    4. Test Adapter fb-checkpresence v0.2.x
    • afuerhoff
      afuerhoff Developer @Neuschwansteini last edited by
      ich hab noch zwei json Table unter fb-devices eingebaut. Bitte nochmal aus Github aktualisieren.
        mameier1234 @Neuschwansteini last edited by Negalein
        Neue Fehler mit der aktuellen Version von Github...
        fb-checkpresence.0	2020-02-09 16:21:04.831	error	(7876) getActive: undefined
        fb-checkpresence.0	2020-02-09 16:21:04.830	error	(7876) soapAction GetSpecificHostEntry -> undefined
        hier das Debug-Log
        fb-checkpresence.0	2020-02-09 16:21:08.416	debug	(7876) getDeviceInfo unknown: 101
        fb-checkpresence.0	2020-02-09 16:21:08.416	debug	(7876) getDeviceInfo active: 71
        fb-checkpresence.0	2020-02-09 16:21:05.661	debug	(7876) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-02-09 16:21:05.592	debug	(7876) checkPresence first run
        fb-checkpresence.0	2020-02-09 16:21:05.591	debug	(7876) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-02-09 16:21:04.768	debug	(7876) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-02-09 16:21:04.723	debug	(7876) request url https://192.168.160.254:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://
        fb-checkpresence.0	2020-02-09 16:21:04.723	debug	(7876) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-02-09 16:21:04.721	debug	(7876) getActive [{"Name":"Martin","Active":"true","Kommt":"2020.02.09 01:54:02","Geht":"2020.02.09 01:38:02"},{"Name":"Claudia","Active":"true","Kommt":"2020.02.09 03:55:03","Geht":"2020.02.09 03:26:
        fb-checkpresence.0	2020-02-09 16:21:04.693	debug	(7876) getActive Dennis 0
        fb-checkpresence.0	2020-02-09 16:21:04.692	debug	(7876) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n
        fb-checkpresence.0	2020-02-09 16:21:04.603	debug	(7876) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-02-09 16:21:04.538	debug	(7876) request url https://192.168.160.254:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://
        fb-checkpresence.0	2020-02-09 16:21:04.538	debug	(7876) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-02-09 16:21:04.503	debug	(7876) getActive [{"Name":"Martin","Active":"true","Kommt":"2020.02.09 01:54:02","Geht":"2020.02.09 01:38:02"},{"Name":"Claudia","Active":"true","Kommt":"2020.02.09 03:55:03","Geht":"2020.02.09 03:26:
        fb-checkpresence.0	2020-02-09 16:21:04.478	debug	(7876) getActive Vanessa 0
        fb-checkpresence.0	2020-02-09 16:21:04.477	debug	(7876) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n
        fb-checkpresence.0	2020-02-09 16:21:04.454	debug	(7876) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-02-09 16:21:04.384	debug	(7876) request url https://192.168.160.254:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://
        fb-checkpresence.0	2020-02-09 16:21:04.383	debug	(7876) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-02-09 16:21:04.364	debug	(7876) getActive [{"Name":"Martin","Active":"true","Kommt":"2020.02.09 01:54:02","Geht":"2020.02.09 01:38:02"},{"Name":"Claudia","Active":"true","Kommt":"2020.02.09 03:55:03","Geht":"2020.02.09 03:26:
        fb-checkpresence.0	2020-02-09 16:21:04.362	debug	(7876) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-02-09 16:21:04.333	debug	(7876) getActive Claudia 1
        fb-checkpresence.0	2020-02-09 16:21:04.332	debug	(7876) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n
        fb-checkpresence.0	2020-02-09 16:21:04.301	debug	(7876) request url https://192.168.160.254:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://
        fb-checkpresence.0	2020-02-09 16:21:04.301	debug	(7876) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-02-09 16:21:04.297	debug	(7876) getActive [{"Name":"Martin","Active":"true","Kommt":"2020.02.09 01:54:02","Geht":"2020.02.09 01:38:02"},
