    4. JavaScript
    5. Sonoff Geräte als HTML Tabelle - Vis
    • Chaot
      Chaot @liv-in-sky last edited by
      @liv-in-sky
      Jetzt läuft gar nichts mehr:
      Script:
      Text Document (neu).txt
      Fehler:
      javascript.0	2020-02-09 16:26:29.834	error	(32723) at Script.runInContext (vm.js:133:20)
      javascript.0	2020-02-09 16:26:29.834	error	(32723) at script.js.Systeminfo.Tasmota1:1517:3
      javascript.0	2020-02-09 16:26:29.834	error	(32723) at writeHTML (script.js.Systeminfo.Tasmota1:444:31)
      javascript.0	2020-02-09 16:26:29.834	error	(32723) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:867:29)
      javascript.0	2020-02-09 16:26:29.834	error	(32723) at script.js.Systeminfo.Tasmota1:460:159
      javascript.0	2020-02-09 16:26:29.832	error	(32723) TypeError: Cannot read property 'toString' of null
      javascript.0	2020-02-09 16:26:29.832	error	(32723) ^
      javascript.0	2020-02-09 16:26:29.831	error	(32723) for (var i=0;i<powArr.length;i++ ) {if (powArr[i].indexOf(ida[0]+"."+ida[1]+"."+ida[2])>-1) {val7_1=getState(id.replace("INFO.Module","POWER")).val.toString();} }
      javascript.0	2020-02-09 16:26:29.831	error	(32723) script.js.Systeminfo.Tasmota1: script.js.Systeminfo.Tasmota1:460
      javascript.0	2020-02-09 16:26:29.830	warn	(32723) at script.js.Systeminfo.Tasmota1:1517:3
      javascript.0	2020-02-09 16:26:29.830	warn	(32723) at writeHTML (script.js.Systeminfo.Tasmota1:444:31)
      javascript.0	2020-02-09 16:26:29.830	warn	(32723) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:867:29)
      javascript.0	2020-02-09 16:26:29.830	warn	(32723) at script.js.Systeminfo.Tasmota1:460:112
      javascript.0	2020-02-09 16:26:29.828	warn	(32723) getState "sonoff.0.DVES_A07498.POWER" not found (3) states[id]=null
      ? liv-in-sky 2 Replies Last reply Reply Quote 0
        A Former User @Chaot last edited by
        @Chaot hast du ein neues Gerät eingebunden und dann in web Oberfläche den Namen geändert?
        Chaot 2 Replies Last reply Reply Quote 0
        • Chaot
          Chaot @Guest last edited by
          @HeinrichB Ja, da war was glaube ich.
          • Chaot
            @HeinrichB Danke für den Hinweis - scheint weg zu sein.
              liv-in-sky @Jeffy last edited by
              @Jeffy habe jetzt meinen mini geflasht und der wird unter den basics angezeigt - ohne das script zu ändern - bei mir steht Sonoff Basic in INFO.Module - ist das bei dir anders ?
                Jeffy @liv-in-sky last edited by
                @liv-in-sky Bei mir steht Sonoff Mini.
                  @Jeffy hat aber die selben datenpunkte wie der basic ?
                    @liv-in-sky Ich habe keinen basic zum Vergleichen.
                    Zum Testen habe ich gerade in der template-Konfiguration den Namen von Sonoff Mini auf Sonoff Basic geändert. Jetzt wird das Modul angezeigt.
                    Vielen Dank für deine Hilfe.
                      liv-in-sky @Jeffy last edited by liv-in-sky
                      @Jeffy ich werde trotzdem den mini dazu nehmen mit eigener überschrift - das liegt sicher am flashvogang - ich habe das diy genommen - da wird wohl basic gewählt - aber fürs erste funktioniert es ja - im nächsten update ist es dann drin
                        liv-in-sky last edited by liv-in-sky
                        UPDATE (mit dank an ( @GiuseppeS @HeinrichB @apollon77 )
                        ( @Jeffy - mini ist drin, wenn in INFO.Module "Sonoff Mini" steht)
                        • ab jetzt kann man auch in der tabelle die POWERx datenpunkte schalten (einstellbar ob erwünscht) - leider habe ich es nicht für die file-ausgabe hinbekommen, aber in der vis (mit standard html-widget und binding) funktioniert es und auch mit fully browser
                        • es werden bei energiemessenden tasmotas heute und gestern (kWh) in einer spalte angezeigt (einstellbar ob erwünscht)
                        • bei 2 oder 3 sonoffarten wurde nochmal nachgearbeitet, was die darstellung der power schalter betrifft
                        //@liv-in-sky Januar 2020 Ver 08.0219:20
                        //HIER WIRD PFAD UND FILENAME DEFINIERT
                        const path = "/htmlsonoff.html";                   //FIlenamen definieren
                        const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
                        let   braucheEinFile=true;                          // bei true wird ein file geschrieben
                        let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
                        let dpVIS="controll-own.0.TABELLEN.SONOFF"         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
                        let dpAnzahl="controll-own.0.TABELLEN.AnzahlSonoff";  //WICHTIG datenpunkt erstellen vom typ "number" - bei 0 kein alarm und größer 0 die anzahl der schlechten batterien
                        let htmlColorDeviceUeberschrift="white"            //  Farbe der Geräte Marken
                        let HTMLbrandSetting="b"                              // style der geräte marken:  möglich b fett; i kursiv; span normal
                        let triggerBySonoffPower=false;
                        // ------------------------    hier einstellen, was man für ein device  hat - die nicht gebraucht werden auf false setzen !!!
