Test Adapter ioBroker.backitup v3.1.x
@simatec
Fixer, Neustart, CCU-Backup und ioBroker Backup im Adapter angestossen, beide erfolgreich und ohne diese Error Meldung. War wohl vielleicht noch ein Überbleibsel meiner Installationsorgie.
Danke für die prompte Hilfe. -
ich habe mir den Adapter auch installiert (version 1.3.6). Aber irgendwie startet dieer ca. alle 30 s neu. Das steht in der Log-Datei:
undefined2020-02-07 21:32:36.605 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 24264 2020-02-07 21:32:36.613 - warn: backitup.0 (24197) Got terminate signal. Checking desired PID: 0 vs own PID 24197 2020-02-07 21:32:36.619 - warn: backitup.0 (24197) Got terminate signal. Checking desired PID: 24264 vs own PID 24197 2020-02-07 21:32:37.117 - info: backitup.0 (24197) terminating 2020-02-07 21:32:37.119 - info: backitup.0 (24197) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2020-02-07 21:32:37.641 - error: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (156) 2020-02-07 21:32:37.642 - info: host.raspberrypi Restart adapter system.adapter.backitup.0 because enabled 2020-02-07 21:32:40.496 - info: backitup.0 (24264) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.18.1 2020-02-07 21:32:40.599 - info: backitup.0 (24264) [iobroker] backup was activated at 02:00 every 1 day(s) 2020-02-07 21:33:07.668 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 24372 2020-02-07 21:33:07.675 - warn: backitup.0 (24264) Got terminate signal. Checking desired PID: 0 vs own PID 24264 2020-02-07 21:33:07.681 - warn: backitup.0 (24264) Got terminate signal. Checking desired PID: 24372 vs own PID 24264 2020-02-07 21:33:08.179 - info: backitup.0 (24264) terminating 2020-02-07 21:33:08.180 - info: backitup.0 (24264) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2020-02-07 21:33:08.701 - error: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (156) 2020-02-07 21:33:08.701 - info: host.raspberrypi Restart adapter system.adapter.backitup.0 because enabled 2020-02-07 21:33:11.955 - info: backitup.0 (24372) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.18.1 2020-02-07 21:33:12.014 - info: backitup.0 (24372) [iobroker] backup was activated at 02:00 every 1 day(s) 2020-02-07 21:33:37.131 - info: info.0 (26285) Popup news was read... 2020-02-07 21:33:38.714 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 24463 2020-02-07 21:33:38.719 - warn: backitup.0 (24372) Got terminate signal. Checking desired PID: 0 vs own PID 24372 2020-02-07 21:33:38.722 - warn: backitup.0 (24372) Got terminate signal. Checking desired PID: 24463 vs own PID 24372 2020-02-07 21:33:39.221 - info: backitup.0 (24372) terminating 2020-02-07 21:33:39.222 - info: backitup.0 (24372) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2020-02-07 21:33:39.745 - error: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (156)Das Backup wird per Nas/copy (Verbindungstyp) an meinen Qnap NAS übertragen (SMB 1 + Mount als root). Die Daten komme auch, aber ich habe das gefühl das diese Unvollstädnig sind, weil der Adapter ständig neu startet.
Ich kann damit leider gar nichts anfange... Könnt ihr mir einen Tipp geben?
@Nas007
So wie es im Log ausschaut, ist der Adapter zweimal gestartet. Stoppe den Adapter und starte ihn im Anschluss neu.