        fb-checkpresence.0	2020-02-09 16:21:04.271	debug	(7876) getActive Martin 1
        fb-checkpresence.0	2020-02-09 16:21:04.270	debug	(7876) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n
        fb-checkpresence.0	2020-02-09 16:21:04.227	debug	(7876) request url https://192.168.160.254:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://
        fb-checkpresence.0	2020-02-09 16:21:04.222	debug	(7876) getDeviceList: [{"Index":"1","IPAddress":"192.168.160.67","MACAddress":"24:5B:A7:BE:7F:28","Active":"1","HostName":"AppleWanClaudia","InterfaceType":"802.11","X_AVM-DE_Port":"0","X_AVM-DE_Speed
        fb-checkpresence.0	2020-02-09 16:21:04.008	debug	(7876) body <?xml version="1.0" encoding="UTF-8"?> <List> <!-- devicehosts :102 --> <Item> <Index>1</Index> <IPAddress>192.168.160.67</IPAddress> <MACAddress>24:5B:A7:BE:7F:28</MACAddress> <Active>1<
        fb-checkpresence.0	2020-02-09 16:21:03.244	debug	(7876) response: 1 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n
        fb-checkpresence.0	2020-02-09 16:21:03.008	debug	(7876) request url https://192.168.160.254:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://
        fb-checkpresence.0	2020-02-09 16:21:03.006	debug	(7876) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n
        fb-checkpresence.0	2020-02-09 16:21:02.997	debug	(7876) request url http://192.168.160.254:49000/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://s
        fb-checkpresence.0	2020-02-09 16:21:02.995	debug	(7876) sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-02-09 16:21:02.995	debug	(7876) createMemberObjects Hilde
        fb-checkpresence.0	2020-02-09 16:21:02.994	debug	(7876) createMemberObjects Dennis
        fb-checkpresence.0	2020-02-09 16:21:02.994	debug	(7876) sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-02-09 16:21:02.994	debug	(7876) createMemberObjects Vanessa
        fb-checkpresence.0	2020-02-09 16:21:02.993	debug	(7876) sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-02-09 16:21:02.993	debug	(7876) createMemberObjects Claudia
        fb-checkpresence.0	2020-02-09 16:21:02.992	debug	(7876) sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-02-09 16:21:02.991	debug	(7876) createMemberObjects Martin
        fb-checkpresence.0	2020-02-09 16:21:02.991	debug	(7876) createGlobalObjects
        fb-checkpresence.0	2020-02-09 16:21:02.989	debug	(7876) sslPort 49443
        fb-checkpresence.0	2020-02-09 16:21:02.987	debug	(7876) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n
        fb-checkpresence.0	2020-02-09 16:21:02.976	debug	(7876) request url http://192.168.160.254:49000/upnp/control/deviceinfo body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="htt
        fb-checkpresence.0	2020-02-09 16:21:02.975	info	(7876) service GetSecurityPort is supported
        fb-checkpresence.0	2020-02-09 16:21:02.955	info	(7876) service X_AVM-DE_GetSpecificHostEntryByIP is supported
        fb-checkpresence.0	2020-02-09 16:21:02.933	info	(7876) service GetSpecificHostEntry is supported
        fb-checkpresence.0	2020-02-09 16:21:02.899	info	(7876) service X_AVM-DE_GetHostListPath is supported
        fb-checkpresence.0	2020-02-09 16:21:02.848	debug	(7876) configuration familymembers: [{"familymember":"Martin","macaddress":"8C:86:1E:61:D8:9B","comment":"","enabled":true},{"familymember":"Claudia","macaddress":"84:AD:8D:B8:F6:06","comment":"","ena
        fb-checkpresence.0	2020-02-09 16:21:02.847	debug	(7876) configuration dateformat: yyyy.mm.dd hh:MM:ss
        fb-checkpresence.0	2020-02-09 16:21:02.847	debug	(7876) configuration history: history.0
        fb-checkpresence.0	2020-02-09 16:21:02.847	debug	(7876) configuration user: Broker
        fb-checkpresence.0	2020-02-09 16:21:02.847	info	(7876) start fb-checkpresence: ip-address: 192.168.160.254 polling interval: 2 Min.