                        var pow=true;
                        var generic=true;            var genericMitDiv=true;   // anzeige mit DIVersen Sensoren
                        var th10=true;
                        var basic=true;              var basicMitTemp=true;    // anzeige mit DIVersen Sensoren
                        var mini=true;
                        var th10=true;
                        var externalMitInfo=false; //noch nicht integriert
                        var externalOhneInfo=false;  //noch nicht integriert
                        var schalter2ch=true;
                        var schalter3ch=true;
                        var dual=true;
                        var schalter1ch=true;
                        var channel4=true;             //Sonoff 4CH
                        var rfbridge=true;
                        var stdoseS2X=true;
                        var teckin=true;
                        var sv=true;
                        var blitzwolf_shp=true;
                        var sonoffDev=true;
                        var gosundSP1x=true;
                        var shelly=true;
                        var ohneInfo=true;             // bei manchen fehlt der INFO ordner - diese werden hier erfasst
                        //Sonderfall
                        var linganSteckdose =true;
                        var mitSchalter=true;           // für freigabe von schaltern für POWER
                        var mitYesterday=true;          // Für anzeige der yestersay werte bei energie-aufzeichnenden geräten (poe, blitzwolf, teckin, ..)
                        var symbolOK="🟢";  // auch möglich: ="✅"}
                        var symbolKO="🔴";     //z.b. auch "<font color=\"red\"><b>X</b>" für ein rotes kreuz ❌"  ⚪  ⚫ ⭕  🔴 🔵 ⏱ 💀 👍 👎 📑 💲 👀
                        var symbolWARN="⚠️";    // ="⚠️"
                        var symbolSwitch="🔄"
                        let mySchedule="  * * * * * ";
                        //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 5
                        var htmlFeld1='Device';       var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
                        var htmlFeld2='Status';        var Feld2lAlign="center";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
                        var htmlFeld3='Version';         var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
                        var htmlFeld4='WLAN';        var Feld4lAlign="right";                    // überschrift Tabellen Spalte4 und  Ausrichtung left,right or center
                        var htmlFeld5='IP';        var Feld5lAlign="left";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                        var htmlFeld6='';        var Feld6lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                        var htmlFeld7='';        var Feld7lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                        var htmlFeld8='';        var Feld8lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                        //hier werden die styles für die tabelle definiert
                        //ÜBERSCHRIFT ÜBER TABELLE
                        let   htmlUberschrift=true;                           // mit Überschrift über der tabelle
                        let   htmlSignature=true;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
                        const htmlFeldUeber='Sonoff Devices';              // Überschrift und Signature
                        const htmlFarbUber="white";                         // Farbe der Überschrift
                        const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
                        const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
                        //MEHRERE TABELLEN NEBENEINANDER
                        let   mehrfachTabelle=1;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
                        const trennungsLinie="2";                             //extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
                        const farbetrennungsLinie="white";
                        const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
                        const htmlFarbTableColorUber="#BDBDBD";               // Überschrift in der tabelle - der einzelnen Spalten
                        //ÜBERSCHRIFT SPALTEN
                        const UeberSchriftHöhe="35";                          //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
                        const LinieUnterUeberschrift="2";                   // Linie nur unter Spaltenüberschrift -
                        const farbeLinieUnterUeberschrift="white";
                        const groesseUeberschrift=16;
                        const UeberschriftStyle="normal"                     // möglich "bold"
                        //GANZE TABELLE
                        let abstandZelle="1";
                        let farbeUngeradeZeilen="#000000";                     //Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                        let farbeGeradeZeilen="#151515";                        //Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                        let weite="auto";                                     //Weite der Tabelle
                        let zentriert=true;                                   //ganze tabelle zentriert
                        const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
                        const htmlSchriftart="Helvetica";
                        const htmlSchriftgroesse="14px";
                        //FELDER UND RAHMEN
                        let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
                        const htmlFarbFelderschrift="#BDBDBD";                  // SchriftFarbe der Felder
                        const htmlFarbFelderschrift2="#D8D8D8";                 // SchriftFarbe der Felder für jede 2te Tabelle
                        const htmlFarbTableColorGradient1="#1c1c1c";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
                        const htmlFarbTableColorGradient2="#1c1c1c";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                        const htmlFarbTableBorderColor="grey";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                        let htmlRahmenLinien="cols";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                        const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
                        // HIER NICHTS  ÄNDERN
                        let borderHelpBottum;
                        let borderHelpRight;
                        let htmlcenterHelp;
                        let htmlcenterHelp2;
                        if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
                        if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
                        if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
                        if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
                        zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
                        zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
                        const htmlZentriert='<center>'
                        const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                                         "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                                         " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                                        // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                                         " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                                         " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                                         "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                                         " </style></head><body> <div>";
                        //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
                        const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                            "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
                        const htmlTabUeber1="<tr height=\""+UeberSchriftHöhe+"\" style=\"color:"+htmlFarbTableColorUber+"; font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+" ;  border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+" \">";
                        const htmlTabUeber3="</tr>";
                        //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 5
                        const buttonScript =  '<script> function setOnDblClickCustom( myvalue ) {	var Self = this; var objID = myvalue;	Self.servConn.getStates(objID, (error, states) => {  console.log(states);  Self.servConn.setState(objID, !states[objID].val); }); } </script>'
                        var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+htmlFeld4+"&ensp;</td><td  align="+Feld5lAlign+">&ensp;"+htmlFeld5+"&ensp;</td><td  align="+Feld6lAlign+">&ensp;"+htmlFeld6+"&ensp;</td><td  align="+Feld7lAlign+">&ensp;"+htmlFeld7+"&ensp;</td><td  align="+Feld8lAlign+">&ensp;"+htmlFeld8+"&ensp;</td>";
                        var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+
                                           "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld4+
                                           "&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld5+"&ensp;</td><td align="+Feld6lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld6+"&ensp;</td><td align="+Feld7lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld7+"&ensp;</td><td align="+Feld8lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld8+"&ensp;</td>";
                        let triggerBySonoffSwitch=false;
                        var anzahl;
                        var AkkuAlarm=[];
                        var htmlOut="";
                        var mix;
                        var counter;
                        var arrTrigger=[];
                        var val1; var val2; var val0; var val3; var val4; var val5; var val6; var val7;
                        var htmlTabUeber="";
                        if (mitSchalter) triggerBySonoffPower=true;
                        function writeHTML(){
                        anzahl=0;
                        htmlOut="";
                        counter=-1;
                        htmlTabUeber="";
                        switch (mehrfachTabelle) {
                           case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
                           case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                           case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2+htmlTabUeber2+htmlTabUeber3; break;
                           case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                        if (!UeberschriftSpalten) {htmlTabUeber=""}
                        //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
                        //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2,val3,val4!!!------------------------------------------------------------
                        if (triggerBySonoffPower) {
                         $('sonoff.*.*.POWER*').each(function(id, i) {           // trigger für power datenpunkte  !!!
