auf 'default' zurückstellen, ggf. auch auf die alternative URL.
                        Und dann alle anderen Adapter auf die jeweils aktuellste Verision in default bringen.
                        info adapter
                        1985