        fb-checkpresence.0	2020-02-09 16:21:02.524	info	(7876) starting. Version 0.2.2 in C:/ioBroker/node_modules/iobroker.fb-checkpresence, node: v10.19.0
        fb-checkpresence.0	2020-02-09 16:20:59.419	debug	2
        fb-checkpresence.0	2020-02-09 16:20:59.419	debug	(7876) States create System PubSub Client
        fb-checkpresence.0	2020-02-09 16:20:59.304	debug	(7876) States create User PubSub Client
        fb-checkpresence.0	2020-02-09 16:20:58.610	debug	(7876) Redis States: Use Redis connection: 0.0.0.0:9000
        fb-checkpresence.0	2020-02-09 16:20:58.608	debug	(7876) objectDB connected
        fb-checkpresence.0	2020-02-09 16:20:58.602	debug	(7876) Objects connected to redis: 0.0.0.0:9001
        fb-checkpresence.0	2020-02-09 16:20:58.578	debug	(7876) Objects client initialize lua scripts
        fb-checkpresence.0	2020-02-09 16:20:58.578	debug	(7876) Objects create User PubSub Client
        fb-checkpresence.0	2020-02-09 16:20:58.577	debug	(7876) Objects create System PubSub Client
        fb-checkpresence.0	2020-02-09 16:20:58.573	debug	(7876) Objects client ready ... initialize now
        fb-checkpresence.0	2020-02-09 16:20:58.518	debug	(7876) Redis Objects: Use Redis connection: 0.0.0.0:9001
        afuerhoff 1 Reply Last reply Reply Quote 0
          Homoran Global Moderator Administrators @sigi234 last edited by
          @sigi234 sagte in Test Adapter fb-checkpresence v0.2.x:
          Kann man eine json haben wo die aktiven und die inaktiven getrennt sind? (Fritzbox devices )
          allerdings ist ja die Fritte seeeeehr träge was Angabe von aktiv/inaktiv betrifft.
          Das kann auch mal 10 Minuten dauern.
          zum Checken der Präsenz ist das nicht schnell genug
          • afuerhoff
            afuerhoff Developer @mameier1234 last edited by
            @mameier1234 sagte in Test Adapter fb-checkpresence v0.2.x:
            Hallo, ich habe die Fehlermeldung noch optimiert. Bitte von Github nochmal aktualisieren. Evtl. ist der Fehler dann klarer.
            • afuerhoff
              afuerhoff Developer @Homoran last edited by
              @Homoran sagte in Test Adapter fb-checkpresence v0.2.x:
              Hallo, das erkennen von aktiv sollte sehr schnell gehen. Das erkennen von Inaktiv dauert bis zu 10 Minuten.
                sigi234 Forum Testing Most Active @afuerhoff last edited by
                @afuerhoff sagte in Test Adapter fb-checkpresence v0.2.x:
                Kann man noch die Anzahl der Inaktiven Devices anzeigen?
                • afuerhoff
                  afuerhoff Developer @sigi234 last edited by
                  Ist drin. Bitte neu von Github installieren.
                  Neuschwansteini 1 Reply Last reply Reply Quote 2
                  • Neuschwansteini
                    Neuschwansteini @afuerhoff last edited by
                    @afuerhoff
                    Hi, super, vielen Dank, ging ja schnell! Funktioniert.