                                //log(id)
                                arrTrigger.push(id) });}
                          if (triggerBySonoffSwitch) {
                         $('sonoff.*.*.Switch*').each(function(id, i) {           // trigger für power datenpunkte  !!!
                                //log(id)
                        //log(arrTrigger.toString())
                        var myColl=[];
                        var val1help;
                         var tempArr=[];var humArr=[];var illArr=[];var sw1Arr=[];var sw2Arr=[];var irArr=[];;var powArr=[];
                         $('sonoff.*.*.*').each(function(id, i) {   var ida = id.split('.'); if(ida[3].indexOf("_Temperature")>-1) tempArr.push(id);
        if(ida[3].indexOf("_Humidity")>-1)  humArr.push(id);
        if(ida[3].indexOf("_Illuminance")>-1) illArr.push(id);
        if(ida[3].indexOf("POWER1")>-1) sw1Arr.push(id);
        if(ida[3].indexOf("POWER2")>-1) sw2Arr.push(id);
        if(ida[3].indexOf("IrReceived_Data")>-1) irArr.push(id);
        if(ida[3].match(/POWER$/)!=null) powArr.push(id);
                        //log(tempArr.toString());  log(humArr.toString()) ;   log(illArr.toString()) ;    log(sw1Arr.toString());     log(sw2Arr.toString())
                        //log(powArr.toString())
                          if (pow){
                                    counter=-1;
                                     for(var i=0;i<mehrfachTabelle;i++ ) {
                                       val0=""; val1=""; val2="";val3="";val4="";val5="";val6="";val7="";counter++;tabelleBind();
                                   //  tabelleMachSchoen()
                                         if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Sonoff Pow (R2)</b>";} else{val0=""; }
                                          val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">kWh Gesamt";
                                          if (mitYesterday) {val6="<font color=\""+htmlColorDeviceUeberschrift+"\">kWh Heute(Gestern)";} else {val6="<font color=\""+htmlColorDeviceUeberschrift+"\">kWh Heute";}
                                          val7="<font color=\""+htmlColorDeviceUeberschrift+"\">Power";
                        //sonoff.0.SonoffPow1.INFO.Module
                         $('sonoff.*.*.INFO.Module').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                              if (getState(id).val=="Sonoff Pow" || getState(id).val=="Sonoff Pow R2") {
                                 // log (id)
                                 anzahl++;
                                  counter++;
                                  val1=getState(id.replace("INFO.Module","alive")).val;
                                  val0=getObject(ida[0]+"."+ida[1]+"."+ida[2]).common.name ;
                                  val4=getState(id.replace("Module","IPAddress")).val
                                  val2=getState(id.replace("Module","Version")).val.replace(/\(.+\)/g,"")
                                  val3=getState(id.replace("INFO.Module","Wifi_RSSI")).val.toString()+" %";
                                   // val7 definition
                                   ichWillSchalten(id);
                                  if (mitYesterday) {      var val6_1=getState(id.replace("INFO.Module","ENERGY_Yesterday")).val
                                                           val6=(getState(id.replace("INFO.Module","ENERGY_Today")).val.toString())+" ("+val6_1.toString()+")";}
                                                    else  {val6=getState(id.replace("INFO.Module","ENERGY_Today")).val.toString();}
                                  val5=getState(id.replace("INFO.Module","ENERGY_Total")).val.toString();
                                  inaktiv(id);
                             tabelleBind();
                        } //ende fritzdect
                          if (gosundSP1x){
                        tabelleAusbessern()
                                              counter=-1;
                                         if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Gosund</b>";} else{val0=""; }
                              if (getState(id).val.includes("Gosund SP1")) {
                                 // log (id)
                                 anzahl++;
                                  counter++;
                                  // val7 definition
                                    inaktiv(id);
                             tabelleBind();
                        } //ende fritzdect
                        if (teckin){
                        tabelleAusbessern()
                                                            counter=-1;
                                         if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Teckin</b>";} else{val0=""; }
                              if (getState(id).val=="Teckin") {
                                 // log (id)
                                 anzahl++;
                                  counter++;
                                  // val7 definition
                                    inaktiv(id);
                             tabelleBind();
                        } //ende fritzdect
                            if (blitzwolf_shp){
                        tabelleAusbessern()
        counter=-1;
                                         if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">BlitzWolf SHP</b>";} else{val0=""; }
                              if (getState(id).val=="BlitzWolf SHP") {
                                 // log (id)
                                 anzahl++;
                                  counter++;
                                //  let val7_1=getState(id.replace("INFO.Module","ENERGY_Yesterday")).val.toString();
                                 // val7_1 ? val7=(" <font color=\"lightgreen\"> ")+"ON" : val7=(" <font color=\"red\"> ")+"OFF";
                                  // val7 definition
                                    inaktiv(id);
                             tabelleBind();
                        } //ende fritzdect
                         if (generic){
                        tabelleAusbessern()
        counter=-1;
                                         if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Generic</b>";} else{val0=""; }
                                          val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">Div";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">Power";counter++;tabelleBind();
                                        if (genericMitDiv) {val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">Div";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">Power"}
                              if (getState(id).val=="Generic") {
                                 //log (id)
                                 anzahl++;
                                  counter++;
                                  val5=getState(id.replace("INFO.Module","Uptime")).val.toString()
                                  val7=" - "; var val7_1="finde"
                                 // let val7_1=getState(id.replace("INFO.Module","POWER")).val;
                                   if (val7_1!="finde")    ichWillSchalten(id); // val7 definition
                                 //getState(id.replace("INFO.Module","POWER")).val ? val7=(" <font color=\"lightgreen\"> ")+"ON" : val7=(" <font color=\"red\"> ")+"OFF";
                                  val6="  ";
                                 if (genericMitDiv) { var val6_1="";var val6_2="";
                                  //-----------------------------TEMP
                                  var val6help="xxx";
                                  for (var i=0;i<tempArr.length;i++ ) {if (tempArr[i].indexOf(ida[0]+"."+ida[1]+"."+ida[2])>-1) val6help=tempArr[i]}
                               //  log(val6help)