Sollte dies nicht helfen, starte mal dein komplettes System neu -
mal kurz etwas OT:
hab mir ne externe SSD an die Fritz gestöpselt und bin begeistert, das Backup wird samt Mount, Zigbee und History in unter 10 Sekunden auf die Platte genagelt
Das hat vorher mit ner normalen HDD wesentlich länger gedauert, alleine bis die aufgewacht ist, waren schon 10 Sekunden um. -
Bei mir macht der Adapter kein Backup mehr. Das System ist wie folgt aufgebaut:
MASTER: Tinkerboard / hier ist der BackitUp Adapter installiert
SLAVE: Raspberry / hier ist die SQL Datenbank installiertDie Log Datei zeigt folgendes an und bleibt stehen ->
Gestartet... [DEBUG] [iobroker] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerMini","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"dbName":"iobroker","user":"LJSven","pass":"****","deleteBackupAfter":"5","host":"192.168.178.44","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"media/usb/history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"10","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"longTelegramNotice","User":null,"onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"","emailSender":"","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"} [DEBUG] [iobroker] - host.tinkerboardmaster 8231 states saved [DEBUG] [iobroker] - host.tinkerboardmaster 9478 objects saved [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2020_02_10-11_44_54_ioBrokerMini_backupiobroker.tar.gz [DEBUG] [iobroker] - done [ERROR] [mysql] - [IGNORED] Error: Command failed: mysqldump -u LJSven -p**** iobroker -h 192.168.178.44 -P 3306 > /opt/iobroker/backups/mysql_2020_02_10-11_45_21_backupiobroker.sql /bin/sh: 1: mysqldump: not found [DEBUG] [ftp] start with {"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21","deleteBackupAfter":0} [DEBUG] [ftp] - FTP connected. [DEBUG] [ftp] - Send iobroker_2020_02_10-11_44_54_ioBrokerMini_backupiobroker.tar.gz [DEBUG] [ftp] - Send mysql_2020_02_10-11_45_21_backupiobroker.tar.gz [ERROR] [ftp] - File "/opt/iobroker/backups/mysql_2020_02_10-11_45_21_backupiobroker.tar.gz" not found [DEBUG] [ftp] - done [DEBUG] [clean] - done [DEBUG] [telegram] - [iobroker] used Telegram-Instance: telegram.0 [DEBUG] [telegram] - done [DEBUG] [history] - backitup.0.history.html [EXIT] 0 [DEBUG] [telegram] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerMini","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"dbName":"iobroker","user":"LJSven","pass":"****","deleteBackupAfter":"5","host":"192.168.178.44","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"media/usb/history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"10","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"longTelegramNotice","User":null,"onlyError":true,"telegramWaiting":0,"systemLang":"de","time":"10. Februar 2020 um 11:45 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"","emailSender":"","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"} [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerMini","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"dbName":"iobroker","user":"LJSven","pass":"****","deleteBackupAfter":"5","host":"192.168.178.44","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"media/usb/history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"10","systemLang":"de","time":"10. Februar 2020 um 11:45 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"longTelegramNotice","User":null,"onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"","emailSender":"","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"} -
@LJSven sagte in Test Adapter Backitup v1.3.x:
mysqldump
mysqldump auf dem Master installieren hilft bei deinem Problem
sudo apt-get install mysql-client -
Ist der jetzt richtig durchgelaufen? Das Fenster schließt sich nicht ->
[DEBUG] [iobroker] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerMini","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"dbName":"iobroker","user":"LJSven","pass":"****","deleteBackupAfter":"5","host":"192.168.178.44","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"media/usb/history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"10","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"longTelegramNotice","User":null,"onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"","emailSender":"","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"} [DEBUG] [iobroker] - host.tinkerboardmaster 8231 states saved [DEBUG] [iobroker] - host.tinkerboardmaster 9474 objects saved [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2020_02_10-12_13_48_ioBrokerMini_backupiobroker.tar.gz [DEBUG] [iobroker] - done [DEBUG] [mysql] - Packed 11MB so far... [DEBUG] [mysql] - done [DEBUG] [mysql] - MySql File deleted! [DEBUG] [ftp] start with {"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21","deleteBackupAfter":0} [DEBUG] [ftp] - FTP connected. [DEBUG] [ftp] - Send iobroker_2020_02_10-12_13_48_ioBrokerMini_backupiobroker.tar.gz [DEBUG] [ftp] - Send mysql_2020_02_10-12_14_06_backupiobroker.tar.gz [DEBUG] [ftp] - done [DEBUG] [clean] - done [DEBUG] [telegram] - [iobroker] used Telegram-Instance: telegram.0 [DEBUG] [telegram] - done [DEBUG] [history] - backitup.0.history.html [EXIT] 0 [DEBUG] [telegram] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerMini","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"dbName":"iobroker","user":"LJSven","pass":"****","deleteBackupAfter":"5","host":"192.168.178.44","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"media/usb/history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"10","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"longTelegramNotice","User":null,"onlyError":true,"telegramWaiting":0,"systemLang":"de","time":"10. Februar 2020 um 12:15 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"","emailSender":"","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"} [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"ioBrokerMini","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"mysql":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"dbName":"iobroker","user":"LJSven","pass":"****","deleteBackupAfter":"5","host":"192.168.178.44","port":"3306","exe":""},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"media/usb/history"},"zigbee":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":null,"host":"192.168.178.1","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":"","user":"Raspberry","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":null,"mount":"192.168.178.1","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/iobroker","dirMinimal":"","user":"Raspberry","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"","dirMinimal":""},"googledrive":{"enabled":false,"type":"storage","source":null,"debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"10","systemLang":"de","time":"10. Februar 2020 um 12:15 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"longTelegramNotice","User":null,"onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"","emailSender":"","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"} -
@LJSven
Ja alles korrekt ... -
@sigi234 sagte in Test Adapter Backitup v1.3.x:
System erfolgreich zurückgesetzt!
Sehr gut ... WebIf geht also auch ...
Moin,
was besagt folgende Fehlermeldung aus?
host.ioBroker 2020-02-26 12:09:35.512 info Restart adapter system.adapter.backitup.0 because enabled host.ioBroker 2020-02-26 12:09:35.511 error instance system.adapter.backitup.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.ioBroker 2020-02-26 12:09:35.511 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3) host.ioBroker 2020-02-26 12:09:35.511 error Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12) host.ioBroker 2020-02-26 12:09:35.511 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32) host.ioBroker 2020-02-26 12:09:35.511 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10) host.ioBroker 2020-02-26 12:09:35.510 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30) host.ioBroker 2020-02-26 12:09:35.510 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/googleapis/build/src/apis/dfareporting/index.js:17:16) host.ioBroker 2020-02-26 12:09:35.510 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18) host.ioBroker 2020-02-26 12:09:35.509 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17) host.ioBroker 2020-02-26 12:09:35.509 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:562:25) host.ioBroker 2020-02-26 12:09:35.509 error Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15) host.ioBroker 2020-02-26 12:09:35.508 error Caught by controller[0]: Error: Cannot find module './v3.3' host.ioBroker 2020-02-26 12:09:35.508 error Caught by controller[0]: ^ host.ioBroker 2020-02-26 12:09:35.507 error Caught by controller[0]: throw err; host.ioBroker 2020-02-26 12:09:35.507 error Caught by controller[0]: internal/modules/cjs/loader.js:638 host.ioBroker 2020-02-26 12:09:33.861 info instance system.adapter.backitup.0 started with pid 2857 -
Auf Github liegt aktuell die Release Version 1.4.0.
Changelog
1.4.0 (27.02.2020)
- (simatec) added next Backup Time
- (simatec) added Name Suffix for mysql Backup
- (simatec) added more Options for mysql
- (simatec) added domain support for cifs
- (simatec) added json historystate
Wer Zeit und Lust hat, kann diese gerne mal testen, um mögliche Fehler noch vor Veröffentlichung im latest zu beheben.
@simatec
läuft
@simatec sagte in Test Adapter Backitup v1.3.x:
Eine Null zu viel beim Datum
@sigi234
Danke für dein Feedback. Wird noch vorm Release geändert.
Kannst du den Widget für die history mal posten? -
Was genau?
posten
Wäre Interessant, wie du den json state in deine VIS eingebunden hast ...
Die Zeitangabe sollte nun auf Github gefixt sein -
@sigi234
Sieht sehr schick aus ...
@sigi234
Danke, funktioniert bei dir Alles nach dem Import? Auch die Animation?
