    4. Wasserzähler - Selfmade
    • Luc3as
      Luc3as last edited by
      Hello gentleman, sorry for writing in english, I know only few words in german and it's from rammstein 😄
      I am trying to modify this amazing project to my needs, the main problem is that we have another design of water meters here. I already sketched up rough mount for the right diameter of water meter, I am gathering data ( images ) to retrain the model because we have different numbers on rolling pins.
      The main question is, how could I modify the server in docker container so it would recognize data from 2 water meters, or possibly more, I am thinking about sensing the gas meter which use the same principle. I know I could run somehow 2 same containers but, I quite don't like this idea of "wasting resources".
      thanks
        jomjol @Luc3as last edited by
        @Luc3as Hi Lucas,
        let me know, when you have enough images for training the CNN. I would be very interested to increase additional number types into the training, increasing its usability for different kind of counters.
        Unfortunately it is not possible to easily implement two counters in only one running docker containers. The whole internal structure (config.ini, it's parsing, the internal data stucture) is intended for a single counter only. I strongly recommend to run two dockers, mapping to different ports.
        Otherwise a full restructuring of the source code is necessary. There is no plan from my side to do this at the moment.
        Best regards,
        jomjol
        • I
          intruder7 last edited by
          @jomjol
          Hallo, ich habe mich die letzten Tage mal wieder intensiver mit der Thematik beschäftigt. Ich habe alles in einem Docker laufen auf einer Syn. Dabei habe ich das Problem, dass sich egelmäßig nach zwei bis drei Tagen der Server aufhängt und ich bei jeder Abfrage folgende Fehlermeldung bekomme.
          Exception happened during processing of request from ('172.17.0.1', 50807)
          Traceback (most recent call last):
            File "/usr/local/lib/python3.7/socketserver.py", line 316, in _handle_request_noblock
              self.process_request(request, client_address)
            File "/usr/local/lib/python3.7/socketserver.py", line 347, in process_request
              self.finish_request(request, client_address)
            File "/usr/local/lib/python3.7/socketserver.py", line 360, in finish_request
              self.RequestHandlerClass(request, client_address, self)
            File "/usr/local/lib/python3.7/socketserver.py", line 720, in __init__
              self.handle()
            File "/usr/local/lib/python3.7/http/server.py", line 426, in handle
              self.handle_one_request()
            File "/usr/local/lib/python3.7/http/server.py", line 414, in handle_one_request
              method()
            File "./wasseruhr.py", line 103, in do_GET
              result = wasserzaehler.getZaehlerstand(url, simple, usePrevalue, single)
            File "/lib/ZaehlerstandClass.py", line 142, in getZaehlerstand
              txt, logtime = self.LoadFileFromHTTP.LoadImageFromURL(url, './image_tmp/original.jpg')
            File "/lib/LoadFileFromHTTPClass.py", line 57, in LoadImageFromURL
              action_process.start()
            File "/usr/local/lib/python3.7/multiprocessing/process.py", line 112, in start
              self._popen = self._Popen(self)
            File "/usr/local/lib/python3.7/multiprocessing/context.py", line 223, in _Popen
              return _default_context.get_context().Process._Popen(process_obj)
            File "/usr/local/lib/python3.7/multiprocessing/context.py", line 277, in _Popen
              return Popen(process_obj)
            File "/usr/local/lib/python3.7/multiprocessing/popen_fork.py", line 20, in __init__
              self._launch(process_obj)
            File "/usr/local/lib/python3.7/multiprocessing/popen_fork.py", line 70, in _launch
              self.pid = os.fork()
          OSError: [Errno 12] Cannot allocate memory
          Habe schon mehrmals neu installiert. Laufen hab ich die letzte rolling version.
          der Fehler ist immer der selbe der dann kommt. Nach einem Neustart des Dockercontainer funktioniert es wieder 2 bis 3 Tage.
          Hast du oder jemand anderes hier vielleicht ne Ahnung woran das liegt?