                                  if (val6help != "xxx") {val6_1=getState(val6help).val+" °C"} else {val6_1=""}
                                  //-----------------------------HUM
                                  var val6help1="xxx";
                                  for (var i=0;i<humArr.length;i++ ) {if (humArr[i].indexOf(ida[0]+"."+ida[1]+"."+ida[2])>-1) val6help1=humArr[i]}
                                  //log(val6help1)
                                  if (val6help1 != "xxx") {val6_2=(getState(val6help1).val)+" %"} else {val6_2=""}
                                  val6=val6_1+" / "+val6_2; if (val6 == " / ") val6=" - ";
                               //   log (val6 +" id: "+ id)
                                  //-----------------------------ILLuminance
                                  var val6help="xxx";
                                  for (var i=0;i<illArr.length;i++ ) {if (illArr[i].indexOf(ida[0]+"."+ida[1]+"."+ida[2])>-1) val6help=illArr[i]}
                                  if (val6help != "xxx") {val6=getState(val6help).val+" lux"}
                                  //-----------------------------POWER1
                                  var val6help="xxx";
                                  for (var i=0;i<sw1Arr.length;i++ ) {if (sw1Arr[i].indexOf(ida[0]+"."+ida[1]+"."+ida[2])>-1) val6help=sw1Arr[i]}
                                  if (val6help != "xxx") {if (getState(val6help).val){val6_1="ON"} else {val6_1="OFF"}}
                                  //-----------------------------POWER2
                                  for (var i=0;i<sw2Arr.length;i++ ) {if (sw2Arr[i].indexOf(ida[0]+"."+ida[1]+"."+ida[2])>-1) val6help1=sw2Arr[i]}
                                  //log(val6help1)
                                  if (val6help1 != "xxx") {if (getState(val6help1).val) {val6_2="ON"} else {val6_2="OFF"}
                                  val6=val6_1+" / "+val6_2; if (val6 == " / ") val6=" - ";}
                               //   log("2er: "+val6)
                                  //-----------------------------IR EMPFANG
                                   var val6help="xxx";
                                  for (var i=0;i<irArr.length;i++ ) {if (irArr[i].indexOf(ida[0]+"."+ida[1]+"."+ida[2])>-1) val6help=irArr[i]}
                                  if (val6help != "xxx") {val6=getState(val6help).val}
                                    inaktiv(id);
                             tabelleBind();
                         } //ende xiaomi
                        if (basic){
                              tabelleAusbessern()
                                                      counter=-1;
                                         if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Basic</b>";} else{val0=""; }
                              if (getState(id).val=="Sonoff Basic") {
                               //  log (id)
                               anzahl++;
                                  counter++;
                                  ichWillSchalten(id)
                                  val6="  ";
                                 if (basicMitTemp) {var val6_1="";var val6_2="";
                                  var val6help="xxx";
                                 // log(val6help)
                                 // log(val6help1)
                                  var val6help="xxx";
                                  var val6help="xxx";
                                  //log(val6help1)
                                   var val6help="xxx";
                                    inaktiv(id);
                             tabelleBind();
                         } //ende xiaomi
                          if (mini){
                                      tabelleAusbessern()
                             counter=-1;
                                         if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Mini</b>";} else{val0=""; }
                                          val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">Power";counter++;tabelleBind();
                              if (getState(id).val=="Sonoff Mini") {
                               //  log (id)
                               anzahl++;
                                  counter++;
                                  ichWillSchalten(id)
                                  val6=""
                                    inaktiv(id);
                             tabelleBind();
                         } //ende xiaomi
                          if (th10){
                                      tabelleAusbessern()
                                                      counter=-1;
                                         if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">TH10/TH16</b>";} else{val0=""; }
                                          val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">Temp/Hum";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">Power";counter++;tabelleBind();
                              if (getState(id).val=="Sonoff TH") {
                               //  log (id)
                               anzahl++;
                                  counter++;
                                  ichWillSchalten(id)
                                  var val6help="xxx";
                                  //log (val6)
                                  val6=val6_1+" / "+val6_2; if (val6 == "") val6=" - ";
                                    inaktiv(id);
                             tabelleBind();
                         } //ende xiaomi
                         if (shelly){
                                      tabelleAusbessern()
                             counter=-1;
                                         if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Shelly</b>";} else{val0=""; }
                              if (getState(id).val=="Shelly 1" || getState(id).val=="Shelly 1PM" || getState(id).val=="Shelly 2.5" || getState(id).val=="Shelly 2") {
                               //  log (id)
                               anzahl++;
                                  counter++;
                                  ichWillSchalten(id)
                                  val6=""
                                    inaktiv(id);
                             tabelleBind();
                         } //ende xiaomi
                          if (schalter1ch){
                                  tabelleAusbessern()
                              counter=-1;
                                         if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Scalter T1 CH</b>";} else{val0=""; }
                              if (getState(id).val=="Sonoff T1 1CH" || getState(id).val=="1 Channel" ) {
                               //  log (id)
                               anzahl++;
                                  counter++;
                                 ichWillSchalten(id)
                                val6="";
                                    inaktiv(id);
                             tabelleBind();
                         } //ende xiaomi
                        if (schalter2ch){
                                    tabelleAusbessern()
                              counter=-1;
                                         if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Schalter T2 CH</b>";} else{val0=""; }
                                          val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">Power 1";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">Power 2";counter++;tabelleBind();
                              if (getState(id).val=="Sonoff T1 2CH") {
                               //  log (id)
                               anzahl++;
                                  counter++;
                                  let val6_1; val6_1=getState(id.replace("INFO.Module","POWER1")).val;