                    Bekomme jetzt beim Starten des Adapters Fehler mit der History:
                    	at tryOnImmediate (timers.js:676:5)
                    history.0	2020-02-09 18:08:08.683	warn	at runCallback (timers.js:705:18)
                    history.0	2020-02-09 18:08:08.683	warn	at Immediate.setImmediate [as _onImmediate] (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:227:41)
                    history.0	2020-02-09 18:08:08.683	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4803:41)
                    history.0	2020-02-09 18:08:08.683	warn	at Object.message (/opt/iobroker/node_modules/iobroker.history/main.js:146:25)
                    history.0	2020-02-09 18:08:08.683	warn	at processMessage (/opt/iobroker/node_modules/iobroker.history/main.js:224:9)
                    history.0	2020-02-09 18:08:08.683	warn	at getHistory (/opt/iobroker/node_modules/iobroker.history/main.js:812:41)
                    history.0	2020-02-09 18:08:08.683	warn	(1967) TypeError: Cannot read property 'start' of undefined
                    history.0	2020-02-09 18:08:08.662	warn	(1967) States system pmessage io.messagebox.system.adapter.history.0 {"command":"getHistory","message":{"result":[],"step":null,"error":null},"from":"system.adapter.fb-checkpresence.0","callback":{"m
                    fb-checkpresence.0	2020-02-09 18:08:08.558	warn	(14975) Unknown command: getHistory
                    fb-checkpresence.0	2020-02-09 18:08:08.557	warn	(14975) Unknown command: getHistory
                    fb-checkpresence.0	2020-02-09 18:08:08.553	warn	(14975) Unknown command: getHistory
                    • afuerhoff
                      @ilovegym
                      Den Fehler kann ich mir jetzt überhaupt nicht erklären. Kommt der jedesmal nach Start des Adapters? Kannst Du evtl. nochmal von Github installieren.
                      Neuschwansteini 1 Reply Last reply Reply Quote 0
                      • Neuschwansteini
                        @afuerhoff kam jetzt nicht mehr... Hab nochmals von git installiert... Hmm Mal beobachten.. 🙂
                        • MathiasJ
                          MathiasJ last edited by
                          Hier das selbe.
                          Von Github drüber installiert, keine Fehler mehr.
                          Sauber, hast Du das hinbekommen! 👍 👍
                            guergen last edited by guergen
                            Die Datenbankverarbeitung scheint nicht richtig zu funktionieren, habe ein Issue dazu aufgemacht...
                            • afuerhoff
                              afuerhoff Developer @guergen last edited by
                              @guergen
                              Hallo, es funktioniert so, wie ich es implementiert habe. Der Adapter legt nach Start die Einstellungen für einen Family Member fest. Wie wichtig ist für Dich der Alias?
                              Kannst Du mal den Reiter Tabelle zum Datenpunkt aus der History posten.
                                guergen @afuerhoff last edited by guergen
                                @afuerhoff Das Problem ist, dass Grafana aus der Datenbank den von FB-Presence gelieferten Daten nicht findet! In der Datenbank sind sie ja drin.
                                Wichtig ist der Alias nicht wirklich, habe nur alle Datenpunkte entsprechend benannt um Sie in Grafana schnell zu finden!
                                Hier die Einstellungen:
                                Hier die History-Einstellungen:
                                • harrym
                                  harrym last edited by
                                  kurze Frage bzgl. InfluxDB. Habe gerade den fb-checkpresende Adapter aus GIT installiert. InfluxDB läuft schon länger auf meinem Broker ... trotzdem hab ich da nur die Auswahl "disabled" oder "History" ?
                                    guergen @harrym last edited by
                                    @harrym Scroll mal...
                                    harrym 1 Reply Last reply Reply Quote 0
                                    • afuerhoff
                                      @guergen
                                      Ich meinte die Daten aus der History
                                      • harrym
                                        harrym @guergen last edited by
                                        @guergen DANKE! da wär ein hinweis toll ^_^
                                          Habe eben mit rumgespielt, daher ist da nicht viel drin
                                          • afuerhoff
                                            afuerhoff Developer @guergen last edited by afuerhoff
                                            @guergen
                                            Ich frage deshalb, weil der Fehler schon mal aufgetreten ist. Dann kommt er bei dir aber wirklich durch den Alias. Es sollte dann kein History Eintrag vom Vortag vorhanden sein.
                                            Das mit dem Alias muss ich mal bei mir testen.
                                            SBorg G 2 Replies Last reply Reply Quote 0
                                            31.7k
                                            79.8k
                                            avm fb-checkpresence fritzbox soap tr-064
                                            26
                                            259
                                            27696