          LG
          Knallochse J 2 Replies Last reply Reply Quote 0
          • Knallochse
            Knallochse @intruder7 last edited by
            @intruder7 Ich kann dir leider nicht bei der Beseitigung des Fehlers helfen, aber du kannst über den Aufgabenplaner der Synology einen Zeitgesteuerten Neustart deines Containers einstellen
            • I
              intruder7 @Knallochse last edited by
              @Knallochse Das wäre eine Alternative. Hatte ich schon mal dran gedacht, aber im Bereich Docker nichts dazu gefunden und auch nicht weiter verfolgt. Werde ich mal umsetzen.
              Danke dir
                jomjol @intruder7 last edited by
                @intruder7 Ja, das Problem ist bekannt. In Tensorflow 2.0 gibt es ein Speicherleck. Mit jeder Bilderkennung wird etwas mehr Speicher geblockt und daher der Fehler. Es ist ein intrinsischer Fehler und soll erst mit einer Nachfolgenden Version beseitigt werden. Die kann ich aber aktuell noch nicht für die Synology kompilieren - bricht bei mir bisher immer ab.
                Ich versuche es aber bei Gelegenheit wieder.
                Beste Grüße,
                jomjol
                • Atifan
                  Atifan last edited by
                  Hallo, bin sehr interessiert daran so einen Wasserzähler Sensor nachzubauen und hätte daher einige Fragen.
                  1. Geht das mit meinem analogen Wasserzähler der Firma Elster (siehe Bild)
                  2. ich habe zufällig ein ESP32CAM hier, bekomme die Kamera aber nicht gedreht bzw. fokussiert. Hat da jemand einen Tipp wie man das einfach hin bekommt oder evtl. einen Tipp für ein Kamera die ich mir bestellen könnte bei der es einfach geht. Ich habe keine originale OV2640 drauf sondern eine XRZ00D1
                  3. Gibt es irgendwo eine detaillierte Anleitung wie man vorgehen muss bzw. wie man den Server einrichtet und konfiguriert? Ich würde gerne den Server auf einem Intel NUC laufen lassen.
                  Schon mal Danke vorab.
                    jomjol @Atifan last edited by
                    @Atifan Hallo Atifan,
                    zu 1) ja sollte gehen, nur das Kondenswasser ist ein Problem!
                    zu 2) bei der OV2640 muss du die Versiegelung des Objektivs leicht lösen und dann kannst du sie drehen (siehe https://www.thingiverse.com/thing:3860911). XRZ00D1 kenne ich nicht
                    zu 3) Idealerweise verwendet du einen Docker Container: https://github.com/jomjol/water-meter-system-complete
                    Beste Grüße,
                    jomjol
                    • pfried
                      pfried last edited by
                      @Atifan Hi Atifan, wenn du das Bild auf diese Größe bekommst:
                      ist auch das Kondenswasser kaum mehr ein Problem. Was ich gemacht habe um das Kondenswasserproblem ganz zu lösen: ich habe mir bei Amazon einen Auto-Entfeuchter von ThoMar (Air Dry Auto-Entfeuchter mit natürlichem Speichergranulat) bestellt. Das sind zwei Kissen drinnen mit 46 * 16 * 3 cm. Dieses 3-teilige Kissen habe ich um das Gehäuse des ESP32 gewickelt, sodass es fast Luftdicht abschließt. Seitdem ist mit Kondenswasser auf dem Schauglas schluss 😊 da diese Kissen komplett der Luft im Gehäuse die Feuchtigkeit entzieht. Die Kissen kann man auch wiederverwenden, dass heißt man legt diese auf die Heizung oder in die Sonne und läßt sie trocknen.
                      Kosten: circa 17,-- Euro
                      W Atifan 2 Replies Last reply Reply Quote 0
                        watcherkb @pfried last edited by
                        @pfried super Tipp, danke dir!
                        @jomjol : ich denke ich habe das Problem mit dem Ausfall der ESP Camera gefunden. Bei mir war es so dass die Verbindung nach einiger Zeit weg war. Auch der Tipp, auf den Parser-Adapter zu verzichten brachte keinen Erfolg. Seit der Anpassung habe ich bisher keinen Ausfall gehabt. Vielleicht hilft es jemandem auch.