                                  val6_1 ? val6=(" <font color=\"lightgreen\"> ")+"ON" : val6=(" <font color=\"red\"> ")+"OFF";
                                  if (mitSchalter){
                                  let valButton=id.replace("INFO.Module","POWER1")
                                  val6_1 ? val6=(" <font color=\"lightgreen\"> ")+"ON" +"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom\(\'"+valButton+"\')\">"+symbolSwitch+"</button>" :
                                  val6=(" <font color=\"red\"> ")+"OFF"+"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom\(\'"+valButton+"\')\">"+symbolSwitch+"</button>";
                                  } else {val6_1 ? val6=(" <font color=\"lightgreen\"> ")+"ON" : val6=(" <font color=\"red\"> ")+"OFF";}
                                  let val7_1; val7_1=getState(id.replace("INFO.Module","POWER2")).val;
                                  if (mitSchalter){
                                  let valButton=id.replace("INFO.Module","POWER2")
                                  val7_1 ? val7=(" <font color=\"lightgreen\"> ")+"ON" +"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom\(\'"+valButton+"\')\">"+symbolSwitch+"</button>" :
                                  val7=(" <font color=\"red\"> ")+"OFF"+"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom\(\'"+valButton+"\')\">"+symbolSwitch+"</button>";
                                  } else {val7_1 ? val7=(" <font color=\"lightgreen\"> ")+"ON" : val7=(" <font color=\"red\"> ")+"OFF";}
                                    inaktiv(id);
                             tabelleBind();
                         } //ende xiaomi
                            if (schalter3ch){
                                     tabelleAusbessern()
                              counter=-1;
                                         if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Schalter T3 CH</b>";} else{val0=""; }
                                          val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">Power 1/2";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">Power 3";counter++;tabelleBind();
                              if (getState(id).val=="Sonoff 3CH" ) {
                               //  log (id)
                               anzahl++;
                                  counter++;
                                  let val5_0; let val5_1; val5_1=getState(id.replace("INFO.Module","POWER1")).val;
                                  val5_1 ? val5_0=(" <font color=\"lightgreen\"> ")+"ON" : val5_0=(" <font color=\"red\"> ")+"OFF";
                                  if (mitSchalter){
                                  val5_1 ? val5_0=(" <font color=\"lightgreen\"> ")+"ON" +"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom\(\'"+valButton+"\')\">"+symbolSwitch+"</button>" :
                                  val5_0=(" <font color=\"red\"> ")+"OFF"+"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom\(\'"+valButton+"\')\">"+symbolSwitch+"</button>";
                                  } else {val5_1 ? val5_0=(" <font color=\"lightgreen\"> ")+"ON" : val5_0=(" <font color=\"red\"> ")+"OFF";}
                                  if (mitSchalter){
                                  ichWillSchalten(id)
                                  val6= val5_0+"&ensp;"+val6;
                                    inaktiv(id);
                             tabelleBind();
                        } // ende ch4
                            if (channel4){
                                         tabelleAusbessern()
                              counter=-1;
                                         if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Schalter 4CH</b>";} else{val0=""; }
                                          val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">Power 1/2";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">Power 3/4";counter++;tabelleBind();
                              if (getState(id).val.includes("Sonoff 4CH") ) {
                               //  log (id)
                               anzahl++;
                                  counter++;
                                  let val4_0; let val4_1; val4_1=getState(id.replace("INFO.Module","POWER1")).val;
                                  val4_1 ? val4_0=(" <font color=\"lightgreen\"> ")+"ON" : val4_0=(" <font color=\"red\"> ")+"OFF";
                                  if (mitSchalter){
                                  val4_1 ? val4_0=(" <font color=\"lightgreen\"> ")+"ON " +"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom\(\'"+valButton+"\')\">"+symbolSwitch+"</button>" :
                                  val4_0=(" <font color=\"red\"> ")+"OFF"+"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom\(\'"+valButton+"\')\">"+symbolSwitch+"</button>";
                                  } else {val4_1 ? val4_0=(" <font color=\"lightgreen\"> ")+"ON" : val4_0=(" <font color=\"red\"> ")+"OFF";}
                                  let val5_0; let val5_1; val5_1=getState(id.replace("INFO.Module","POWER2")).val;
                                  if (mitSchalter){
                                  val5_1 ? val5_0=(" <font color=\"lightgreen\"> ")+"ON " +"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom\(\'"+valButton+"\')\">"+symbolSwitch+"</button>" :
                                  let val6_0; let val6_1; val6_1=getState(id.replace("INFO.Module","POWER3")).val;
                                  val6_1 ? val6_0=(" <font color=\"lightgreen\"> ")+"ON" : val6_0=(" <font color=\"red\"> ")+"OFF";
                                  if (mitSchalter){
                                  let valButton=id.replace("INFO.Module","POWER3")
                                  val6_1 ? val6_0=(" <font color=\"lightgreen\"> ")+"ON " +"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom\(\'"+valButton+"\')\">"+symbolSwitch+"</button>" :
                                  val6_0=(" <font color=\"red\"> ")+"OFF"+"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom\(\'"+valButton+"\')\">"+symbolSwitch+"</button>";
                                  } else {val6_1 ? val6_0=(" <font color=\"lightgreen\"> ")+"ON" : val6_0=(" <font color=\"red\"> ")+"OFF";}
                                  let val7_0; let val7_1; val7_1=getState(id.replace("INFO.Module","POWER4")).val;
                                  val7_1 ? val7_0=(" <font color=\"lightgreen\"> ")+"ON" : val7_0=(" <font color=\"red\"> ")+"OFF";
                                  if (mitSchalter){
                                  let valButton=id.replace("INFO.Module","POWER4")
                                  val7_1 ? val7_0=(" <font color=\"lightgreen\"> ")+"ON " +"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom\(\'"+valButton+"\')\">"+symbolSwitch+"</button>" :
                                  val7_0=(" <font color=\"red\"> ")+"OFF"+"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom\(\'"+valButton+"\')\">"+symbolSwitch+"</button>";
                                  } else {val7_1 ? val7_0=(" <font color=\"lightgreen\"> ")+"ON" : val7_0=(" <font color=\"red\"> ")+"OFF";}
                                  val6= val4_0+""+val5_0;
                                  val7= val6_0+""+val7_0;
                                    inaktiv(id);
                             tabelleBind();
                        } // ende ch4
                          if (dual){
                                       tabelleAusbessern()
                             counter=-1;
                                         if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Dual (R2)</b>";} else{val0=""; }
                              if (getState(id).val=="Sonoff Dual" || getState(id).val=="Sonoff Dual R2") {
                               //  log (id)
                               anzahl++;
                                  counter++;
                                  if (mitSchalter){
