    5. Skriptprobleme
    Skriptprobleme
      Dragon last edited by
      Habe folgendes Skript bei mir laufen. Die eizung schaltet er ohne Probleme, aber die davor liegende AUfgabe den SmartMirror anzuschalten führt er nicht aus. Warum? Bin echt überfragt.
        <block type="schedule" id="ePf`KPdmxWadnp](g2Ix" x="23" y="-226">
          <field name="SCHEDULE">{"time":{"exactTime":true,"start":"06:30"},"period":{"days":1}}</field>
            <block type="controls_if" id="@,{_hWZ?+1{p?_49]`ib">
                <block type="logic_compare" id="k{*]a2ZqAc!y).yMEg7w">
                  <field name="OP">EQ</field>
                    <block type="get_value" id="9TZ*Ff1{(y.;yc3pqEx(">
                      <field name="OID">javascript.0.scriptEnabled.common.Anwesenheit_David</field>
                    <block type="logic_boolean" id="OwtAD$V^oR9wMIIL?V]6">
                <block type="control" id="I_@CO%Sc{`hx7R*_.Ly1">
                  <field name="OID">sonoff.0.SmartMirror.POWER</field>
                    <block type="logic_boolean" id="]:UsCl~$CTT@F{n^vSn2">
                    <block type="controls_if" id="9tGptB^1vagX9?toX|HG">
                        <block type="logic_compare" id="F$;X_)D#DP04^h9tQ0XU">
                            <block type="get_value" id="O+mKAt%(Ei6wy:-`Xp6+">
                              <field name="OID">javascript.0.EigeneDatenpunkte.Sommermodus</field>
                            <block type="logic_boolean" id="`g_qyyb{6R-ZF=^!Ta7~">
                        <block type="control_ex" id=")AUEgr!#tK+leml!?spS">
                          <value name="OID">
                            <shadow type="field_oid" id="Dk}6ZyLZl?)Z8-S7ij0w">
                              <field name="oid">fritzdect.0.Comet_119610463648.targettemp</field>
                            <shadow id="{6;csy?:]uI{VSb%=q(D" type="logic_boolean">
                            <block type="math_number" id="WCEj`O@tFBN/PH7NiCY{">
                              <field name="NUM">21</field>
                          <value name="DELAY_MS">
                            <shadow type="math_number" id="+@N:#j%LhvnVstEH.Seh">
                              <field name="NUM">400</field>
                            <block type="control_ex" id="`@miUlKTrV*N{i*1-k?Q">
                              <value name="OID">
                                <shadow type="field_oid" id=":R{!$|ezU5+V#v/s%95B">
                                  <field name="oid">fritzdect.0.Comet_119610628792.targettemp</field>
                                <block type="math_number" id="wOm#rNJ;%R2@gJWIUz-}">
                                <shadow type="math_number" id="OKO)TS@B?Ruu;w!1F9hz">
                                  <field name="NUM">100</field>
                                <block type="control_ex" id="^FzWVqOhD}QM2/Qxp6[4">
                                  <value name="OID">
                                    <shadow type="field_oid" id="Clb7zxh#Vj!V[7W0llR_">
                                      <field name="oid">fritzdect.0.Comet_119610659288.targettemp</field>
                                    <block type="math_number" id="5r(`7EL[9`Vcj|W1au;D">
                                    <shadow type="math_number" id="Y*k@7*UO}65sLju_u5Gr">
                                      <field name="NUM">200</field>
                                    <block type="control_ex" id="JIga!0q=2aeCOg8%{2up">
                                      <value name="OID">
                                        <shadow type="field_oid" id="S+QQ=C+.r`8RsFF[1Z%r">
                                          <field name="oid">fritzdect.0.Comet_119610662952.targettemp</field>
                                        <block type="math_number" id="()CBc1q[vK0^IF;q-ey6">
                                        <shadow type="math_number" id="b8ez5{.tfC~R%vg(2%][">
                                          <field name="NUM">300</field>
            <block type="schedule" id="2MENtB]D1^}8s7{Ngh,u">
              <field name="SCHEDULE">{"time":{"exactTime":true,"start":"23:00"},"period":{"days":1}}</field>
                <block type="controls_if" id="e!R#?n6)LJW~{4s2U$PC">
                    <block type="logic_operation" id="Z7SP.vze.;T=Kj0ye9*k" inline="false">
                      <field name="OP">AND</field>
                        <block type="logic_compare" id="9`?rtjctxH#=lO{c4M|B">
                            <block type="get_value" id="kG*.ZPe`b.h!!,lD(%t.">
                            <block type="logic_boolean" id="Gx^Z.{,J~Iy}xV-)/6~p">
                        <block type="logic_compare" id="o2F=lyxdFHEUYaRs=2G;">
                            <block type="get_value" id="XQ.YJD*NJ6MJtnA$6n)-">
                            <block type="logic_boolean" id="R2IPy~ypOsRC]Bn|_-Qx">
                    <block type="control_ex" id="oG1{jv)V1vuORA0hyqYK">
                      <value name="OID">
                        <shadow type="field_oid" id="zkfX)=`Lc;m.eLY;KSG3">
                        <block type="math_number" id="Md?r{=JBSz{].I9S}?An">
                          <field name="NUM">17</field>
                        <shadow type="math_number" id="=+6{I^VgQLF~uO5G[O_*">
                          <field name="NUM">0</field>
                        <block type="control_ex" id="4Fia$X^0mcXO]X_wR4/)">
                          <value name="OID">
                            <shadow type="field_oid" id="*q(vaV94Fs}*p_nMc11R">
                            <block type="math_number" id=",cw/_9?`U!6E-Hp}!sB]">
                            <shadow type="math_number" id="RnhZjet#i*jdhu4.SuV7">
                            <block type="control_ex" id="x27O3$QR]nm1ZrOWo9x^">
                              <value name="OID">
                                <shadow type="field_oid" id="QX+IbFJ.,`^$]PnSZY%$">
                                <block type="math_number" id="CL{VN?r9@AzzAhyZhPrV">
                                <shadow type="math_number" id="(?,1?uy9*6+g?@*.V[e*">
                                <block type="control_ex" id="UkZ|xp8Ihr~^+%P}:_3l">
                                  <value name="OID">
                                    <shadow type="field_oid" id="tK`*z9KUShK![!77T{P$">
                                    <block type="math_number" id="=rz=_eAep~}.Hww$~Zwk">
                                    <shadow type="math_number" id="ENwDT3j=PeWKg~]M(PS1">
                                    <block type="control" id="]:0lYs*^{5$DP}?{#RY?">
                                      <mutation delay_input="true"></mutation>
                                      <field name="DELAY_MS">400</field>
                                      <field name="UNIT">ms</field>
                                        <block type="logic_boolean" id="@_N^oIQ1VtT0(#=FgqPN">
        Homoran Global Moderator Administrators @Dragon last edited by
        @David-Froebus was ist das für ein datenpunkt beim Smart mirror?
          Das ist der datenpunkt eines sonoff pow mit dem das gerät an und ausgeschaltet wird. der datenpunkt stimmt auch, da meine schalter die auf diesen datenpunkt zugreifen funktionieren. ein manuelles ändern des datenpunktes auf true funktioniert auch
            Homoran Global Moderator Administrators @Dragon last edited by Homoran
            @David-Froebus sagte in Skriptprobleme:
            mit ACK (bestätigt) oder ohne?
            wenn mit, dann probiere bitte mal den aktualisiere Block
              Nein habe ich immer ohne