                        Meine Lösung: die Methode WifiReConnect() in der Zeile 14-21 in der Datei ESP32CAM_Server-GitHub.ino angepasst:
                        void WifiReConnect()
                          pinMode(INT_LED, OUTPUT);         // Initialize the LED_BUILTIN pin as an output
                          digitalWrite(INT_LED, HIGH);      // turn the LED on.
                          if (WiFi.status() != WL_CONNECTED)
                            WiFi.mode(WIFI_STA);
                            WiFi.begin(ssid, password);
                            Serial.println("");
                            // Wait for connection
                            // attempt to connect to Wifi network:
                            while ( WiFi.status() != WL_CONNECTED) {
                              Serial.print("Attempting to connect to WPA network, SSID: ");
                              Serial.println(ssid);
                              // wait 10 seconds for connection:
                              delay(10000);
                            Serial.println("");
                            Serial.print("Connected to ");
                            Serial.print("IP address: ");
                            Serial.println(WiFi.localIP());
                            if (MDNS.begin(host)) {
                              Serial.print("MDNS responder started - Host: "); Serial.println(host);
                            for (int i=0;i<3;i++){
                              digitalWrite(INT_LED, LOW);          // turn the LED on.
                              delay(500);         // wait
                              digitalWrite(INT_LED, HIGH);         // turn the LED off.
                              delay(500);   // wait
                              delay(0);                        //to prevent watchdog firing.
                        Atifan J 2 Replies Last reply Reply Quote 0
                        • Marcel saß
                          Marcel saß last edited by Marcel saß
                          Super Projekt.
                          bekomme nach das als Ausgabe:
                          .4434 00000 4434 ErrorRateTooHigh (294.4704) 294.9138
                          die letzte Zahl stimmt. Warum steht davor was? habe ich etwas doppelt am laufen?
                          Wie bekomme ich jetzt diese Zahl in den IOBroker?
                          wie dieser anfrage im Script : http://192.168.XXXXXXX/setPreValue?value= bekomme ich gar keine Ausgabe.
                          Marcel saß J 2 Replies Last reply Reply Quote 0
                          • Marcel saß
                            Marcel saß @Marcel saß last edited by Marcel saß
                            Hier stand mist...
                            • Atifan
                              Atifan @watcherkb last edited by Atifan
                              hier stand auch Mist.
                              • Atifan
                                Atifan last edited by Atifan
                                So, habe die Firmware von Github auf meinen ESP32 geflasht und die Änderungen von @watcherkb vorgenommen.
                                Die Kamera an sich funktioniert und macht Bilder, wenn ich über Browser aufrufe "http://192.168.178.197/capture".
                                Was aber nicht funkioniert ist die LED an und AUS schalten, da tut sich nix, LED bleibt immer aus.
                                Weiß einer was das sein kann?
                                Die LED ist nicht defekt, hatte extra eine andere FW geflasht zum Testen.
                                  watcherkb @Atifan last edited by
                                  @Atifan du musst die Adafruit Neopixel Library installieren da sie in dem Sketch von jomjol verwendet wird.
                                  https://www.arduino.cc/en/Guide/Libraries
                                  Atifan 1 Reply Last reply Reply Quote 0
                                  • Atifan
                                    @watcherkb sagte in Wasserzähler - Selfmade:
                                    Hi, ja Danke, habe ich bereits rausgefunden 😄 Habe es geflasht und funktioniert soweit alles bis auf die LED. Warum die nicht geht weiss ich nicht 😞
                                      @Atifan hast du den richtigen Aufruf? http://deineIP/capture_with_flashlight
                                      • Atifan
                                        Ja, habe versucht
                                        http://192.168.178.197/capture_with_light
                                        http://192.168.178.197/lighton
                                        funktioniert beides nicht 😞
                                        http://192.168.178.197/capture funktioniert und liefert ein Bild
                                          @Atifan ist nicht dasselbe wie flashlight. Probiere was ich dir geschrieben habe.
                                          • Atifan
                                            Ah mist ich bin so doof, sorry 🙂
                                            Sehe jetzt erst dass es verschiedene Befehle gibt 🙂
                                            how-to wasser wasserzähler
                                            48
                                            1089
                                            350368