                                  val6_1 ? val6=(" <font color=\"lightgreen\"> ")+"ON " +"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom\(\'"+valButton+"\')\">"+symbolSwitch+"</button>" :
                                  if (mitSchalter){
                                  val7_1 ? val7=(" <font color=\"lightgreen\"> ")+"ON " +"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom\(\'"+valButton+"\')\">"+symbolSwitch+"</button>" :
                                  inaktiv(id);
                             tabelleBind();
                         } //ende xiaomi
                        if (stdoseS2X){
                                      tabelleAusbessern()
                             counter=-1;
                                         if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Steckdose S2x</b>";} else{val0=""; }
                              if (getState(id).val=="Sonoff S2X"  ) {
                               //  log (id)
                               anzahl++;
                                  counter++;
                                   ichWillSchalten(id)
                                  val6=""
                                    inaktiv(id);
                             tabelleBind();
                         } //ende xiaomi
                        if (linganSteckdose){
                                        tabelleAusbessern()
                              counter=-1;
                                         if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Lingan Steckdose</b>";} else{val0=""; }
                              if (getState(id).val=="Lingan SWA1") {
                               //  log (id)
                                  anzahl++;
                                  counter++;
                                  val3="na";
                                  val5="na";
                                  ichWillSchalten(id)
                                  val6=""
                                   inaktiv(id);
                             tabelleBind();
                         } //ende xiaomi
                        if (rfbridge){
                                       tabelleAusbessern()
                              counter=-1;
                                         if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">RF Bridge</b>";} else{val0=""; }
                                          val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">Received";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">Power";counter++;tabelleBind();
                              if (getState(id).val=="Sonoff Bridge") {
                               //  log (id)
                               anzahl++;
                                  counter++;
                                   ichWillSchalten(id)
                                  val6=getState(id.replace("INFO.Module","RfReceived_Data")).val;
                                  inaktiv(id);
                             tabelleBind();
                         } //ende xiaomi
                         if (ohneInfo){
                                        tabelleAusbessern()
                             counter=-1;
                                         if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Sonderfälle ohne Info</b>";} else{val0=""; }
                        var arrFilt=[];
                         $('sonoff.*.*').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                                //  log(ida[0]+"."+ida[1]+"."+ida[2]+"."+"INFO.IPAddress")
                                  $(ida[0]+"."+ida[1]+"."+ida[2]+"."+"INFO.IPAddress").each(function(id, i) {   // kontrolliere ob  vorhanden
                                      var idc = id.split('.');
                                      if(!arrFilt.includes(idc[2])){
                                    //  log(idc[2])
                                   arrFilt.push(idc[2])}
                         $('sonoff.*.*.alive').each(function(id, i) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                           //log(ida[2])
                              //  log (" hier die werte: "+id)
                            //  if (filterArray.includes) {
                                  if (!arrFilt.includes(ida[2])) {
                              //   log (id)
                               anzahl++;
                                  counter++;
                                  val1=getState(id).val;
                                  val4=" na ";
                                  val2=" na ";
                                  val3="na";
                                  val5="na";
                                  val7="na"
                                  ida[2].includes("Bridge") ?  val6=getState(id.replace("alive","RfReceived_Data")).val : val6="";
                                  inaktiv(id);
                             tabelleBind();
                         } //ende xiaomi
                          if (sv){
                                        tabelleAusbessern()
                              counter=-1;
                                         if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Sonoff SV</b>";} else{val0=""; }
                                          val1=""; val2="";val3="";val4="";val5="<font color=\""+htmlColorDeviceUeberschrift+"\">Uptime";val6="<font color=\""+htmlColorDeviceUeberschrift+"\">";val7="<font color=\""+htmlColorDeviceUeberschrift+"\">";counter++;tabelleBind();
                              if (getState(id).val=="Sonoff SV") {
                               //  log (id)
                               anzahl++;
                                  counter++;
                                  val7="";
                                  val6=""
                                    inaktiv(id);
                             tabelleBind();
                         } //ende xiaomi
                            if (sonoffDev){
                                        tabelleAusbessern()
                             counter=-1;
                                         if(i==0){val0="<font color=\""+htmlColorDeviceUeberschrift+"\"><"+HTMLbrandSetting+">Sonoff Dev</b>";} else{val0=""; }
                              if (getState(id).val=="Sonoff Dev") {
                               //  log (id)
                               anzahl++;
                                  counter++;
                                  val7="";
                                  //val7=getState(id.replace("INFO.Module","ENERGY_Total")).val.toString();
                                  val6=""
                                    inaktiv(id);
                             tabelleBind();
                         } //ende xiaomi
                        //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                            tabelleFinish(); // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
                            setState(dpAnzahl,anzahl);
                        } // function ende
                        //MAIN:
                        schedule(mySchedule,  function () {
                         writeHTML();
                         if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                         writeHTML();
                           				 function tabelleBind(){
                             //HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT - hat man oben 5 Felder definiert, braucht man hier 5 Werte
                                 case 1:  if(counter%2==0){  htmlOut=htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td></tr>"; break;} else
                                                          {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td></tr>"; break;}
                                case 2:  if(counter%4==0) {
                                          if(counter%2==0)            {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td>"; }
                                                      else {htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val7+"&ensp;</td></tr>";} break;
                                               }else{
                                          if(counter%2==0)            {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td>"; }
                                                      else {htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val7+"&ensp;</td></tr>";} break;}
                                case 3: if(counter%2==0 ) {
                                           if(counter%3==0)           {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td>"; }
                                                      else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val6+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td>";}
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td></tr>";}
        } break; }else{
                                           if(counter%3==0)                {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td>"; }
                                                      else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"; color:"+htmlFarbFelderschrift2+"\">&ensp;"+val7+"&ensp;</td>";}
        } break;      }
                                case 4: if(counter%8==0)  {
                                           if(counter%4==0)               {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td>"; }
                                                          else {if(counter%4==1 )  { htmlOut = htmlOut+"<td  align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+" style=\border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"; color:"+htmlFarbFelderschrift2+"\">&ensp;"+val7+"&ensp;</td>";}
        else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\>&ensp;"+val7+"&ensp;</td></tr>";}
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td>&ensp;"+val1+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td>";}}
        } break;  }else{
                                           if(counter%4==0)               {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td>"; }
                                                          else {if(counter%4==1 )  { htmlOut = htmlOut+"<td  align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"; color:"+htmlFarbFelderschrift2+"\">&ensp;"+val7+"&ensp;</td>";}
        else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val7+"&ensp;</td></tr>";}
        } break;       }
                             } //switch ende
                        function tabelleAusbessern() {
                               case 1:    break;
                               case 2:
                                         if(counter%2==0)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                          break;
                               case 3:   if(counter%3==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                         if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                         if(counter%3==0)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                          break;
                               case 4:   if(counter%4==3)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                         if(counter%4==2)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                         if(counter%4==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                         if(counter%4==0)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                         break; }
                        function tabelleFinish() {
                               case 1:    break;
                               case 2:
                                          if(counter%2==0) { htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');   }
                                          break;
                                          break;
                                         break; }
                              // tabelle fertigstellen
                                            var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss")+"&ensp;&ensp;Anzahl: "+anzahl+"</p>";
                               var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss")+"&ensp;&ensp;Anzahl: "+anzahl+"</div>"
                                if (!htmlSignature) htmlUnter="";
                                  //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                                   var htmlOutVIS="";
                                 //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                                    if (htmlUberschrift)
                                        { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" + "bla bla"+htmlUnter + buttonScript;
                                         // log(htmlOutVIS)
                                      } else {
                                       zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>" + "blabla"+htmlUnter+ buttonScript ;
                        // log("bin raus aus tabelleBind");
                                   if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
                         var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                         var htmlEnd="</table>"+htmlUnter+"</div></body>";
                        //log(buttonScript)
                         //mit oder ohne überschrift - zentriert oder links
                        htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+buttonScript+htmlEnd+buttonScript : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+buttonScript+htmlEnd+buttonScript;
                         //log(htmlOut);
                            on({id: arrTrigger, ack: false, change: "any"}, function (obj) {
                              // log("TRIGGERED");
                            writeHTML();
                        function ichWillSchalten(id) {
                           let val7_1; val7_1=getState(id.replace("INFO.Module","POWER")).val;
                                  if (mitSchalter){
                                  let valButton=id.replace("INFO.Module","POWER")
                        function inaktiv(id) {
                           if (!getState(id.replace("INFO.Module","alive")).val) {
                        val1=symbolKO;
                                      val4=("<font color=\"red\">")+val4;
                                      val2=("<font color=\"red\">")+val2;
                                      val3=("<font color=\"red\">")+" 0 %";
                                      val5=("<font color=\"red\">")+" --- ";
                                      val6=("<font color=\"red\">")+" --- ";
                                      val7=("<font color=\"red\">")+" --- ";
                                      val0=("<font color=\"red\">")+val0}
                                  else{
                                      val1=symbolOK;
                        bitte testen - erst dann kommt es in den ersten post
                        Glasfaser J 2 Replies Last reply Reply Quote 2
                        • Glasfaser
                          Glasfaser @liv-in-sky last edited by
                          @liv-in-sky
                          Sehr schön …..dein UPDATE 😉 👍
                            liv-in-sky @Chaot last edited by
                            @Chaot du hast in deinem sonoff.x ordner neue installiert - sonoff.0.DVES_A07498.POWER
                            bitte löschen und unnötige aufräumen - und script neu starten
                              Jeffy @liv-in-sky last edited by Jeffy
                              @liv-in-sky Danke für das schnelle Umsetzen und der Möglichkeit zum Schalten.
                              Habe auch noch etwas größere Steckdosen als die Gosund SP111. Sie heißen bei Am**on KLAS REMO und in INFO.Module steht "SWA11". Wenn ich den Namen in "Sonoff Basic" ändere tauchen sie in der Tabelle auf.
                              Ich habe aber noch folgendes Phänomen: Manche Steckdosen oder Module erscheinen zwar in der Tabelle mit Name, Version und IP-Adresse, der Status ist jedoch rot und bei WLAN erscheint 0%. Sie befinden sich aber im WLAN und sind auch erreichbar. Das betrifft sowohl die SP111 als auch die Sonoff Mini und die SWA11 (welche ich in Sonoff Basic umbenannt habe).
                                @Jeffy die sp111 : steht im INFO.Module "Gosund SWA11" oder nur "SWA11"
                                wegen dem anderen thema du solltest die nicht als basic nehmen - schreibe besser BlitzWolf SHP rein - die haben ja alle eine energie anzeige ? oder wenn sie alle eine energieanzeige haben brauche ich die genaue bezeichnung in INFO.Module
                                was soll ich machen (groß klein schreibung wichtig)
                                Gosund SP111
                                Gosund SWA11 oder nur SWA11
                                Sonoff Mini gibt es schon seit der letzten version - kann ich selbst nicht testen - die mini haben keine energieanzeige- daher diese als basic definieren - bei mir sind sie als basic drin
                                was steht in den datenpunkten bei denen , wo keine werte bzw 0 drinsteht - für z.b WLAN - sind d awerte drin und vorallem was steht im dp "alive"
                                der sonoff mini ist in der neuen version drin - ich habe die selber bei mir eingepflegt
                                  @liv-in-sky Hi, die Gosund-Steckdosen laufen schon in deinem Skript mit der Version 08.0219:20.
                                  Im INFO.Module steht bei den Gosund-Steckdosen: "Gosund SP111".
                                  Im INFO.Module steht bei den KLAS REMO-Steckdosen: "SWA11". Keine Energieanzeige.
                                  Ich habe jetzt mal alle Sonoff-Devices Ordner in javascript.0 gelöscht. Jetzt tauchen alle meine angeschlossenen Geräte im vis richtig auf. Allerdings sind die Sonoff-Devices Ordner in javascript.0 immer noch weg.
                                    @Jeffy
                                    ok also wenn die SWA11 keine energieanzeige haben, nehme ich sie standardmäßig in die basic kategorie mit auf - dann müßt ihr da nichts mehr umstellen oder willst du da eine eigene überschrift dafür ?
                                    die Gosund SP111 nehme ich in der Gosund kategorie auf
                                    die ordner kommen manchmal nach einem browser refresh - wären sie nicht im system, hättest du ein volles rotes log !
                                      habe nochmal ein update
                                      • mir ist erst jetzt aufgefallen, dass man ja die links zu den sonoff-web-interface mit einbeziehen könnte - kann auch abgeschalten werden - symbol vor ip-adresse öffnet popup
                                      • im design
                                        -farbe und style für nicht erreichbare sonoffs ist einstellbar
                                      • die schalter farben ON bzw OFF können mit farben belegt werden
                                      • distance-messer sind jetzt sichtbar für basics und generics
                                      es sind einige variablen im settingbereich dazugekommen - daher wäre es am besten , die settings von hand wieder anzupassen - direktes kopieren der settings von der letzten test version ist nicht möglich
                                      das script liegt im ersten post
                                      J Chaot 2 Replies Last reply Reply Quote 2
                                        @liv-in-sky HI, klasse Idee mit dem web-interface.
                                        Funktioniert. Fensterhöhe vom web-interface ist bei mir nur etwas zu klein, ab das kann man ja größer ziehen. Oder noch eine Variable einbauen, welche man definieren kann.
                                        Ist übrigens nur bei den Geräten mit Leistungsmessung zu klein. Bei den Anderen passt es.
                                        Übrigens: Der Sonoff-Devices Ordner im Verzeichnis javascript.0 ist immer noch leer. Keine Einträge drin. Aber dein script geht. Auch nach mehreren Neustarts vom Raspberry.
                                        Noch ein Vorschlag zum ersten post:
                                        • Vielleicht noch ein (einfaches) changelog der Versionen einfügen mit ner kurzen Beschreibung.
                                        • Sonoff Mini bei den bisher integrierten Devices eintragen
                                        • Chaot
                                          @liv-in-sky Schön geworden 👏
                                            @Jeffy das mit dem sonoff devices ordner verstehe ich nicht - was ist das für ein ordner
                                            es gibt 2 dp die du anlegen mußt und diese beiden dp müssen dann im script eingetragen werden
                                            javascript monitoring template
                                            34
                                            632
                                            130971
